"Official" Yamaha RX-A1000/RX-A2000/RX-A3000 thread - Page 294 - AVS Forum | Home Theater Discussions And Reviews
 50Likes
post #8791 of 9321 Old 05-09-2014, 11:22 AM
Cravit8's Avatar
Quoted: 1152 Post(s)
Liked: 610
Originally Posted by lfox View Post
Has anyone lost the ability of the Yamaha iphone based control ap to find their receiver on their LAN? I had to manually enter its IP address to reestablish control.
UPDATE: I ran into the same problem. Not a coincidence that I updated the app. I'm going to roll it back since I keep a copy of all important iOS apps.
It's a bugger. It wouldn't find my A2000 until I turned it on with the power button.
PSN: Cravit8
XBL: oOo_Crav_oOo
Cravit8 is offline
post #8792 of 9321 Old 05-09-2014, 03:45 PM
Daring Dude's Avatar
Originally Posted by marcusj50 View Post
I had a problem yesterday with my A2000 that I was hoping someone could provide some advice on.
We were watching Frozen, daughter’s birthday party, on Blue Ray with my Yamaha BD-A1010. The problem I had was that I could not get the audio to output to the L and R Surround Back Speakers in my 7.1 set up. The indicator lights on the front panel of the A2000 would only show the 5.1 setup and all those speakers received their audio signals perfectly.
The BD Player’s on screen display showed that it was outputting “DTS-HD Master Audio – 7.1” and the A2000 was set to “Straight” which I thought would pass the signal right through to ALL the speakers. I use an HDMI cable from the Blue Ray to the A2000. Also, I have the “Power Amp Assign” Speaker Set Up set to “7ch+1 Zone”, not sure if that matters or not.
Things I tried:
• Switching from “Straight” to other sound field effects including 7-channel stereo, which worked fine in all 7 speakers, and “Sur-Decode” modes.
• Tried using another Blue Ray, Tangled , which was also outputting in “DTS-HD Master Audio – 7.1”.
• Switched the BD audio output to other formats like Spanish, French, etc. and the audio from the speakers changed accordingly.
Does anyone have any thoughts on how this can be corrected so that the A2000 will output 7.1?
Are there other settings I can try on the A2000?
Is there a way to verify what signal format the A2000 is receiving from the BD player or if it is being additionally processed at the A2000?
Any thoughts would be greatly appreciated. Thanks.
Maybe I misunderstood, but you mentioned "7ch+1 Zone". Was the additional zone turned on or active? If so, I believe that limits the A2000 to 5 channels in the main zone since it can only power 7 total speakers.
Daring Dude is offline
post #8793 of 9321 Old 05-09-2014, 05:22 PM
jimfrench's Avatar
Just a thought but is Network Standby turned on in the setup? I think this is needed to keep the A2000 connected to the network. I haven't had any problem with the app in finding the AVR with the latest update.
jimfrench is offline
post #8794 of 9321 Old 05-12-2014, 06:36 PM
marcusj50's Avatar
Thank you for the reply. I was just mentioning that I had it set to “7ch+1 Zone. But I did not have the other zone turned on at the time.
However, I think I finally figured it out. I went to the set up menu on the receiver and looked at the “Audio Signal” under “Information” while playing the movie Frozen with the audio output from the BD player set to “dts-HD Master Audio-7.1”. The manual said that this portion of the setup menu, “Displays information on the current audio signal.”
Here is what it returned:
Format – “DTS”
Sampling – 48kHz
Channel – 3/2/0.1
Bitrate – 1536kbps
Dialogue – 0dB
The definition from the manual for “Channel” was as follows, “The number of source channels in the input signal (front/surround/LFE). For example, a multi-channel soundtrack with 3 front channels, 2 surround channels and LFE is displayed as “3/2/0.1”.” All this was straight forward.
However, underneath this in the footnote section it had the following:
“Some high-definition audio bitstream contents may not include the discrete surround back left and right channel signals, but are encoded at a sampling rate of 192 kHz.” I didn’t think this had anything to do with my problem. However, the next footnote said:
“Even when direct bitstream output settings are applied, some players convert the Dolby TrueHD or Dolby Digital Plus bitstreams to the Dolby Digital bitstreams, while converting DTS-HD Master Audio or DTS-HD High Resolution Audio bitstreams to DTS bitstreams.” All of this was on pg. 127 of the manual.
