Onkyo SC5508 Surround processor [No Price Talk] - Page 35 - AVS Forum | Home Theater Discussions And Reviews
Old 05-22-2011, 11:29 PM
Johnla's Avatar
Quoted: 39 Post(s)
Liked: 30
Originally Posted by pepar View Post
With them being identical units and reports of 5508 freezing, wouldn't it be relevant here as well? And I'm curious as to where your info came from?
Jeff
Alan is a authorized Integra dealer in Corpus Christi TX, which is also a Onkyo/Integra repair/service center, so I would trust his input on problems like this.
Johnla is offline
Old 05-23-2011, 06:28 AM
jmschnur's Avatar
Originally Posted by alanl715
There is a 40 pin (20 pin double row socketed pin -at each end- cable that goes from the display brd to the main micro brd). There may be a discolored area between 2 pin near one end.
Maybe be solder flux...and could be causing those 2 pins to short out causing a multitude of problems. I am sure you could clean it off with some type of solvent like rubbing alcohol or acetone as well as cleaning the 40 pin soldered area off as well.
Only units affected are those with a '0' in the eighth digit of the serial number OR the 9th digit is a ' 1, 2, 3 ' .
Are replacement cables easily available and if done at home (either cleaning or replacement ) would doing so violate the warranty?
Does the short have any long term effects on the rest of the system. To put it another way : once the cable is fixed/replaced is the unit as good as new?
jmschnur is offline
Old 05-23-2011, 06:48 AM
anthonymoody's Avatar
Quoted: 439 Post(s)
Liked: 281
Any sense for when the 5509 and assorted other 2011 top of the line stuff will appear? (3009, 5009 receivers too)
TIA.
Stuck up, half witted, scruffy looking, nerf herder.
Double True!
anthonymoody is offline
Old 05-23-2011, 07:13 AM
Oppo Beta Group
RichB's Avatar
Quoted: 870 Post(s)
Liked: 571
TIA.
I am also interested. But looking at the 809, I noticed it will have both the HQV Vida and QDEO Video processors. Presumably, the QDEO to get to 4K scaling which is nice marketing but useless for almost all home theater systems. That worries me a bit.
- Rich
Oppo UPD-203 | Sonica DAC | BDP-105D | HA-1 | PM-1 | Emotiva XMC-1 |ATI Signature AT6002 x 2 + AT6006 | Revel Salon2s, Voice2, Studio2s | Velodyne HGS-15 | LG B6 | Lumagen 2020
RichB is online now
Old 05-23-2011, 07:28 AM
mjf_uk's Avatar
TIA.
They are due for release around September in the UK, but they might be out slightly before that in the USA, so maybe August.
- Rich
Why would that worry you? I'm sure there's plenty of other technology inside that you will never use. I'll be buying a 5509 to use for sound only. It will have a single HDMI cable going into it, 2 Subs connected and component out for when I need to go into the menu.
mjf_uk is offline
Old 05-23-2011, 07:33 AM
gurkey's Avatar
Quoted: 113 Post(s)
Liked: 89
To my knowledge 4K is needed for the upcoming new shutterless (no eye glasses) 3D Display modes.
gurkey is offline
Old 05-23-2011, 07:53 AM
Oppo Beta Group
RichB's Avatar
Quoted: 870 Post(s)
Liked: 571
TIA.
I do not intend to use either but the more stuff in series the more oportunity for issues. If history is the judge, expect firmware updates.
OK.
- Rich
RichB is online now
Old 05-23-2011, 09:58 AM
XynyX's Avatar
Hi,
Just bought the 5508. Set up rs232 for my Pronto 9800 remote.
All commands work fine, but no feedback.
Old processor was a Denon witch worked fine. rs232 protocol's for both processors don't differ in setup (bautrate,parity etc). Also the serial cable has the same Rx,Tx,GND config.
Im starting to think there's some wrong with the 5508.....
If somebody has a (good) working 2-way rs232 comm,
Any comment would be appreciated!
XynyX is offline
Old 05-23-2011, 10:19 AM
jmschnur's Avatar
Are you sure the rs 232 is supposed to be active on this unit? Most remotes use the Ethernet and wifi for it.
jmschnur is offline
Old 05-23-2011, 11:02 AM
Wireless member
pepar's Avatar
Quoted: 911 Post(s)
Liked: 502
Some comments here, please ...
http://www.avsforum.com/avs-vb/showt...5#post20476015
"The future is already here, it's just not evenly distributed." W. Gibson
"I like the future, I'm in it." F. Theater
pepar is offline
Old 05-23-2011, 11:15 AM
XynyX's Avatar
Yes, should be active. Commands are accepted. Only feedback is NULL
Remote is routed through a RFX9600 unit from Philips Pronto.
XynyX is offline
Old 05-23-2011, 11:24 AM
mjaudio's Avatar
Quoted: 39 Post(s)
Liked: 75
Orders in!
I hope I get it by the end of this week and will post some comments once I have had a chance to try it out.
mjaudio is online now
Old 05-23-2011, 03:47 PM
mcallister's Avatar
Quoted: 100 Post(s)
Liked: 39
I have "0" as the 8th number in my serial. I have no audio how easy would this be to do myself? what do I need? I don't want to be without a pre/pro for months.
mcallister is online now
Old 05-23-2011, 04:11 PM
jmschnur's Avatar
You might pm Alan
jmschnur is offline
Old 05-23-2011, 05:00 PM
monstosity12's Avatar
Quoted: 17 Post(s)
Hey Guys -
In the market for a new pre pro... I have a denon 4308, but its going out, so I need to upgrade.
