Marantz SR5005 / Marantz SR6005 HDMI V1.4 ABT AV Receiver Owners' Thread - Page 28 - AVS Forum | Home Theater Discussions And Reviews
 3Likes
post #811 of 845 Old 01-27-2015, 06:58 AM
dje31's Avatar
Thanks for everyone's input on this thread. It's been a big help for the last couple of years owning my SR5005.
Generally very happy with it, but as of late, it seems to be acting a bit weird. It's almost as if Audyssey is either self-regulating, intervening, or simply forgetting settings. Should it need to be rerun on a regular basis?
e.g., the center channel volume sometimes is so low as to be almost silent. Dialog is so low, you have to turn on closed captioning. I thought maybe the cat had knocked the speaker wires out of joint, but they were fine. Sounds was coming out, so it was in straight 2-channel stereo mode.
I've rerun the Audyssey setup a few times, with inconsistent results. Now the center channel is bumped up +10 dB, so it's dominating in volume, but the quality is shoddy at best. Boxy, muffled...as someone else mentioned, like Loudness is turned up way too high.
I can related to what Patrick relayed in post #794 , so I played with the custom / manual EQ. Seems better, but the levels are still funky by speaker. Can I re-run Audyssey without it goofing up the EQ? Couldn't find an easy spot on the on-screen menus to adjust each channel's level manually.
Any and all help is greatly appreciated. Thanks kindly in advance.
-- Doug
dje31 is offline
post #812 of 845 Old 01-27-2015, 07:15 AM
jdsmoothie's Avatar
Quoted: 12079 Post(s)
Liked: 5500
You shouldn't have to run Audyssey again. Try setting Dynamic Volume to OFF if using it. Could also be the center channel amp is going out. Try doing a soft reset by unplugging the power cable for 10 minutes.
jdsmoothie is offline
post #813 of 845 Old 03-09-2015, 09:00 AM
Scott Oakley's Avatar
Quoted: 36 Post(s)
Liked: 89
Source Displayed on StartUp
Hello,
Is there a setting to force the SR5005 to switch to a specific Source upon startup? For some reason, mine is stuck (always turns on to) BD. I'd like it to default to SAT.
Thank you,
Scott
Panasonic 2013 55VT60
Marantz SR-5005 AVR
B&W 805 Speakers
Velodyne 15" Sub
TiVO Roamo OTA
Scott Oakley is offline
post #814 of 845 Old 03-09-2015, 11:42 AM
jdsmoothie's Avatar
Liked: 5500
Originally Posted by Scott Oakley View Post
Hello,
Thank you,
Scott
It should remember the last source used when the unit was powered off, however, you should also be able to select the SAT button on the remote to power on the AVR and select that source.
post #815 of 845 Old 03-09-2015, 12:34 PM
Quoted: 36 Post(s)
Liked: 89
So the answer is "no," right? There is no menu setting to set a default source upon startup? There was something like that on the cable box I had at one time.
It must have something to do with my connection to my Panasonic TV via HDMI. The AVR keeps defaulting to BD; we watched a BluRay about 3 months ago, but have watched TV in the interim. Weird.
Marantz SR-5005 AVR
B&W 805 Speakers
Velodyne 15" Sub
TiVO Roamo OTA
post #816 of 845 Old 03-09-2015, 12:46 PM
jdsmoothie's Avatar
Liked: 5500
Correct. Although if you have HDMI Control enabled, you could try setting it to OFF. Or another option, if HDMI Control is enabled, set the Standby Source to SAT.
post #817 of 845 Old 03-09-2015, 01:38 PM
Quoted: 36 Post(s)
Liked: 89
I'll give it a shot, thanks.
Marantz SR-5005 AVR
B&W 805 Speakers
Velodyne 15" Sub
TiVO Roamo OTA
post #818 of 845 Old 03-11-2015, 08:20 AM
Quoted: 36 Post(s)
Liked: 89
There is no SAT under Standby when HDMI Control is On, just Off, Last, HDMI, 1, 2, and I think 3. So I tried Last to no avail, still defaults to BD.
Marantz SR-5005 AVR
B&W 805 Speakers
Velodyne 15" Sub
TiVO Roamo OTA
post #819 of 845 Old 03-11-2015, 09:07 AM
jdsmoothie's Avatar
Liked: 5500
Select whichever HDMI input is used for the SAT/CBL source. Try unplugging the AVR power cord for 10 minutes (ie. soft reset).
post #820 of 845 Old 04-08-2015, 06:28 PM
nastynice's Avatar
hey, can anyone comment on the headphone amp found in the SR 6005? I bought some nice headphones which are pretty hard to drive, 120 ohms but according to many people actually seem harder to drive than other higher impedence headphones. I'm wondering if this receiver will be good enough to drive these headphones.
