Onkyo clicking noise - AVS Forum | Home Theater Discussions And Reviews
post #1 of 20 Old 07-26-2010, 04:04 PM - Thread Starter
dx31698's Avatar
So I just got a rc260, little brother to the 608. And when the audio formats are changing, the receiver clicks every time. It's very annoying especially when starting off a movie with all the previews and stuff. I previously owned a 705 and it did the clicking as well but I was able to get rid of it but I don't remember how and I don't have it anymore. Does anybody have any solutions
dx31698 is offline
post #2 of 20 Old 07-26-2010, 04:58 PM
MichaelJHuman's Avatar
Quoted: 266 Post(s)
Liked: 148
It might just be the relays switching between stereo and multi-channel.
"But this one goes up to 11"
MichaelJHuman is offline
post #3 of 20 Old 07-26-2010, 05:19 PM
Secret Squirrel's Avatar
Quoted: 44 Post(s)
Liked: 39
Yep, It's the relays switching according to the incoming source material. Im an Onkyo owner so Im familiar with this. They all do this.
Secret Squirrel is offline
post #4 of 20 Old 07-26-2010, 05:24 PM
N8DOGG's Avatar
Quoted: 985 Post(s)
Liked: 1055
yup and it annoying as hell! lol Just make sure you set the audio on all the inputs then it will only do it once you switch to a different input.
N8DOGG is online now
post #5 of 20 Old 07-26-2010, 05:33 PM
kmike's Avatar
The accepted answer on the clicking is it a relay that shuts down and brings up the amps as the input switches from 5 channel to 2 channel, usually Dolby Digital. Try this to see if it helps: Setup->Listening Mode Preset-> (select the source where having the problem, usually DVD/BD or CBL/SAT->D.F.2ch-> All Channel Stereo or any other listening mode that keeps 5 channels active with 2 channel input.
This is supposed to keep all 5 amps engaged when the input switches from 2.0 DD to 5.1 DD, like trailers on a DVD or TV show/movie cutting to commercial.
Hope this helps...worth a try. BTW, it worked on my RC180 until Onkyo isssued a firmware update that helped tremendously. There's still some clicking but it's muted now so I guess the buffered the input voltage to the relay.
Mike
_____________
I may be a rookie but I'm the expert at what looks and sounds good to me.
kmike is offline
post #6 of 20 Old 07-26-2010, 05:37 PM
Gooddoc's Avatar
Quoted: 2720 Post(s)
Liked: 1893
I get it with my 875, but it doesn't bother me anymore. I guess I got used to it.
Gooddoc is online now
post #7 of 20 Old 07-26-2010, 06:15 PM
Liked: 61
Both of my Onkyos (TX-NR807 and HT-R540) click. I always thought it was a design feature to let you know the audio signal changed. Guess it never bothered me.
Don't believe everything on the Interwebz! A duck's quack DOES echo!
Tulpa is offline
post #8 of 20 Old 07-26-2010, 10:06 PM
RoboRay's Avatar
This is the usual way to eliminate the clicking. You can use All Channel Stereo, ProLogic II, or whatever matrix-sound mode you prefer to direct the incoming stereo sound to all speakers. No more clicks.
RoboRay is offline
post #9 of 20 Old 07-27-2010, 05:54 AM
joerod's Avatar
Quoted: 617 Post(s)
Liked: 497
Did we really need a new thread for this?
My Sony 5000ES Review PART 2 FINISHED:
http://hstrial-jrodriguez996.homeste...=1462841668379
joerod is offline
post #10 of 20 Old 07-27-2010, 06:12 AM
kmike's Avatar
Sure
EDIT...maybe it should be a sticky
Mike
_____________
kmike is offline
post #11 of 20 Old 07-27-2010, 08:49 AM
mbyrnes's Avatar
Quoted: 93 Post(s)
Liked: 186
I keep my 805 in Pure Audio and don't hear the clicks. Don't know if the 260 has that option.
