Onkyo SC5508 Surround processor [No Price Talk] - Page 34 - AVS Forum | Home Theater Discussions And Reviews
Old 05-19-2011, 09:22 AM
spike9876's Avatar
Quoted: 42 Post(s)
Thanks for the info Maddmaster. It's good to know if its worth the investment doing a 7.1 or 9.1 setup.
I previously mentioned that I got acoustic panels... And since I'm so impressed with sound I'm getting with my current 5.1 setup... Really to me it's not even worth experimenting with 7.1 or 9.1 or don't even see the need at this time...
Fronts: Sanders Sound M10d, Sanders Magtech Amp. Surround: B&W CM1, 2x JL Audio F112, Integra DHC-80.3, Emotiva XPA-5, OPPO 93 & HTPC
spike9876 is offline
Old 05-19-2011, 10:23 AM
bslep's Avatar
Quoted: 94 Post(s)
Liked: 77
Care to post pics of what those panels and the trap looks like?
bslep is offline
Old 05-19-2011, 10:31 AM
LarryChanin's Avatar
Originally Posted by FoSheezy View Post
This isn't 100% accurate. The Onkyo can do wides + heights but not when the surround backs are engaged.
One needs to choose only 2 of the 3 - wides, heights, surround backs.
There has been a lot of confusion in this area due to the manual not being very clear, but it is definitely possible to run wides + heights because I am doing it. The heights are awesome and I prefer the wides over the surround backs.
Hi,
Thanks for the clarification.
I was aluding to the fact that only the Denon AVR-4311 can run 11.2 channels with both wides and heights and run MultEQ XT 32. This requires adding an additional two channels of external amplification.
Larry
LarryChanin is offline
Old 05-19-2011, 11:06 AM
spike9876's Avatar
Quoted: 42 Post(s)
Sure... When I get home tonight... I will take some pics and post
Old 05-19-2011, 02:05 PM
Maddmaster's Avatar
Quoted: 71 Post(s)
Liked: 31
I'm really leaning towards the 5508 but wanted to get some opinions...
When you say better movie performance... Are you referring to sound or picture quality ?
By the way, I would like to check out prices... can anyone point me to a online retailer that I can purchase online ?
I sent you a PM with info.
Ooops I posted 5808 in some of my post. 5508 is what I have.
Definitive Technology:Front Height - Mythos Gem XL
Front - Mythos ST, Center - Mythos 10 & 8
Side Surround - Gem XL
Back Surround - Gem XL
Sub - Supercube Ref & SVS SB13 Ultra
There can never be enough music
Maddmaster is offline
Old 05-19-2011, 02:41 PM
mjaudio's Avatar
Quoted: 39 Post(s)
Liked: 75
Just to be clear I have not compared the 5508 to the 4311, rather it was a comparison between the 4311 and the Onkyo 886 pre-pro that I had on hand.
Musically they are very similar but for movies the SQ of the 886 was better than the 4311 in that it was more dynamic with a bigger soundstage. It was very easy to hear the difference and they were both connected via the same RCA cables and all other components were the same, the only difference was the 4311 vs the 886.
I do know that Chris from Audyssey mentioned that manufacturers are able to implement Audyssey into there products in regards to x-overs. This is why he has said to go back and change the x-over back to 80hz all around once the calibration is done. I do not know exactly what else the mfg. can control but I can tell you for sure that Audyssey in the Denon 4311 and Onkyo 886 are just different in regards to the EQ applied to the subs. My normal routine is to set my SMS-1 with all the EQ levels 0 and Polarity + and Phase at 0 so it is out of the equation. With the Denon 4311 I have to go back after XT32 does it's things and tweak it out with the SMS-1 after to get it flatter. With the Onkyo 886 it surprised me in that it hardly needed any additional EQ from the SMS-1, I really could have just removed the SMS-1.
Now before everyone asks I did follow the procedure for Audyssey calibration using the handy Audyssey guide here at the AVS. I used a mic boom arm and measured the maximum 8 locations at ear height and followed the same routine for both the 4311 and 886 which were both in my rack at the same time to facilitate comparison. I did go back after Audyssey calibration and set all my speakers to 80hz and the sub x-over to 80hz as well then used my Galaxy CM-140 to verify a 75db level for all my speakers and subs. I even went as far as using the Dayton Omnimic I had at the time to verify levels when I was going back and forth between the 4311 and 886. The dynamic impact of the 886 for movies was enough for me to even use the available test discs I had on hand to check levels coming out of my Oppo BDP-83 for all the channels to make sure the Onkyo was not boosting the HDMI signal.
