"Official" Yamaha RX-V667/RX-V767 Thread - Page 10 - AVS Forum | Home Theater Discussions And Reviews
 5Likes
Old 10-26-2010, 06:35 PM
Jcruz145's Avatar
Hey guys, I was just wondering if the Yamaha rx v667 would be enough to power my Polk audio monitor 70 series speakers?
Jcruz145 is offline
Old 10-26-2010, 07:00 PM
Quoted: 860 Post(s)
Liked: 348
It would seem illogical. The speakers can handle 275 watts and that's 3X what the the V667 can provide. Even the v867 is only 95w x 7.
JoeKustra is offline
Old 10-26-2010, 07:09 PM
dmercer3's Avatar
Quoted: 709 Post(s)
Liked: 395
I have the 667 hooked up to my 70's, 40's, and c20 and it works just fine.
Video: 78JS9500(MAIN) / 60E8000 Plasma [Previously:58c8000/75hu8550/78ju7500] BD Player: Samsung K8500
Audio: Marantz 7010 / SVS PB-13 Ultra / Klipsch RF-7ii RC-64ii Polk M70's IC-5800 (5.1.4)
dmercer3 is offline
Old 10-26-2010, 07:41 PM
Old School's Avatar
Huh? Joe, the 275 watt rating is just their power handling capability is all. Note that Polk suggests power as little as 20 watts would be sufficient to power them. The 667 could easily power these no problem. I know people recommend that even though this speaker is large that you still should set them to "small" configuration IF you have a subwoofer - which one byproduct of doing that is the receiver won't have to reproduce the low bass in the larger speakers which requires more power and drain. Even so though, these speakers are sensitive at the spec 90dB rating and are 8 ohm, which the 667 will be able to handle without question.
Any typical speaker with an 8 ohm rating and 90 dB sensitivity will work fine with the 667 at a reputed 90 watts/ch. Speakers with a sensitivity rated in the lower 80's is harder for an amp to drive, and also 4 ohm speakers too. Power handling specification is just a recommended minimum and maximum power amp rating you would want to use with the speakers. In this case an amp putting out more than 275 watts might pose stress on the speaker at high volumes resulting in distortion or frying them, likewise an amp putting out under 20 watts would likely not drive them well and cause distortion.
Old School is offline
Old 10-27-2010, 08:51 AM
Jcruz145's Avatar
dmercer3 - Any typical speaker with an 8 ohm rating and 90 dB sensitivity will work fine with the 667 at a reputed 90 watts/ch. Speakers with a sensitivity rated in the lower 80's is harder for an amp to drive, and also 4 ohm speakers too. Power handling specification is just a recommended minimum and maximum power amp rating you would want to use with the speakers. In this case an amp putting out more than 275 watts might pose stress on the speaker at high volumes resulting in distortion or frying them, likewise an amp putting out under 20 watts would likely not drive them well and cause distortion.
Thanks for the info really helps as this is my first receiver and speakers system.
Jcruz145 is offline
Old 10-28-2010, 05:17 AM
gregdpw's Avatar
I am just wondering if the 667 has a loudness option? I currently have the 665 and it doesn't have a loudness option. I like the loudness cuz I think it gives rock music a nice boost. Thanks guys
gregdpw is offline
Old 10-28-2010, 06:12 AM
Old School's Avatar
Nope, it does not. Music Enhancer kind of does a little bit of what a loudness button does in a small way.
Another thing you can do, likely in the 665 too, is boost the bass and treble tone controls to achieve the same thing (that's all a loudness button does) and you can do this for every source input. You might already know this, but for every source you can go into the "Option" menu via the remote and bring up a number things you can change specifically for that source, one of which is tone controls. Go into Option in whatever source you use for music and make the tone control adjustments, it will only affect that source input.
Old 10-28-2010, 06:16 AM
gregdpw's Avatar
Do any of the yamaha receivers have a loudness button or option?
gregdpw is offline
Old 10-28-2010, 06:27 AM
Old School's Avatar
I don't think any of them do. I updated my previous post with an idea you might consider.
Old 10-28-2010, 06:50 AM
gregdpw's Avatar
Thanks very much! I wonder how much I would have to raise the bass and treble to recreate a loudness option?
gregdpw is offline
Old 10-28-2010, 10:49 AM
Old School's Avatar
Raise it until it sounds good to you. I remember most receivers that had a loudness button manufacturers would put in the specs what exactly the loudness button did. Seems like in old receivers I have owned in the past it boosted the bass like 6-10 dB's at like 60, maybe 70 Hz, and like 6-10 dB's at like 10 Khz. I think you need to just play with it until you find the sound you want.
Old 10-29-2010, 01:34 PM
jjpowell76's Avatar
Where are you guys finding the firmware update? I have DirecTV and would love it if I did not have to manually change the TV when I want to watch the 3D.
I go to the Yamaha website and I don't see any downloads for firmware. Also, where can you find the firmware in the receiver. I have the 667.
Any help is appreciated.
jjpowell76 is offline
Old 10-29-2010, 03:44 PM
Whitestar2's Avatar
I was going to post a link but I see that Yamaha has now changed their web page. The firmware update was listed under the "downloads" tab when the RXV667 receiver was selected on the web page. I was trying to find it for you but no luck. I would just e-mail customer service & I'm sure they will get back to you, they always have with me.
