Marantz AV7005 - Page 139 - AVS Forum | Home Theater Discussions And Reviews
 8Likes
Old 03-04-2011, 03:44 PM
Audioguy1's Avatar
FYO
Marantz AV7005/MM7055 review available in the Home Theater magazine, April issue.
Found a thread of interest, upgraded AV7005. Scroll down page to the AV7005 line, click "here" to view the report. Google will translate, didn't install language pack myself.
Cheers
Audioguy1 is offline
Old 03-04-2011, 03:46 PM
Audioguy1's Avatar
Apologies, links coming.
Audioguy1's Avatar
Old 03-04-2011, 03:51 PM
Audioguy1's Avatar
Originally Posted by tomefs View Post
Not waiting any longer for the av7005 that has been on backorder for at least three months,I am ordering an integra 80.2 If anyone is in Canada good luck getting a av7005.
Bought mine at "Kromer Radio" in Toronto, don't know if they have stock now, but they some units when everyone else was back ordered.
Old 03-04-2011, 04:21 PM
westmd's Avatar
Quoted: 770 Post(s)
Liked: 260
Does the AV7005 support the use of 21:9 screens? I do have such a screen and "overproject" the picture of my JVC DAL350. So when I watch only 16:9 material I zoom in (currently with an iscan VP50)
westmd is offline
Old 03-04-2011, 04:27 PM
Audioguy1's Avatar
The review I read in Home Theater said the passthrough feature of HDMI video signals, worked perfectly.
Old 03-04-2011, 04:51 PM
tomefs's Avatar
I was buying mine straight from d & m at a large discount.
tomefs is offline
Old 03-04-2011, 05:08 PM
exm
exm's Avatar
Quoted: 117 Post(s)
Liked: 80
Tough to read, but thanks anyway!
exm is offline
Old 03-04-2011, 05:57 PM - Thread Starter
Kabillyhop's Avatar
I bought mine in Markham two weeks ago. I didn't wait a day.
I called several stores - some were sold out, others had in stock. Prices were discounted a lot more than I expected they would be.
The bitterness of poor quality lingers long after the sweetness of low price has passed.
Kabillyhop is offline
Old 03-04-2011, 06:09 PM
handruin's Avatar
For those who stream FLAC music to your AV7005, what software do you use on your computer so that the 7005 can connect to it and stream?
handruin is offline
Old 03-04-2011, 06:16 PM
hifichip76's Avatar
Quoted: 23 Post(s)
I still find the Dynamic EQ turns up the bass WAY too high, defeating the purpose of watching bd's at lower volume and making less noise overall. The bass is too much. The offset helps. I've also tried turning the subwoofer level down (not very effective because all the channels are bass-pumped, plus it's a pain having to turn it back to Audyssey's calibrated level for other sources) and turning down the LFE...
I think someone suggested turning the source level (in this case for bd) down so that I'd be turning the master volume up more, which would make Dynamic EQ increase the bass less. Is this true or would it just be the same?
hifichip76 is offline
Old 03-04-2011, 06:57 PM
m. zillch's Avatar
Quoted: 1832 Post(s)
Liked: 1173
^Based on the principals of equal loudness curves that is indeed what it should do.
My cursory examination of the Dynamic EQ was that it was too bass heavy as well, (male voices in dialog sounded artificially heavy) although I didn't play with incoming level reduction at all, and different offset levels just a little.
In A/V reproduction accuracy, there IS no concept of "accounting for personal taste/preference". As art consumers we don't "pick" the level of bass, nor the tint/brightness of a scene's sky, any more than we pick the ending of a novel or Mona Lisa's type of smile. "High fidelity" means "high truthfulness", faithful to the original artist's intent: an unmodified, neutral, accurate copy of the original master, ideally being exact and with no discernable alterations, aka "transparency".
m. zillch is offline
Old 03-04-2011, 07:34 PM
avman09's Avatar
I guess the discount is huge here because the list price is much higher than that in the US. This is one of those odd times that Canadian prices are better. It is the same with the power amps, at least it is with the MM8003. By the way I did not realize you can buy directly from D&M holdings.
avman09 is offline
Old 03-04-2011, 07:46 PM
yellowbalt's Avatar
Quoted: 31 Post(s)
Where in Markham?
yellowbalt is offline
Old 03-05-2011, 10:16 AM
tomefs's Avatar
I am an AV installer.
tomefs is offline
Old 03-05-2011, 11:06 AM - Thread Starter
Kabillyhop's Avatar
Originally Posted by yellowbalt View Post
Where in Markham?
Regency
Old 03-05-2011, 02:36 PM
Musicmatters's Avatar
Can the 7005 be hooked up to to the Internet wirelessly, or does it have to be hardwired with an ethernet cable? Can you use a USB modem, or a wireless bridge?