Xbox Live: TheRealMaxPower --- PSN: TheRealMaxPower (no PS4 currently) Panasonic TC-P65VT60    Vienna Acoustic Mozart Grands    Pioneer SC-72   Sony BDP-S790 Xbox One S Astro Mixamp 2013   Soundblaster X7 (Sparkos Op Amps) Schiit Modi Multibit/Magni   LTA MicroZOTL2 AKG K702 65th Anniversary   Fostex TH-X00 Ebony DT990 Pro 250 ohm  Massdrop/Sennheiser HD6XX and PC37X Audio Technica ATH-M50x Antlion ModMic
mbyrnes is offline
post #12 of 20 Old 07-27-2010, 10:59 AM
runnin''s Avatar
Liked: 45
I've heard this 'complaint' from different Onkyo owners, some of whom were quite irate about it. I have the 876 and have NEVER had the issue simply because I have it set as suggested above. That's right folks, no clicking whatsoever. Because you simply set all sources to Dolby Prologic. And you never hear clicks. Again.
runnin' is offline
post #13 of 20 Old 07-27-2010, 11:38 AM
hdtv00's Avatar
Quoted: 131 Post(s)
Liked: 73
Actually great topic I've had my 876 for 2 yrs wasn't aware of this "solution" to the clicking. It doesn't bother me really but I won't miss it for sure. Hope I set it all right.
Marantz 7702MKII/Outlaw 7140 65" 4k Samsung KS8000
i7 4770K/16 gig 2133/970's SLI 840 PRO SSD
Paradigm Studio v3 100/570/20's/2200 Sub
hdtv00 is offline
post #14 of 20 Old 12-31-2010, 01:15 AM
kyotousa's Avatar
Cool...i'll try that tomorrow.
kyotousa is offline
post #15 of 20 Old 02-15-2011, 07:50 PM
JN99's Avatar
Sorry to dredge up an old thread but I have a 180 and tried the recommended fix posted here of selecting a listening mode preset but no luck. I get still get a rathe rloud click when the input source changes from multi channel to 2 channel, regardless of the listening mode preset.
This is extremely annoying when watching cable because this happens repeatedly during every commercial break going back and forth with multi channel to 2-channel source. Just wondering if there are any other tips or tricks to try to eliminate this?
JN99 is offline
post #16 of 20 Old 02-15-2011, 08:01 PM
Bill Mac's Avatar
Quoted: 1273 Post(s)
Liked: 1465
Originally Posted by Secret Squirrel View Post
They all do this.
Maybe I got lucky but my 805, 885 and 886 never had or presently have the clicking issue with audio format changes with cable TV. So you might want to change that to almost all do this. I setup all these Onkyos as already mentioned using DD PLIIx and never had an issue with clicking
Bill
My SACD collection and HRAudio.net Library, getting larger as my wallet gets smaller ;-).
Emotiva XMC-1, Wyred 4 Sound SX-500s, ST-500, ST-250, Oppo BDP-103/105D, Panasonic TC-P60GT50 plasma, Panamax 5100EX, Salk HT2-TLs, Salk 1801b center, Salk 1801TL (surrounds) and two Rythmik F12SEs.
Bill Mac is online now
post #17 of 20 Old 02-15-2011, 09:12 PM
eliteconcept's Avatar
Normal...mine does this too.. somewhat a annoyance but oh well
eliteconcept is offline
post #18 of 20 Old 02-06-2013, 07:04 AM
stephen123456's Avatar
I have a onkyo ht-r390 change listening mode put not pre set , is there any other way of stoping clicking because its doing my tits in !!
stephen123456 is offline
post #19 of 20 Old 02-06-2013, 07:06 AM
I can enter listening mode but can't pre set y is this ? I have a HT-R390
post #20 of 20 Unread Today, 02:05 PM
Liked: 0
I got a TX-NR656 and noticed the clicking as well only I have it during movies.
Audio stream does not change. The clicks seem random and not related to and action like changing from one movie config to another.
Anybody an idea if that is something different?
spawnreaper is online now