Then I was off to my BD Player manual which is a Yamaha BD-A1010. Basically it noted that if the HDMI audio output was set to “Reencode” that it would output DTS-HD Master Audio tracks containing “Secondary Audio-SA” or “Button Click Sounds-BCS” as DTS only. If no SA or BCS were present then DTS-HD Master Audio would be output. My player was set to “Reencode” and therefore was outputting “DTS” only. Once I changed the setting to “Bitstream” the problem was fixed and all 7.1 channels were now being broadcast and noted on the receiver’s front display.
A simple fix that took too long to figure out.
marcusj50 is offline
post #8795 of 9321 Old 05-13-2014, 12:42 AM
Squishy Tia's Avatar
Quoted: 49 Post(s)
Liked: 27
Yeah, unless your player (a PS3 in most cases) self converts to PCM first, you want the setting to be bitstream or else you won't get TrueHD or DTS-HD audio, you'll get the lossy core DTS/Dolby Digital or sometimes something worse.
When a Priest says they're going to Flash you, it isn't for healing.
Squishy Tia is offline
post #8796 of 9321 Old 05-14-2014, 04:06 PM
rdcollns's Avatar
Quoted: 20 Post(s)
My newest issue is that I cannot put an audio CD in my bluray player to listen to in zone 2 or 3 without turning on party mode and sending the music to all zones even when the other zones are powered down. It is the only input that seems affected. I think it had worked in the past, but I would have only tried it with the main set to bluray as well (AV1). I am using the optical feed. Has anyone had a similar issue?
rdcollns is offline
post #8797 of 9321 Old 05-14-2014, 05:24 PM
Cravit8's Avatar
Liked: 610
Kudos Marcus on due diligence.
Your workflow educated you, too bad it was lengthy.
The issue you experienced is extremely common with different receivers using different sources including game consoles.
And almost every time (especially with the RX-Ax000 series) it's not the receiver but the source.
As I read your second sentence I knew it'd be your source's output.
PSN: Cravit8
XBL: oOo_Crav_oOo
Cravit8 is offline
post #8798 of 9321 Old 05-14-2014, 05:27 PM
Cravit8's Avatar
Liked: 610
It's possible it was my phone, going from 4G to home wifi. That seemed to be the commonality of the 2 previous connectivity problems. I actually haven't tested it since and did not roll back the app yet.
I haven't changed the Network Standby setting since installing the AVR 3 years ago so it's not that, but it did indeed act like that function was turned off.
PSN: Cravit8
XBL: oOo_Crav_oOo
Cravit8 is offline
post #8799 of 9321 Old 05-14-2014, 05:58 PM
kriktsemaj99's Avatar
Quoted: 659 Post(s)
Liked: 382
Digital inputs (e.g. HDMI or optical) can't be sent to other zones (except in party mode).
kriktsemaj99 is offline
post #8800 of 9321 Old 05-14-2014, 06:42 PM
rdcollns's Avatar
Quoted: 20 Post(s)
The HDMI from my computer works perfectly. I can send that to any zone. I was under the impression that digital inputs could go anywhere as long as you only used one at a time since there was only one DAC.
rdcollns is offline
post #8801 of 9321 Old 05-14-2014, 07:08 PM
Cravit8's Avatar
Liked: 610
Are you in the right thread? Because what was posted above you is absolutely correct for the threads model.
PSN: Cravit8
XBL: oOo_Crav_oOo
Cravit8 is offline
post #8802 of 9321 Old 05-15-2014, 11:11 AM
rdcollns's Avatar
Quoted: 20 Post(s)
Yeah, I have the RX-A2000. Maybe I need to double check my connections, perhaps I have an analog connection run too. That could probably get me around the blu-ray issue. However, I also listen to Pandora in every zone independantly, and obviously that is digital.
rdcollns is offline
post #8803 of 9321 Old 05-15-2014, 11:18 AM
Quoted: 659 Post(s)
Liked: 382
Network connections such as Pandora all work in other zones, it's sources with their own digital inputs that don't.
