Marantz AV7005 - Page 266 - AVS Forum | Home Theater Discussions And Reviews
 8Likes
Old 03-24-2012, 08:59 AM
CannondaleSV's Avatar
Ok thanks, on the other one I never had it over -34.
CannondaleSV is offline
Old 03-24-2012, 01:32 PM
bweissman's Avatar
Quoted: 224 Post(s)
Liked: 88
Originally Posted by bweissman View Post
Lately, my AV7005 is prone to locking up at power-on. It powers up and sits there silent, almost completely unresponsive. The only control which responds is the Input changer. No other button or dial does anything. I have to power cycle it by pulling the plug to get it working again.
I think I've narrowed down when this happens; if the last thing I was doing before power off was playing music via AirPlay, subsequent power-on fails. If I was doing something else at power-off, all is well. (Obviously, this suggests a workaround, but I'd prefer a fix.)
I have the latest firmware and I have tried the CPU reset procedure several times with no success.
Have any of you experienced this? And found a fix? Other suggestions?
Originally Posted by Darren Wadsworth View Post
I have. Exact same thing happened. The only thing you can do is unplug the Marantz from power and plug back in after a bit. Since the most recent update however, I haven't had this happen again. Although I have cut back on my use of Airplay. I was using it to play stuff from youtube from my iPhone.
Darren
Thank you for replying. Misery loves company.
There is one thing I haven't tried yet: a CPU reset without saving and restoring all the user settings. I haven't done it because it will be a pain to restore everything manually, but I will probably resort to this fairly soon. Did you try that, Darren?
bweissman is offline
Old 03-25-2012, 10:33 AM
Scott Horton, techht.com
GetGray's Avatar
Quoted: 170 Post(s)
Liked: 146
Anyone ever come up with a fix/workaround for the volume ramp up issue? Via IR that is. Didn't have the issue with the previous AV8003, but it's a handful with the AV7005. Have to be too careful and too conscious of it when changing the volume. Thanks, Scott
GetGray is offline
Old 03-25-2012, 11:05 AM
ccotenj's Avatar
Liked: 101
nope, not really... it's a pervasive "feature" throughout the d&m product lines....
mz and i came up with a "small workaround", by adjusting channel levels... he will pop in with the link to it sooner or later... the basic idea is that it moves "faster" or "slower" dependent on where on the volume scale you are... but that's definitely a kludge...
- chris
ccotenj is offline
Old 03-25-2012, 11:06 AM
m. zillch's Avatar
Quoted: 1838 Post(s)
Liked: 1175
^Yes. [edit to add: I am responding to GetGray]
Chris and I discussed this and through my slow motion video analysis discovered that the annoyingly fast volume changing speed only occurs at levels lower than -8 or -10. So if you can keep your use higher than this, the volume ramping speed is nice and smooth/slow.
Ah, but what if such volumes are higher than you actually like using? The answer is to calibrate through the auto mic/Audyssey setup and then uniformly reduce the gain of all of the channels (including sub) of your power amps, or, conversely, decrease the efficiency of all of the speakers (including sub), until use of the product in the range it works most smoothly at is also acceptable in terms of SPL to the ear.
This should be a snap for people with power amps that have gain controls (volume), ideally with visible, calibrated divisions (you know, like "11" ) but people without would need outboard potentiometers and possibly an SPL meter to ensure consistency between channels (if they are separate and all channels are not "ganged together" on one master knob).
One could possibly re-purpose an old AVR with a multichannel in and preouts to serve this function. It, effectively, becomes the "multi channel outboard potentiometer".
Note: Use of "dynamic volume" and "dynamic EQ" may not function as expected if recalibrating as I've just discussed. [I don't use either.]
In A/V reproduction accuracy, there IS no concept of "accounting for personal taste/preference". As art consumers we don't "pick" the level of bass, nor the tint/brightness of a scene's sky, any more than we pick the ending of a novel or Mona Lisa's type of smile. "High fidelity" means "high truthfulness", faithful to the original artist's intent: an unmodified, neutral, accurate copy of the original master, ideally being exact and with no discernable alterations, aka "transparency".
m. zillch is offline
Old 03-25-2012, 11:07 AM
ccotenj's Avatar
Liked: 101
lol... and as if i could summon him through the ether, there's how to do it...
howdy mz...
- chris
ccotenj is offline
Old 03-25-2012, 11:12 AM
m. zillch's Avatar
Liked: 1175
Hi Chris.
My post was written before I saw yours.
Old 03-25-2012, 11:13 AM
ccotenj's Avatar
Liked: 101
yup, i figured... i was just amused that i mentioned that you'd show up with a link on how to do it, and BOOM, there it was...
- chris
ccotenj is offline
Old 03-25-2012, 01:29 PM
GetGray's Avatar
Quoted: 170 Post(s)
Liked: 146
Thanks guys. Guess I'll wire up RS232 then, I don't care for the IR workaround. Have to dig out the delay someone used on the MSC400. Unless one of you remember.