After all that I just couldn't keep the 4311 even though it had the more advanced Audyssey XT32 and better ergonomics than the 886. I am not arrogant enough to say that the 4311 won't be better than the 886 or 5508 in someone else's system. I am just fortunate enough to be able to try what I want in my own system and make up my mind for my-self.
The only reason I have not bought the 5508 yet is because in my current system it would be close enough that any relay clicks would be too annoying. I had a Integra 80.1 for about a month that I had to get rid of because the relay clicks were too much to handle. I am in escrow on a new home that would have a dedicated space for a HT and a room next to it to hide the components. This is when I will get the 5508 as relay clicks won't be a problem in another room.
From all the comments I am really looking forward to getting the 5508. Just in case though, I am not selling my 886 until I know for certain that it has been replaced for good.
As far as video I didn't notice a difference besides the fact that the 4311 switch inputs faster than the 886. I am more of an audio guy though, video is secondary to me.
mjaudio is online now
Old 05-19-2011, 03:39 PM
Bill Mac's Avatar
Quoted: 1269 Post(s)
Liked: 1446
Definitely a wise move to hold on to the 886 till you are sure the 5508 will work well for you. I will most likely get the 5508 in the future but the relay clicking concerns me as well.
Bill
My SACD collection and HRAudio.net Library, getting larger as my wallet gets smaller ;-).
Emotiva XMC-1, Wyred 4 Sound SX-500s, ST-500, ST-250, Oppo BDP-103/105D, Panasonic TC-P60GT50 plasma, Panamax 5100EX, Salk HT2-TLs, Salk 1801b center, Salk 1801TL (surrounds) and two Rythmik F12SEs.
Bill Mac is offline
Old 05-19-2011, 04:08 PM
Maddmaster's Avatar
Quoted: 71 Post(s)
Liked: 31
Bill
I have the 5508 and the relay clicking is something I prefer (it confirms that there was a change). I moved from a B&K Ref 50 that also had relay clicks that were twice as loud. I used it for years and the relays never caused a problem so I wouldn't think it is a big concern ( i actually never had a problem with the Ref 50 at all).
Old 05-19-2011, 05:27 PM
spike9876's Avatar
Quoted: 42 Post(s)
OK, I have attached some pics. The column free standing bass trap is in the corder behind sub.
Old 05-19-2011, 05:35 PM
bslep's Avatar
Quoted: 94 Post(s)
Liked: 77
Very nice. They look great. Thanks for posting.
bslep is offline
Old 05-20-2011, 02:52 AM
e2g_'s Avatar
I think i missed you mentioning where you got those panels from.
e2g_ is offline
Old 05-20-2011, 04:53 AM
spike9876's Avatar
Quoted: 42 Post(s)
I got the panels from acoustimac.com but I got pic separately from shutterstock.com
Old 05-21-2011, 01:10 PM
Mp0wer's Avatar
Does anyone know where I can find the Onkyo 5508 cheaper than retail price?
Could you PM me.
Mp0wer is offline
Old 05-21-2011, 03:18 PM
Bghead8che's Avatar
Can some describe for me what the relay clicking issue is and when does it occur? I don't own an Onkyo yet.
-Brian
Brian R. Smith
Bghead8che is offline
Old 05-21-2011, 06:40 PM
KK20's Avatar
Quoted: 12 Post(s)
My 5508 has been working flawlessly for months... until today!
I turned it on today and it is completely locked up! Unresponsive to the remote, NONE of the buttons on the panel will respond, including standby.
I unplugged the unit, waited for several minutes and upon plugging it in, the unit powers on to the same locked state it was in before. The only way to turn it off is to unplug it.
I've tried some of the reset methods mentioned in the forum, but with the buttons unresponsive, a reset is impossible.
Anyone's help is greatly appreciated!!!
KK20
KK20 is offline
Old 05-21-2011, 09:03 PM
Maddmaster's Avatar
Quoted: 71 Post(s)
Liked: 31
-Brian
The relays click when the unit sensers a format change. Example is the previews on a DVD are not Digital Dolby. When the movie comes on that is in 5.1 you will here a click. This can happen often if formats change between tracks of music or previews on DVD. It also happens once the movie is finished and format is no longer 5.1 or whatever it was. They also clcik when you change input source (CD, DVD, Tape, etc). For me it is not an issue except when I start a CD. It seems to not change state (clip) until the first second of the song has played. I know something has changed without looking by the click.
Old 05-21-2011, 09:20 PM
Maddmaster's Avatar
Quoted: 71 Post(s)
Liked: 31
I have looked too and have not found an answer for you. There has to be a combination of buttons to push. It would happen to you on the weekend. That sucks.
