Pre-amp out? what is this? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 07-13-2010, 08:11 PM - Thread Starter
Se7enwolf's Avatar
the new receiver I'm getting has Multichannel hook ups in back with one sub connection and it has Pre-Amp out with 2 subwoofer connections. What is Pre-amp out?
If I'm hooking up speakers with the bare wire connections, which one do I use to connect the subwoofer if the subwoofer uses a coax connection? by the way, my subwoofer is a power subwoofer
Se7enwolf is offline
post #2 of 15 Old 07-13-2010, 08:32 PM
Kal Rubinson's Avatar
Quoted: 672 Post(s)
Liked: 457
In general, the multichannel "hook ups" are inputs for use with certain players. The preamp outputs, including those for the subs, are used to power external amplifiers, including powered subs.
So, connect your sub to one of the 2 sub outputs. The user's manual should tell you if there is a difference between them.
It would help if you told us what model AVR you are referring to.
Kal Rubinson
"Music in the Round"
Kal Rubinson is offline
post #3 of 15 Old 07-13-2010, 08:35 PM
schroedk's Avatar
Pre-amp outs are line-level RCA connections for connecting the receiver to an outboard amplifier, and using the receiver as a pre/processor. It's a way to keep what you've got if you decide that you need more power for hard-to-drive speakers, or simply want more headroom in your system. When you connect the pre-amp outs to an amplifier, it bypasses the receivers internal amplifiers, taking some of the load off of the receiver.
With a powered subwoofer, you would simply run an RCA cable from one of the pre-amp outs designated "subwoofer" to the LFE input on your subwoofer. If you already have a coax cable run in place, you can get a pair of these adapters: http://www.radioshack.com/product/in...tId=2103580&cp to convert the coax ends into RCA ends.
Two things are infinite: the universe and human stupidity. And I'm not sure about the universe. -- Albert Einstein
schroedk is offline
post #4 of 15 Old 07-13-2010, 08:36 PM
schroedk's Avatar
Hi, Kal. As usual, you're quick on the draw
schroedk is offline
post #5 of 15 Old 07-14-2010, 02:09 PM - Thread Starter
Se7enwolf's Avatar
I'll be getting the YAMAHA RX-V765.
You say connect it by RCA but it looks like a coaxial connection to me, the same thing my current Onkyo 606 has that my sub is connected to. maybe i'm misunderstanding something.
Though I get that I should plug my sub into one of the pre-out connections. Thanks. I would have hooked it up to the multichannel one if I wouldn't have asked.
post #6 of 15 Old 07-14-2010, 02:26 PM
jdsmoothie's Avatar
Quoted: 12079 Post(s)
Liked: 5500
The multi channel analog inputs are generally for connecting a DVD or BDP via analog cables vice an HDMI or other digital cable. These are especially useful with older AVRs that don't have an HDMI input but the user still wants to pass the HD audio to the AVR.
As noted the pre-amp outputs must be connected to some type of amp or power source. Your sub is powered and therefore has it's own power. In your Yammy's case, you have (2) sub outputs that can be used to connect 2 separate subs. The sub pre-out can be connected with either a video composite RCA cable or digital coax cable, although sounds like you've already got the sub cable.
jdsmoothie is offline
post #7 of 15 Old 07-14-2010, 02:34 PM
phantom52's Avatar
Quoted: 27 Post(s)
Liked: 84
A RCA connection is a coaxial type of connection. You will be connecting your sub to one of the pre-outs marked sub. The other pre-outs are for connecting an additional amp if you should want to in the future as Kal and others have pointed out.
phantom52 is offline
post #8 of 15 Old 07-14-2010, 02:39 PM
MichaelJHuman's Avatar
Quoted: 266 Post(s)
Liked: 148
I would call RCA a coaxial connection. But people usually say RCA when they mean an RCA plug terminated cable (RCA plugs originating as a phono connector and named for the company.) RCA terminated connections are used for many purposes such as line level analog audio, digital audio, and video.
Coaxial used without a context is often used to refer to RG-58 or similar cables.
In this case, the subwoofer output jack is designed for RCA terminated cables just like those freebie red/white cables, but it's mono.
Any RCA terminated cable would work.
The important thing is to not confuse the subwoofer OUTPUT with the subwoofer input grouped with the other multi-channel inputs. This is all to easy to do when wiring with limited light in tight confines (done it myself.)
"But this one goes up to 11"
MichaelJHuman is offline
post #9 of 15 Old 07-14-2010, 03:10 PM - Thread Starter
Se7enwolf's Avatar
ok thanks guys.
one last question. Which gives a better connection? a bare wire connection for the speakers or banana connectors?
post #10 of 15 Old 07-14-2010, 03:14 PM
phantom52's Avatar
Quoted: 27 Post(s)
Liked: 84
ok thanks guys.
I prefer banana, but only because I'm always doing something to my setup and its just more convenient to me. Good banana connectors at Monoprice.com.
post #11 of 15 Old 07-14-2010, 03:39 PM - Thread Starter
Se7enwolf's Avatar
does the sound quality differ?
post #12 of 15 Old 07-14-2010, 03:48 PM
phantom52's Avatar
Quoted: 27 Post(s)
Liked: 84
No. It's just more convenient. Also less chances of a stray wire touching another speaker post. No change in sound quality with any of the connections IMO.
post #13 of 15 Old 07-15-2010, 11:07 AM
Quoted: 672 Post(s)
Liked: 457
The RCA connection is used for coaxial audio connections, analog and digital.
Kal Rubinson
post #14 of 15 Old 07-15-2010, 11:13 AM
Quoted: 266 Post(s)
Liked: 148
And composite/component video.
It's been conveniently overused
post #15 of 15 Old 07-15-2010, 11:20 AM
Quoted: 672 Post(s)
Liked: 457
In a cinch!
Kal Rubinson
