"Official" Pioneer Elite SC-37 - Page 22 - AVS Forum | Home Theater Discussions And Reviews
 4Likes
post #631 of 4612 Old 08-10-2010, 11:47 AM
bcollins's Avatar
Originally Posted by ccotenj View Post
audio parameters are global... although there are some that will not be applicable in certain input modes... and if they aren't applicable in a given input mode, you can't modify them there...
here's what it says underneath the "video parameters" instructions...
"All of the setting items can be set for each input function."
which doesn't mean "can be set uniquely for each input function"...
not saying you "can't"... but as i think recent events have shown, reading more into the manual than what it really says can lead to some misconceptions...
so can you try it out for us? should be easy... pick an input, change a video setting... go to another input and change it... then go back to the first input and see what it says...
Guilty as charged. They do like to play word games with their documentation don't they?
I'll try it out tonight and report back.
bcollins is offline
post #632 of 4612 Old 08-10-2010, 11:53 AM - Thread Starter
Jnipz's Avatar
you SURE video is per input?
here's what the manual says underneath the "audio parameters" instructions...
"Depending on the current status/mode of the receiver, certain options may not be able to be selected. Check the table below for notes on this."
The video can be set uniquely, I had the isf tech adjust each input andit retains it's unique values.
As for the aduio, I will verify later this evening.
Jnipz is offline
post #633 of 4612 Old 08-10-2010, 11:54 AM
ccotenj's Avatar
Liked: 101
fear not... before long, you too will own a "pioneer manual secret decoder ring"...
cool, thanks! always good to get the empirical evidence...
- chris
ccotenj is offline
post #634 of 4612 Old 08-10-2010, 11:58 AM
ccotenj's Avatar
Liked: 101
ah, more empirical evidence... good deal...
if audio is per input, there are going to be a LOT of happy people...
because then you'd be able to set your hdmi setting of through/amp per input, and those who want to watch tv and listen through their tv speakers and only use their avr's for movies could quit griping that they can't do it without going in and changing the parameter manually....
- chris
ccotenj is offline
post #635 of 4612 Old 08-10-2010, 11:58 AM
ibre34's Avatar
Quoted: 12 Post(s)
Going back to the Denon, Pioneer discussion.
I know may not be a great difference while watching a movie because an explosion should sound the same but what about sterero mode while listening jazz or an opera or a classical concert?
ibre34 is offline
post #636 of 4612 Old 08-10-2010, 12:17 PM
SpedInFargo's Avatar
No, It will not show the volume on-screen. The 37 will show the volume on the RF remote, when set to RF mode.
Hmmmm - RF remote you say. This might be an acceptable workaround. Does the RF remote come with the 35 and 37 or is it extra?
I really shouldn't be in this thread... I've been dissatisfied with my Denon 3808 combined with Mythos STS and Mythos 9 for a long time and have heard that those speakers match up better with the Pioneer SCx machines...
Really don't want to talk myself into an upgrade purchase...
SpedInFargo is offline
post #637 of 4612 Old 08-10-2010, 12:20 PM - Thread Starter
Jnipz's Avatar
RF Remote comes with the 37 and is NOT available for the 35.
Jnipz is offline
post #638 of 4612 Old 08-10-2010, 12:21 PM - Thread Starter
Jnipz's Avatar
Quick question...
Should one shell out an extra $150 for a BB protection plan on the 37?
Jnipz is offline
post #639 of 4612 Old 08-10-2010, 12:39 PM
ccotenj's Avatar
Liked: 101
imo, no....
ime, if electronics are gonna croak, they generally do it pretty much right away... once they get past the first 10-20 hours of use, they seem to last a darn long time... sure, there are some failures past the 2 year warrantee period, nothing is perfect... but (again, ime), those are pretty rare with audio equipment...
ymmv... but i'd buy 150 dollars worth of cd's instead...
- chris
ccotenj is offline
post #640 of 4612 Old 08-10-2010, 12:44 PM
avsnoob10's Avatar
Quoted: 17 Post(s)
If you go back a page on this thread "ccotenj" did a very fair and complete comparison. thanks to ccotenj and ss9001 for answering tons of questions and fair advice.
avsnoob10 is offline
post #641 of 4612 Old 08-10-2010, 12:49 PM
bsoko2's Avatar
Quoted: 79 Post(s)
Liked: 80
Originally Posted by bcollins View Post
The sound quality of the Pioneer is much better, no question. In particular, the bass is much more present and substantial for some reason. The Denon sounded very thin and scenes that I am very familiar with that should have tremendous bass left me flat and scratching my head. I was spending all of my movie watching time tweaking and wondering why I couldn't get it to sound right. That's the main reason I bought the 37. Believe me, I wasn't anxious to part with another $2K and had no intention of "upgrading" this quickly. If I wasn't happy with the SQ of the Pioneer I would send it back. Feature wise, I would almost consider this a lateral move as the Pioneer doesn't offer that much that I didn't already have on the Denon.
The UI on the Denon trounces the Pioneer though. It's much more comprehensive, has a transparent overlay for all menu functions and has an OSD for volume/source. Those things are secondary to sound quality though so it doesn't bother me that much. Once I get everything set up I won't be visiting the menus much and the RF (two-way) remote and the iPhone app mitigate the OSD shortcomings pretty well.
