Do receivers need left/right "breathing" room? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 07-14-2010, 10:57 AM - Thread Starter
TheSteelPhantom's Avatar
Short and sweet: The Onkyo RC260 receiver I'm looking at getting is 17 1/8" wide. The table I'm looking at for my center speaker, receiver, Xbox, TV, etc, is this one. The two cubbies in the middle are 17 5/8" wide (I'm viewing the line-art).
The shelves are adjustable, so I know I have enough height, and depth is fine. What I'm wondering, as a complete noob in audio, will the 17 1/8" receiver be alright in a 17 5/8" size space? Is it like a computer, it will overheat in a very small cubby space? Is 1/4" on each side enough, or should I look at a different table?
TheSteelPhantom is offline
post #2 of 8 Old 07-14-2010, 11:00 AM
MichaelJHuman's Avatar
Quoted: 266 Post(s)
Liked: 148
I admit that I have always put receivers into a cabinet with almost no room on the sides. I don't think my receivers have side vents though. I think it's important to have enough room on the top for adequate ventilation. And I think you need room to vent behind, so I don't use cabinets with closed backs.
"But this one goes up to 11"
MichaelJHuman is offline
post #3 of 8 Old 07-14-2010, 11:34 AM - Thread Starter
The back has a back panel, but pretty big holes for all the cables... Is that alright? I can move the shelves down to give it tons of top-room. How much is suggested? 2 inches? 3? 4? Curious now.
post #4 of 8 Old 07-14-2010, 11:51 AM
Antibayi's Avatar
Would losing the back of the stand hurt rigidity? If not, I would get rid of the back and get a fan to move the hot air. If the back cannot be removed, I would think twice about the stand as Onkyo's are known to get very hot. I briefly had an Onkyo. It had vents on the sides, towards the back. I would feel more comfortable with more space to the sides if the receiver you're considering has the same side vents.
Brian
Antibayi is offline
post #5 of 8 Old 07-14-2010, 11:53 AM
Antibayi's Avatar
About 8 inches on top of the unit is what Onkyo recommends. Actually, they recommend plenty of space all around the unit, but stress the space above.
Brian
Antibayi is offline
post #6 of 8 Old 07-14-2010, 12:01 PM
Quoted: 266 Post(s)
Liked: 148
It could. I had one set of shelves I never put the back in place on, because I like shelves without backs, and it was not stable.
My AV rack seems to have held up to years of hacking pieces of the back though (there's almost nothing left of the original hard cardboard back). I was thinking of adding some bracing using cheap moulding.
post #7 of 8 Old 07-14-2010, 12:45 PM
Easyaspie's Avatar
I can see it now, someday the OP will be posting in an "Onkyos run hot" thread.
Bottom line: If you have to ask that means you have reservations and probably shouldn't do it. Error on the side of caution.
Easyaspie is offline
post #8 of 8 Old 07-14-2010, 01:44 PM - Thread Starter
Hmm, perhaps I'll look into different different stands... I really liked this one though. >_< Bah.