Musicmatters is offline
Old 03-05-2011, 03:01 PM
exm
exm's Avatar
Quoted: 117 Post(s)
Liked: 80
It doesn't have wireless but a wireless bridge will work
exm is offline
Old 03-05-2011, 03:07 PM
2010SSRS's Avatar
so i'm ordering my Middle Atlantic Custom Shelves for the AV7005 and the MM7025, but do not see one for the MM7055. i emailed Middle Atlantic and they stated they have not received an MM7055 to measure.
anyone know something different, or if the MM8003 may have the same dimensions?
please PM me if anyone knows something! i'd rather NOT UPS my MM7055 into them.
2010SSRS is offline
Old 03-05-2011, 05:45 PM
I just bought and installed it on a wireless bridge and it works!!!
Old 03-05-2011, 06:01 PM
yellowbalt's Avatar
Quoted: 31 Post(s)
Regency
Hi, can you give more details? I live in Stouffville, what/where is Regency?
Old 03-05-2011, 06:38 PM
bweissman's Avatar
Quoted: 224 Post(s)
Liked: 88
Just FYI, when I initially installed my 7005 on my wireless G network, updating the firmware failed. I had to hard-wire my 7005 before the firmware update would succeed.
My old wireless network (since upgraded) wasn't the most reliable. Your mileage may vary. If wireless update fails, though, don't panic. Reconnecting to a wired network will succeed.
bweissman is offline
Old 03-05-2011, 06:41 PM
bweissman's Avatar
Quoted: 224 Post(s)
Liked: 88
http://lmgtfy.com/?q=markham+regency+audio+video
You're welcome.
Old 03-05-2011, 06:43 PM - Thread Starter
Kabillyhop's Avatar
Where in Markham?
Regency Audio Video is on Woodbine - South of 407, North of Steeles.
Old 03-05-2011, 08:18 PM
sSolar's Avatar
at least I'm not the only one waiting. I ordered first week of january and been waiting since. I was told a couple days,a couple weeks, a month then a month or two and finally once again a month. Add that all together and the final date was mid-march. If I dont recieve it by mid-march I will cancel my order and just forget upgrading my processor for now as spring/summer is coming lol. I will use the money to DIY some new speakers instead.
I will say it is not a total loss as I've re-kindled my love for music etc. in the last month or so. The thought of upgrading got me thinking I need some high quality recordings to listen too as well. I have been updating my music library and actually relaxing with some music. It has felt like some years since I've sat in my "sweet spot" with my feet up listening to music.
sSolar is offline
Old 03-05-2011, 08:37 PM
bweissman's Avatar
Quoted: 224 Post(s)
Liked: 88
Home Theater Magazine vs. Secrets of Home Theater and High Fidelity
So my Home Theater mag finally arrived today with its mostly glowing review of the 7005. The lone digital video "Fail" is chroma resolution with Video Convert enabled.
The previously published online review from SHT&HF locates the problem at 4:4:4 input, with 4:2:2 not showing the chroma problem.
Can I therefore infer that HT didn't test the 7005 with 4:2:2 input, which would presumably have passed their test?
Old 03-05-2011, 08:44 PM
avman09's Avatar
Why can't they just get the information from the Marantz website? I can tell you the MM8003 has the same dimensions as the AV7005. I just measured it.
avman09 is offline
Old 03-05-2011, 09:59 PM
2010SSRS's Avatar
as the AV7005 or the MM7055? i would think they should be about the same.
2010SSRS is offline
Old 03-06-2011, 11:04 AM
hh78's Avatar
I'm using FLAC files a lot on my AV7005 from my Synology NAS server. I found the sound quality much better then my Pioneer DV-717 using the SPDIF output. For example, it has much more bass.
In order to navigate easily through the copies of all my CDs, I have set a directory structure with on the first level the characters of the alphabet, then the composer and finally the title of the album.
Eg.:\\D\\Dire Straits\\Love of Gold
When using the Media Server and then Folder option to select the albums, this works very well for me.
Hope this helps others.
hh78 is offline
Old 03-06-2011, 12:26 PM
fecund's Avatar
I currently have a separate setup with a carver av705. Even after all this time the amp still seems to hold its own. I'm also a believer of separates.
I'm now looking at replacing my pre/pro and this seems to be my choice. However the price difference between the av7005 and the sr7005 is only a hundred dollars. A hundred dollars gets me 7 channels of amplification, it almost seems like a no brainer. There doesn't seem to be anything stopping me from using the preouts on the marantz to power my carver. I could even use both to setup a 7/9.1 speaker setup as well in the future.
The carver has no XLR inputs and reading most people end up going unbalanced a lot of the time anyway and I have no concerns about distance. Is there anything that should convince me to go sans amp and pick up the av7005? I'm sure this a small difference in S/N or even a slightly higher noise floor, but in reality will that even be noticeable when watching Inception?
You are reading my signature.
fecund is offline
Marantz Av7005 Pre Processor