nastynice is offline
post #821 of 845 Old 04-08-2015, 06:36 PM
jdsmoothie's Avatar
Liked: 5500
Give it a go. You can always buy an external headphone amp if you feel it is required.
post #822 of 845 Old 04-08-2015, 11:10 PM
nastynice's Avatar
yea, will do. I'm just hoping to avoid the whole buying another amp for headphones, given how expensive a unit this is. Its a little frustrating that not only is there nothing to be found in the manual or marantz online, even when I contacted Marantz themselves they told me they don't know anything regarding the headphone amp. Seems a little sloppy on their part, how could an entire facet of the receiver like this be completely not documented anywhere?
post #823 of 845 Old 04-10-2015, 06:16 AM
dje31's Avatar
Here's one I haven't seen addressed yet:
We have the Dish Hopper HD DVR Receiver connected to our 5005. I believe most inputs are defaulting to Auto for the surround mode.
Unfortunately, half or more of the time, it doesn't go to the correct setting. Sometimes it's in 2ch Stereo, so my center channel gets nothing.
I've had to manually change the surround mode to Dolby Digital, or PLII Movie to get the right setting.
I'm guessing part of that is the source info from the Hopper, as some feeds may default to stereo, or a non-surround mode. It doesn't seem consistent, making it even more frustrating.
Is there a way to force / default it to a 5.1 mode? Either DD or PLII Movie?
Thanks much in advance!
-- Doug
dje31 is offline
post #824 of 845 Old 04-10-2015, 07:24 AM
jdsmoothie's Avatar
Liked: 5500
AFAIK, there are only 3 types of audio that the Dish box can produce .... PCM 2.0, DD 2.0, and DD 5.1. Once you select DD PLII - Movie for each of the non DD 5.1 sources, the AVR should remember this setting and always simulate 5.1 from the 2.0 source.
post #825 of 845 Old 04-12-2015, 06:04 AM
Quoted: 36 Post(s)
Liked: 89
-- Doug
If my 5005 was left in PLII Movie the last time I used it, PLII Movie will be the sound setting when its turned back on. Also, I'm out of town right now so I can't check but I very vaguely remember a settings in the Manual portion of the Menu that lets you select a sound field for each source. Don't quote me on this, its been a long time though.....
Marantz SR-5005 AVR
B&W 805 Speakers
Velodyne 15" Sub
TiVO Roamo OTA
post #826 of 845 Old 06-30-2015, 03:11 PM
01svtL's Avatar
Quoted: 37 Post(s)
Looking at picking up a used SR5005. Anything I should be aware of? Are there any newer offerings out there that sound about the same that would be a better buy at this point? Looking to stay under $400. Care more about sound than the latest apps etc. Only using 3.1 right now. Klipsch RF5 L&R and an RC7 center and a 10" Onix Rocket sub. Fairly small living room, seating position is only about 10-12 feet away from the TV. I use it mostly for TV/movies, but do like to connect the iPhone5 to listen to music. I also have a fairly old turn table, but it doesn't get as much use. I know I like the Marantz sound compared to the older (2008ish) Yamaha AVR's with these Klipsch speakers. I have heard that some of the newer Yamaha's are a bit less harsh though. What about comparable Denon offerings? Also saw a CA Azur 351r which is quite a bit less powerful, but I don't really need 100+ watts in this room.
01svtL is offline
post #827 of 845 Old 06-30-2015, 04:38 PM
Quoted: 36 Post(s)
Liked: 89
I LOVE my 5005. I bought it when that model first came out and as the Marantz line got more complicated and Internet-connected, I've often thought of upgrading but I'm glad I didn't. The sound is warm, yet detailed. I can connect my iPOD to the front USB connection and all sounds great. The iPOD does sometimes drop connection but not so often to piss me off. I do not have a turntable and honestly can't tell you if the 5005 has a connection for that. The only other thing is that menu system is sometimes a bit unintuitive but you just have to fight your way thru that. All details, manual, etc are here:
http://us.marantz.com/us/Products/Pa...oductId=SR5005
As far as other options, you're on your own on that, like all of us cuz its all subjective.
Scott
Marantz SR-5005 AVR
B&W 805 Speakers
Velodyne 15" Sub
TiVO Roamo OTA
post #828 of 845 Old 12-04-2015, 07:48 AM
Quoted: 36 Post(s)
Liked: 89
SR5005 - Volume Leveling?
Hello,
Does the Marantz SR5005 contain a volume leveling feature, across Sources? I cant seem to remember or find it.
Thank you,
Scott
Marantz SR-5005 AVR
B&W 805 Speakers
Velodyne 15" Sub
TiVO Roamo OTA
post #829 of 845 Old 12-04-2015, 08:38 AM
Quoted: 36 Post(s)
Liked: 89
Hello,
Is there a volume leveler (across Sources) on the 5005?