What about ramping issues via IP? Anyone tried that (e.g. via iRule)?
GetGray is offline
Old 03-25-2012, 01:37 PM
m. zillch's Avatar
Liked: 1175
I've never tried RS-232 control, however I'd be surprised if that is immune to the annoyingly fast ramping speed at levels below -10 dB.
I guess if it allows one to type in the numerical value one wants for volume directly, that could be seen as a "workaround", however I think I'd find that even more annoying, personally. YMMV.
edit to add: I just reconnected my ethernet cord to control the AV7005 from my computer [which I don't normally leave connected because it crashes my router now and then] and discovered there is no ramping volume at all. All you have is the tap, tap, tap method [.5dB per tap] or clicking on a bar graph where you want the volume to be.]
Old 03-25-2012, 01:41 PM
ccotenj's Avatar
Liked: 101
yup, you can bring it under control with rs-232, since you can control the ramp rate of the command being issued... that is what i do with my msc-400... correction: did, but it works the same way on my a100...
when you set up the command, edit it, and you can change the ramp rate... also change the repeat to 1... drop me a pm if you get stuck with it, i can send you a copy of my ccp file...
- chris
ccotenj is offline
Old 03-25-2012, 02:07 PM
GetGray's Avatar
Quoted: 170 Post(s)
Liked: 146
Thanks Chris. I think I know how to do it in CCP. Do you remember the ramp delay you used on the MSC?
GetGray is offline
Old 03-25-2012, 02:15 PM
ccotenj's Avatar
Liked: 101
yea...
i used 30 for ramp start and 40 for ramp speed... minimum repeat of 1 and repeat when button pressed check box on...
that might be a bit slow for some, but works for me... keeps my cat from adjusting it too much when he steps on the remote...
- chris
ccotenj is offline
Old 03-25-2012, 02:18 PM
GetGray's Avatar
Quoted: 170 Post(s)
Liked: 146
Thank you.
GetGray is offline
Old 03-25-2012, 05:44 PM
flyingvfreak's Avatar
I just got in the CLub, Picked up a OPen Box buy at Magnolia, I was using a SR 6005 so set up was quick and EZ.. I currently have a HK 5 channel..I need a new 7 channel Amp now..I Miss my SBRears!! Can you all recommend me an Amp.. is the MM 8003 any Good any one here use this.?? I found one and was thinking bout getting it.. I Use all in Walls B &W CWM 7.3, & 7.4's Whats AMps Are you Using..
flyingvfreak is offline
Old 03-27-2012, 07:13 AM
horrornh's Avatar
I will be getting my AV7005 on Thursday and setting it up on Saturday. My Anthem AVM-30 bit the dust this past Saturday and that gave me the push I needed to get a more modern pre/pro.
I have always been a fan of Marantz and the price I got it for was too good to pass up.
I have been reading through a lot of this thread the last couple of days and it seems the best way to hook up my Oppo BDP-83 is with HDMI, setting Blu-Ray output to bitstream and SACD / DVD-Audio output to PCM. Is this correct?
There is no need to use the 7.1 analogs anymore is there as the Marantz will be doing all the processing?
I am also looking forward to what Audyssey can do for my room. It is not the best room conducive for sound as I have a big bay window, the front door, stairs and opening to another room and a opening to my kitchen. I always did everything manually and it sounded good to me, so I am excited to try Audyssey.
horrornh is offline
Old 03-27-2012, 07:32 AM
SoundofMind's Avatar
Liked: 166
^Correct, absolutely use HDMI from Oppo 83 to 7005, not analog. Send everything via HDMI and yes bitstream BluRay. I preferred sending everything possible from Oppo 83 via bitstream including DSD off SACD (but I am a Denon processor guy so cannot comment on the 7005 irt music bitstr/PCM settings). IME it makes only a small difference to some peoples' ears (like mine) anyway; Oppo says if your processor can decode DSD try sending it, as you may well like the SQ better.
Before running Autosetup, it is helpful to read the Audyssey setup guide and the brand new very informative Audyssey FAQ.
Yes, I still like playing with Dalis.
SoundofMind is offline
Old 03-28-2012, 11:05 AM
horrornh's Avatar
^^ Thanks sound of mind and I will definitely check out the Audyssey links you sent
horrornh is offline
Old 03-28-2012, 06:05 PM
DHF
DHF's Avatar
No sound coming from L/R speaker.
I ran into this problem a couple months back. Tried everything I could think of. Re booted, checked wiring, etc etc. I was ready to call my dealer and frantically beg for a replacement unit. The reason it took me months to report this is because it was just a stupid user problem. If you inadvertently hit the Speaker AB button on the front of the unit, or if you inadvertently hit the same button on the remote, your front L/R speakers will make no sound at all.
I was talking to my dealer, explaining this, and I apparently just "fixed" a couple of other 7005 units. So I am not the only one, somehow that makes me feel better.
DHF is offline
Old 03-28-2012, 09:59 PM
danny_isr's Avatar
got my AV7005 yesterday night,
downloaded the new firmware including airplay.
noticed those things : a small hum from my Rotel 1095 (didnt have that with the Denon 3312).
