New Onkyo TX-NR5008 & TX-NR3008 - Page 290 - AVS Forum
Old 08-18-2014, 06:38 AM
jebbj's Avatar
I purchased the Onkyo TX-NR5008 from Newegg in September of 2010 knowing that this receiver would deliver great sound for years to come. What a shocker when connecting the Onkyo TX-NR5008 no sound from my Martin Logan Aerius i's that I treasured for years. After thoroughly checking connections resetting the receiver I was persuaded by a Onkyo tech to drive it to the nearest shop for diagnosis. They kept the receiver a month and found no apparent problems. The receiver did work after connection. However I knew it had to be a problem. With the device working let well enough alone. However over the next few years I watched this forum and noticed the problems with the hdmi boards begin to appear. My problem began anew just about every 4 or 5 months no sound or intermittent audio. Finally no sound and greyed out menus started to appear. Which meant I could not conect to the internet or receive updates. This was insane. I called Onkyo which is now 4 years later and expected to hear the worse. To my shock and awe I was instructed to be patient while they would send me a postage free box to ship my unit to Onkyo for repair. I'm in a state of shock! Proactive customer service exists...will keep you all updated on the progression. Any comments with similar experience would be appreciated. Please keep the FORUM alive it is a major help. No problem is too small or too large that cannot be shared.
Blue Rain likes this.
jebbj is offline
Old 09-09-2014, 03:53 PM
jebbj's Avatar
Follow-UP
Just receive the Onkyo tx-nr5008 on Friday 09/05/2014 and am in the process of reconnection. Speedy return.
I did notice that the sound is now being emitted will soon have all devices connected and will give a full report.
jebbj is offline
Old 09-12-2014, 07:01 AM
jebbj's Avatar
Smile Onkyo TX-NR5008 In Service
To whom it may concern my Onkyo TX-NR5008 has been returned to active duty. The hdmi board has been replaced and the osd, internet access and radio features are back online. Thanks to ONKYO customer care and repair for taking good care of my needs for service.
jebbj is offline
Old 09-14-2014, 07:40 PM
skoobydoo's Avatar
Quick return from Onkyo for a one time honoring of out of warranty warranty service. Back up and wondering how long hdmi board will last this time around.
skoobydoo is offline
Old 10-22-2014, 03:39 PM
HAMP568's Avatar
Quoted: 14 Post(s)
Hey guys, I know this subject has been touched on a few times, but I wanted to give another option for using AMPS with the Onkyo 5008 or with none zone 1 trigger AVR’s.
I believe there is a work around to use the zone 2 for a trigger/s
Here is another way.
I bought an Emotiva ET3, and I am using a ‘USB to 3.5mm’ cable instead of the 3.5mm cable that came with the device to trigger my external amps.
I simply plug the new cable(USB to 3.5mm) I have into the back(or front) USB slot of my Onkyo 5008, and plug the 3.5mm end into the ET3. There is enough power coming from the USB to trigger the ET3, which triggers the selected amps I am using(which happens to be 3 separate external amps).
I’m not sure you would want to call this a work around, but it works nicely.
Maybe I should create a thread, and let everyone else who isn’t using an Onkyo 5008.
HAMP568 is online now
Old 10-26-2014, 08:23 AM
AVS Club Gold
anthonymoody's Avatar
Quoted: 18 Post(s)
Liked: 66
My 5008 just developed the HDMI board fail/no sound AGAIN. It's already been replaced (the board, not the receiver) once. Contacted the service center and they said bc it's out of warranty I need to go through Onkyo first to get them to authorize the repair.
Ugh. Hopefully I can convince them to send me a replacement, even if it's a refurb, rather than service this one again.
Stuck up, half witted, scruffy looking, nerf herder.
Double True!
anthonymoody is offline
Old 10-28-2014, 01:22 PM
Toknowshita's Avatar
Quoted: 35 Post(s)
Liked: 47
That sucks. How long between failures? I had my 3008 fixed about a year ago.
Toknowshita is offline
Old 10-28-2014, 05:30 PM
bakerwi's Avatar
Quoted: 42 Post(s)
Liked: 37
Good luck. Mine was repaired 3 times.
Pioneer Elite PRO-151FD
Zektor MAS7.1
Classé CA-2200/CA-5200
Oppo BDP-105, Denon DVD-5910CI, Cambridge 752BD, Cambridge 640C V2
Paradigm Signature S8, Paradigm Signature ADP1
Paradigm Signature ADP3, Paradigm Signature C5
REL R-505 Sub (2)
Oppo BDP-93, BDP-103D, Pioneer BDP-320
Sony BDP-S790
bakerwi is offline
Old 10-31-2014, 06:11 AM
AMarinho's Avatar
I gave up on my Onkyo TX-NR5008. The same HDMI board issue.