Had a question about the onkyo sc5508.
The Denon 4308 I own now has dynamic discrete surround circuitry... What does the onkyo have? And is it better at decoding than the denon 4308 D.D.S.Circuitry.
I was about to go for a marantz 7005, but just curoius.
monstosity12 is offline
Old 05-23-2011, 05:43 PM
mjf_uk's Avatar
Originally Posted by monstosity12 View Post
Hey Guys -
VLSC (Vector Linear Shaping Circuitry) would be Onkyo's fancy name for what DDSC does in the Denon.
Having compared an Onkyo 3008 to a Denon 4311, I prefer the Onkyo. I believe Onkyo's DSP is superior to Denon.
I would skip the Marantz and go for the 5508, as Audyssey XT32 is a huge improvement over XT.
mjf_uk is offline
Old 05-23-2011, 05:45 PM
Wireless member
pepar's Avatar
Quoted: 911 Post(s)
Liked: 502
pepar is offline
Old 05-23-2011, 06:00 PM
Kal Rubinson's Avatar
Quoted: 678 Post(s)
Liked: 461
And what is that?
Kal Rubinson
"Music in the Round"
Kal Rubinson is offline
Old 05-23-2011, 06:03 PM
mjf_uk's Avatar
Originally Posted by Kal Rubinson View Post
And what is that?
Clever marketing talk to try and impress people.
mjf_uk is offline
Old 05-24-2011, 04:32 AM
runnernorth's Avatar
Hi, does anyone Know if and when there will be a new Onkyo sc 5509 on the market? Is it known if any/what improvements are made? :-)
kindly
Jan
runnernorth is offline
Old 05-24-2011, 04:46 AM
mjf_uk's Avatar
Around September time, maybe August if you're lucky. The 5509 will have 4k2k scaling and Spotify. There could also be a couple of other tweaks, but details haven't yet been released.
mjf_uk is offline
Old 05-24-2011, 04:59 AM
Oppo Beta Group
RichB's Avatar
Quoted: 870 Post(s)
Liked: 571
And what is that?
I believe both products have DAC's and marketing departments
- Rich
RichB is online now
Old 05-24-2011, 05:32 AM
heja's Avatar
11.2 balanced pre out is what will teh feature that will make my upgrade from my 5508 (already have aquired the amps and speakers needed (front wide in addition to height) :-D
heja is offline
Old 05-24-2011, 05:38 AM
Thank you for your quick reply, I'm looking forward to September then :-)
kindly
Jan
Old 05-24-2011, 07:50 AM
mjf_uk's Avatar
Unless anything changes, you'll be keeping the 5508 for at least another year then.
mjf_uk is offline
Old 05-24-2011, 08:01 AM
Wireless member
pepar's Avatar
Quoted: 911 Post(s)
Liked: 502
Is there enough physical space on the back panel to add two more phono and two more XLR connections?
pepar is offline
Old 05-24-2011, 08:21 AM
mjf_uk's Avatar
There is looking at the actual panel, but inside may be another story.
It's about time they got rid of the AM/FM section and a few analogue connections could easily be removed, especially the Phono input. Surely anyone who listens to vinyl would either use a dedicated Hi-Fi system or have a decent Phono Pre-Amp.
mjf_uk is offline
Old 05-24-2011, 11:16 AM
mjf_uk's Avatar
Having just seen the spec of the TX-NR1009, it includes DTS Neo:X - apparantly the first Receiver to have it. So even though the 1009 only has 9 internal Amps, it must be 11.1 capable (obviously using 2 external Amps) for it to support DTS Neo:X.
So you may be looking at upgrading after all, as the 3009/5009/5509 will surely all be 11.2 capable if the 1009 is.
I'm glad Onkyo realised that they would be a missing out on this opportunity to improve over the 08 series, as I was quite surprised when I originally heard that they weren't.
I can now see the 5509 being in my system for many years.
mjf_uk is offline
Old 05-24-2011, 11:45 AM
mjaudio's Avatar
Quoted: 39 Post(s)
Liked: 75
Hey Guys -
I have just recently had both the Denon 4311 and Marantz AV7005 in my system but went back to my Onkyo 886 pre-pro. Both the Denon and Marantz are really good and a little better for music but the 886 was just more dynamic for movies in my system. I actually really liked the Marantz AV7005, good looking and sounded great but every time I swapped the 886 back in the movie performance won out. The Denon 4311 was basically the same as the difference but the bass seamed even more subdued over the 886 for movies. Some may say that the bass seamed more subdued due to the Audyssey XT32 in the 4311 over the normal XT in the 886 but I measured with the SMS-1, REW and the Dayton Omnimic which I had for about 3 weeks before returning it to make sure I was comparing as fairly as possible.
I just ordered the Onkyo 5508 and hopefully it arrives this week. I am going to compare it to my 886 and post my thoughts on this thread in a few weeks.
Old 05-24-2011, 01:27 PM
Wireless member
pepar's Avatar
Quoted: 911 Post(s)
Liked: 502
Be prepared to be delighted.
pepar is offline
Onkyo Pr Sc5507 Pre Amplifier Home Theater Av Controller Preamp 9 2 Channel New
