New Onkyo TX-NR5008 & TX-NR3008 - Page 291 - AVS Forum | Home Theater Discussions And Reviews
 10Likes
post #8701 of 8714 Old 03-11-2015, 12:21 AM
jdsmoothie's Avatar
Quoted: 15028 Post(s)
Liked: 7248
Originally Posted by Iron Maiden View Post
Feeding my 3008 with an Oppo 103. Tried putting in Dark Side of the Moon SACD tonight, no sound. Flashes the hdmi input then goes to analog and no sound. If I set the Oppo to output auto/pcm, then I get sound. I had it set to output DSD before and no problems. What am I missing here?
AFAIK, DSD bitstream only works on HDMI 2 on 103 as opposed to either output on 103D.
jdsmoothie is online now
post #8702 of 8714 Old 03-11-2015, 10:37 AM
Iron Maiden's Avatar
Quoted: 537 Post(s)
Liked: 207
Thanks, I will see if that is it.
60" Panasonic Plasma ~ BenQ HT1075 / 92" Screen~Onkyo TX-NR3008(Pre/Pro)
Earthquake Cinenova Grande Amplifier ~ Oppo BDP-103 ~ Xbox One & PS4
Musical Fidelity Tri-Vista Tube DAC ~ Monster Cable Signature Series HTPS7000
Energy Veritas V2.3i (mains)~Veritas V2.4i (Front Wides)~Veritas V2.2i (center)
Energy Veritas V2.1 & CAT Tiburons(Surr)~Subs: 2 FTW-21's~Fp10000q clone/2x4dsp
Iron Maiden is offline
post #8703 of 8714 Old 10-26-2015, 09:33 AM
JBHorne's Avatar
Question Issue with Composite and Component --> HDMI
Hi everyone,
I have a TX-NR5008 and am having an issue with converting Composite or Component to HDMI output. All of my other sources are HDMI, so I currently don't have any component/composite devices. I picked up a wii cheap for the kids and am having an issue getting to to output over HDMI. The Onkyo manual states this is possible, but it won't work with any settings I try. I can connect the Wii just fine via composite or component directly to the TV. Then I tried using the composite inputs on the front (AUX) and I get sound but blue screen. OSD menus work. Connecting component to the GAME inputs and setting the mapping to IN3, same issue. I've tried with both the 480i and 480p settings in the Wii.
This unit has had the HDMI board replaced twice already. Is this a sign that it's failing again? I wouldn't think the HDMI board handled the conversion (would think that would be a separate video processor), but I'm at a loss here.
I've ordered an HDMI converter for the Wii, so hopefully that will be an ok workaround, but I'd still like to fix the issue.
Any ideas are greatly appreciated! Thanks!
JBHorne is offline
post #8704 of 8714 Old 08-02-2016, 04:34 PM
valero_r's Avatar
My 3008 just died again. This time, I have the no audio issue and no network connection. Thank God Onkyo extended the warranty. I'm thinking of getting the Denon X6300W when it comes out. Has anyone with a 3008/5008 experienced the loss of audio problem with a receiver that has been repaired in 2016?
valero_r is offline
post #8705 of 8714 Old 08-09-2016, 10:43 AM
Quoted: 537 Post(s)
Liked: 207
I have the 3008 as well. I bought it used. It had just came back from having the HDMI repair done. I knew it was a gamble, but for $500 I jumped on it as I wanted to try some new speaker setups. Mainly front wide channels.
Knowing the big issue with these receivers is the HDMI board getting cooked(at least what I have read) I have always used my Parasound Z-Breeze over the top of the HDMI board. Think have had the receiver for a couple years now and no issues and the unit stays nice and cool. I also don't keep my gear in an enclosed rack or cabinetry. The receiver sits in open air with nothing above it, just the Z-Breeze. Fingers crossed I never have issues as I'm not ready to replace it!!!!
Good luck with yours.
post #8706 of 8714 Old 08-09-2016, 11:00 AM
valero_r's Avatar
Thanks for the reply. Onkyo sent me the packing materials, and I should be getting them tomorrow. I keep my 3008 in a open metal/glass rack/stand, and I use a pair of ~7" fans on top of the receiver. When I get my new receiver, my 3008 will replace my 807 as my secondary/backup receiver.
valero_r is offline
post #8707 of 8714 Old 09-04-2016, 04:13 PM
valero_r's Avatar
I'm not sure what the proper term is, but I'm trying to make my 3008 put out an "up-converted" simulated surround sound from a stereo source (PS4 and PC). I just got my receiver back from repair, and now it will not put out simulated surround sound no matter which sound mode it's in. I'm pretty sure I wasn't having this problem before it was sent in. Sound only comes out of L/R channels even if the front panel says all of the speakers are in use. All audio and video is being sent to the receiver via HDMI cables from my PC and PS4.
I know that my speakers (9.2 no wides) are all working since I hear pink noise when checking the speakers in the "Level Calibration" menu. I also hear sound from the center channel when I'm able to provide a 5.1 source (BD/DVD/NetFlix). If it matters, yes, I have run the Audyssey setup.
If I am forgetting to adjust a menu item on the 3008 or PS4, please point it out. Unfortunately, I can't remember how to set this up.
valero_r is offline
post #8708 of 8714 Old 09-28-2016, 09:46 AM
Quoted: 537 Post(s)
Liked: 207
Did you call them? Get it fixed? I run Audyssey DSX for pretty much everything except music. I run 5 front speakers(wides) and 4 rear. Not sure if I will ever try the height speakers as I may just move on to Atmos.
