The Official Marantz SR7005 Receiver Page!! - Page 49 - AVS Forum | Home Theater Discussions And Reviews
 15Likes
post #1441 of 2644 Old 04-17-2012, 03:50 AM
jdsmoothie's Avatar
Quoted: 12078 Post(s)
Liked: 5499
Although you can manually change any speaker setting in MANUAL SETUP (p. 80), the recommendation by Audyssey is to set all speakers to SMALL (with at least 60hz or 80hz crossovers) regardless of what the AUTO SETUP sets them too. Doing so not only passes the lower frequencies to the sub which has 8x more filters than the speakers, but also increases the available headroom of the AVR.
jdsmoothie is offline
post #1442 of 2644 Old 04-17-2012, 08:16 PM
mbushnell's Avatar
I have a Marantz SR7005 that I picked up just before Thanksgiving. So far, I like it, but I'm having an issue with the audio on several TV Channels/Shows.
It is a problem that I believe (but not positive) is with the mixing of the audio in the Post Production phase of putting the show together. The issue is that the background music that is coming out of the left & right speakers is really overpowering the narration of the program coming out the center channel. This is especially true on just about all programs that I've seen on the Smithsonian & National Geographic Channels. I've also noticed it on Pro Football games on CBS & Fox, where the crowd noise coming out of the forward Left & Right channels is overpowering the announcers coming out of the center channel (but in this case, it might be a good thing)
For my speakers, I've got a 5.1 setup, NHT SuperZero's for the forward left & right, NHT VS-2 for the center, NHT SB-1's for the left & right surrounds, & a Velodyne 1512 subwoofer.
I ran the auto set-up (as described in the receiver's manual) the night that I bought the receiver, but really haven't touched the setup since then.
Any thoughts on how to correct this problem (how about complaining to Smithsonian & NatGeo)?
Thanks for any input.
Mark
mbushnell is offline
post #1443 of 2644 Old 04-17-2012, 08:23 PM
kevin_mahaney's Avatar
Liked: 26
Mark
From what you're saying, it seems like you've nailed it on the head (it's source-dependent). If you'd like to make sure, a great investment is an SPL meter. I always go back through after Audyssey and adjust/equalize the channel levels with one (and Audyssey is always off a bit in my room).
kevin_mahaney is online now
post #1444 of 2644 Old 04-18-2012, 04:15 AM
jdsmoothie's Avatar
Liked: 5499
Mark
If you have Audyssey Dyn EQ enabled, then try setting the Reference Level Offset (p. 76) to -10db.
post #1445 of 2644 Old 04-18-2012, 06:27 PM
erhurd's Avatar
Location: Buckeye, Arizona (Phoenix); USA; Planet Earth
Quoted: 61 Post(s)
Liked: 52
I purchased my new Marantz SR7005 AVR on April 2nd. The new receiver gave me the incentive to finally take my pair of aging M&K Sound MX-70 subwoofers to the shop for badly needed (reconing) service.
I set up the receiver in the meantime in the absence of the subs and have been very much enjoying the new receiver's outstanding sound and capabilities, and patiently awaited for the shop to inform me that my mini-monsters were repaired and ready to be taken home.
I just picked up the pair of subs earlier this afternoon, connected them, ran Audessey setups and did some fine tuning. I am having the time of my life! Everything if fine and sounds great. I was expecting the Audessey GUI to indicate two subwoofers in the graphic display for the Speaker Configuration. It did not; nevertheless I can feel both subs at work and I'm very happy with my setup. Still tweaking [smile]...
Edwin R. Hurd
AVS Forums Lurker-In-Training!
My Tight-space A/V Setup
erhurd is offline
post #1446 of 2644 Old 04-18-2012, 06:48 PM
m. zillch's Avatar
Quoted: 1821 Post(s)
Liked: 1167
^Although there are two sub outs on the back, they are nothing more than the output of an internal "Y cord". There is no difference in level, phase, EQ, etc.
Units that do differentiate the sub outs usually have the up scale XT32 technology which does indeed treat the two outputs differently.
In A/V reproduction accuracy, there IS no concept of "accounting for personal taste/preference". As art consumers we don't "pick" the level of bass, nor the tint/brightness of a scene's sky, any more than we pick the ending of a novel or Mona Lisa's type of smile. "High fidelity" means "high truthfulness", faithful to the original artist's intent: an unmodified, neutral, accurate copy of the original master, ideally being exact and with no discernable alterations, aka "transparency".
m. zillch is offline
post #1447 of 2644 Old 04-18-2012, 06:58 PM
erhurd's Avatar
Quoted: 61 Post(s)
Liked: 52
I read the entire thread since I made my purchase and remember you mentioning something similar in an earlier posting. That's what kept me from becoming perplexed; thanks for reminding me. I wonder what other AVRs utilize the XT32 technology? Thanks for your reply M. Zillich; I have enjoyed your presence throughout this thread!