Old 05-21-2011, 09:58 PM
Maddmaster's Avatar
Quoted: 71 Post(s)
Liked: 31
Try pluggin in the mic for Audyssey and then remove it. It may trigger it to respond again.
Old 05-21-2011, 10:39 PM
KK20's Avatar
Quoted: 12 Post(s)
Did that and the unit went into Audyssey setup, however, nothing would respond and it was locked on the setup screen, remote unresponsive.
When removing the mic, the 5508 went back to the original mode and still frozen/locked.
KK20
KK20 is offline
Old 05-22-2011, 01:59 AM
GeorgeHolland's Avatar
Quoted: 45 Post(s)
Liked: 46
I had no response from the remote for the first time tonight but I could control the 5508 from the front panel. I took the batteries out of the remote and after putting them back in the remote functioned again.
GeorgeHolland is offline
Old 05-22-2011, 07:18 AM
Wireless member
pepar's Avatar
Quoted: 911 Post(s)
Liked: 502
There is a firmware update coming soon, but I don't know what it is fixing.
Kal, do you know if it will address the freezing problem members are experiencing?
Jeff
"The future is already here, it's just not evenly distributed." W. Gibson
"I like the future, I'm in it." F. Theater
pepar is online now
Old 05-22-2011, 07:37 AM
Mp0wer's Avatar
-Brian
I wonder if someone could upload a video to youtube, so we can hear this clicking?
I'm using a Anthem avm30 and there is no clicking, I'm interested in hearing this clicking and if it will indeed bother me.
Mp0wer is offline
Old 05-22-2011, 11:14 AM
e2g_'s Avatar
+1
That and just an overview of the GUI. We can see what the inputs and outputs are but never the GUI, and just using the device (clicks).
e2g_ is offline
Old 05-22-2011, 11:38 AM
alanl715's Avatar
There is a 40 pin (20 pin double row socketed pin -at each end- cable that goes from the display brd to the main micro brd). There may be a discolored area between 2 pin near one end.
Maybe be solder flux...and could be causing those 2 pins to short out causing a multitude of problems. I am sure you could clean it off with some type of solvent like rubbing alcohol or acetone as well as cleaning the 40 pin soldered area off as well.
Only units affected are those with a '0' in the eighth digit of the serial number OR the 9th digit is a ' 1, 2, 3 ' .
alanl715 is offline
Old 05-22-2011, 11:58 AM
jmschnur's Avatar
What about the 80.2 serial #s with potential problems?
jmschnur is offline
Old 05-22-2011, 12:30 PM
alanl715's Avatar
Sorry guys...this was not meant to be posted on the 5508 blog...it should be on the 80.2 blog and only seems to affect the unit 'locking' up with no functions working.
alanl715 is offline
Old 05-22-2011, 12:43 PM
Wireless member
pepar's Avatar
Quoted: 911 Post(s)
Liked: 502
With them being identical units and reports of 5508 freezing, wouldn't it be relevant here as well? And I'm curious as to where your info came from?
Jeff
pepar is online now
Old 05-22-2011, 01:54 PM
KK20's Avatar
Quoted: 12 Post(s)
Mine has the "0" in the serial... could the multitude of problems include the freezing/lock up issue?
As a follow-up, I unplugged the 5508 overnight and it is now fully operational. Waiting to see if the freeze issue recurs!
KK20
KK20 is offline
Old 05-22-2011, 02:26 PM
mjaudio's Avatar
Quoted: 39 Post(s)
Liked: 75
-Brian
I don't have the 5508 yet but when I had the Integra DHC-80.1 the relay clicks and audio drop-outs were mainly with DirecTv while watching ESPN HD live and Showtime HD DVR'ed shows. I can understand when watching regular TV that the relay's would click when switching to commercials but the DVR'ed showtime shows would make no sense as they don't have commercials, only before and after. For music and movies it was not a problem but when watching Monday night Football on ESPN there would be a lot of relay clicks and occasional audio drop-outs after the clicks that I would have to rewind a bit to get the signal to lock on again.
I bet it's only a problem for a very small percentage of users but unfortunately I am in that small percentage. I still plan on picking up the 5508 for my next system though as I know the 80.1 sounded great so I expect the 5508 to be just as good if not better. My second system will be for mainly watching movies and listening to music, I am going to keep my Onkyo 886 pre-pro for the everyday TV watching system as it has always been a solid performer.
Old 05-22-2011, 04:04 PM
Kal Rubinson's Avatar
Quoted: 681 Post(s)
Liked: 461
Jeff
I do not know but I hope so.
Kal Rubinson
"Music in the Round"
Kal Rubinson is offline
Onkyo Pr Sc5507 Pre Amplifier Home Theater Av Controller Preamp 9 2 Channel New