Hope you got it fixed.
post #8709 of 8714 Old 09-28-2016, 04:05 PM
valero_r's Avatar
The problem isn't really fixed, but I found a way to make it work. I called Onkyo tech support, and the tech said that my DSP chip appeared to be malfunctioning. I sent it back a third time, and it came back better than before. Audio from my media players is separated into multiple channels, but audio from YouTube is still Stereo (L&R only)...and this is from the same computer. Non-5.1 movies on Netflix (PS4) also play in stereo only. I hooked up my PS3 slim to my 3008, and stereo movies (same movie) now have "surround" sound. I know I'm just being picky, but I want the majority of the dialogue to come from the center channel...so I guess I'll keep the PS3 hooked up. I also tried switching to different HDMI ports on the back of the 3008.
A new Denon receiver is looking more tempting every day.
EDIT: I also tried switching HDMI cables--no change.
valero_r is offline
post #8710 of 8714 Old 10-05-2016, 09:40 AM
d3193's Avatar
Quoted: 61 Post(s)
Liked: 48
Control via HDMI
I've recently purchased an LG OLED TV whose remote can control the Onkyo via HDMI. This is convenient except that it always turns the Onkyo on to its number 1 input, which is where I have my PS3 connected (it also turns on the PS3).
Is there some way to have the Onkyo start with a different input (e.g. Cable/Sat)? I cannot find anything in the menus.
d3193 is offline
post #8711 of 8714 Old 10-21-2016, 12:26 PM
JBHorne's Avatar
Onkyo has to be the WORST company in the AV business. After installing hundreds of their AVRs and other products, I will NEVER buy from them again. I have had nothing but problems with my TX-NR5008. It has been into service several times already for the same issue -- the audio dropout issue. Last service was done in April. Now, the issue is occurring again. Onkyo Customer Care will not repair the unit stating that since it was already repaired once, the issue "has to have been fixed". Apparently they removed a chip that was causing the issue, and since that chip is no longer there, it's "impossible" for the issue to be still occurring.
If you are not familiar, Onkyo extended the warranty for these units due to this issue (see http://www.onkyousa.com/Support/service_info.php). Within this bulletin it states, "As part of this program we are also extending our standard limited warranty period to cover this issue for affected receivers through December 31, 2018. All other terms, conditions and limitations of the original limited warranty shall continue to apply for the duration of the original standard limited warranty."
The rep flat out stated that they did NOT extend the warranty and will only cover the first repair. Where does it state this within their notice? It's BS and I'll fight this until the end.
Same issue = not fixed.
JBHorne is offline
post #8712 of 8714 Old 10-21-2016, 04:58 PM
valero_r's Avatar
That's odd. When I got my 3008 repaired again (~1 mo. ago) for the same problem, they didn't have a problem repairing it under the extended warranty. I don't remember who I spoke to, but I would call back, and hopefully you can talk to a different person in tech support. Good luck. If my 3008's sound dies again, I'll probably end up getting the Denon 6300.
valero_r is offline
post #8713 of 8714 Old 03-18-2017, 06:54 PM
chrishicks's Avatar
I tried searching this topic but I didn't see anything like what I'm experiencing with my 3008 currently. I'm in MI and about 2 weeks ago we lost our power. It was out for my area for 5 days. In this time my house had no heat so the house dropped to around 40 degrees over time. My 3008 was working prior to the power going out and was plugged into a UPS. Once I noticed the power wasn't coming back(around 3-5 minutes) I powered down the receiver. Fast forward those 5 days and power comes back finally. The house is still an icebox because the furnace died so I start checking other things out. I power up the 3008 again and it turns on, I get sound but no video. I try running through the various settings on the display and it's as if the output is stuck on 480i/60. My TV says "not supported". I check one of my sources(Tivo since it has a video output button to cycle through) and no matter what I try I still get not supported on the TV. I pull up the display on the 3008 and I see 2 resolutions on the screen. The top is the 480i/60 and the bottom one is 1080p/60 and it's flickering. I then try to run a standard A/V cable to the TV and it's all wonky. I get 4 boxes on the screen and all of them are just a blur.
I start to suspect the TV so I reconnect my HTPC to the TV directly and it works. I test all the HDMI on the set and they're all fine. Go back to the receiver and it's the same not supported mode on screen. Also, switching between say HDMI Main and Sub as well as using "both" all result in mode not supported on the TV. I'm guessing it's something to do with the 480i/60 shown on the display. After a while of messing with it I decide to do a reset on the unit. After that it's still the same issue. No video at all. Is there some other thing I should try to get this to maybe start working or is it just dead again? I had the HDMI board repaired/replaced back in 2013 due to no sound before Onkyo did the extended warranty so this would be the second repair on it. The Onkyo extended warranty page basically says to toss it in a landfill because I have sound so I'm not sure what to do here.
And just to toss this out there, I connected a Pioneer 1130 I had and everything works with that so it's definitely an issue with the 3008.
chrishicks is offline
post #8714 of 8714 Old 05-06-2017, 03:21 PM
jayman_1975's Avatar
I'm wondering if anyone has tried using their 5008 as a 2 channel pre being fed by a really good analogue source. Just wondering if I need a 2 channel preamp or just a really really good player or maybe dac. Wondering if the 5008 is up to the task
jayman_1975 is offline
