"Official" Yamaha RX-V667/RX-V767 Thread - Page 116 - AVS Forum | Home Theater Discussions And Reviews
 5Likes
Old 03-25-2012, 09:23 AM
moreira85's Avatar
I'm not following you here. I know I can go into input and select the source but when I turn off the tv the audio goes off on the receiver. I want to turn the tv off and continue to listen to audio on the rec. seems when I turn the tv off there's a hand shake issue.
moreira85 is offline
Old 03-25-2012, 09:37 AM
sofast1's Avatar
Originally Posted by moreira85 View Post
Is it possible to turn off the tv n listen to music through dish? When I turn off the tv the audio turns off bcause hdmi.
Your problem might be in your tv set-up. I can turn my tv(Panasonic) off and listen to the audio from my dish dvr or my cable box. There's about 2-3 seconds without sound when the tv is turned off. Both dish dvr and cable box connected w/hdmi to 667,667 to tv,via hdmi.
sofast1 is offline
Old 03-25-2012, 09:52 AM
rdgrimes's Avatar
Quoted: 1993 Post(s)
Liked: 1321
Try this: instead of turning off the TV, switch it to a different input first, then turn it off. If that doesn't work, then try switching the AVR to a different input and back again. the Yamaha is designed to work as an "audio-only" HDMI device, but it requires a TV that actually turns off its HDMI port (which many do not), which is why switching the TV to a different input often works.
rdgrimes is online now
Old 03-25-2012, 10:22 AM
moreira85's Avatar
Thanks. I switched the tv input to ota tv then turned it off and it worked. It's kind of a pain because I have to switch from hdmi to ota every time I want to listen without the tv but at least I figured this out. This really comes in handy when i am using the 2nd zone for outdoor and I don't want the tv on.
Old 03-25-2012, 11:09 AM
keiron99's Avatar
I've had an Apple TV2 (jailbroken, with XBMC installed) and Yamaha 667 in my stsme for a few weeks now.
However, XBMC only occasionally works with the receiver - most times I just get a gray screen. This is only happens with XBMV, not the other Apple TV funcctions.
I seem to have tried every possible setting - different inputs on the TV and the amp, different cables, different skins on the Apple. Nothing works. I downloaded a new version of XBMC this morning, hoping against hope, to no avail.
Does anyone have ant ideas for how to resolve this?
keiron99 is offline
Old 03-30-2012, 08:29 AM
sofast1's Avatar
After getting 2 new subs,I decided to run YPAO again. I got a E1 error code(no front speaker) which I knew was false(they all work,even w/test tone). I called Yamaha customer service & sent an email. The next day I received a call from them,they're sending a new mic. no charge. Way to go Yamaha!
sofast1 is offline
Old 04-04-2012, 03:06 PM
khalsalem's Avatar
I have 667 more than a year now, I inserted the plug in 220v while the AVR voltage switch was on 110v...(by mistake I forgot to switch to 220)
tried to switch on but it stayed in sleep (standby)
once I realized my mistake I cut off power, checked the protective fuse and it was fine, so I switched the voltage to 220, re-inserted the plug and tried to switch it on but nothing happened, it stays in sleep mode,
so I tried going into self diag so pressed Main zone + tune control+ info and this fixed it, and I could switch it on and it functions normally EXCEPT for the front panel display,
nothing at all is visible (like it is still in standby mode) completely blank despite that the unit is working fine with OSD visible on the TV and sounds in speakers.
did I fry the front panel display? or there are some steps I can do to re-enable the display?
khalsalem is offline
Old 04-05-2012, 01:28 AM
tomandbeth's Avatar
By any chance, do you have HDMI Control turned ON? Pgs 102-103 of the manual.
tomandbeth is offline
Old 04-06-2012, 05:26 PM
sofast1's Avatar
A follow-up to my previous post;Yamaha did send me a replacement mic. to fix the YPAO. Unfortunately, it also is defective. They will not send me another one,said I would have to send the 667 in for service. I replied that I will not be without my entire system for weeks or months. I have a sound level meter and a tape measure,don't need YPAO. At least now I know what my next upgrade will be.
Anyone want to buy a 667? It's perfect except for the damn mic.
sofast1 is offline
Old 04-06-2012, 06:40 PM
lvtdude's Avatar
It doesn't sound like the mic is defective. More likely, some connection inside that carries the signal from the mic. Probably why they want the unit. Don't you have an authorized service center near you?
lvtdude is offline
Old 04-06-2012, 06:58 PM
sofast1's Avatar
The 2 mic.s had different error codes and problems. The first wouldn't detect a working speaker(E-3,I think),the second wouldn't activate the subs and had a partially scrambled on screen display. Like I said before, I've got a calibrated spl meter and a tape measure. Adios YPAO,hello Audyssey. It's a shame, I've been a Yamaha fan a long,long time. The previous Yamaha receiver failed after around 7 years. Not that bad, but still.........
No, local service center. Even if there was,it probably would still take weeks if any parts weren't backordered. Sorry,I'll replace it before I'll go weeks or months without music or tv. Then I'll just sell the 667.
sofast1 is offline
Old 04-07-2012, 06:24 PM
anikun07's Avatar
Quoted: 32 Post(s)
Liked: 47
When I run YPAO on my 667, it sets the subwoofer to 26.8 ft away and all of the fronts are about 10 and the rears 2.5, should I correct the subwoofer distance manually with my tape measure or will this upset the timing the AVR sends out the LFE signal? My subwoofer is a Tuba HT, so is it possible that the "Maze" of the sub takes longer for the audio wave to exit the sub to the mic? YPAO also sets the level of the sub to -10.0 which I always reset to 0.0 because I control the subwoofer volume on the amp.
anikun07 is offline
Old 04-07-2012, 09:41 PM
rdgrimes's Avatar
Liked: 1321
Your sub is running way too hot when you use YPAO, you need to turn it down and run again. When YPAO finishes with the sub close to "0", then you're where you want to be. You can turn it up again at the sub if you wish. Don't worry about the distance setting for the sub.
