New Onkyo TX-NR5008 & TX-NR3008 - Page 82 - AVS Forum | Home Theater Discussions And Reviews
 10Likes
Old 01-22-2011, 09:59 AM
bakerwi's Avatar
Quoted: 65 Post(s)
Liked: 42
Originally Posted by william06 View Post
Unfortunately you are right it's called business and for us silly enough to fall for it. I did and hate to say I am not sorry. Love my 5008, the only thing I hope in a future firmware they will allow you to switch between Wides and heights together or Highs or wides with backs. This is something joerod mentioned a few weeks back that was possable. I tried the denon 4311 between selling my 5007 and getting a 5008 and did not care for it. My reasons were explained in detail a while back. The biggest improvement to me was the upgrade to xt32 and the ability to go heights and wides together unfortunately to do that you have to connect the wide speakers to the back terminals and then if you want to use backs you have to switch back. Hopefully Onkyo can rectify this foolishness with the firmware upgrade, well see. all else with unit is fine with me.
William,
You are right about this being business. I think I'm set for the next couple of years with my recent acquisitions. My listening and viewing needs are simple since I basically only listen and watch shiny discs. This was my first major AVR acquisition (used Marantz SR7002) in almost 10 years. I am glad to see you are still enjoying your 5008. Audyssey MultEQ XT32, the ability to do 9.2 or 11.2 (Denon AVR-A100) and HDMI 1.4a (though not currently interested in 3D) were compelling enough reasons to upgrade. These all seemed like major advances in my opinion.
Willie
Basement: Oppo BDP-105D, Denon DVD-5910CI, Arcam FMJ BDP300
Master Bedroom: Sony BDP-S790
Family Room: Oppo BDP-93, Pioneer BDP-320
Breakfast Area: Pioneer BDP-320
Office: Pioneer BDP-320, Cambridge 640C V2
Revel F208 (pair), C208
bakerwi is offline
Old 01-22-2011, 10:17 AM
A&M 350Z's Avatar
I am curious to here some opinions on the local dealers view of Onkyo. I was set to purchase the 3008 and went to the local store to check price (knowing it would likely be way too high!) Even though they carry onkyo, they were strongly advising against and recommended the 4311 or 7005. Here is why:
1. Problem with reliability since change to lead free solder. (obviously the 4311 has issues too though)
2. Sluggish audio response. (new one to me!)
3. Underpowered compared to specs (most avr do this when all powered afaik)
The 3008 i am looking at will go with 7 kef 9000 inwalls, and likely an emotiva amp.
A&M 350Z is offline
Old 01-22-2011, 10:29 AM
nezff's Avatar
Quoted: 141 Post(s)
Liked: 63
i still cant seeing spending that much more on the denon.
nezff is offline
Old 01-22-2011, 11:02 AM
djbluemax1's Avatar
Quoted: 54 Post(s)
Liked: 300
Originally Posted by Bman321 View Post
Hi
The amp freezes but I can use the buttons on the amp, unfortunatly there is no volume control on there. I have also found another work around where i turn the picture off on the TV which allows me to adjust the settings on the amp but this is not acceptable either IMHO.
Vieralink does not seem to be working so I cant even use the TV remote to adjust the volume.
You mentioned that the IR conflict is a problem with current 3D tech. Does this apply to all makes or just onkyo because if not I will simply return and choose another make.
No volume control on the receiver? Did you try the BIG dial/knob on the right side of the receiver? That doesn't work?
As far as which devices have IR conflicts with each other, it's difficult to say as there are different displays (with different 3D emitters) as well as different avr's with their different remotes.
You could try asking both in the Panasonic TV threads and in the threads of whichever other avr you might be considering if anyone else has had problems using the avr remotes when the VT25 3D emitter is active.
Might also want to pose the question here to any other VT25 + 3008/5008 if they also have problems using the Onkyo remote when the VT25 is displaying 3D. If they do, then it's just an incompatibility between the 2. If other VT25 owners have no problems, then it could be your Onkyo that has a problem.