Edwin R. Hurd
erhurd is offline
post #1448 of 2644 Old 04-18-2012, 08:32 PM
m. zillch's Avatar
Liked: 1167
^The Denon AVR4311 and the pretty similar A100 have XT32 and are part of the same "Denon and Marantz" family.
XT32 has higher resolution filters than XT, especially for the bass, so it is "better", however I concocted a time consuming procedure to set the level and phase ("distance") of two differently placed subs using the computer assistance and microphone of XT alone, not XT32 , which I describe here, should you be interested.
post #1449 of 2644 Old 04-18-2012, 11:24 PM
jdsmoothie's Avatar
Liked: 5499
In addition to the Denon 4311CI and A100, XT32 is also currently offered on the upper level Onkyo and Integra models. Of the new 2012 models, it will be moving down to the Onkyo 818.
post #1450 of 2644 Old 04-20-2012, 01:22 AM
smaragd's Avatar
Originally Posted by jsechler View Post
tried to do the free firmware update and at 07 minutes to go the sr7005 shut down and rebooted for a retry and the stated the failure code B4. any ideas? i reset the unit twice.
Had the same issue first when upgrading the firmware on the day I bought the SR7005 last week. It looped through the "Firmware Update" rebooting several times and retrying the update. Unplugging didn't help.
Solution: I unplugged the Ethernet cable from my router's WAN port (normally feeding into the router) and plugged it directly into the SR7005, literally bypassing the router. The SR7005 got connected to the Internet and did the firmware update without problems this time.
This makes me think that certain routers may be blocking the ports needed to contact Marantz servers where the updates are pushed.
smaragd is offline
post #1451 of 2644 Old 04-20-2012, 01:25 AM
smaragd's Avatar
For those with Android devices and with a NAS connected to their SR7005, I found a nice remote app that works much faster than the internal GUI or AVR-remote app.
I now use BubbleUPNP which even shows album art on my Galaxy Note.
http://www.google.com/url?sa=t&rct=j...wFXMJnJsP3GIkg
smaragd is offline
post #1452 of 2644 Old 04-21-2012, 06:24 PM
HeadRusch's Avatar
Quoted: 119 Post(s)
Liked: 90
Guys, QQ: I'm contemplating finally upgrading my ancient Marantz SR7000 (circa 1998 I think, no digital video switching, etc) to the SR7005......is this receiver still viable, or is Marantz expected to announce 2012 models in the not too distant future?
Thanks in advance.
Xbox Live / PS3 / Steam: HeadRusch1
Keeping the world safe from the evil antics of Bernie Tanaka and Mel Fujitsu since 1986
HeadRusch is offline
post #1453 of 2644 Old 04-21-2012, 06:39 PM
jdsmoothie's Avatar
Liked: 5499
D&M Holdings should be making a public announcement of the new Marantz models sometime next month.
post #1454 of 2644 Old 04-21-2012, 06:43 PM
HeadRusch's Avatar
Quoted: 119 Post(s)
Liked: 90
*sigh*....I was so close to ordering one too......probably better to wait. I really need the dual HDMI outputs of the 7005, but I don't necessarily need 125wpc, my current Marantz feeds 105wpc and its deafening in my room.....but I need to upgrade, maybe if that feature trickles down into one of the mid-tier models I can save a few dollars.
thx.
post #1455 of 2644 Old 04-21-2012, 06:45 PM
jdsmoothie's Avatar
Liked: 5499
Last year's 6006 also has dual HDMI outputs. Also note that unless you have difficult speakers to drive, that "deafening" volume is likely achieved with < 5W/CH.
post #1456 of 2644 Old 04-21-2012, 06:53 PM
HeadRusch's Avatar
Quoted: 119 Post(s)
Liked: 90
Right, my point was I don't need 125wpc, its an empty number....the price premium isn't really worth the uprated amps for me, one of the things you're paying for is that marketing, I'm looking more at features at this point. I'm driving 14 year old Monitor 9's and Monitors/Atoms by Paradigm in a 5.1, hardly difficult.
