Onkyo TX-SR608 Wiring/Zone 2 Issue - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 07-30-2010, 06:26 PM - Thread Starter
tiger1234's Avatar
Hi guys, I have searched through the archive but did not see anything so will appreciate any help.
I have an Onkyo TX-SR608, which have:
HDMI In's: DVR, WD TV Live, Xbox 360
Analog Audio In (TV/CD Input): Sonos ZR90
I have hooked up a 5.1 system as well as Zone 2.
The problem is that if I play any HDMI sources, I cannot get it to play in Zone 2. Also, Sonos would only play in Zone 2 and not through 5.1
I would appreciate any replies.
tiger1234 is offline
post #2 of 6 Old 07-30-2010, 06:32 PM
JChin's Avatar
Quoted: 349 Post(s)
Liked: 204
Hi tiger1234, only analog input sources are output by the ZONE 2.
For Sonos to play through 5.1, set "TV/CD" Digital Audio Input to none (-----).
JChin is offline
post #3 of 6 Old 07-30-2010, 06:35 PM - Thread Starter
tiger1234's Avatar
Thanks so much for the reply!
I can hear the ZP90 in main area now. Now I just have to figure out how to play it with the TV off, right now if I turn the TV off, 608 also turns off.
Should I just run analog audio cables to 608 to be able to hear in zone 2?
post #4 of 6 Old 07-30-2010, 07:37 PM
JChin's Avatar
Quoted: 349 Post(s)
Liked: 204
If the receiver and tv are turning off together most likely HDMI-CEC feature is set to "On". Check your Tv menu under HDMI-CEC feature and set this to Off. Some HDMI-CEC trade names are Samsung is AnyNet+, Panasonic is Viera Link, Pioneer is Kuro Link, Sony is Bravia Sync, etc....
Correct, the HDMI sources will need analog audio cables to play out to Zone 2.
JChin is offline
post #5 of 6 Old 07-30-2010, 07:58 PM - Thread Starter
tiger1234's Avatar
Perfect! Got everything up and running just as I want
Thanks very much for your help!
post #6 of 6 Old 07-30-2010, 08:08 PM
JChin's Avatar
Quoted: 349 Post(s)
Liked: 204
Glad to help, enjoy.
JChin is offline