Max
djbluemax1 is offline
Old 01-22-2011, 11:06 AM
Schuyler Bain's Avatar
Quoted: 33 Post(s)
5008 went down another $200 at NewEgg today.
Schuyler Bain is offline
Old 01-22-2011, 11:29 AM
JamMasterJames's Avatar
Originally Posted by kosmo69 View Post
is the 5008 worth the extra money ($450ish) over the 3008?
the 5 has the toroidal, "FINEST" Burr-Brown and a meaningless 5watts more power.
Id like to know if its worth shelling out the extra money for a 5008 as well.
Doesn't the 3008 have a toroidal PSU ?
JamMasterJames is offline
Old 01-22-2011, 11:31 AM
Is their price about the best that can be had on a 5008? thanks
Old 01-22-2011, 11:39 AM
Eldiablos's Avatar
Yes
Eldiablos is offline
Old 01-22-2011, 11:40 AM
Blue Rain's Avatar
Quoted: 140 Post(s)
Liked: 40
OK my 3008 arrived today
Going to open box now..should I connect to the web before powering it up ?
What's the latest firmware I should b expecting?
Polk 7.1
Samsung PN60F8500
73" 73738 Mits DLP
Onkyo TX-NR3008
Panasonic AE4000 Projector
Blue Rain is offline
Old 01-22-2011, 11:55 AM
e2g_'s Avatar
+1
Is there truly a (big difference) difference (when using external amps and an htpc)?
e2g_ is offline
Old 01-22-2011, 11:59 AM
skoobydoo's Avatar
Your dealer doesn't know what he is talking about. All three statements are not true. He makes way more money by selling you a Denon. Read the professional review at Home Theater.
skoobydoo is offline
Old 01-22-2011, 12:01 PM
skoobydoo's Avatar
Originally Posted by e2g_ View Post
+1
The main difference is pride of ownership for those that want the best. It is unlikely you will hear the difference. Denon did the same thing with their 4311, offering the A100 with even less difference, for $500.00 more.
Old 01-22-2011, 12:14 PM
kosmo69's Avatar
+1
no way. However external amps are $$$$, especially 9 channels
kosmo69 is offline
Old 01-22-2011, 12:15 PM
kosmo69's Avatar
I just bot it today from newegg.
kosmo69 is offline
Old 01-22-2011, 12:16 PM
kosmo69's Avatar
Yes, the other authorized are anywhere from 200-300 more.
kosmo69 is offline
Old 01-22-2011, 12:28 PM
Are you a 3008 owner?
Old 01-22-2011, 01:26 PM
ratboy's Avatar
Question: How can I watch one hdmi source and listen to another? I like to listen to SACD on my oppo while I'm on my PC through the 3008, but it doesn't seem to allow it.
ratboy is offline
Old 01-22-2011, 01:28 PM
FilmMixer's Avatar
Quoted: 1723 Post(s)
Liked: 2084
You can't.
FilmMixer is offline
Old 01-22-2011, 02:55 PM
ripley161's Avatar
Originally Posted by ripley161 View Post
I have changed my 905 for a 5008 and have this problem so far. On TRUE HD only so far, and bad on HOW TO TRAIN YOUR DRAGON. The amp shut itself off 3 times during the movie. I press it back on again and plays for so long then shuts off to standby. True Hd is too loud compared to playing DTS HD and PCM. Never had this problem on the 905 and it is not my speakers shorting as I can play music etc loud , just TRUE HD so far......
In conclusion to why this happened since I first posted the above .