Old 04-07-2012, 11:17 PM
anikun07's Avatar
Quoted: 32 Post(s)
Liked: 47
Thank you, I've gotten the sub to where I think it properly complements the other channels so I disregard what YPAO wants to do with it. The gain is set to about 3/8, 1/2 being the 12 o'clock position.
anikun07 is offline
Old 04-08-2012, 07:07 AM
rdgrimes's Avatar
Liked: 1321
Nevertheless, when you run YPAO its balancing ALL channels, and a hot sub will cause it to lower the other channels. It's better to turn it down, run YPAO, then turn it back up if you must.
Old 04-11-2012, 02:20 PM
tomandbeth's Avatar
I see on page 30 of the manual NOT to be connected at both the SPEAKER and PRE-OUT terminals. Googling around I see where this might be debateable but rather than take a chance of frying the AVR ... I'll go with the manual.
What ISN'T clear to me is if the Pre-outs of the RX-V667 will control the external amp's (ART SLA1) volume to the speakers, and so will not need another switch or component.
I've also seen pros and cons of bi-amping (pg 18) and note that would also require setting this AVR in the drop down menu to run a 5 speaker system.
I realize I should just leave a working system alone, but then one doesn't learn. I would rather learn without the need of a fire extinguisher. Also note that what is contemplated here should also be easily reversable.
Old 04-11-2012, 05:35 PM
rdgrimes's Avatar
Liked: 1321
The pre-outs are volume controlled, as well as having all the other DSP, EQ, etc. So when using an external amp, you still do all the same setup in the AVR.
Old 04-11-2012, 08:35 PM
tomandbeth's Avatar
Excellent! Thanks for taking the time to help me (again).
Old 04-16-2012, 01:25 PM
joeblow's Avatar
Liked: 233
It has been awhile since I stopped by this thread. Has there been a firmware update that removes the annoying volume GUI from the HDTV when adjusting the sound levels with the remote?
Los Angeles Lakers - 16 NBA Championships!
joeblow is offline
Old 04-16-2012, 02:43 PM
sofast1's Avatar
No.
sofast1 is offline
Old 04-16-2012, 02:52 PM
sofast1's Avatar
Just a follow-up to my previous post; I called Yamaha again,got a different rep. who sent me another mic. This one worked fine. I was right,the original and first replacement were both bad. Persistence is the key to success. As a side note,if you have a good sound level meter and a tape measure forget YPAO entirely and use the manual set-up. Every manufacturer has to have some kind of room correction nowadays and not all of them want to pay Audyssey their fee. While I'm not a fan of Audyssey(although I have the highest respect for Chris and Tom),it is the best room correction while YPAO is the simplest and not comparable at all.
sofast1 is offline
Old 04-16-2012, 03:45 PM
tomandbeth's Avatar
Not to hi-jack the thread, but was looking for a meter in the $50 range. Radio Shack does/used to have a good digital meter in that range. Mind if I ping you on a good Sound Pressure device (I am using db Meter Pro now on the Itouch).
Old 04-16-2012, 05:35 PM
sofast1's Avatar
Sent you a pm,but I don't think the links worked. Here they are again;
http://www.soundandvisionmag.com/art...r-good-measure
http://www.cross-spectrum.com/measur...ted_cm140.html
sofast1 is offline
Old 04-17-2012, 02:11 AM
mastersm's Avatar
Hi how can I have video from one source eg: blu ray playing on tv and audio from another eg: cd?
mastersm is offline
Old 04-17-2012, 07:11 AM
joe01880's Avatar
this has been covered many times; read your owners manual, search this thread, play with your system.
I took the red pill.
(and got screwed by Toshiba)
joe01880 is offline
Old 04-17-2012, 08:30 AM
sofast1's Avatar
on screen>input(what you want to watch)>arrow up>audio in>select input you want to hear
sofast1 is offline
Old 04-17-2012, 08:31 AM
sofast1's Avatar
It took less key strokes to help him than to reprimand him. Remember when you needed help?
sofast1 is offline
Old 04-17-2012, 09:35 AM
MarkSmith's Avatar
Its limited to network, usb and tuner and can be chosen within the input menu by choosing one of the above three input options and pressing the up cursor.
Mark
MarkSmith is offline
Old 04-17-2012, 01:20 PM
sofast1's Avatar
Mark
No, it's not. You can select any AV(1-6) input as well as Audio 1&2. I frequently listen to CDs(Audio 1),LPs(Audio 2) and my Squeezebox(AV1) while watching TV(HDMI1) or Bluray/Netflix(HDMI2)!
sofast1 is offline
Old 04-17-2012, 06:56 PM
marmyk1's Avatar
I have a yamaha HTR 6063. (RX-V667). I am running a 6.2 setup, I just added the 2nd subwoofer, a Polk audio PSW 111. the first sub is a velodyne CT100. I ran the YPAO setup and it only shows 1 sub on the display, so there is only a single x-over and level control. with this AVR is there any way to control these subs seperatly.
marmyk1 is offline
Yamaha , Yamaha Rx V667 Receiver , Receivers Amplifiers