Scott
Marantz SR-5005 AVR
B&W 805 Speakers
Velodyne 15" Sub
TiVO Roamo OTA
post #830 of 845 Old 02-04-2016, 12:26 PM
squeeks's Avatar
Quoted: 43 Post(s)
Liked: 29
Hey Everyone,
Looking to upgrade my sr6005 to a sr6009 and need to get rid of the 6005. It's in excellent condition and I still have the retail box. Where would be my best place to list it for sale and what should I expect to get for it?
squeeks is offline
post #831 of 845 Old 02-04-2016, 12:26 PM
squeeks's Avatar
Quoted: 43 Post(s)
Liked: 29
Hey Everyone,
squeeks is offline
post #832 of 845 Old 02-04-2016, 06:32 PM
jdsmoothie's Avatar
Liked: 5500
Originally Posted by squeeks View Post
Hey Everyone,
You could list it in the Classifieds section of AVSForum or your local Craigslist likely getting $400 or so.
http://www.avsforum.com/forum/209-audio-gear/
post #833 of 845 Old 05-14-2016, 06:46 PM
Joeroe's Avatar
I didn't take the time to read all 832 posts so if this has been asked already I apologize.
I have A 6005 that was used in a large open floor plan setting but now has been moved to a small theater that I just built. The new room is causing some problems with room modes so I added treatments. Now it's DSP time and the 6005 doesn't have have an input to loop a DSP. Have any of you overcome this and if so how. Just wondering if I need to ditch the 6005 or add an amp. I'm happy with my setup when it comes to movies but bass production in music needs some improvement so not sure if there is a way to only power the mains with a 2 channel amp or what.
Any help you give will be appreciated
Joeroe is offline
post #834 of 845 Old 05-14-2016, 06:53 PM
jdsmoothie's Avatar
Liked: 5500
Did you re-run Audyssey again? Sounds like you don't have a dedicated sub rather simply using the woofers in the FL/FR speakers? The SR6005 does have 7.2 main zone pre-outs, so if you prefer to, you could certainly use an external amp to power the FL/FR speakers.
post #835 of 845 Old 05-14-2016, 07:05 PM
Joeroe's Avatar
Wow that was fast. Thanks for the quick response. I have a Rythmik fv15HP and my mains are definitive Mythos STS. Audyssey set everything up wrong so I had to disable it. When running the receiver in 2 channel mode my sub wasn't doing anything so I disabled Audyssey, changed my mains to small rather than full range and also changed the crossover point of the mains to 60Hz to reduce a null at 70Hz. I'm running REW and the treatments have helped quite a bit but I still have some issues that will require DSP.
Joeroe is offline
post #836 of 845 Old 05-14-2016, 07:07 PM
jdsmoothie's Avatar
Liked: 5500
Not sure what you mean by "set everything up wrong"? Just because you reset the FL/FR speakers to SMALL/60Hz doesn't mean you have to disable Audyssey.
Also note ... Audyssey doesn't set the speakers to LARGE, rather the AVR will set them to LARGE if it detects the speakers can go < 50Hz.
post #837 of 845 Old 05-14-2016, 07:39 PM
Joeroe's Avatar
I'm no where near an expert when it comes to home theater but for some reason after running Audyssey 3 times my sub would barely work when listening to music. I think the problem was that my bp2006's in the rear were putting out bass that was not being used when running stereo. The rears have 250watt amps pushing 8" woofers. I had an acoustical engineer over to help with room treatment and he told me to disable it and adjust everything manually. He said he would only use it to figure out speaker distance. I took his advice and it made a huge difference. My system sounds unbelievable to me but there are still some problems to be addressed and according to what I've read DSP is the next step.
Joeroe is offline
post #838 of 845 Old 05-15-2016, 10:11 AM
jdsmoothie's Avatar
Liked: 5500
The sub is EQ'd independently from the speakers. If the FL/FR speakers get set to LARGE, in Manual Setup simply reset them to SMALL/80Hz and the lower frequencies will go to the sub (movies, TV, music, etc.). No reason to disable Audyssey.
post #839 of 845 Old 05-31-2016, 09:05 AM
ja00's Avatar
Quoted: 197 Post(s)
Liked: 129
Anybody know the subwoofer preamp output level for the SR5005? I have it connected to a QSC PLX amp and I have to set the sub level 10dB hotter than the other channels, with the amp volume level at max, to get the subs to be heard.
ja00 is offline
post #840 of 845 Old 07-12-2016, 01:12 PM
Figjr24's Avatar
Audio Refresh While Watching TV
Hi All,
I'm finding now that while I am watching TV every few minutes or so the the display flashes quickly and the sound drops out for less than a second. It's been bugging the crap out of me and I was hoping someone can provide some insight.
I've tried different HDMI inputs and the result is the same.
Figjr24 is offline
Marantz Sr5005 Audio Video Receiver Black , Marantz Sr6005 Audio Video Receiver Black
