Sony system - need help getting sound from TV - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 06-25-2010, 05:15 PM - Thread Starter
Art K.'s Avatar
Might be a stupid question, but I'm a newbie! I just purchased a Sony HT-SS370 home theatre system to hook up my KDL-52Z5100 Sony TV and my Sony Blu-Ray player via Bravia Sync with HDMI cables. Everything works, except I have my TV connected to the internet directly - now when I try something like Netflix or Amazon video, I get no audio - shouldn't it be coming out of the receiver? I think I have all of the settings correct (HDMI switched to ON, Audio Return Channel set to ARC ON) - but still nothing. Do I need to connect the optical audio out from the TV to the receiver? I would have thought that the HDMI cables would handle this. Help!!
Art K. is offline
post #2 of 8 Old 06-25-2010, 06:41 PM
Roger Dressler's Avatar
Quoted: 1522 Post(s)
Liked: 710
Both products need to support HDMI 1.4 in order for the return channel to work. I looked at the info on the Sony HT-SS370 but could not find evidence that it supports ARC. Can you confirm?
Deadwood Atmos theater [HTOM]
AV7702 Atmos 7.4.4, SSP-800 PLIIx 7.4
Aerial Acoustics 7B/CC3B fronts, B&W CWM8180 surrounds, Tannoy Di6 DC heights, Hsu ULS-15 subs
Roger Dressler is offline
post #3 of 8 Old 06-25-2010, 07:28 PM
mbyrnes's Avatar
Quoted: 93 Post(s)
Liked: 186
Hook up to the analog or fiber optic out from the TV and hook that into your AVR. HDMI 1.3 doesn't send audio back to your AVR from the HDTV.
Xbox Live: TheRealMaxPower --- PSN: TheRealMaxPower (no PS4 currently) Panasonic TC-P65VT60    Vienna Acoustic Mozart Grands    Pioneer SC-72   Sony BDP-S790 Xbox One S Astro Mixamp 2013   Soundblaster X7 (Sparkos Op Amps) Schiit Modi Multibit/Magni   LTA MicroZOTL2 AKG K702 65th Anniversary   Fostex TH-X00 Ebony DT990 Pro 250 ohm  Massdrop/Sennheiser HD6XX and PC37X Audio Technica ATH-M50x Antlion ModMic
mbyrnes is offline
post #4 of 8 Old 06-25-2010, 08:44 PM - Thread Starter
Art K.'s Avatar
The manual for the HT-SS370 does say it supports ARC.
Art K. is offline
post #5 of 8 Old 06-25-2010, 11:41 PM
JChin's Avatar
Quoted: 349 Post(s)
Liked: 204
Yes the HT-SS370 does support ARC but the Tv does not (did not see in the specs or manual).
JChin is offline
post #6 of 8 Old 06-26-2010, 08:37 AM - Thread Starter
Art K.'s Avatar
Okay - looks like it's the fiber optic cable! Thanks!
Art K. is offline
post #7 of 8 Old 06-26-2010, 09:29 AM
Easyaspie's Avatar
When you get the TV connected to your receiver via optical let us know how it works out. There have been several dicussions here over the years about what TVs will send via their optical outputs. Usually it is info that is derived from one of the TV's internal tuners, either OTA or cable.
I'm curious what happens with an internet feed.
If it doesn't work, you could always use analog. I believe Netflix streamed from the net is only 2 channel at this point anyway.
Easyaspie is offline
post #8 of 8 Old 06-27-2010, 12:28 PM - Thread Starter
Art K.'s Avatar
Hooked up an optical cable today, and all is well!
Art K. is offline