AMarinho is offline
Old 11-03-2014, 01:24 PM
AVS Club Gold
Quoted: 18 Post(s)
Liked: 66
Just over 2 years.
Have you guys gotten yours repaired under the relatively recent recall program? There's another thread here on it. I found it after I posted in this thread. Apparently a bad set of chips caused the issue. They didn't diagnose it and get clean chips until some time later in 2013. So apparently any repairs before then were just ticking time bombs. Now they send you a box, packing material, and pre-paid label to send it back to them for repair and, once done, the warranty goes all the way to 2018. Mine is on the way to Onkyo now.
Double True!
Old 11-04-2014, 06:30 AM
djbluemax1's Avatar
Quoted: 30 Post(s)
Liked: 289
Just over 2 years.
Got a link to this? I had mine repaired in... 2012? Or was it 2011? I can't even recall when I got the 5008. I think it was in Nov/Dec 2010, it developed the HDMI board problem about 18 months later, i.e. first symptoms around July 2012. Sent in twice around Sep/Oct (they mistakenly put in a 3008 board without the rear USB port the first time).
Put some bigger fans from coolerguys.com on it when I got it back and it's been trouble free so far, but if there's a new recall + extended warranty, you'd better believe I'm in.
Max
djbluemax1 is offline
Old 11-04-2014, 06:53 AM
AVS Club Gold
Quoted: 18 Post(s)
Liked: 66
Max
Here's the thread link:
Onkyo acknowledges failed units and extending warrranties until 2018
The first post has a link to the page at Onkyo. You basically enter you s/n and it tells if you're eligible. Good luck!
Double True!
Old 11-04-2014, 07:47 AM
djbluemax1's Avatar
Quoted: 30 Post(s)
Liked: 289
Thanks! Wouldn't have known of this without your post in this thread.
Max
Old 11-04-2014, 12:39 PM
AVS Club Gold
Quoted: 18 Post(s)
Liked: 66
Max
NP. I found it just scanning through threads here. HEY MODS can we make it a sticky?
Double True!
Old 11-04-2014, 01:02 PM
Super Moderator
Kysersose's Avatar
Quoted: 12 Post(s)
Liked: 27
Stickyfied
"Good... Bad... I'm the guy with the gun."
Ash - Army of Darkness
Kysersose is online now
Old 11-05-2014, 09:48 AM
kevin g.'s Avatar
Quoted: 104 Post(s)
Liked: 67
I think maybe they were asking for the recall thread to be stickied?? I think that would be more useful. Not sure why a specific model thread would need a sticky. Especially one that is four years old?
"Once you learn good English...Can't nobody take it away!"
Xbox LIVE Gamertag: KEVIN G 40
kevin g. is offline
Old 11-07-2014, 09:10 PM
thucker's Avatar
Quoted: 20 Post(s)
I got my 5008 back from HDMI board repair in June, finally getting around to setting my theater room up at the new house. Then I realized that I misplaced my Audyssey microphone. Can someone please take a look at the one they have and tell me the model number? I want to make sure I buy the right one.
If you have one sitting around that you don't need, please let me know.
thucker is online now
Old 11-08-2014, 10:15 AM
kevin g.'s Avatar
Quoted: 104 Post(s)
Liked: 67
I have an extra one for my defunct 807, that you're more than welcome to...I have no way of knowing what part numbers are for which AVR, though.
Where are you located?
kevin g. is offline
Old 11-08-2014, 01:33 PM
Super Moderator
Kysersose's Avatar
Quoted: 12 Post(s)
Liked: 27
Sorry, did it in a rush.
Fixed.
Old 11-08-2014, 04:49 PM
djbluemax1's Avatar
Quoted: 30 Post(s)
Liked: 289
If you check the Audyssey thread, there's an FAQ that lists the Audyssey mics.
Max
Old 11-09-2014, 10:53 AM
thucker's Avatar
Quoted: 20 Post(s)
I'm in Portland, OR. I'll gladly pay for shipping though. If it's the silver tower looking mic then that's the one.
Old 11-09-2014, 12:27 PM
kevin g.'s Avatar
Quoted: 104 Post(s)
Liked: 67
Yeah, its the silver model. According to this...they're pretty much all the same for multiple years/models. I did verify here, on Onkyo's site to make sure. (plugged in models from different years, always comes back as 245044.)