(using XLR with the Marantz, and just RCA with the Denon).
and today i can hear some random noises from the Sub (when it's connected to the av7005), and it happens when it's not playing anything and i crank the volume up...
but the really annoying thing , this morning . i'm playing a song via airplay.
i notice the remote doesnt have any effect. so i go to the unit , nothing ...it's frozen. Still playing but it wont respond to anything even the ON/OFF.
i had to unplug and plug back.
Is this the "glitchy" behavior i heard about ? or my unit is just bad ?
thanks Dan
BP - Sony BDP-S5100 PreAmp - Marantz AV7005 PowerAmp - Rotel RMB - 1095
Main - Dynaudio Focus 220 MKII Center - Dynaudio 200c Sub - Paradigm DSP-3200 Rear Mission SC-5MK
danny_isr is offline
Old 03-28-2012, 10:19 PM
well from what i got so far make sure you hit the Amp button on the Remote and that should control it, Maybe you got some bad cables, try hookin it up with the Rca's.. Im using Rca and my unit is dead Quiet!!
Old 03-28-2012, 10:23 PM
danny_isr's Avatar
yeah will try RCA (kind of defeating the purpose) but yeah .
yeah i know about the AMP button , but it was dead frozen . no control from the unit itself....
Old 03-28-2012, 11:29 PM
bweissman's Avatar
Quoted: 224 Post(s)
Liked: 88
thanks Dan
Yes, similar problem, look for my post from a few days ago. (on my iPad now, difficult to make a link to the post.) My hypothesis was that if the last activity before power-off was playing AirPlay, the next power-on would lock up. I haven't yet found a fix.
Old 03-29-2012, 05:35 AM
dlowenst's Avatar
I had the same problem back in September and posted here for help, which resulted in a quick resolution. I'm starting to feel slightly less embarrassed knowing how many folks have run into this issue inadvertently.
Dave
dlowenst is offline
Old 03-29-2012, 10:47 AM
danny_isr's Avatar
I would expect a more "polished" stable unit at this tag price , not to mention ...how much time it's been around ? They had endless time to fix firmware issues by updates ...unless again
Me and you are dealing with faulty units or it's a once in a life time glitch ....I will report here if it happens again .
But I did notice yesterday some noise from the sub (when no music) , and clicks when I turn on volume while it played CD (a click per volume level - and no clicks when it didn't play ...very weird) .again I just get the impression it's not performing
Smoothly/polished as its price tag.
SQ wise I have no compliance , sounds great.
Not sure if any better then the 3312 I had here
It's hard to remember , but I would say it sounds at least as good .
Menus/GUI is one generation backwards
But as long all the functionality is there , then it's ok.
Remote is nicer too on the Marantz (with back light ,LCD and other nice features(.
And yeah it's much nicer to look at
Old 03-29-2012, 12:43 PM
Dynarider's Avatar
I have to say I'm a little disappointed with AirPlay. Too glitchy for me. I'm glad it was a free upgrade. Did anyone ever find a solution to the high volume issue when starting AirPlay?
I backed up my iTunes library on a hard drive and connected it to our router, and was pleasantly suprised at how the 7005 easily connects, finds, and plays the music, displays info, pictures, etc. from the drive, so I won't lose any sleep over the AirPlay thing. The idea was to lose the two CD carousels I was using. Looks like I can stick with the plan.
Yeah, SQ is a fantastic step up from where I was before. Audyssey is a great program, and a lot of fun to play with.
Set up was easy. I have a gigantic pile of analog cables that I don't need now.
Overall, I'm happy. BTW, kudos to OneCall. Great service, great price.
Dynarider is offline
Old 03-29-2012, 03:43 PM
WestCoastD's Avatar
Quoted: 252 Post(s)
Liked: 96
I would hope Apple (along with Denon, etc.,...) would streamline function of AirPlay app.
So you're using direct navigation from AV7005? That's how I'm planning to operate.
I have a WD MyBookLive with a 20GB WMA archive connected to my network, works beautiful
WestCoastD is offline
Old 03-29-2012, 04:30 PM
jbn008's Avatar
Quoted: 97 Post(s)
Liked: 46
Quick questions:
which should I let scale to 1080p? 7005 or my projector (jvc dal-rs25)
dynamic volume? on or off
Headless Petie
jbn008 is offline
Old 03-29-2012, 05:18 PM
Quoted: 1393 Post(s)
Liked: 587
jbn008
If you're using bluray disk, it won't (or shouldn't) matter as the scaler won't be active.
If however you're referring to standard definition content, then it may vary. You might want to try both and see if either one stands out as being better. In many cases, its too close to tell.
JimP is offline
Old 03-29-2012, 07:02 PM
jbn008's Avatar
Quoted: 97 Post(s)
Liked: 46
Thanks, how about the dynamic volume? Does anyone use this feature?
Headless Petie
jbn008 is offline
Marantz Av7005 Pre Processor