This problem solved today. I had my center speaker set to full band on my old 905, and did the same on the 5008. However using DYNAMIC EQ and FULLBAND on the 5008 didnt mix. Changed my center from fullband to 60hz and the film played fine ( as well as a couple of others movies I had problems with in certain scenes ) I never really should have had it set to FULLBAND in the first place . Movie stays on without DYNAMIC EQ !!! So in this case my center speaker was to blame 99% certain as I have run tests all day !! Anyway thats my conclusion !!! Just thought I would post and say thanks to everyone that has tried helping me with this annoying issue !!
ripley161 is offline
Old 01-22-2011, 03:35 PM
TV addict#2's Avatar
Quoted: 26 Post(s)
did the setup on my 3008 and it's a keeper for me
just to keep the 6A piggy fed now
1.AsusXonarD2X...Kenwood8540...CarverTFM55x....... .901Bose
2.nVidiaHDmi...DENON AVR-4520CI...EMPTeKR55Tix4... R56Ci...SVSUltra/2...Toshiba55WX800U
TV addict#2 is offline
Old 01-22-2011, 04:21 PM
lorjam's Avatar
Quoted: 113 Post(s)
Liked: 114
[quote=A&M 350Z;19875662]I am curious to here some opinions on the local dealers view of Onkyo. I was set to purchase the 3008 and went to the local store to check price (knowing it would likely be way too high!) Even though they carry onkyo, they were strongly advising against and recommended the 4311 or 7005.
I'm sure you are familiar with term "profit margin"
JVC-RS4910, Samsung 64H5000, LG 60PA6550
Oppo 203, Oppo 93, Oppo 83SE, DirecTV HR44-200, Samsung DTB260F, Roku 3, Denon DP-1200
Marantz AV7702, Onkyo PR-SC5507, Onkyo TX-NR3008, McIntosh C26, DVDO Duo
Parasound A51, Parasound HCA-806A, Emotiva UPA-1s, Marantz MA500s, McIntosh MC2105
Paradigm Studio V4s & V5s, Hsu subs X2,
lorjam is offline
Old 01-22-2011, 04:23 PM
kosmo69's Avatar
as said above you cant. the 2nd source has to be ANALOG. These are the shorting comings of most receivers. There are some higher priced units that can do this.
kosmo69 is offline
Old 01-22-2011, 05:04 PM
dasanii19's Avatar
Quoted: 116 Post(s)
Liked: 30
Can someone please tell me the actual height of the 3008?
MY NAME IS SUE!!! HOW DO YOU DO!!!
"I started out with nothing, and I still have most of it."
dasanii19 is offline
Old 01-22-2011, 05:07 PM
7 13/16" according to Onkyo
Old 01-22-2011, 05:21 PM
bakerwi's Avatar
Quoted: 65 Post(s)
Liked: 42
Schuyler,
The price you see today is Newegg's weekend price. When you stated it went down another $200.00 I was expecting to see it for under $1,500.
Willie
bakerwi is offline
Old 01-22-2011, 05:26 PM
dasanii19's Avatar
Quoted: 116 Post(s)
Liked: 30
This 3008 receiver is massive, I don't think it will fit on my tv stand. Right now I have a Denon avr 1910, is there any other "quality" receivers that is about the same dimensions as my 1910?
Old 01-22-2011, 05:58 PM
mesasone's Avatar
I had a similar issue, the height is fine (I believe my shelves give me 9.5" vertically), but I hadn't considered the length of the 3008... so it's sticking a good 4-5" out from the front of the stand
The front feet are just barely (and only partially) on the stand.
IBEW Local 1362
Speakers: Energy RC-70 (L/R), RC-LCR (center), RC-RCR (surround)
Subwoofer: UM18-22 in 4cu sealed box powered by iNuke 6000DSP
mesasone is offline
Old 01-22-2011, 06:32 PM
dasanii19's Avatar
Quoted: 116 Post(s)
Liked: 30
Yea, I just measured the depth and I cant fit the 3008 there. I guess ill just keep my 1910.
Old 01-22-2011, 06:45 PM
mjf_uk's Avatar
Seems a shame because the 3008 is in an entirely different league.
mjf_uk is offline
Old 01-22-2011, 06:48 PM
kosmo69's Avatar
try the Marantz sr7005.
kosmo69 is offline
