"Official" Yamaha RX-A1000/RX-A2000/RX-A3000 thread - Page 295 - AVS Forum | Home Theater Discussions And Reviews
 23Likes
Old 06-19-2014, 09:01 AM
oleon621's Avatar
Quoted: 28 Post(s)
Liked: 29
Thanks for the responses fellas. I ended up boosting both subs equally by 7DB to really get some ooomph. I love the sound quality of the receiver just needed a little more bass. Maybe its time for a major sub upgrade
oleon621 is offline
Old 06-22-2014, 11:41 PM
Sweetmeat's Avatar
Quoted: 34 Post(s)
Originally Posted by oleon621 View Post
So I have a 7.2 setup I've ran YPAO setup and made some manual changes like setting all speakers to small and 80HZ. However i find my setup lacking some ooomph in the bass department if I leave it the way YPAO leaves it. I find myself raising the db in manual setup by at least 5. Any advice? I have a SVS PB10-NSD and a Polk DSW PRO 600
thanks
This is quite normal, especially for this receiver. I don't have time to do the searching for proof, but it's well documented that YPAO does not level set the sub correctly in the receiver. I believe, but maybe I'm wrong, the RX-A3010 fixed that issue. I've ran YPAO multiple times and ALWAYS have to adjust my sub settings with a SPL at the end.
Sweetmeat is offline
Old 06-23-2014, 07:28 AM
billmich's Avatar
Quoted: 246 Post(s)
Liked: 55
I have a 3010 and I also noticed some lack of OOMPH with the sub
billmich is offline
Old 06-23-2014, 09:00 AM
Sweetmeat's Avatar
Quoted: 34 Post(s)
Does anyone have a Sirius subscription and listen to it via their RX-A3000? I thought I read awhile back that it wasn't available anymore, but can't remember for sure.
Also, what are people using to stream music from apps (Slacker, TuneIn Radio, etc) on their phone/iPad to their stereo? Would Apple TV work for this, or is there something else?
Old 06-23-2014, 06:38 PM
Cravit8's Avatar
Quoted: 1149 Post(s)
Liked: 610
Apple TV is method one.
Bluetooth receiver connected via SPDIF or Stereo L/R is method two.
Only iTunes music will stream straight to the Ax000 receiver line.
Cravit8 is offline
Old 07-02-2014, 11:06 AM
Liked: 0
Hello everyone. I have a yamaha RX-A3000 and it recently started showing the "Yamaha Wallpaper" at the bottom of whatever is playing on the TV screen. It doesn't matter which input device I use dvd,ps3 or Apple TV. The wallpaper is supposed to vanish from the screen when a video signal is sent to TV, but about a two in strip is visible below the movie, show or game. As far as I know i haven't changed the settings. Any ideas from anyone?
Rifflepass is offline
Old 07-02-2014, 11:12 AM
in3rtia's Avatar
Quoted: 84 Post(s)
Liked: 25
If you just shut off the unit and unplug it for a sec, does it go away?
in3rtia is offline
Old 07-02-2014, 12:21 PM
Liked: 0
Shut off and unplug which unit, the rx-a3000?
Old 07-02-2014, 12:24 PM
in3rtia's Avatar
Quoted: 84 Post(s)
Liked: 25
Yeah, sorry. It's been known to fix a few random graphical bugs and glitches.
in3rtia is offline
Old 07-02-2014, 12:47 PM
Liked: 0
Hell I'll give it a shot. I'll leave it unplugged for about a half hour.
Old 07-02-2014, 02:34 PM
VARTV's Avatar
Quoted: 44 Post(s)
Originally Posted by kriktsemaj99 View Post
If you haven't tried it already, the first thing I would do is power the unit off for a few seconds, then back on (you have to pull the plug, because the "power" button only puts it in standby mode).
Just wanted to let you know this was great advice. I couldn't get the receiver to connect to my network. Pulled the plug for a few seconds and now all is well...
Robert F Corbin
VARTV.com | Virginia Media News & Information
email: editor@VARTV.com
facebook: facebook.com/VARTV
twitter: twitter.com/VARTV
linkedin: linkedin.com/in/VARTV
google+: plus.google.com
pinterest: pinterest.com/VARTV
VARTV is offline
Old 07-02-2014, 03:33 PM
Liked: 0
You're a genius! I was dreading pulling every connection, troubleshooting all cables, and swoop in like Spider-Man with the simplest no mus no fuss solution. Thank you. I owe you a virtual/online beer.
Old 07-02-2014, 03:51 PM
in3rtia's Avatar
Quoted: 84 Post(s)
Liked: 25
Glad it worked!
in3rtia is offline
Old 07-02-2014, 03:56 PM
in3rtia's Avatar
Quoted: 84 Post(s)
Liked: 25
Along this same line... I've had 100% solid connectivity ever since I assigned a static IP through my router for my A2000.
If you frequently get network errors I would suggest doing the same. Even if you're not, it's a good idea.
in3rtia is offline
Old 07-03-2014, 12:06 AM
Cravit8's Avatar
Liked: 610
I also use static IP for the AVR and have never had a network problem. That method basically removes a troubleshooting step.
Cravit8 is offline
Old 07-03-2014, 11:51 AM
bdfox18doe's Avatar
Quoted: 193 Post(s)
Liked: 102
I have question here for other 3000 owners..seems to me..that if you are running Pandora..and go to another input..even for an extended period of time..that pandora keeps sucking data..unless you hit stop before changing inputs....
Bob
The views expressed here are my own and do not necessarily represent those of ABC, CBS, CW, FOX, MeTv, or AntennaTv; my employer; or its parent company.
