"Official" Pioneer Elite SC-37 - Page 149 - AVS Forum | Home Theater Discussions And Reviews
 4Likes
post #4441 of 4612 Old 01-27-2014, 07:33 AM
ss9001's Avatar
Quoted: 358 Post(s)
Liked: 422
there are 2 issues:
1) can you watch/listen to all your sources going thru the receiver when receiver is turned on? if yes -
2) how to setup Standby or pass-thru so you can watch/listen when receiver is turned off
my assumption is #1 is yes but if that's not the case, then that's a different problem and troubleshooting could involve the input assignments, associated an HDMI input with a named device input. you don't have to assign them, can leave them unassigned as HDMI 1,2,3...
and any incompatibilites with cable box etc will show up here - if you can't get video to your TV going thru the receiver but it works OK going directly to the TV. if you can't get video/audio from the Comcast box when the receiver is turned on, then it may not work in Standby either, but it's also possible it might. pass-thru does imply exactly that. but the input assignment has to be correct. IOW, if you want cable HDMI to work when you select CBL/SAT on the receiver display, you manually have to assign whatever HDMI port it's connected to, to the CBL/SAT named input, so it will be piggy-backed on top of the analog AV connections labeled CBL/SAT on the rear panel. also, make sure SIGNAL SELECT is set to Auto or HDMI . with audio inputs, the selection priority is always HDMI >> Digital >> Analog, so literally you can have both HDMI and digital or analog connected to the same source and choose which one to use manually. but Auto will always pick HDMI 1st. SIGNAL SEL is a button on the remote.
Standby pass-thru isn't setup as an automatic feature, you have to set it up and only for one device at a time. this entails going into the Setup Menu >> select System Setup >> select HDMI Setup >> Standby is default turned off, so scroll down to it, use right/left buttons to move it off OFF and select the source you want to have passed -thru when receiver is off >> then exit. from how the SC-68 works, there is not a way to have all HDMI sources passed thru when receiver is off. if you want the family to be able to watch Comcast, then you have to select that HDMI input or if its assigned to CBL, then select CBL for the Standby device. you can't also have a Apple TV in Standby mode at the same time. in the SC-68, you only get 1 choice for Standby at any one time, without going back into the setup menus to change it to the other source.
good luck today.
Steve
ss9001 is offline
post #4442 of 4612 Old 01-27-2014, 08:29 AM
sawzalot's Avatar
Quoted: 17 Post(s)
In regards to your question 1. well as for 1. yes when the AVR is "on" all four hdmi signals will pass thru to the Kuro when selected . I can set the AVR to AMP or Bypass for each signal as needed which will allow the sound to come from either the Kuro speakers or AVR . IE- AMP ON the sound will come from the AVR and my HT system.If I set it to BYPASS and AMP off and sound comes out of the KURO..
Now I know in essence that is the way pio created the by pass feature in this unit, But I prefer a bypass/pass thru that will let an un-touched signal pass thru the unit to the monitor without the unit powered up. I see all of your part two post contains good info and I will try that as well today because to be honest , I need to get this room back together today.
sawzalot is offline
post #4443 of 4612 Old 01-30-2014, 07:55 PM
saprano's Avatar
Quoted: 551 Post(s)
Liked: 545
Anybody selling a SC37 let me know.
home theater addict
saprano is offline
post #4444 of 4612 Old 01-31-2014, 05:49 AM
MSchu18's Avatar
Quoted: 166 Post(s)
Liked: 359
you can find a 35/37 fairly easily... just keep looking.
My Name is Nobody...
Klipsch x11i - Klipsch x20i - Oppo HA2
Pioneer SC85 - Bel Canto REF 500M
Klipsch La Scala II - Klipsch Cornwall/Crites/Aletheia Audio - Klipsch RC64II - SW-115
Wyred 4 Sound DAC2 DSDse - OPPO BDP-93
Samsung PN64D8000
MSchu18 is offline
post #4445 of 4612 Old 01-31-2014, 10:46 AM
saprano's Avatar
Quoted: 551 Post(s)
Liked: 545
Show me. All I see is this seller from amazon-
http://www.amazon.com/Pioneer-SC-37-7-1-Channel-Ready-Receiver/dp/B004140PUQ
home theater addict
saprano is offline
post #4446 of 4612 Old 02-13-2014, 08:36 AM
saprano's Avatar
Quoted: 551 Post(s)
Liked: 545
Wow I forgot how good this receiver sounds. I haven't had it for month and getting it hooked back up was sure a treat. I've been using my Onkyo 705 and while it did a great job the SC37 is just too clean sounding. Real buttery smooth amps.