I was going to upgrade, but I think...with new product on the horizon....maybe I'll just drop $50 on an HDMI amp and use my HDMI switch a while longer, see what the feature sets look like on the new A/V Receivers. I'd thought, foolishly for a moment, of going separates but I'm not hardcore enough for the expenditure......although it was fun to window shop for Krell components..."I'll sell my car, get an amp, sell the other car, get a pre-amp"
post #1457 of 2644 Old 04-29-2012, 05:15 PM
llep64's Avatar
Quoted: 83 Post(s)
My 7005 whent into standby mode and now it looks like is it's going to turn on I can see the screen showing the volume but then it turns off and the red light starts blinking! Did I fry it?! All I did was to take the cables of one of my speakers and then it turned off..... Man any ideas guys maybe a reset? How do I reset it?
llep64 is offline
post #1458 of 2644 Old 04-29-2012, 06:34 PM
m. zillch's Avatar
Liked: 1167
^You are most likely shorting two of the speaker wires together. This is a common pitfall of using spade lugs, single banana plugs, or bare stripped wire (instead of dual banana jacks); when you disconnect a speaker and let the wires fall to the floor, the red and black touch and cause a dead short.
Most modern amps go into protection mode when this happens but hopefully once you remedy the situation the unit will come back to life. If however the rcvr goes into this off mode all by itself even when all your speakers are disconnected from the back, then I'm afraid you need to send your unit in to service.
post #1459 of 2644 Old 04-29-2012, 08:33 PM
llep64's Avatar
Quoted: 83 Post(s)
Well I unplugged all the cables and pulled the receiver out and still not working .... I wonder what can be.... I don't know if I should let it sit there for a while and try later but I think I think it might need service an d the worst of it is that I have no warranty. What to do?
llep64 is offline
post #1460 of 2644 Old 04-29-2012, 08:42 PM
jdsmoothie's Avatar
Liked: 5499
Try the reset procedure listed in your Owner's manual. Repair outside of warranty is likely to cost at least $200-$300.
post #1461 of 2644 Old 04-29-2012, 08:58 PM
llep64's Avatar
Quoted: 83 Post(s)
What really gets me is that it looks like if it's going to work , I see the screen info volume etc., but then the red blinking light! Ughhhhh
llep64 is offline
post #1462 of 2644 Old 04-30-2012, 12:34 PM
jaramill's Avatar
Quoted: 14 Post(s)
My Surround Right input terminals are producing static instead of pure white noise when I do my test tones. I just found this out because I finally got my 2 surround side speakers to turn my 3.1 system to 5.1, after having the SR7005 since last Nov. But hey...that's what warranties are for. But still backlog could be about 4-6 weeks because it's at the DSP level and the whole board may have to be taken out and sent to Marantz in NJ Oh well. Better do it now than later.
jaramill is offline
post #1463 of 2644 Old 05-01-2012, 10:53 PM
kachua's Avatar
Will these Marantz SR 7005 be Made in China or in Japan? Anyone have the Chinese version? Any problem with them?
You can choose your kicks, but you don't get to choose your kick-backs.
kachua is offline
post #1464 of 2644 Old 05-02-2012, 06:05 AM
jdsmoothie's Avatar
Liked: 5499
Most likely in China, as the shift was made after the earthquake in Japan. There should be no difference in quality, rather simply the printing on the back of the AVR.
post #1465 of 2644 Old 05-13-2012, 03:39 PM
djPerfectTrip's Avatar
Liked: 29
Anybody heard of a 7006 coming out any time soon?
Turn it up!
djPerfectTrip is offline
post #1466 of 2644 Old 05-13-2012, 05:17 PM
jdsmoothie's Avatar
Liked: 5499
The X006 models were released last year. The new X007 models will be released this summer.
post #1467 of 2644 Old 05-13-2012, 05:59 PM
Liked: 29
Ah, I gotcha. I just figured they hadn't released the 7006 yet. Any word on when the new line will be released?
Never mind, just saw on a website late August.
Turn it up!
post #1468 of 2644 Old 05-17-2012, 06:31 PM
slider03's Avatar
Just got an AV 7005. Liking it except the little door on the front does not want to close. Any ides?
slider03 is offline
post #1469 of 2644 Old 05-17-2012, 07:18 PM
m. zillch's Avatar
Liked: 1167
Warranty time, my friend.
Many of these sorts of doors are on their hinge via a snapped on "C" shaped section, one at both ends, with the "C" clicked around a cylinder, but if you don't know what your are doing it could get even worse and you might break the hinge entirely {they might deem that "abuse" and not cover you, is the problem with trying yourself}
edit to add: you didn't remove the four feet by any chance, did you? That could be your problem right there.
post #1470 of 2644 Old 05-17-2012, 08:00 PM
slider03's Avatar
Thanks, did not remove the feet. I had it installed by a pro who wanted to remove the feet to make it fit in my cabinet on a different shelf. I said no. He is coming back to do some more remote programing and I will have him address this. He works at the place I bought the unit from.
slider03 is offline
Marantz , Marantz Sr7005 Audio Video Receiver Black