Nor my wife for that matter!
bdfox18doe is offline
Old 07-03-2014, 12:29 PM
DavidMP's Avatar
Quoted: 22 Post(s)
Yes, I have noticed this too. Not sure why it does that.
DavidMP is offline
Old 07-04-2014, 10:30 AM
Cravit8's Avatar
Liked: 610
Bob, that is exactly right. It is not just the 3000, but the 2000 also.
Pandora continues to play, so it does use data, but non "Pandora One" accounts use so little data even playing 24/7 that data would not be an issue for a regular ISP. Tethering through a phone could be problematic.
I brought up an issue a year ago where I thought the headphone jack was picking up AM or FM radio. I discovered the headphone jack can hear the Pandora when the volume is up on another input but little to no sound from that input. This the is the method you can use to prove Pandora is still playing.
Best practice is to press the pause button via the Yamaha app then switch to desired next input.
Cravit8 is offline
Old 07-04-2014, 12:28 PM
VARTV's Avatar
Quoted: 44 Post(s)
I do use DHCP Reservation but for some reason I just couldn't connect the receiver to the network...
Robert F Corbin
VARTV is offline
Old 07-08-2014, 12:14 PM
bdfox18doe's Avatar
Quoted: 193 Post(s)
Liked: 102
Yea, I have gotten in the habit of hitting stop (well, most of the time when I remember to....) before changing sources.
Bob
Old 07-08-2014, 12:15 PM
tommylicious's Avatar
AM antenna "GND"
Gents what exactly does the "GND" tab on the AM antenna input area do? The receiver isn't grounded right (no 3rd pin)? So what is it? Thanks.
tommylicious is offline
Old 07-08-2014, 01:25 PM
billmich's Avatar
Quoted: 246 Post(s)
Liked: 55
antenna ground is different than a power ground
billmich is offline
Old 07-09-2014, 05:32 AM
billmich how so? thanks.
Old 07-26-2014, 01:19 PM
sm4llz's Avatar
Quoted: 40 Post(s)
I'm hoping somebody can help me out. I just got my theater room finished and installed my rear surrounds but can't get them to play unless I change my RX-A2000 to 7 channel stereo. Here's my setup:
RX-A2000
Emotiva XPA-5
Western Digital Live Hub
JVC x-500r Projector
Front L/R Speakers - Definitive Mythos ST
Center - Definitive Mythos 10
Supercube 4000
Surround L/R Speakers - Definitive UIW RSS II
Surround Back Speakers - Definitive Mythos Gem XL
The Front, Center, and Surround speakers are connected to the Emotiva leaving only the surround back connected to the Yamaha. I have the speakers setup for in the Yamaha for 7ch with zone 2. If I play something through the Western Digital I get 5.1 using Straight on the Yamaha. The only time I see the surround backs active though is if I choose 7 channel stereo. I believe this takes the full audio signal and puts it through each of the speakers so you lose the "surround" function.
Is there another option for setup that takes the signal coming from the source and simulates 7.1? help.
sm4llz is offline
Old 07-26-2014, 02:58 PM
kriktsemaj99's Avatar
Quoted: 591 Post(s)
Liked: 328
Originally Posted by sm4llz View Post
...Is there another option for setup that takes the signal coming from the source and simulates 7.1?
Yes, find Extended Surround in the Option menu and set it to Dolby PLIIx Movie (or one of the other options).
kriktsemaj99 is offline
Old 07-26-2014, 04:19 PM
sm4llz's Avatar
Quoted: 40 Post(s)
This is one of the many reasons why I love this forum. Thank you!
This resolved the issue. Mine was set to auto
sm4llz is offline
Old 07-28-2014, 02:25 AM
uriah's Avatar
Quoted: 24 Post(s)
receiver will not relay AV to tv on 5 of 7 av inputs
Just got Samsung PN 8500 and at first all was well then some how, probably some thing I did, the receiver (2000) quit relaying audio or video to TV. I checked by hooking up the old TV and got a mirror of the new. I checked all the HDMI cords, (3d high speed with Ethernet), I was able to see the green forest background and I was able to see the menu's and go into receiver set up on both TV's I started checking each input and inputs 3 and 4 work with all devices however none of the others The Ethernet (gigabit router and cat 7) works fine.
Anybody have suggestions and is there a way to revert the 2000 all the back to factory defaults so I can start again or see if I need to send the receiver in for service.
uriah is offline
Old 07-29-2014, 04:02 PM
drjill's Avatar
New Speakers needed
I recently moved and left my surround speakers with the house. I have the 3000 and now need new speakers. It is wired for 5.1 which are what I am wanting. Considering Energy Take Classic 5.1 or Energy RC Micro 5.1 because I want something more design conscious and unobtrusive. Any issues running these speakers with this receiver?
TIA
Jill
drjill is offline
Old 07-29-2014, 10:51 PM
xuniman's Avatar
Do you have DirecTV, a recent upgrade they did to their boxes caused mine to lock up whenever HDMI was used. When I tried component everything worked fine. After troubleshooting it was determined that the HDMI handshake between the DirecTV box and the Yamaha (I have a 3000) was causing the lockups.
Did you try component though the receiver to the TV?
xuniman is offline
Old 07-30-2014, 11:03 AM
uriah's Avatar
Quoted: 24 Post(s)
I have dish and the problem is not limited to satellite, when I shift the dish over to inputs 3 or 4 four it works fine. I have not yet tried component but will do so now. Did you find a way to resolve your issue with HDMI ? Thanks for your suggestion.
uriah is offline
taboola here
