The Official Marantz SR7005 Receiver Page!! - Page 52 - AVS Forum | Home Theater Discussions And Reviews
 16Likes
post #1531 of 2649 Old 05-26-2012, 04:00 PM
woodsart's Avatar
Hey guys, anyone experienced downloading airplay with ethernet issue. Seems shows up as "1GB ethernet" Obviously it is not upgrading, but won't stop....any suggestions? Internet/wireless seems to be fine.
Checked connections, etc. etc.
Can't get it downloaded and can't get out of it.
woodsart is offline
post #1532 of 2649 Old 05-26-2012, 04:50 PM
jdsmoothie's Avatar
Quoted: 14326 Post(s)
Liked: 6764
Disconnect the power cord ... wait a few minutes, plug it back in and power the AVR back on. The update should continue at that point.
jdsmoothie is offline
post #1533 of 2649 Old 05-26-2012, 05:16 PM
woodsart's Avatar
Thank you Jds, but even ethernet being 1gb that would work?
woodsart is offline
post #1534 of 2649 Old 05-26-2012, 05:18 PM
jdsmoothie's Avatar
Liked: 6764
Your choice is either to give it more time to complete the update or unplug it. You asked out to "make it stop".
post #1535 of 2649 Old 05-26-2012, 05:21 PM
woodsart's Avatar
It is still unplugged at this point, however, jds, it was doing this for 2 hours last night over and over again. 6%, 5% then 4 then starting over.
plugged in back in and at this point says update retry.
Oh, didn't see that, yes is there a way to cancel the upgrade?
woodsart is offline
post #1536 of 2649 Old 05-26-2012, 05:28 PM
jdsmoothie's Avatar
Liked: 6764
By "making it stop", I was referring to getting it out of it's loop which can be done by unplugging the unit. If it stays in a loop, then you'll need to follow the microprocessor reset procedure listed in your Owner's manual and see if that resolves the issue. If you haven't yet used the WEB CONTROL feature to SAVE the config file to a PC, suggest doing so before doing the reset so it's easier to return to your current configuration to include Audyssey settings. Also, good idea to use Notepad or a hex viewer to ensure the file isn't all zeroes as well.
post #1537 of 2649 Old 05-26-2012, 05:30 PM
woodsart's Avatar
Then follow the microprocessor reset procedure listed in your Owner's manual and see if that resolves the issue. If you haven't yet used the WEB CONTROL feature to SAVE the config file to a PC, suggest doing so before doing the reset so it's easier to return to your current configuration to include Audyssey settings. Also, good idea to use Notepad or a hex viewer to ensure the file isn't all zeroes as well.
I did try the microprocesser reset, but the upgrade booted me out!
Suppose I could try it one more time, maybe it will be willing!
And, could be a heavy demand on AirPlay downloads?
I did accomplish the microprocesser reset, but still attempting the AirPlay update!
woodsart is offline
post #1538 of 2649 Old 05-26-2012, 06:53 PM
jdsmoothie's Avatar
Liked: 6764
Doubt there's a heavy demand on the Airplay download as the AV/SR7005 have been out for 2 years now.
post #1539 of 2649 Old 05-26-2012, 06:59 PM
woodsart's Avatar
Thanks, will call Tech Support on Tuesday!
woodsart is offline
post #1540 of 2649 Old 05-27-2012, 03:44 AM
tiger6969's Avatar
Most likely you have the front main speakers set as LARGE ... so reset them to SMALL with 80hz crossovers and the lower bass from CD audio will pass to the sub.
Perfect, fixed it thanks very much!
tiger6969 is offline
post #1541 of 2649 Old 05-27-2012, 06:27 PM
Cafeine's Avatar
Same problem with the firmware update. Loop (amp restart, display "SR7005 Upgrade" as name, never noticed that before. Then try again to update. I did reset the network card, lost all the settings in the process... I can't believe a stupid firmware upgrade PUSHED to the user fails like that. Well, I'm out of the loop but I would love to actually UPGRADE and be done with it before doing all my settings again. :x
Cafeine is offline
post #1542 of 2649 Old 05-27-2012, 07:08 PM
woodsart's Avatar
Hummmm, over and over again, just locked in a new cat5e cable, hopefully this would have help, but, nope started all over again. The problem is that the amp is stuck in that mode of upgrade, I can't stop it and can't watch movie, TV or listen to music, until this is solved.
I suppose the only solution is support on Tuesday.
Please tell me how you got out of the loop?
woodsart is offline
post #1543 of 2649 Old 05-28-2012, 07:54 AM
smaragd's Avatar
http://youtu.be/bYgJXlRhnEg
New details for SR7007 available sometime August 2012
smaragd is offline
post #1544 of 2649 Old 05-28-2012, 08:08 AM
jdsmoothie's Avatar
Liked: 6764
Try unplugging the AVR for a few minutes and start the update again. If still no joy, power off the AVR, and do a "network reset" ie. while pressing/holding the and buttons, power on the AVR, releasing them after 4-5 seconds (just as is done with a microprocessor reset).
post #1545 of 2649 Old 05-28-2012, 09:00 AM
woodsart's Avatar
With pure direct and up arrows on the remote and standby on on the receiver is awkward, regardless did not work! with the remote standby button or receiver.
woodsart is offline
post #1546 of 2649 Old 05-28-2012, 09:04 AM
m. zillch's Avatar
Quoted: 1958 Post(s)
Liked: 1244
I don't speak German, but I did catch something which I found a bit alarming. The SR-5007 is said to use "Direct Energy" which I believe is industry obfuscation jargon for "Class D amplifiers".
