Marantz SR5005 / Marantz SR6005 HDMI V1.4 ABT AV Receiver Owners' Thread - Page 26 - AVS Forum
post #751 of 763 Old 03-26-2014, 05:27 PM
agorena123's Avatar
As I wrote previously I'm using an optical cable for TV to 6005 but still getting some kooky behavior. I have the satellite set to bypass when the AVR is off but even when I turn the AVR on or change from BD to SAT I often get nothing or the sounds wants to stay in bypass mode. I have to turn off the receiver and turn it back on to the signal to work. Also happens when going from SAT to BD. PS3 will be on but no sound until I turn off and turn on. Not sure where to even begin trouble shooting......
agorena123 is offline
post #752 of 763 Old 03-26-2014, 05:36 PM
585-645-1006
jdsmoothie's Avatar
Quoted: 371 Post(s)
Liked: 1332
First step in troubleshooting is a "soft reset" by unplugging the power cord to the AVR for at least 10 minutes.
"JD" – jd@avscience.com ; shop.avscience.com ; 585-645-1006, AVScience - AVSForum sponsor for 15 years
Mon - Fri: 8am – 8pm EST (Sat/Sun too, will return call if I don't pick up)
Call for pricing on Denon, Marantz, Yamaha, Onkyo, Klipsch, Def Tech, Oppo, Parasound
** Think the AVR is defective?  Reset the microprocessor 4-5 times.
jdsmoothie is online now
post #753 of 763 Old 03-26-2014, 05:40 PM
585-645-1006
jdsmoothie's Avatar
Quoted: 371 Post(s)
Liked: 1332
Originally Posted by Vader2000 View Post
I'm experiencing an audio lag problem on my SR6005.
I have most of my devices fully connected to the receiver first and then the picture pipes back out to the TV via HDMI. For a couple devices, though, I am hooked up a bit differently:
  • Xbox 360 - HDMI to TV, Xbox's optical to receiver
  • Laptop - HDMI to TV, TV's optical to receiver
When I play content on the above two devices, I notice some audio lag. Not that the sound is coming too soon, which tends to be the more typical case, but that it is coming late. It's as if the processing of the sound at the receiver is taking too long. I'm aware that the receiver has the option to add delay into the sound, but in this case I want to remove delay, however it is already at 0ms.
Is there anything that I can do on the receiver end to resolve this, or am I just going to have to fully hook these two devices up to the receiver as well in order to take advantage of the "auto lip sync" function? My primary reason for connecting directly to the TV in the first place is to reduce any input lag for gaming.
This can happen from time to time depending on the sources selected. Try connecting both sources to the AVR via HDMI and set the Video Mode (p.54 OM) for each source to "GAME" if there is any lag experienced
post #754 of 763 Old 03-26-2014, 05:42 PM
agorena123's Avatar
Thanks - I'll do that tonight.
post #755 of 763 Old 03-27-2014, 02:59 PM
Vader2000's Avatar
Thanks JD, I shall give that a go then.
Is there detailed information anywhere that describes the differences between Movie and Game video processing? I'm assuming Game reduces any extra processing, but I'm curious what kinds of thing Movie is adding to the mix. Also, will using Game lock-out any specific features like scaling or converting (from say SD to HD)?
Vader2000 is offline
post #756 of 763 Old 03-27-2014, 07:14 PM
585-645-1006
jdsmoothie's Avatar
Quoted: 371 Post(s)
Liked: 1332
post #757 of 763 Old 03-27-2014, 07:32 PM
Vader2000's Avatar
Interesting. Ok, thanks!
post #758 of 763 Old 03-29-2014, 07:49 AM
agorena123's Avatar
The soft reset did not fix the problem. The other weird thing is that although I thought I had only set up the satellite for bypass, the PS3 went bypass the other day as well with the sound coming out of the TV even though the 6005 was on to control the hdmi source.
Changing the sequence of turning the equipment on makes a difference. If I turn satellite and tv on, then 6005 everything ok. If unit is on and then i power up other equipment or switch between sources I may have issues.
post #759 of 763 Old 03-29-2014, 07:58 AM
585-645-1006
jdsmoothie's Avatar
Quoted: 371 Post(s)
Liked: 1332
Powering on in a specific sequence is often required otherwise the next step would be a "hard" reset p. 92 Owner's manual.
post #760 of 763 Old 03-31-2014, 09:37 AM
Vader2000's Avatar
Couple more questions:
  1. Is it possible to simultaneously play the video of one source and the audio of another? For example, if I'm on HDMI 5/Game and I want to play the audio from my CD player hooked via analog RCA or mp3 player via USB, can I do that?
  2. Is it possible while using headphones to utilize the 9-band equalizer?
post #761 of 763 Old 03-31-2014, 10:31 AM
Vader2000's Avatar
Darn it... think I just answered my own questions. Too bad it's a no on both fronts. If I'm mistaken though, someone please let me know. tongue.gif
Answer to #1 - (p.53 OM) "It is not possible to select HDMI input signals."
Answer to #2 - (pg.57 OM) "When using headphones, “MultEQ” is automatically set to “OFF”."
post #762 of 763 Old 03-31-2014, 01:25 PM
585-645-1006
jdsmoothie's Avatar
Quoted: 371 Post(s)
Liked: 1332
1. Yes. There are two ways to do this ... (a) Either assign (if digital) or connect the analog audio cables to the same source named input as used for the HDMI input (eg. other than GAME as there are no GAME analog audio inputs) and then once done, change the INPUT MODE setting to "Digital" or "Analog" as appropriate. (b) Connect the video via component cables and use the Video Select setting on the audio source to select the component video source.
2. No. based on the page you posted.
post #763 of 763 Old 04-01-2014, 09:43 AM
Vader2000's Avatar
Well, at least there are some workarounds for #1. Thanks, as always, for your help!
Marantz Sr5005 Audio Video Receiver Black , Marantz Sr6005 Audio Video Receiver Black