If it's audio CDs that you specifically want in another zone then an analog cable will solve the problelm, as will ripping all your CDs to network storage.
post #8804 of 9321 Old 05-18-2014, 05:56 AM
warek's Avatar
[SIZE=3
]I have a Yamaha RXA 3000 and think it is developing a few problems. Any advice welcome before I take it in for warranty repairs.
I have owned this unit for 3 years,
I run an OPPO 83 as a source DVD Blu ray player
Last year when I selected setup it did not display on TV, I tried it several times over a week and it was not visible. I had made no wiring or other changes before or after. Then for no apparent reason it began working normally and the on screen display has been working perfectly ever since.
The receiver randomly decides to switch itself off, sometimes 3-4 times in the same day, then works perfectly for months. Last month it turned itself off once, after running for 4 hours on low playing 7 channel stereo internet radio via an Apple TV.
I currently have some of my equipment in storage, so have the A3000 powering front L and R speakers and (centre and surrounds L and R) running through a power amp. I have the front presence and back surrounds all set at -10 under the speaker manual setup.
I watched half a movie last night and it was a Dolby digital 5.1 DVD. The receiver was set to Movie Sci Fi, and I also have subs on mono into a DsSpeaker antimode 8033 with 4 large subwoofers. The Yamaha displayed PCM on its display screen and I thought the bass was lacking. Tonight I finished the movie, same settings, but this time the Yamaha displayed Dolby digital and there was more bass.
It is common for the Yamaha to display PCM on its display when I am watching a dolby digital 5.1 source. Often displays decoder off when movies are starting or finishing.
It also seems to lack a little volume at times and I usually run the Yamaha at -13 on volume control for normal movie use, and sometimes at -10,but I do have it in a room of 150 cubic metres
Thanks for any suggestions
Kevin
[/SIZE]
warek is offline
post #8805 of 9321 Old 05-22-2014, 05:31 AM
nathanddrews's Avatar
Quoted: 406 Post(s)
Liked: 348
Anyone know of a good way to rackmount my RX-A3000? I know I could just put it on a shelf, but I was curious is there was a way to flush-mount it into my 19" rack.
nathanddrews is offline
post #8806 of 9321 Old 05-24-2014, 12:03 PM
bdfox18doe's Avatar
Quoted: 241 Post(s)
Liked: 140
yep..custom order a rack kit from a middleatlantic.com dealer.....pricey, but has that factory look..that is what I do for all my gear.
http://www.middleatlantic.com/resources/rsh-lookup.aspx
Bob
The views expressed here are my own and do not necessarily represent those of ABC, CBS, CW, FOX, MeTv, or AntennaTv; my employer; or its parent company.
Nor my wife for that matter!
bdfox18doe is offline
post #8807 of 9321 Old 05-30-2014, 09:15 AM
dan webster's Avatar
Quoted: 185 Post(s)
Liked: 141
Does anyone here know what a Yamaha 3000 receiver in great condition with original box and all accessories is worth? I bought one for my father 2 years ago for s system and he wants to buy a zvox sound bar instead. My mother can never figure out how to usr the system.
Dolby Atmos 7.2.4 Marantz AV8802a processor Gemstone 200x7 Emotiva upa-500 amps
Oppo 103 Sony UBP-X800 4K Ultra HD Blu-ray Jvc RS500 projector Vivitek 1186 projector
Carada 110"BW screen Monster HTS 5100 MK11 power conditioner
Golden Ear Triton 5 L&R &super center XXL triton 7's sides Martin logan motion 12 rears
4 RSL C34 in ceiling SVS PB2-plus sub Outlaw LFM-1-plus sub
dan webster is offline
post #8808 of 9321 Old 05-30-2014, 09:58 AM
Home Theater Lover
Craig Peer's Avatar
Quoted: 4023 Post(s)
Liked: 4077
Check eBay or the classifieds here at AVS and see what they have sold for.
