"Official" Yamaha RX-A1000/RX-A2000/RX-A3000 thread - Page 299 - AVS | Home Theater Discussions And Reviews
 6Likes
post #8941 of 8954 Old 02-23-2015, 03:16 PM
Cravit8's Avatar
Quoted: 701 Post(s)
Liked: 389
Originally Posted by calincole View Post
Awesome, thanks man. Sorry to bring it up again, but 298 pages was a little intimidating to search through. I appreciate the help.
At 298 pages, I don't think you would have found your answer in a timely fashion even with searching keywords.
I'm happy to answer questions about weird lesser-known troubleshooting facts not documented in the manual. I kind of refuse to tell someone how to save Scene.
PSN: Cravit8
XBL: oOo_Crav_oOo
Cravit8 is online now
post #8942 of 8954 Old 02-23-2015, 05:39 PM
mickey79's Avatar
Guys,
Does anyone know if it's possible to output video through the Component ports, if you have an HDMI input from a device? In other words, if I connect my blu-ray player to the RX-A2000 using HDMI, can I use the Component output to connect to my TV and get the signal?
7.1: Polk RTi12 Fronts, RTi8 Surrounds, Monitor70 Surround Backs, CSi A6 Center + Outlaw LFM-1 EX Subwoofer.
Yamaha RX-A2000 AVR
Epson 5010 3D Projector
Intel Sandy Bridge 3D HTPC / Blu-ray Player
mickey79 is online now
post #8943 of 8954 Old 02-23-2015, 08:05 PM
kriktsemaj99's Avatar
Quoted: 277 Post(s)
Liked: 196
No, there's no HDMI to component conversion. On the plus side, time for a new TV .
kriktsemaj99 is online now
post #8944 of 8954 Old 02-24-2015, 07:56 AM
Arbypb's Avatar
Originally Posted by kriktsemaj99 View Post
^ Not quite sure what you mean. Can you explain the problem in more detail?
I want to split the signal form HDMI out of a bluray player to my RX-A 1000 and the other end directly to the tv.
The signal works ok to the tv however the signal to the receiver does not show up on the tv.
I am thinking there is some type of copyright blockage?
I am doing this so that the receiver does not have to be on and then I can watch Bluray directly through to the tv using my sound bar.
Also in an unrelated question, I am using the receiver to listen to the tv sound via Toslinkk optical from the tv.
I noticed that the receiver is only allowing me to listen in the straight mode,. So I can not use any surround processing.
I hit the straight button on the remote repeatedly or hit the surround button and nothing changes it out of the straight mode.
Is this normal??
Thanks!!
Arbypb is offline
post #8945 of 8954 Old 02-24-2015, 08:33 AM
Cravit8's Avatar
Quoted: 701 Post(s)
Liked: 389
Is this normal??
Thanks!!
Does the 1000 not have HDMI passthrough like the 2000/3000?
I would think it does.
Man I wish I could find a 1000 or 1010 for super cheap.
PSN: Cravit8
XBL: oOo_Crav_oOo
post #8946 of 8954 Old 02-24-2015, 01:50 PM
Ovation's Avatar
Quoted: 43 Post(s)
Liked: 30
It does. At least my A1000 does (though I don't use the feature, I've read about in the manual).
Ovation is online now
post #8947 of 8954 Old 02-24-2015, 03:29 PM
Quoted: 277 Post(s)
Liked: 196
You can do that without a splitter if you enable "Standby Through" in the receiver. This means that when you turn off the receiver it automatically passes one HDMI input (whichever one you select) through to the TV.
Is this normal??
No idea what's happening in this case. You should be able to select different modes.
post #8948 of 8954 Old 02-24-2015, 03:40 PM
Arbypb's Avatar
Thanks!! I will give it a try. Just returned my HDMI splitter to Sewell. A great mail order place for well made inexpensive wires and connections.
Arbypb is offline
post #8949 of 8954 Old 02-24-2015, 03:41 PM
Arbypb's Avatar
Thats what I thought. I may unplug the receiver to reset it and see if that helps.
Otherwise may have to do a factory reset. Yikes. will then have to reset my 30 fm and HD FM presets.
Arbypb is offline
post #8950 of 8954 Old 02-25-2015, 01:40 PM
Arbypb's Avatar
I bought a refurbished 1000 from accessores4less.com for $499. Pretty good deal.
Arbypb is offline
post #8951 of 8954 Old 02-25-2015, 03:47 PM
in3rtia's Avatar
Quoted: 76 Post(s)
Just keep an eye on craigslist. I got my 2000 for $425 almost two years ago
Cravit8 likes this.
in3rtia is offline
post #8952 of 8954 Old Yesterday, 10:57 AM
mickey79's Avatar
My situation is different, doesn't demand a new TV. I have the Epson 5010 Projector and we have two XBOX One's in the house; my wife's & mine. We both like to play co-op multiplayer with each other. Right now we have the two consoles in two different rooms, but want to get them together in one room so we can sit side-by-side. This can be effectively achieved in our Home Theater with Projector displaying Split-Screen, side-by-side displays. I have a 106" Screen so the two displays come out around 50" (diagonal) each which is perfectly acceptable to us for gaming. It's like having two 50" TV's side by side.
Anyhow, the Projector, just like any others I know of, does not split-screen on 2 HDMI Inputs; however, it does 1 HDMI and 1 Component brilliantly (Tested with my XBOX One on HDMI and XBOX 360 on Component).
We plan to pass one XBOX One via HDMI to the HDMI Input, and the other by converting the HDMI -> Component, to the Component Input. This way we'll get both consoles side-by-side on the screen.
HDFury has the Gamer-to-Component device for $150 that works with XBOX One effectively, and is going to be our most likely solution. However, before I pull the trigger on that, just want to explore all possible cheaper solutions. Thought I'd try this. Doesn't look like it can work though.
Who was your response aimed at? Lots of questions in this thread. You gave no indication who you're replying to.
Yamaha RX-A2000 AVR
post #8953 of 8954 Old Yesterday, 03:14 PM
Cravit8's Avatar
Quoted: 701 Post(s)
Liked: 389
Ovation was replying directly above him, it's not always necessary to quote.
I know the HDMI HDCP can be bypassed on the Playstation 4 if one needs HDMI to DVI, FYI. Maybe Xbox One can do the same.
Your entire scenario doesn't seem to have much to do with the AVR side.
PSN: Cravit8
XBL: oOo_Crav_oOo
post #8954 of 8954 Old Today, 08:56 AM
Ovation's Avatar
Quoted: 43 Post(s)
Liked: 30
Really? How about the post just above mine (which, incidentally, is very easily decipherable just by reading the posts in consecutive order and is the most logical way of reading my response, since I didn't quote something else)? You know, the one that asks:
