The **Official** Denon 3311CI/ 991 Owner's Thread NO PRICE TALK - Page 359 - AVS Forum | Home Theater Discussions And Reviews
 17Likes
post #10741 of 10763 Old 02-23-2017, 10:58 AM
Nikonowski's Avatar
Quoted: 103 Post(s)
2. The 3311CI can only operate 7CH (5.1+FH/FW/SB). You must upgrade to the X4200W (7CH expandable to 9CH using 2CH amp).
Edit: Front Wide is no longer supported on the 2016 models, so the X4300H would not work for your use case.
3311CI to my knowledge is also 7 channels avr expandable to 9CH using 2CH amp. And I did use an external amp and still, I only could get either Front Wide or Front Height but not 4 at all the same time, even with an external amp. So something is odd, I even tried to set-up all that manually without surround back speakers (set to none in manual setup) but still could not get Front Wide and Front Height play at all the same time. One or other pair (FW or FH) played but not both at the same time. And on top of that SB still played !!! What gives ? How can I only play get Front Wide and Front Height at a the same time. Can I setup my system with only these 4 speakers FW and FH) only - forget all other surround. By the way I also have x4200w and I believe that it has the exact same specs as 3311CI which is (7CH expandable to 9CH using 2CH amp)
I am a bit confused here , sorry
N.
Nikonowski is offline
post #10742 of 10763 Old 02-23-2017, 11:00 AM
jdsmoothie's Avatar
Quoted: 15384 Post(s)
Liked: 7527
N.
The 3311CI was released in 2010 and cannot expand beyond 7CH. In fact the first successor model to the 3311CI that can expand is the 2014 X4100W.
jdsmoothie is online now
post #10743 of 10763 Old 02-23-2017, 11:09 AM
Nikonowski's Avatar
Quoted: 103 Post(s)
So what's advantage of adding external amp to 3311CI - none ? Also, are you saying that x4200w with an external amp that has 2 channels, can do what I described - playing both FH and FW at the same time ? If so, what surround mode could I achieve with that - would that be Audyssey DSX driven for all channels ?
N.
post #10744 of 10763 Old 02-23-2017, 12:00 PM
jdsmoothie's Avatar
Liked: 7527
N.
1. A more powerful external amp (eg. Emotiva XPA-2 @ 300W) would provide more power than the AVR internal amps.
2. Correct. The X4200W could use either Audyssey DSX or DTS Neural:X for a 7.1.2 configuration (ie. 5.1 + FW + FH).
post #10745 of 10763 Old 02-23-2017, 01:14 PM
Nikonowski's Avatar
Quoted: 103 Post(s)
Thanks JD , one more clarification then - when I look at the back of my 4200w I see that there are 13.2 preouts plus additional pre-outs for zone 2 and 3. So if I am not mistaken, analog preouts are live at all times so which channels I am getting on these 13.analog preouts if I only can get 7.1.2 or 9.1 with this avr with an external amp ?
Is the only way to have 11.2 channels playing at all times is the get the 630H model ?
N.
post #10746 of 10763 Old 02-23-2017, 01:21 PM
jdsmoothie's Avatar
Liked: 7527
N.
1. Although you can connect up to 13 speakers, only 9 of them will operate at any one time depending on the surround mode that is selected.
2. Again, if you want to use Front Wide speakers, they are not supported on the 2016 models (X4300H, X6300H), rather you would have to purchase the X6200W (9CH expandable to 11CH using 2CH amp) if you want the AVR to operate 11 speakers in the main zone to include Front Wide speakers.
post #10747 of 10763 Old 02-23-2017, 03:28 PM
theanimala's Avatar
Quoted: 22 Post(s)
Pull the cable from the sub pre-out and rub your finger over the tip of the cable. Hear static from the sub? If no, either the cable or the sub is defective. Use a different cable to test (can use a red/white/yellow composite video cable for testing).
Ended up running a new cable from my AVR-991 to my sub, still doesn't work. I feared it was the AVR as I have dual subs, I didn't think that both would stop at the same time. Bites that this receiver only lasted 6 years. My previous receiver, a Sony STR-DA30ES which I bought back in 2000 is still working as my garage receiver feeding my outdoor speakers.
theanimala is offline
post #10748 of 10763 Old 02-27-2017, 06:31 PM
Nikonowski's Avatar
Quoted: 103 Post(s)
OK so if I bought X6200W (9CH expandable to 11CH using 2CH amp), then I could operate (playing sound though them) 11 speakers , right ?
N,
post #10749 of 10763 Old 02-28-2017, 02:49 AM
jdsmoothie's Avatar
Liked: 7527
N,
Right .... as long as you added a 2CH external amp.
post #10750 of 10763 Old 02-28-2017, 02:54 PM
mikmax1's Avatar
Still an issue...even with 4300
Quote: Originally Posted by mikmax1
I have a JVC (One of the last) VCR hooked up to my 3311 via the DVR ports (Analog RCA Jacks).
The TV is of course, hooked up to the 3311 via HDMI. Everything else works great.
When I try to play the VCR thru the 3311, the Video comes on briefly, then goes black. Then it cylces back on, then off, etc. Reminds me of old MacroVision problems. Yet this it a Home-made VHS Camcorder tape.
The VCR and Tape play fine via the Coax cable to the TV with the TV on "good old Channel 3".
Anyone got a clue why the VCR will not cleanly pass thru the HDMI?
As noted in the manual, the AVR sometimes has issues with older technology video sources. You may need to connect the yellow composite video cable to the TV directly.
This quote is a few years old...and back then....I GAVE up. Now I have a new 4300. Pretty much same problem. Sound from VHS works thru the Denon. Video works, but if I touch the VCR Menu button, the menu pops up, screen goes black. Only if I unplug the RCA video jack from the Denon and re-plug back in, will the video return. Not a good solution, once I push the 4300 in the rack. I tried running RCA jacks into the TV and using ARC with limited success. Was also trying to use the Optical to run Audio thru TV and back out to Receiver...NADA. Anybody got any insight into this. I even tried swapping out the VHS machines. (Yeah....I still have two of them in service)
mikmax1 is offline
post #10751 of 10763 Old 03-25-2017, 10:43 PM
jtara's Avatar
Only 6 inputs are usable? Or did I hide some?
I just added a Chromecast device to my AVR-3311CI, and tried to use HDMI4 and had some trouble.
It's been a while since I've done input assignments. I *vaguely* recall that there's some way to hide unused inputs, and I must have done so in the past. I can't for the life of me figure out how to un-hide them now...
I realize that on input assign there are really just "slots", and you supply a name for each and select an input from a drop-down (in web interface, but similar concept using remote - I tried both!)
Thing is, there are 6 HDMI inputs (PLUS other types of inputs), but not enough slots to use them all. There is a gap in my list.
I was able to set-up the Cast device on HDMI 4 by re-assigning the last slot, which was assigned to V.AUX, which I seldom use.
So, I got it to work, but it's bugging me that I have two HDMI inputs that I apparently can't use.
Here is my current input assign:
Bluray HDMI1 None None
AppleTV HDMI2 None None
TV None OPT1 None
Cable HDMI3 None None
(gap on web page)
CAST HDMI4 None None
These are all of the slots that are available, and can see no way to add more.
I wrote down all of the settings and reset the input assign, but that didn't buy me any more slots.
How do I get my "hidden" slots back?!
BTW, if you are wondering why I have both Apple TV and ChromeCast, I'm a software developer, and am working on an open-source text-to-speech service/audio file player (based on node google-home-notifier, but will be renaming my fork google-cast-public-address, since it now does more than just TTS and as well isn't limited to just playing on Google Home..., and needed a Cast device to test casting to devices other than Google Home... It's main use is to send asynchronous TTS feedback to a Google Home device from home automation controllers, etc.
jtara is offline
post #10752 of 10763 Old 03-25-2017, 11:32 PM
JJ7
JJ7's Avatar
Quoted: 64 Post(s)
Liked: 51
TV None OPT1 None
(gap on web page)
Through the web interface you can do this under manual setup, option(1). And it's also available with the on screen interface.
JJ7 is offline
post #10753 of 10763 Old 03-26-2017, 03:10 AM
jdsmoothie's Avatar
Liked: 7527
TV None OPT1 None
(gap on web page)
Source Delete (p. 87 Owner's manual) : Manual Setup --> Option Setup --> Source Delete
post #10754 of 10763 Old 03-26-2017, 01:36 PM
jtara's Avatar
Source Delete
Thanks so much!
However, it is giving me no love.
I used the web interface, and when I change a radio button from Delete to ON, it briefly shows ON, the page refreshes, and then it goes back to Delete.
I will see if this can be configured using remote and on-screen menu, and perhaps I will have more luck.
Edit: I was able to do it. I had to use the remote and on-screen menu.
I'm guessing that the web UI is using some Javascript that is now obsolete in (at least some) browsers. The above behavior was observed with latest Chrome 57. I didn't try other browsers. I was able to do other parts of the setup (e.g. renaming, selecting scaling options, etc.) with the web UI.
jtara is offline
post #10755 of 10763 Old 04-17-2017, 10:57 PM
caline's Avatar
Dear AVR-3311CI owners, DO NOT UPGRADE TO THE "NEW" LATEST FIRMWARE, you will end up in the classic Denon upgrade loop.
All my Denon amplifiers are ethernet wired, and I upgrade the firmware a couple of times a year: it has always worked great, but not anymore on the 3311CI.
As you know, you can get out of it with factory reset (arrow up + down + power on).
BTW, this one cannot be reflash via USB.
I have no details as the Denon site no longer list the 3311CI firmeware of it, although they keep sugested some over internet to the receiver.
5 Denon AVR's, all working great!
AVR-2112CI, AVR-1312, AVR-3311CI, AVR-2106, AVR-3300
caline is offline
post #10756 of 10763 Old 05-17-2017, 05:50 PM
theanimala's Avatar
Quoted: 22 Post(s)
Can I have different subwoofer levels set by input? I'm running a few DB hot for blurays and it sounds great. But when watching cable through the Denon there is a constant, low rumble. If I turn down the sub level in Sat/Cable will it effect the Bluray input?
post #10757 of 10763 Old 05-18-2017, 05:18 AM
jdsmoothie's Avatar
Liked: 7527
No, however, beginning with the 2014 models, a new OPTION - CH LEVEL ADJUST setting was introduced that allows setting independent speaker/sub levels per input.
post #10758 of 10763 Old 06-20-2017, 06:26 PM
Liked: 0
HDMI inputs not working
Seeking help from formum members... Starting today I lost audio and video on all HDMI inputs at once. I tested them all multiple times with different cables and sources and nothing. However, OSD still works perfectly via HDMI connection to the TV set, including menus and all AVR generated content like internet radio and network media sources. Sound over coax and toslink work OK as well but video from component inputs I tested is not being converted to the HDMI output. In short, it seems that it's lost HDMI input and conversion but output and OSD remain. Any ideas?
cvinhaes2 is offline
post #10759 of 10763 Old 06-20-2017, 06:27 PM
Liked: 0
Before I forget, model is Denon 3311ci.
post #10760 of 10763 Old 06-21-2017, 01:29 AM
jdsmoothie's Avatar
Liked: 7527
Possibly a lightning strike took out the HDMI board. Try doing a few microprocessor resets (p. 116 Owner's manual) in a row and if still no joy, time to purchase something more current. The new 2017 networking models being released will all now feature a 32bit DAC and HEOS module with the X3400H featuring the much better version of Audyssey MultEQ XT32.
post #10761 of 10763 Old 10-08-2017, 08:18 AM
theanimala's Avatar
Quoted: 22 Post(s)
Has anyone noticed that Pandora continues “playing” even when the receiver is turned off? If I switch to an input on my AVR-991 that has no signal (say CD) I can quietly hear pandora playing through my speakers. I also received a message from the Pandora app that I listened to 16,333 minutes of music last month. I don’t mind as I don’t hear Pandora when playing an input that has a signal, just curious if other people’s receivers do this, and I wonder if the 2017 models to it as well?
post #10762 of 10763 Old 10-21-2017, 11:22 AM
mjclifford's Avatar
Guys, perhaps you can help and / or confirm. I've had a 3311CI for many years and it worked perfectly, pulling music via DLNA from a NAS and streaming via vtuner, usually to Zone 3.
Lately I noticed a 1 to 2 minute silence for internet music every so often. Then streaming to the NAS would stop and I would have to navigate back to the playlist and start again. This could occur once every 2 hours or four times per hour.
Finally it occurred while I was watching the on screen GUI. It was a reboot of the NET/USB board, with the exact console messages that occur when the server is rebooted and it's set to the NET/USB source (Connecting ... / Assigning IP address ... etc). A ping diagnostic showed no connectivity during the 2 minutes for the board to connect.
First, is a microprocessor reset necessary? What else could remedy this problem?
Also, I looked at all the config files saved over the years. All had 130 bytes, with only NUL symbols. After a few hours of tries, I still had a 340 byte file, but it had information in it as well. Given this, can I count on restoring all settings?
Any advice appreciated.
By the way, I bricked 3 3310 CI units during upgrades until Denon took pity and gave me this, so I've very reluctant to reset or upgrade.
mjclifford
mjclifford is offline
post #10763 of 10763 Old 10-21-2017, 11:27 AM
jdsmoothie's Avatar
Liked: 7527
mjclifford
1. Given your issue, you would be much better served doing a "Network Reset" (press/hold UP/DOWN arrow buttons on front panel while powering on the AVR) which also includes a microprocessor reset in the process.
2. A SAVE that consists of all NUL symbols or 0's is a bad save. If there is information in the file, then it will most likely result in a successful LOAD.
Denon Avr 3311ci Receiver , Denon , Receivers Amplifiers