I'll check and make sure they have the same numbers on the one for my 818.
kevin g. is offline
Old 11-09-2014, 12:51 PM
OnkyoUSA's Avatar
Quoted: 28 Post(s)
Hi AVS Forum Users,
For those affected with the HDMI no Audio issue we have a special service program setup to repair the units affected in warranty or not.
Please follow the link below:
http://www.onkyousa.com/Support/service_info.php
There will be instances where the repair portal will not be able to assist in the repair of your unit, we ask that you give us the opportunity to hear your concerns and perhaps offer resolution by emailing us at askonkyo@us.onkyo.com. Please include your contact information along with the affected units serial number.
Onkyo USA Product Support Department
Website: www.onkyousa.com
Email: askOnkyo@us.onkyo.com Onkyo Products/ Services
askIntegra@integrahometheater.com Integra Home Theater Products/ Services
Phone: (800) 229-1687 (Onkyo)
(800) 225-1946 (Integra Home Theater) 24 hours a day/ Monday- Sunday
OnkyoUSA is offline
Old 11-24-2014, 08:59 PM
valero_r's Avatar
Originally Posted by OnkyoUSA View Post
Hi AVS Forum Users,
Thanks for addressing this problem and taking care of the affected customers.
The link provided states:
As part of this program we are also extending our standard limited warranty period to cover this issue for affected receivers through December 31, 2018
My unit already had the no audio problem several years ago, was sent to an authorized repair facility as directed by Onkyo USA, and is currently functioning normally. Has my TX- NR3008's warranty period already been extended as part of the program stated in the link above? If it has not already been extended, what do I need to do to extend the warranty?
valero_r is offline
Old 11-25-2014, 02:38 PM
kevin g.'s Avatar
Quoted: 104 Post(s)
Liked: 67
Add your serial number to the provided link to make sure you are covered.
kevin g. is offline
Old 11-25-2014, 04:57 PM
valero_r's Avatar
I did that, and the site says that my receiver is eligible for the program, but it also says "This program is for Onkyo USA customers who are currently experiencing the loss of audio or network capabilities on their receiver." Unless I missed it, it does not say that my warranty was extended when my 3008 was repaired several years ago. I just want to be sure my receiver is covered in the future if the same problem occurs again...like it did to several people here.
valero_r is offline
Old 11-25-2014, 07:14 PM
kevin g.'s Avatar
Quoted: 104 Post(s)
Liked: 67
That's why you add your serial number. Follow through with the procedure, until you see that you are covered, or not. My guess is: Yes.
kevin g. is offline
Old 11-28-2014, 10:56 AM
OnkyoUSA's Avatar
Quoted: 28 Post(s)
Hi AVS Forum,
As part of our commitment to quality and customer service we have determined that a limited number of Onkyo Brand receivers manufactured between 2009 and 2012 may experience loss of audio or loss of network connection. This malfunction has been traced back to a defective network chip.
We deeply regret any frustration or inconvenience this situation may have caused.
To address the problem and help people who may have an impacted receiver, Onkyo is launching a special Customer Care Program to remedy this issue for those receivers that may be affected by this loss of audio/network connection issue. This program has three steps:
1. Verify if your Onkyo receiver is impacted
2. Decide how you prefer to address the issue
3. Send us your receiver in a prepaid box and label that we will provide at no cost to you
As part of this program we are also extending our standard limited warranty period to cover this issue for affected receivers through December 31, 2018.
All other terms, conditions and limitations of the original limited warranty shall continue to apply for the duration of the original standard limited warranty.
Importantly, please note that the loss of audio/network connection issue will not result in harm to any connected components or speakers since the issue is contained to a single element within the affected receivers.
To determine if your receiver is eligible under this Customer Care Program please click here
Loss of Audio/Network Connection Customer Care Program for US and Canada customers
Click here to check the status of your repair.
Please give us the opportunity to assist you, if for any reason the portal is not able to assist you please email us your contact information, units serial number along with a brief description of the problem and we will do our best to resolve the issue.
Onkyo again apologizes for any inconvenience this may have caused and we thank you for your loyalty!
OnkyoUSA is offline
Old 12-17-2014, 03:09 PM
rickardl's Avatar
Quoted: 39 Post(s)
Liked: 44
As an owner of Onkyo TX-NR3008, I sincerly appreciate your commitment to your customers.
rickardl is online now