Current home theater photos - http://www.avsforum.com/photopost/sh...hp?cat=2386514
craigpeer@earthlink.net
Craig Peer is offline
post #8809 of 9321 Old 06-03-2014, 05:56 AM
Quoted: 406 Post(s)
Liked: 348
You can get them brand new in the box for $800-1,000, but you can also often find feature-comparable units (Burr-Brown, 2+ zones, 4K) several generations newer go on sale for around $500-700. Nothing under $1,000 matches its power output though. Be happy if you get between $500 and $900... That's why I'll probably never sell mine - I wouldn't be happy.
post #8810 of 9321 Old 06-03-2014, 05:29 PM
Tacoboy's Avatar
I know someone with a RX-A3000 which has a non-functional headphone output, any rough idea on how much it would usually cost to have the headphone output fixed?
Yamaha RX-V671 receiver
Infinity Beta 5.1
Vizio D58U-D3 (Costco) TV
Tacoboy is offline
post #8811 of 9321 Old 06-08-2014, 07:58 PM
Quoted: 49 Post(s)
Liked: 27
That's going to depend on a few factors: Where the problem actually lies (is it in the circuitry, the power supply, or a physical break in the jack's connection to the PCB?), and whether or not the unit is still under warranty.
post #8812 of 9321 Old 06-08-2014, 08:14 PM
Tacoboy's Avatar
Everything else works on the A3000.
Just wondering if there is any common issues (known problems) with the Yamaha headphone jack.
Infinity Beta 5.1
Tacoboy is offline
post #8813 of 9321 Old 06-08-2014, 08:43 PM
Quoted: 49 Post(s)
Liked: 27
To the best of my knowledge, there isn't a known defect with the headphone jacks. I've had several come loose over the years on both PCs and AVRs though from repeated use. For some reason, little quality goes into making these jacks, despite the fact that many of us do use them.
post #8814 of 9321 Old 06-08-2014, 09:38 PM
Cravit8's Avatar
Liked: 610
I have used my jack more than the average user I suspect and it's seems solid.
But I can fathom a few circumstances that would cause it to fail, mostly from the user's mistake or accident.
PSN: Cravit8
XBL: oOo_Crav_oOo
Cravit8 is offline
post #8815 of 9321 Old 06-15-2014, 04:21 PM
oleon621's Avatar
Quoted: 28 Post(s)
Liked: 29
So I have a 7.2 setup I've ran YPAO setup and made some manual changes like setting all speakers to small and 80HZ. However i find my setup lacking some ooomph in the bass department if I leave it the way YPAO leaves it. I find myself raising the db in manual setup by at least 5. Any advice? I have a SVS PB10-NSD and a Polk DSW PRO 600
thanks
oleon621 is offline
post #8816 of 9321 Old 06-16-2014, 04:48 AM
in3rtia's Avatar
Quoted: 84 Post(s)
Liked: 25
I boost my subs by as much as 10db. YPAO level matches your subs with your mains, and the LFE track in movies requires a 10db boost in the sub department.
in3rtia is offline
post #8817 of 9321 Old 06-16-2014, 06:38 AM
Quoted: 659 Post(s)
Liked: 382
The receiver handles the 10dB boost automatically for the LFE track. But some people boost the sub level because they prefer it.
post #8818 of 9321 Old 06-16-2014, 07:13 AM
in3rtia's Avatar
Quoted: 84 Post(s)
Liked: 25
My mistake, I didn't realize it was automatic
in3rtia is offline
post #8819 of 9321 Old 06-16-2014, 11:20 AM
rdcollns's Avatar
Quoted: 20 Post(s)
thanks
I have the same problem, but I have full size speakers with no sub. I compared side to side with a Sony ES model, and I could clearly tell that music was stellar with the sound quality, but didn't have the oopmh.
I went into the receiver manager software, and boosted first two bands of the parametric EQ while listening to a bass heavy music track. I set the levels so that it sounds natural with the bass set to 0dB, and if I want a big kick, I can crank it up to 6dB. I can now happily say that I am 100% satisfied with the sound.
rdcollns is offline
post #8820 of 9321 Old 06-17-2014, 12:03 PM
Quoted: 406 Post(s)
Liked: 348
All this time I thought the LFE track itself was boosted. Or was that only with previous DTS tracks? (thus, an effective 20dB boost)
EDIT: that said, my computer setup has a Rel Q201E hooked up. On the back it has two low-level ports: 0dB and +12dB. So if the LFE track is boosted, the receiver is boosted, and I'm using the +12dB port... BOOM!
