"Official" Yamaha RX-A1000/RX-A2000/RX-A3000 thread - Page 262 - AVS Forum | Home Theater Discussions And Reviews
 41Likes
post #7831 of 9272 Old 04-18-2012, 03:50 PM
Venomous's Avatar
Originally Posted by rdgrimes View Post
There's a pretty big difference between "roll-off" and the simple absence of boost in the VLF octaves. If you boost the upper octaves, you may perceive a roll-off, but that's not what it is.
So what would you conclude with missing deep base with ypao engaged opposed the deep base present in manual mode? I've measured it in REW a few months back and anything lower than 30hz is gone.
If I engage the subs internal crossover and manually set it, the bass is present as well.
Venomous is offline
post #7832 of 9272 Old 04-18-2012, 04:03 PM
Dominic26's Avatar
Quoted: 54 Post(s)
Originally Posted by andjayik View Post
i did update to the new 3.20 update for the HTR-8063 and now my net radio says not connected? it was working fine with the 3.17 firmware? Is there anywhere to download the older files?
Ok. Now ny net radio says not connected. I did nothing except pull the plug the other day. That was to correct the missing part of the OSD. I can still connect to Pandora and my home network. I can still connect through my iPod and android apps. What gives?
Dominic26 is offline
post #7833 of 9272 Old 04-18-2012, 04:34 PM
andjayik's Avatar
fixed my problem it ended up being a ip issue!! net radio working again!!
Yamaha HTR-8063
B&W DM-604
B&W CC6
B&W L1
Fluance AVBP2 Bipolar Surround Sound Satellite Speakers
Polk Audio PSW125 Sub
Klipsch AW-400 out door
andjayik is offline
post #7834 of 9272 Old 04-18-2012, 04:42 PM
Dominic26's Avatar
Quoted: 54 Post(s)
I pulled the plug for 10 seconds. That worked for me. AVR only.
post #7835 of 9272 Old 04-19-2012, 05:29 PM
burts's Avatar
My yamaha a2000 seems to have lost all my settings, my eq settings as well.
How Come?
The name of my scenes are still there but all ypao settings is gone etc, my standby through was off also
burts is offline
post #7836 of 9272 Old 04-19-2012, 08:41 PM
pheroy's Avatar
Quoted: 49 Post(s)
Liked: 27
How Come?
Did you lose power? I was just about to post that my A2000 has a problem with losing all settings for YPAO, input names, display dimmer - basically anything I've touched in setup - whenever I lose AC power.
This is something I haven't seen happen in any modern piece of A/V gear I've owned, and it's super annoying. All it takes is a flicker of 1 second or so and I have to spend 15 minutes redoing YPAO, input names etc. I do have a UPS unit that I may have to just go ahead and plug it into, but haven't b/c I prefer to reserve it for lower power stuff like DVR.
Is this typical for the A2000 to lose all memory settings with a power loss? Seems like something that should not happen and could perhaps be corrected with a firmware update. (Last time I checked was a few months ago and no update was found.)
HT: Sony VPL-HW55ES, Screen Innovations 110" motorized Black Diamond, Samsung PN51F8500, Mirage OMD-28/OMD-C2, Revel W873 x 4 surrounds, Revel C763L x 4 heights, Hsu VTF-15 x 2, Anthem AVM-60, NHT Power5 / Marantz MM8003, Denon DBT-1713UD, DirecTV HR-34 Genie
2 channel: Martin Logan Summit X, Krell S550i, PS Audio DirectStream DAC, Oppo BDP-105D, Mac Mini with JRiver Media Center
pheroy is offline
post #7837 of 9272 Old 04-19-2012, 09:32 PM
kriktsemaj99's Avatar
Quoted: 636 Post(s)
Liked: 357
It should keep its settings when it loses power. Maybe you should call Yamaha and see what they say about it.
kriktsemaj99 is offline
post #7838 of 9272 Old 04-23-2012, 01:36 PM
Big Ave's Avatar
Question:
I have the rx-a2000 and I run the multichannel setup from my bluray player. When I put the video on pause and then hit play, the receiver jump to AV1 everytime. Is there a setting it can change to stop this from happening or is there a firware upgrade that eliminates this.
