The "Official" TX-NR708 Owners Thread - Page 19 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #541 of 1654 Old 11-05-2010, 07:29 AM
leftnose's Avatar
Originally Posted by porterxx View Post
I've had to add turn on avr, switch to x input and turn off avr for each of my activities that don't use avr. I have to do this because, when I set up the Harmony your way, the Harmony thinks the avr is already on so the input doesn't get changed. Does anyone have a better more efficient way?
Instead of having the remote switch the 708 to CBL input when it is being shut off, change the activities that use the receiver, but not the cable box, switch to CBL input when on leaving.
So, if I'm watching a Bluray, I have the Watch Bluray activity switch to the CBL box on exit. So I can turn off the system and it will switch to CBL input. The one drawback is when switching between activies that use the receiver but not the cable box. Say I switch from Watch Bluray to Play Xbox360, when I hit the new activity button, it will switch to CBL input and then switch to the GAME input. There's no additional time but there is that extra step.
Remember to add switch to CBL on exit to all of your activities that use the Receiver but not CBL.
leftnose is offline
post #542 of 1654 Old 11-05-2010, 12:58 PM
icu_nxtime's Avatar
Originally Posted by litew8 View Post
You can NOT have both Front WIDE and Front HIGH. You can ONLY have one (FRONT HIGH, FRONT WIDE, or BACK SURROUND).
So, if you want a 7.1 setup, you should have:
2 FRONT MAINS
1 CENTER
2 SURROUND
1 SUB
And then pick ONE you like the best:
2 FRONT WIDE
or 2 FRONT HIGH
or 2 BACK SURROUND
Edit: Also, I think you might actually have to run Audessy to enable the FRONT WIDE or FRONT HIGHS or BACK SURROUND.
Got my un65c8000 on Wed night so I can take the weekend to try and set it up properly, I did go in right away and enable the speakers, they are off by default but I was able to test each one in the menu and set the distances up. I will try to configure the Audyssey to for the best sound.
I will have to rethink my speakers as I had it setup for 9.2 instead of 7.2 I thought the wide and high could be on at the same time I will just connect the front to the wides and leave the highs on probably.
I know it says not to connect 2 sets of speakers on one chanel but I haven't had a problem with it before. any major things to watch out for ?
icu_nxtime is offline
post #543 of 1654 Old 11-05-2010, 02:52 PM
rgathright's Avatar
Quoted: 219 Post(s)
Liked: 26
My permanent setup will be as follows. I am assuming this receiver will have not have any problems with this.
2 fronts
1 center
1 sub
2 surrounds
2 back surrounds
Here is another question. Does anyone have this connected to a projector using 35' long HDMI cables?
Sony XBR-75X850C - Living Room
Samsung UN60J6300AFXZA - Bedroom
rgathright is offline
post #544 of 1654 Old 11-06-2010, 12:32 PM
rgathright's Avatar
Quoted: 219 Post(s)
Liked: 26
Originally Posted by rgathright View Post
my permanent setup will be as follows. I am assuming this receiver will have not have any problems with this.
2 fronts
1 center
1 sub
2 surrounds
2 back surrounds
here is another question. Does anyone have this connected to a projector using 35' long hdmi cables?
BTTT - for the last question
post #545 of 1654 Old 11-07-2010, 03:14 PM
grod777's Avatar
Has it been confirmed without doubt that the latest firmware has fixed the problem with the Network connection?
I have been holding off purchasing because of the many complaints.
Also some posters have complained of having to adjust volume higher than they would normally on older units-Is this just the way it is or is their a fix in the new firmware?
grod777 is offline
post #546 of 1654 Old 11-07-2010, 06:22 PM
Typ53b's Avatar
My network problems were 100% solved with the firmware update. I'm confident that th fix is solid.
The volume thing is no big deal. The displayed "number" seems high for the volume you get. But high compared to what exactly? It's really a meaningless figure.
It's a solid receiver, I'm sure you'll be very happy with your purchase if you pull the trigger.
Typ53b is offline
post #547 of 1654 Old 11-07-2010, 07:34 PM
grod777's Avatar
I guess that's good enough for me. I guess if there's any problems I could always return it. Now to bargain hunt for the best deal!.Thanks!.
grod777 is offline
post #548 of 1654 Old 11-08-2010, 04:49 AM
Winky's Avatar
I got mine at newegg.com. They had the best price a couple months ago, and I think it's even lower now.
Try as they might, they cannot steal your dreams.
Winky is offline
post #549 of 1654 Old 11-08-2010, 08:50 AM
litew8's Avatar
The Volume issue isn't an issue at all, it's peoples inability in understanding how to configuring the unit properly.
litew8 is offline
post #550 of 1654 Old 11-08-2010, 09:10 AM
Liked: 27
It's currently $550 at NewEgg and they do seem to have the best deal. Amazon may be similar, but they tax in more states and their free shipping is usually slower than NewEgg's.
SynergyNT is offline
post #551 of 1654 Old 11-08-2010, 09:41 AM
rgathright's Avatar
Quoted: 219 Post(s)
Liked: 26
This is why this receiver is on the top of my list, but I cannot buy it until early next year.
post #552 of 1654 Old 11-08-2010, 11:27 AM
Liked: 27
Maybe it will be less by Black Friday. I plan to buy this or the 808 by the end of the month.
post #553 of 1654 Old 11-08-2010, 11:43 AM
rgathright's Avatar
Quoted: 219 Post(s)
Liked: 26
This is also why I am working up my list now - I get the Black Friday ads via e-mail each day.
post #554 of 1654 Old 11-08-2010, 11:53 AM
ckoral's Avatar
I am having the same issue. I set the IP/MAC reservation on my router. Could someone share with me what the current version of firmware is?
ckoral is offline
post #555 of 1654 Old 11-08-2010, 11:58 AM
kaoztheory's Avatar
Everytime I power on unit defaults to TV imput any way to have it default to cable input?
kaoztheory is offline
post #556 of 1654 Old 11-08-2010, 12:01 PM
evilaspie's Avatar
Hopefully a simply question.