If the way we are going to migrate to 9, 11, 13, etc channel receivers which are still compact in chassis size, is to change over to class D amplifiers (which are smaller, more efficient, and generate less heat), count me out. [Not to say they can't be done well, but all things being equal I'd rather avoid them and stick to class A/B].
Here's a direct link to the time, around 7m 30s into the video, where the on screen graphics mention it:
http://www.youtube.com/watch?v=bYgJX...utu.be#t=7m25s
In A/V reproduction accuracy, there IS no concept of "accounting for personal taste/preference". As art consumers we don't "pick" the level of bass, nor the tint/brightness of a scene's sky, any more than we pick the ending of a novel or Mona Lisa's type of smile. "High fidelity" means "high truthfulness", faithful to the original artist's intent: an unmodified, neutral, accurate copy of the original master, ideally being exact and with no discernable alterations, aka "transparency".
m. zillch is offline
post #1547 of 2649 Old 05-28-2012, 09:39 AM
jdsmoothie's Avatar
Liked: 6764
I'm sure it is awkward ... good thing you use the buttons on the front panel of the AVR just as you would with a microprocessor reset.
post #1548 of 2649 Old 05-28-2012, 10:57 AM
Jim Griffin's Avatar
Jim Griffin is offline
post #1549 of 2649 Old 05-28-2012, 10:58 AM
woodsart's Avatar
Sorry, but it seems you were offering me another option to "microprocesser reset", but I have done that 3 times to no avail. And, it seems that "Cafiene" did something differenet to get out of the "LOOP"!
Maybe I am wrong!
woodsart is offline
post #1550 of 2649 Old 05-28-2012, 11:19 AM
djPerfectTrip's Avatar
Liked: 29
By what you said here, I don't see any reason why you would dislike class D...Why is class A/B better?
Turn it up!
djPerfectTrip is offline
post #1551 of 2649 Old 05-28-2012, 11:23 AM
jdsmoothie's Avatar
Liked: 6764
Maybe I am wrong!
What I suggested is a "network reset" which also resets the network card in addition to doing a microprocessor reset.
post #1552 of 2649 Old 05-28-2012, 11:28 AM
woodsart's Avatar
I could not do the network reset, or a least it did not work, or I couldn't tell as the Upgrading continued upon turn on.
I did understand the microprocessor reset and did so and seemed to work.
but could you in detail again explain what I am looking for...... when the netword card reset is accomplished?
Thanks, I appreciate it.
woodsart is offline
post #1553 of 2649 Old 05-28-2012, 11:32 AM
jdsmoothie's Avatar
Liked: 6764
The same thing you're looking for when doing a microprocessor reset as I noted.
post #1554 of 2649 Old 05-28-2012, 12:15 PM
m. zillch's Avatar
Liked: 1244
Class D, an old design from the late 50's or early 60's which was for the most part rejected from the hi-fi world and relegated to lo-fi applications only (but has recently been much more common and has improved, some), doesn't have a well defined and nearly fixed frequency response, regardless of the speaker load it sees, as class A/B does.
Some class D amplifiers acknowledge this deficiency, er, "variability", by giving the owner a selectable filter which compensates for the expected high frequency alteration, often with crude and rudimentary positions labeled, "4 ohm", "8 ohm", etc, however this is to pacify the user into thinking it is as simple as that. It isn't (always).
post #1555 of 2649 Old 05-28-2012, 12:22 PM
woodsart's Avatar
Thanks, I will contact support tomorrow, hopefully they can resolve this.
The manual states on page 117 "Resetting the microprocesser", for reset returning to default settings.....Pressing SURROUND MODE and AUTO.
Then press and hold SLEEP and MENU for more than 3 seconds. (Without memory saving).
This hasn't worked for me. Steps 1-5 or 2-4.
woodsart is offline
post #1556 of 2649 Old 05-28-2012, 03:05 PM
Cafeine's Avatar
Maybe I am wrong!
Well, it's Caféine in fact. Yeah, french for caffeine. Whatever.
So : I just unplugged the SR7005 RJ45 from my router. No network, no update. The fact that it keeps booting with SR7005 Upgrade as name tells me it REALLY wants to do it.
Well, I'll try the REAL power off for 10min, see if something is still around in RAM. If that fails too, it will be time to bug my friend at marantz.
PS: yeah I tried Network AND processor reset. Lost all my settings, problem still here. I love to lose my time like that...
Cafeine is offline
post #1557 of 2649 Old 05-28-2012, 03:30 PM
woodsart's Avatar
Thanks, Cafeine for loggin in!
I had unplugged the cat5e cable and now able to watch bluray movies. So that helped for now, til tomorrow when I have to call marantz, but you think it might be Apple downloads?
BTW I did unplug for more than 10 min.
woodsart is offline
post #1558 of 2649 Old 05-28-2012, 03:46 PM
Cafeine's Avatar
I have the same pain, I keep watch of this thread
My connection is really good, my guess is a firmware bug or a prob server side for Marantz.
My update says 6 min then painfully reach 4 before going back to 6. My router says the dl speed is around 20kb/s ... I can dl up to 12 Mb/s... ****ing stupid we cant access the file and use an USB key to do that ****. :/
Cafeine is offline
post #1559 of 2649 Old 05-28-2012, 03:50 PM
woodsart's Avatar
Yep 6 then 5 or 4 then back to ground zero 6 again, so dumb! Going on for 3 days. Does your say "updating IMG 06min"
This was one of the few main features I wanted in this amp )>:
woodsart is offline
post #1560 of 2649 Old 05-28-2012, 04:00 PM
Cafeine's Avatar
yep, it says that :/ When the "arrows" dont show anymore, it will wait a bit, reboot and retry the whole process...
Cafeine is offline
Marantz , Marantz Sr7005 Audio Video Receiver Black