Not sure if this is covered in this thread but 262 pages and growing is daunting to say the least.
Big ave
Big Ave is offline
post #7839 of 9272 Old 04-23-2012, 01:46 PM
snowghost's Avatar
Quoted: 20 Post(s)
Originally Posted by private Angus View Post
Thanks a lot for the help. Yeah i'm using it with my ipad, the app is really great!
I just installed the app on my newly acquired iPad and really like how it's laid out.
There appears to be one bug though. When you are in the DSP settings you cannot toggle through the Surr Decoder settings. That is to say, if my Yamaha is set to DPLIIx Music, hitting that icon does nothing. If another DSP mode is selected and you press Surr Decoder, it will go back to the last Surr Decoder setting the amp was on, i.e. DPLIIx Music. But I don't see a way to access the other Dolby settings or even Neo 6.
Am I maybe missing something?
"The best long distance runners eat raw meat, run naked and sleep in the snow."
snowghost is offline
post #7840 of 9272 Old 04-23-2012, 05:01 PM
Ross Ridge's Avatar
Liked: 81
Try disabling HDMI CEC in the Blu-Ray player, receiver and/or TV. Different manufacturers have differing names for HDMI CEC, Yamaha just calls it "HDMI Control" ([On Screen] -> Setup -> HDMI -> HDMI Control).
Ross Ridge is offline
post #7841 of 9272 Old 04-24-2012, 02:59 PM
markymiles's Avatar
Quoted: 109 Post(s)
Liked: 44
I noticed that as well, annoying but haven't managed to find a way round it on the app.
markymiles is offline
post #7842 of 9272 Old 04-25-2012, 06:20 AM
tommylicious's Avatar
Hi gents-- those of you using external amplifiers with the RX-A series, do the output levels seem low to you? If so, any workaround?
tommylicious is offline
post #7843 of 9272 Old 04-25-2012, 06:39 AM
batt50's Avatar
It did until I ran ypao again (after connecting the amps). Levels evened out after.
batt50 is offline
post #7844 of 9272 Old 04-25-2012, 07:54 AM
JackOften's Avatar
Likewise. Unless you count the subwoofer which is usually set too low by YPAO.
JackOften is offline
post #7845 of 9272 Old 04-25-2012, 09:03 AM
froh's Avatar
One thing (I've forgotten to do this a few times as well) but when you run YPAO make sure the volume is at the correct setting before you kick it off.
I believe it's -25dbs?
froh is offline
post #7846 of 9272 Old 04-25-2012, 09:51 AM
froh's Avatar
wouldn't mind hearing others opinions about their sub setups with the RX-A
I've been messing around with speaker settings and crossovers to achieve an optimal deep base scene for some movies. If you've had luck with the manual setup for the sub i'd be interested in the entire setup.
I just used the YPAO for a 9.2 setup and then changed the speakers all to small and set the sub crossovers to 80 manually.
still messing around but if someones already done the work, that would be great info!
froh is offline
post #7847 of 9272 Old 04-26-2012, 07:45 AM
KevinG's Avatar
Quoted: 332 Post(s)
Liked: 160
Really? Is this necessary? I don't think I've ever worried about my volume level before kicking off YPAO...I assumed it was taking complete control of signal level.
KevinG is offline
post #7848 of 9272 Old 04-26-2012, 08:14 AM
rdgrimes's Avatar
Quoted: 1993 Post(s)
Liked: 1321
You are correct. The user's volume setting has no bearing on YPAO. YPAO ignores ALL user settings and runs itself at "reference levels".
rdgrimes is online now
post #7849 of 9272 Old 04-26-2012, 01:46 PM
pappaduke's Avatar
Quoted: 137 Post(s)
Liked: 133
Someone in a recent post suggested running YPAO in all eight positions to get better results and possibly fix phase errors. Just want to say thanks because my right rear surround no longer registers as out of phase. Now I just need to see if all the settings sound right or if I need to manually adjust some things. Also , my sub was set to -1 db instead -5 db when I only used one position.