Good Luck!
"Understanding Is A Three Edged Sword!"
Whitestar2 is offline
Old 10-29-2010, 09:22 PM
Old School's Avatar
Good Luck!
This is really aggravating. A company like this should have their $*it together and make sure they don't lose crap like this when they update their web site, it's VERY annoying and makes them look like idiots.
Old 10-29-2010, 09:55 PM
Quoted: 860 Post(s)
Liked: 348
I still haven't seen anything about my V867 change from 1.01 to 1.02 after a month. They're not idiots, just stupid. Or maybe they're just normal. I have the same issue with Sony for my BR and TV. Where would we be without this forum? I shudder when I think about it.
jjpowell76's Avatar
I just emailed them. I will let you know what they say.
Old 10-30-2010, 09:20 AM
peter460's Avatar
I'm thinking of getting Paradigm 11 or B&W 683's for my Rx-v767. Can the Yamaha handle the low impedance of the paradigms ? Anyone tried bi-amping the 767?
Pete
peter460 is offline
Old 10-30-2010, 10:32 AM
Old School's Avatar
Which version of the Paradigm 11 are you talking about? The latest? It looked to me after doing a quick search that the latest Model 11's are 8 ohm speakers which will work just fine with the 767. 8 ohm speakers are just fine for use with the 767. Even the B&W 683's appear to be 8 ohm as well. It's when you get down to 6 and 4 ohm speakers, how many pairs you would run off the 767, that's where things get questionable.
Old 10-30-2010, 03:37 PM
dlormans's Avatar
Pete
I bi-amp my 767 with B&W DM 602 S3"s and it sounds terrific.
dlormans is offline
Old 10-30-2010, 05:33 PM
FGEvans's Avatar
i currently own an onkyo 705 and whilst its a cracking machine with my new PS638000 3d tv i cant pass through 3D etc. I also have a projector and its becoming a pain having to change the hdmi leads every time i watch a movie.
so the rx-v767 sounds ideal for me
one question i have though is that with my onkyo there is a feature (not sure what its called) that when the amp is switched on the sound from any connected source bypasses the tv sound and comes from the amp and also the tv shows an onscreen volume control which can be controlled by the tv remote volume control, switch the amp off and the sound comes through the tv speakers etc,
does the yamaha have this feature
FGEvans is offline
Old 10-30-2010, 07:15 PM
wcmlutz's Avatar
If you don't want to keep switching HDMI ports, I would look at an RX-V867 since it has two HDMI outputs, so you could run your TV and projector with out swapping cables.
wcmlutz is offline
Old 10-31-2010, 12:34 AM
peter460's Avatar
Thanks guys, - was wondering does the 767 do any filtering between the the the two "vertical " channels when in bi-amping ? Have not tried it yet , still waiting for new speakers. - Also any way to upgrade the firmware on the unit?
pete
peter460 is offline
Old 10-31-2010, 03:53 AM
centauro74's Avatar
Expo electronics has a deal on the denon AVR-3311Ci, you have to use coupon LSDA1022 (35% off).
centauro74 is offline
Old 10-31-2010, 06:53 AM
Quoted: 860 Post(s)
Liked: 348
There is a feature called ARC (Audio Return Channel) that will use the amp for audio if the Yamaha is turned on and the tv speakers if the amp is turned off. I'm sure the exact functionality depends on the TV. I have the HDMI control disabled on my TV since the TV speakers are not as good as the 5.1 from the Yamaha.
Old 10-31-2010, 10:15 AM
FGEvans's Avatar
it seems that in the uk where i live that the rx-v767 has 2 hdmi outputs,
FGEvans is offline
Old 10-31-2010, 08:50 PM
wcmlutz's Avatar
In the US they have not introduced the RX-V767. We go right from the 667 to the 867. Sorry I misread that you were talking about the 767.
wcmlutz is offline
Old 11-01-2010, 10:04 AM
barcoed's Avatar
Folks,
I'm trying to get HD sound from my HTPC (ATI 4xxx) via the HDMI connection to the 667 with no TV connected. I'm using a CRT projector (15pin rgbhv) as the other (only) monitor (bypassing the 667) and only want sound to go via HDMI. - Is this possible?
barcoed is offline
Old 11-01-2010, 10:18 PM
Quoted: 860 Post(s)
Liked: 348
Originally Posted by barcoed View Post
Folks,
I don't know if this is a fair test, but I frequently have my TV turned off when playing music from a BR player. You can make a case for saying that there is still video coming out of the BR, and nothing can stop that. I guess you will have to wait for an answer from someone doing what you are doing. And, by the way, could you clarify "HD" sound? As in 5.1, DTS, LPCM, etc.? Best of luck.
Old 11-02-2010, 03:48 AM
barcoed's Avatar
By HD-Sound I mean DTS-MA etc.
Actually I got lucky and discovered the super secret menu on the 667 and turned MON.CHK to skip. This appears to have done the trick. I get sound via HDMI to the 667 and RGBHV picture straight from the PC to the projector. Job done!
barcoed is offline
Old 11-02-2010, 07:40 AM
Quoted: 860 Post(s)
Liked: 348
Please share. Please. I won't tell anyone about the super secret menu. Just whisper it to me.
Yamaha , Yamaha Rx V667 Receiver , Receivers Amplifiers