Do receiver manufacturers employ different LFE settings? I noticed the Pioneers LFE channel is noticeably more tighter and full. This is with out any EQ.
No I wasn't looking for any differences before anyone claims placebo. I've been using this receiver for 2 years. i guess using another receiver for awhile then going back to the SC37 makes you notice any differences much easier.
sawzalot likes this.
home theater addict
saprano is offline
post #4447 of 4612 Old 02-13-2014, 11:13 AM
MSchu18's Avatar
Quoted: 166 Post(s)
Liked: 359
there is NO COMPARRISON between the onkyo and the 37 pioneer elite... night and day difference. I went from a nr806 to a sc35 and I would NEVER go back.
Ice based amps FTW!
Samsung PN64D8000
MSchu18 is offline
post #4448 of 4612 Old 02-13-2014, 06:28 PM
sawzalot's Avatar
Quoted: 17 Post(s)
Glad you got it back, and in one piece wooo. Now if I can get this pass thru . aww nevermind lol
sawzalot is offline
post #4449 of 4612 Old 03-03-2014, 12:27 PM
MOMENTUM69's Avatar
Hello,
Need a little help here..I searched the forum and still am a bit confused.
Im helping my friend with this amp with regards to the icontrolav app listed in iTunes for ipads
I am confused if there is.
1) a Ipad app that works to control this amp
2) if so are there different update version
3) if not is there another way to control media streaming from pc to this amp.
I really don't want to have to used MonkeyTunes with Media Monkey to control pc audio remotely and then run a audio cord out of the pc to an input to the amp.
Any app at all to allow pc media control streaming to this amp?
mo
MOMENTUM69 is offline
post #4450 of 4612 Old 03-05-2014, 12:26 PM
DocOrange88's Avatar
Quoted: 190 Post(s)
Liked: 133
Just upgraded from a 520-K to a SC-37.
Uh yea kind of mind blowing the difference. Switching out most of my speakers to JBL cinema style. Just picked up 4-8330A's for my new surrounds. Trying to hunt down a deal on a 3677.
DocOrange88 is offline
post #4451 of 4612 Old 03-07-2014, 02:32 PM
turnne1's Avatar
Quoted: 1913 Post(s)
Liked: 470
Ice based amps FTW!
you didnt have the right Onkyo
any of the 805/875/876 models would have seriously given the SC35 a run for its money
I have owned all of that group...sans the 876
Warren
Rm 1 Samsung 65KS9800 Marantz 8802A prepro Sherbourn 5/1500A amp B&W CM10s..CM2 center...CM5's.rears
Rm 2 Vizio P50 Denon 4520 Celestion 305 speaker system
Rm 3 Panasonic 50ST50 Denon4520 Kef 2005.2 speaker system
Rm 4 Samsung 55KS8000 Pioneer SC95 Mirage Omni sat speaker system
turnne1 is offline
post #4452 of 4612 Old 03-08-2014, 04:57 AM
Chise's Avatar
Quoted: 339 Post(s)
Liked: 133
Went back to mines two days ago it plays music better than Denon4311 but with Movies it's a toss up.
Chise is offline
post #4453 of 4612 Old 03-08-2014, 07:06 AM
MSchu18's Avatar
Quoted: 166 Post(s)
Liked: 359
Warren
not from my perspective... the blackness of a Ice based SC is really nice and better matched to my high efficiency speakers than any of those Onkyos in the 8 series... I just was not happy.
I am not even happy with the SC now that I have monoblocks.
Samsung PN64D8000
MSchu18 is offline
post #4454 of 4612 Old 05-17-2014, 03:42 PM
dogger99's Avatar
Can someone tell how you turn the mcacc off? Thanks
dogger99 is offline
post #4455 of 4612 Old 05-17-2014, 09:45 PM
DonH50's Avatar
Quoted: 2102 Post(s)
Liked: 1664
Use Pure Direct
dogger99 likes this.