Yamaha 2010
Oppo 103D,ATV3,PS3, Samsung UN60ES7100F, Bluesound Vault 2 and Pulse Mini, Harmony One, Paradigm Monitor 9's, CC-390, 2ADP 390's/190's, 2 PDR 100's. B&W P5
Zone2-Paradigm SE-1's, Zone3-Paradigm-Stylus 370-SM
pappaduke is offline
post #7850 of 9272 Old 04-27-2012, 10:59 AM
froh's Avatar
Good to know - thought I read somewhere in the manual about the volume.
froh is offline
post #7851 of 9272 Old 04-27-2012, 02:09 PM
DDailey's Avatar
Quoted: 114 Post(s)
Liked: 103
How Come?
I lost all of the settings on my A3000 recently - had to reset all of them. First time it has happened. No power outage, just dropped them. Gave me another opportunity to see how clumsy the interface is with "scenes" - but when they are programmed properly, I really love this feature. Hopefully Yamaha will do better with the GRI in future models. I don't use YPAO, but I know how to calibrate manually, and would never recommend for beginners. No amount of EQ can overcome a bad room IMO. I still love this unit, swiss army knife of receivers.
DDailey is offline
post #7852 of 9272 Old 04-27-2012, 09:23 PM
LansdaleHokie's Avatar
anyone else have an issue with the iPhone app - when playing music from your iPhone, if you select a song from whatever list you are in (album, songs, playlist) it will never play the right song?
Mancave: UN46D7000, Onkyo 818, Mirage OMD-C1, OMD-5 (2), HSU STF-2, PS3, XBox360, Wii, DirecTV, AppleTV v2
Den: LG 55LX9500, Onkyo 709, Polk RC85i (3), Polk PSW10, DirecTV, AppleTV v3
LansdaleHokie is offline
post #7853 of 9272 Old 04-27-2012, 11:19 PM
Venomous's Avatar
Weird... Perhaps they did fix it in the xx10 models. I've had the 3010 for 7 months with no loss of settings.
Venomous is offline
post #7854 of 9272 Old 04-28-2012, 04:17 AM
jimfrench's Avatar
See if shuffle is selected. It seems to use the selection made as the last song and immediately move on.
jimfrench is online now
post #7855 of 9272 Old 04-28-2012, 06:35 AM
Quoted: 636 Post(s)
Liked: 357
That's not supposed to happen, but I would still be sure to make a backup of my settings with Receiver Manager. Then you have everything saved and you can reload if you need to.
post #7856 of 9272 Old 04-28-2012, 06:28 PM
Dominic26's Avatar
Quoted: 54 Post(s)
On the panel of my 2000, it shows how the sound is processing from all my HDMI connected components except my Blu Ray player (Panasonic BDP-55). Does anyone here have a Panasonic. And if so, how is the audio set so I can see the type of signal (DD, DTS, etc) it is passing to the Yamaha?
post #7857 of 9272 Old 04-28-2012, 07:20 PM
Ross Ridge's Avatar
Liked: 81
Keep pressing the Info button on the remote until it shows the "Audio Decoder" on the front panel. If it says "PCM" then the Blu-Ray player is doing the decoding.
post #7858 of 9272 Old 04-29-2012, 05:17 PM
turnne1's Avatar
Quoted: 1754 Post(s)
Liked: 410
you also might need to change the setting in the Pansonic player to bitstream...under its audio output settings
Warren
Rm 1 Samsung 64F8500 Marantz 8801 prepro Sherbourn 5/1500A amp B&W CM10s..CM2 center...CM5's.rears
Rm 2 Hisense H50C Yamaha A2050 Celestion 305 speaker system
Rm 3 Panasonic 50ST50 Denon4520 Kef 2005.2 speaker system
Rm 4 Samsung 51E8000 Sony DA5400ES Mirage Omni sat speaker system
turnne1 is online now
post #7859 of 9272 Old 04-29-2012, 05:21 PM
turnne1's Avatar
Liked: 410
hmm...interesting...I have never had that issue with my A3000 and I have used it daily for about a year
The only issue I have had ..twice..is it losing its internet connectivity when I try to use internet radio or an online app such as Pandora
Warren
post #7860 of 9272 Old 04-29-2012, 07:06 PM
jimfrench's Avatar
Warren
This is likely the problem. I had to make this switch with the same 2 models a few months ago.