Also palying into the audio is the difference between Audyssey and MCACC. I had a Integra DHC 9.9 with Audyssey Pro and now the SC-37. Audio and bass through MCACC is much better then Audyssey. Audyssey is too flat where MCACC isn't and MCACC has way less control over the LFE channel, where Audyssey controls everything and it is flat.
bsoko2 is online now
post #642 of 4612 Old 08-10-2010, 01:25 PM
izub's Avatar
Hi...It says the 37 decodes FLAC...I have some 24 bit flac audio on a USB stick and my computer...can you just plug in the USB and it will play? If not, will it play from my computer(ethernet hook up to 37)If neither works how do you play it? (also will the 27 play it?) Thanks for help, I need to upgrade!!
izub is offline
post #643 of 4612 Old 08-10-2010, 01:36 PM - Thread Starter
Jnipz's Avatar
I don't think the 27 supports the playback of FLAC.
16bit FLAC is the highest the 37 supports.
As for the USB, I will have to verify that.
Jnipz is offline
post #644 of 4612 Old 08-10-2010, 01:37 PM
croseiv's Avatar
Yes it does.
croseiv is offline
post #645 of 4612 Old 08-10-2010, 01:39 PM - Thread Starter
Jnipz's Avatar
Thanks for the correction on the 27
Jnipz is offline
post #646 of 4612 Old 08-10-2010, 01:42 PM - Thread Starter
Jnipz's Avatar
Specs on FLAC for the 37/27..
FLAC .flac FLAC Sampling frequency 8 kHz, 16 kHz, 22 kHz, 32
kHz, 44.1 kHz, 48 kHz
Quantization bitrate 8 bit, 16 bit
Channel 2 ch (8-bit monaural audio
is not supported)
Bitrate —
VBR/CBR Not supported/Supported
Jnipz is offline
post #647 of 4612 Old 08-10-2010, 01:55 PM
izub's Avatar
Thanks so I guess my 16 bit flacs will play but not the 24...I think I'll need to burn to DVD then...
izub is offline
post #648 of 4612 Old 08-10-2010, 01:56 PM
mhdiab's Avatar
Quoted: 73 Post(s)
Liked: 42
Quick question...
Last TV I bought at BB was bought with a $400 discount if I paid $400 for the EW......
So try to negotiate $150 discount if you buy the EW. They are rated by the number of EW's they sell as that is a big money maker. They don't get commission so may as well lower the price and get kudos for selling the EW
mhdiab is offline
post #649 of 4612 Old 08-10-2010, 02:04 PM - Thread Starter
Jnipz's Avatar
The EW is an after thought, have 30 days from time of purchase to decide. I'll probably take Chris's advice and not get one.
Jnipz is offline
post #650 of 4612 Old 08-10-2010, 02:40 PM
bcollins's Avatar
Unfortunately, it doesn't appear that the audio settings are per input. I've changed several and the changes have carried over to each input. That's not to say that all of them are global because I didn't test every setting but so far that looks to be the case.
bcollins is offline
post #651 of 4612 Old 08-10-2010, 03:10 PM
ccotenj's Avatar
Liked: 101
thanks for trying it.
it's exhibiting the "expected behaviour" for a pio avr...
- chris
ccotenj is offline
post #652 of 4612 Old 08-10-2010, 03:17 PM
Toknowshita's Avatar
Quoted: 37 Post(s)
Liked: 61
Which is the whole reason for the difference in the approach to room correction... Audyssey corrects the biggest problem areas ie. the lower frequencies. You can always turn Audyssey off or jack the sub a few dB if you don't like it.
MCACC has not advanced much.
Toknowshita is offline
post #653 of 4612 Old 08-10-2010, 03:32 PM
dogone's Avatar
Hi fellers...I'm I missing something here?...I have my HDMI outputs set to both. One going to Projector and the other going to a flatscreen in another room... Now when I turn on my Flatscreen TV, it comes on without the projector being turn on, But when I'm in my theater and I just want the projector on...it won't come on unless I turn the flatscreen on in the other room. What gives???
dogone is offline
post #654 of 4612 Old 08-10-2010, 03:34 PM
Juan's Avatar
Turn off HDMI control.
Juan
My HT
Juan is offline
post #655 of 4612 Old 08-10-2010, 03:42 PM
dogone's Avatar
Yes, I know about that...I did that already, but still when I have the receiver set to both, and I only want the projector to play (with the flatscreen off), well, it won't...I have to either switch the output setting to output 1 (projector), or if output is left on both, I have to turn on the LCD flatscreen before the projector will play...However, when left on both, I "can" operate the flatscreen without turning the projector on. It just doesn't work vice-versa...
dogone is offline
post #656 of 4612 Old 08-10-2010, 03:51 PM
Juan's Avatar
Make sure HDMI control is also turned off on the TV.
Juan
My HT
Juan is offline
post #657 of 4612 Old 08-10-2010, 04:09 PM
dogone's Avatar
I don't think this cheap flatscreen has that...I just went into the menu and don't see anything related to HDMI control.
dogone is offline
post #658 of 4612 Old 08-10-2010, 04:14 PM
dogone's Avatar
The flatscreen is not 1080P it is 1080i...and the projector is 1080P...could this have something to do with it?....Maybe both displays need to be the same?
dogone is offline
post #659 of 4612 Old 08-10-2010, 04:21 PM
Juan's Avatar
Flatscreens (digital displays) are not usually 1080i, who makes the flatscreen? Also, HDMI control might be called something else on that TV.
Juan
My HT
Juan is offline
post #660 of 4612 Old 08-10-2010, 04:49 PM
mhdiab's Avatar
Quoted: 73 Post(s)
Liked: 42
Which is HDMI 1 vs 2? Have you tried switching them to see if the problem gets reversed?
So does the TV accept 1080P Just curious, but don't think that is the issue
mhdiab is offline