With the 708 while using HDMI does the sound cut out while in the Setup Menu?
This happens to me and just wondering if this is normal operation?
evilaspie is offline
post #557 of 1654 Old 11-08-2010, 12:26 PM
HRD2PLZ's Avatar
Are you using the Anynet+ function on your TV? I have a Samsung with Anynet enabled and have the same problem.
I had to program my Harmony Remote to send an extra delayed signal to change the input again after power on.
HRD2PLZ is offline
post #558 of 1654 Old 11-08-2010, 01:28 PM
moneyonmymind32's Avatar
Can somebody tell me what the exact height from the self to the top of the receiver is? I have limited shelf height on my entertainment center. The specs say 6 7/8". Just want to make sure this from the bottom and not the face of the receiver. Thank you for your time.
moneyonmymind32 is offline
post #559 of 1654 Old 11-08-2010, 06:12 PM
icu_nxtime's Avatar
It's 6 7/8" from the bottom of the feet not the face. The vents are on the top though you might want some air around it !!!
post #560 of 1654 Old 11-08-2010, 07:26 PM
madadd's Avatar
Yup just measured icu is correct it is exactly 6 7/8" but since it vents from the top your going to need some space. My shelf is about 8 1/4" and I have no heat issues.
madadd is offline
post #561 of 1654 Old 11-09-2010, 06:22 AM
rgathright's Avatar
Quoted: 219 Post(s)
Liked: 26
How does the HDMI switching work with the HDMI cable being 35' long?
post #562 of 1654 Old 11-09-2010, 07:00 AM
I will have a little room above it. There are just 2 metal bars that i'm going to have to squeeze it into. I can't move those metal bars and there's only 7 of space between the bottom of the shelf to bottom of the bar. Then there s a few inches before the next shelf starts. I just wanted to make sure I could fit it before ordering it. I've been trying to build a HT for about a year now and I'm finally going to order me a receiver for Xmas. I might get one of those little PC fans to put on top of it just to make sure. If anybody knows a good one I would appreciate it. I think it would fit in the small gap. I don't know why I didn't think of the shelf spacing before I got the 375 dollar stand(stupid!)
post #563 of 1654 Old 11-09-2010, 09:09 AM
rworne's Avatar
Liked: 32
Don't feel so bad. Imagine how I felt when I replaced my TX-NR507 with an HT-RC180. Whoops.
This was the deciding factor for me when I went form the HT-RC180 to the TX-NR708. The TX-NR808 disqualified itself just based on size.
rworne is offline
post #564 of 1654 Old 11-09-2010, 11:20 AM
litew8's Avatar
Probably the same way it works with an HDMI cable being 6' long. Just make sure it is high quality.
litew8 is offline
post #565 of 1654 Old 11-09-2010, 12:59 PM
rgathright's Avatar
Quoted: 219 Post(s)
Liked: 26
To make sure I had no issues I bought the Series 1 cables from Blue Jeans Cables.
post #566 of 1654 Old 11-09-2010, 01:04 PM
ckoral's Avatar
could someone verify the current FIRMWARE version on their receiver. I would like to see if it matches.
ckoral is offline
post #567 of 1654 Old 11-09-2010, 02:38 PM
Silver1omo's Avatar
Is anybody driving 4ohms speakers with the 708? If so, have you noticed any overheating or clipping?
Silver1omo is offline
post #568 of 1654 Old 11-09-2010, 02:41 PM
litew8's Avatar
smoke/fire?
litew8 is offline
post #569 of 1654 Old 11-09-2010, 03:19 PM
dgf2002's Avatar
Hello Folks -
Took advantage of great Amazon pricing to purchase the 708 for my living room Home Theater / HTPC setup. I will be moving my Pioneer vsx-919 (which I really love) to master bedroom and an early 90's pioneer to large porch.
I seriously considered the pioneer 1020 and 1120 units, but the network capabilities and phono input swayed me to the Onkyo. I would have gotten the 808, but unfortunately it would not fit in my cabinet and I don't really need the extra power to drive my Polk Monitor Series 60's (front), 40's (surround) and Cs2 Center and powered psw505 subwoofer.
I am interested to hear comments about the musicality and power output of the 708 and whether I can expect any noticeable improvements over my Pioneer. I listen to / watch allot of Pandora from HTPC, LP's, Netflix and Bluray, in addition to cable programming via Windows Media Center and the Ceton Infinitv4, a 4 tuner digital cable card released this summer.
Also, does the 708 have extensive sound enhancement features of the Pioneer? (see 1/2 half way down the specs page in link below).
Noteably, the 708 weighs 8lbs. more than the Pioneer.
Here is a link to the Pioneer:
http://www.pioneerelectronics.com/PU...-919AH-K?tab=B
Thanks in advance for comments!
David
Winter Park, FL.
dgf2002 is offline
post #570 of 1654 Old 11-10-2010, 12:16 AM
litew8's Avatar
Originally Posted by evilaspie View Post
Hopefully a simply question. With the 708 while using HDMI does the sound cut out while in the Setup Menu? This happens to me and just wondering if this is normal operation?
I think Yes. It cuts out with my 808. To get around this, depending on what you need to set, hit the Home button on the remote and apply changes there instead.
litew8 is offline