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
post #4456 of 4612 Old 05-18-2014, 01:47 PM
dogger99's Avatar
Also I'm trying to calibrate a sub...how do i turn all speaker but the sub off?
dogger99 is offline
post #4457 of 4612 Old 05-19-2014, 01:17 PM
dogger99's Avatar
anyone
dogger99 is offline
post #4458 of 4612 Old 05-19-2014, 02:31 PM
smurraybhm's Avatar
Quoted: 1617 Post(s)
Liked: 2009
Its been a while since I used my Elite but you should be able to send a test tone to the sub only by adjusting the speaker trim levels manually. Maybe someone smarter than I am can offer a better solution.
There is no perfect display, quit looking for faults and enjoy
LG B7 OLED 65" (waiting for cal by DNice)
Ascend's with RAAL, Love my PSA v1800 and a 7.2.4 speaker config, Oppo 203 and other toys
smurraybhm is offline
post #4459 of 4612 Old 05-19-2014, 03:18 PM
Chise's Avatar
Quoted: 339 Post(s)
Liked: 133
anyone
From my knowledge you can turn up or down macacc does go job to me.
Chise is offline
post #4460 of 4612 Old 05-20-2014, 01:12 PM
dogger99's Avatar
anyone else?
dogger99 is offline
post #4461 of 4612 Old 05-20-2014, 01:56 PM
DonH50's Avatar
Liked: 1664
Not something I have tried recently. IIRC, I saved the MCACC settings into one of the unused memories, then went into manual setup and turned off all the other speakers in that memory for testing. The other way is to buy a test DVD that excites only the LFE (sub) output.
DonH50 is offline
post #4462 of 4612 Old 05-22-2014, 12:43 PM
dogger99's Avatar
I dont understand
dogger99 is offline
post #4463 of 4612 Old 05-22-2014, 02:01 PM
Chise's Avatar
Quoted: 339 Post(s)
Liked: 133
I dont understand
Go on your manuals settings turn up or down the subwoofer.
Chise is offline
post #4464 of 4612 Old 05-24-2014, 04:49 PM
dogger99's Avatar
so if i use pure direct i don't get any sound from the sub...if i use anything in the standard category like PLII movie i get sound out of the sub...i need sound out of the sub using PURE DIRECT.... What do I have to do to achieve this?
Originally Posted by DonH50 View Post
Use Pure Direct
dogger99 is offline
post #4465 of 4612 Old 05-24-2014, 07:19 PM
smurraybhm's Avatar
Liked: 2009
You need a disk for example that has a 5.1 mix - like a movie would or a DVD-A or SACD with a multi-channel mix.
post #4466 of 4612 Old 05-25-2014, 06:35 AM
dogger99's Avatar
I'm use REW software so to use DVD would not work...
dogger99 is offline
post #4467 of 4612 Old 05-25-2014, 07:04 AM
Vader424242's Avatar
Quoted: 79 Post(s)
Liked: 67
I hook up REW to the front RCAs, set the setting to stereo (NOT direct), raise the crossover to maximum (250Hz in my case), and disconnect/disable the front channel. That way, everything is sent to the sub(s) via redirection, and the mains are out of the picture. Works great!
Peace... Vader
"Ya see, we plan ahead. That way we don't do anything right now. Earl explained it to me." - Valentine McKee
One sub to rumble them all. One sub to shake them. One sub to humble them all. And in the darkness break them....
Vader424242 is offline
post #4468 of 4612 Old 05-25-2014, 12:44 PM
DonH50's Avatar
Liked: 1664
Without a test disc you have to use a mode that engages bass management as mentioned above then turn off the other channels.
DonH50 is offline
post #4469 of 4612 Old 06-05-2014, 08:23 AM
TyatNU82's Avatar
Searched this thread but couldn't find an exact answer...
I bought two outdoor speakers for my deck, and I hooked them up to my SC-37 as a Zone 2. I am able to watch TV inside on Zone 1 and listen to my IPOD outside as Zone 2. The problem I'm having is that I cannot get the TV signal audio to play in Zone 2.
My TV signal is from a Comcast Xfinity X1 set top box, which is connected to my SC-37 via an HDMI cable.
The only thing that I can think of is that the SC-37 will not play HDMI audio signals to ZONE 2 ???
Does anyone know if this is the case?
Tyler
TyatNU82 is offline
post #4470 of 4612 Old 06-05-2014, 08:31 AM
MSchu18's Avatar
Quoted: 166 Post(s)
Liked: 359
I think it should... all you are doing is switching zones.
page 79-80 in your manual.
http://www.manualslib.com/manual/350636/Pioneer-Sc-37.html?page=80#manual
Samsung PN64D8000
MSchu18 is offline
