The Official Marantz SR7005 Receiver Page!! - Page 83 - AVS Forum
post #2461 of 2477 Old 09-26-2014, 05:56 PM
scmtngirl's Avatar
sr7005 + Rega Fono issues - HALP!
Hi everyone...searched for anyone having this issue and didn't find anything so forgive me if I'm inadvertently asking a redundant question.
So here's the deal: I just purchased a Rega Fono MM to go along with my Technics 1200 mk2. However, once I get it going the sound is hugely distorted when the record is playing and when it's not, I hear a faint, pulsing hum in the speakers. I've check the interconnects...both sets (in & out) sound fine when connected directly. My TT is grounded to the sr7005.
So what am I missing? It's about the most simple device I own so I can see how I'm screwing it up but ya know how that goes.
I'm a noob at all this so any feedback from all you gurus out there would really help a girl out.
Thanks in advance!
scmtngirl is offline
post #2462 of 2477 Old 09-26-2014, 09:06 PM
m. zillch's Avatar
Quoted: 281 Post(s)
Liked: 257
The SR7005 already has a fairly decent phono preamp built in so this extra external phono preamp isn't needed. Can you return it for a refund?
Do phono preamps differ? Yes, a little, but not by much, and only by a small fraction of the amount that phono cartridges do, however by using external devices you are more susceptible to hum, hiss, and ground loops as the signal passes from one device to the next, especially with very weak signals like the tiny amount of electricity which is generated by the wiggling of your phono stylus.
Anyway, let's assume you can't return this thing and/or have been duped into thinking that "it makes a big improvement" as so many millions of other people have. You'll know that I'm right and they're wrong when on a whim you bypass this thing, using the phono stage already built in, connect the turntable plugs and ground to the back of the SR7005 directly, to the input called "phono" of course, and suddenly have none of the problems you are currently experiencing.
The correct signal path, if you insist on using the external phono stage, is to connect the turntable's ground wire to it, not to the Marantz, and then the output of that phono box goes to any unused input on the Marantz EXCEPT "phono".
In A/V reproduction accuracy, there is no concept of "accounting for taste". We don't "pick" the level of bass any more than we get to pick the ending of a play. High fidelity is an unbiased, neutral, exact copy (or "reproduction") of the original source's tonal balance, timing, dynamics, etc..
m. zillch is offline
post #2463 of 2477 Old 09-27-2014, 11:10 AM
scmtngirl's Avatar
Well, I'm now forced to have a longer cable run than is optimal so I figured this would help. I've been running my TT directly to the phono stage of the sr7005 for a couple of years and even at shorter runs the sound is decent but I have to really crank up the dB's, obviously. The issue here is that my room configuration no longer allows the TT to sit close to the receiver.
Anyway, I'll try your suggestion of hooking it up to a different input to see if that takes care of the problem. I appreciate your feedback!
post #2464 of 2477 Old 10-02-2014, 10:08 AM
keenly's Avatar
I need a new remote for this receiver; why could I get one from.
keenly is offline
post #2465 of 2477 Old 10-02-2014, 10:25 AM
585-645-1006
jdsmoothie's Avatar
Quoted: 1477 Post(s)
Liked: 1615
Directly from Marantz. Although likely better served with a Harmony remote which could then likely control ALL of your devices.
"JD" – jd@avscience.com ; shop.avscience.com ; 585-645-1006, AVScience - Authorized dealer for AVRs, Speakers, etc.
Daily 8am – 8pm EST (Sat/Sun too if you leave message)
Call for pricing - Denon, Marantz, Yamaha, Pioneer, Onkyo, Def Tech, Atlantic Tech, Oppo
** Think the AVR is defective?  Reset the microprocessor 4-5 times.
jdsmoothie is online now
post #2466 of 2477 Old 10-15-2014, 09:33 AM
Gsaraco's Avatar
My receiver is ALMOST back from repair, so I am preparing for its return. I'd like to use banana plugs to tidy things up in the back. However looking around the web, I see that the SR7005 has some sort of caps in the terminals. Is it easy to get those off? I read one account of someone who took a drill them, which sounds crazy. Then someone else said you can just screw off the top of the terminal and the cap falls right out from the inside. Which is closer to the truth?
Also, are any particular types of banana plugs recommended or advised against?
Gsaraco is offline
post #2467 of 2477 Old 10-15-2014, 10:29 AM
585-645-1006
jdsmoothie's Avatar
Liked: 1615
The caps only apply to European models. Not the case for the USA models.
post #2468 of 2477 Old 10-15-2014, 01:26 PM
m. zillch's Avatar
Quoted: 281 Post(s)
Liked: 257
Some products which have plastic caps on their banana holes are nothing more than plugs with a domed top you can easily pry/pull out with long finger nails, although I can't say for sure this is the style you have.
post #2469 of 2477 Old 10-15-2014, 02:08 PM
Gsaraco's Avatar
Thanks for the feedback. My SR7005 is a U.S. model, so sounds like it might not even be an issue.
Any reason for me to go for Sewell's "Silverback" banana plug over this "Deadbolt" model? I prefer the low-profile design of Deadbolt, but the company claims a better connection with Silverback. I'm like 99% sure it's just marketing spin that I don't need to worry about, but I was wondering if anyone could give me a good reason backed by experience.
Gsaraco is offline
post #2470 of 2477 Old 10-15-2014, 04:34 PM
m. zillch's Avatar
Quoted: 281 Post(s)
Liked: 257
I recently bought a 10 pack of red and a ten pack of black double banana jacks from Monoprice, for my speakers, and they were a great deal, including the shipping.http://www.monoprice.com/Product?c_i...seq=1&format=2
post #2471 of 2477 Old 10-21-2014, 07:23 AM
Gsaraco's Avatar
Thanks for the tips all. Got banana plugs on everything now, because my receiver is finally back!! It's so sweet after nearly 3 months of TV sound only... gah!!
I celebrated by upgrading to 7.1, so I've got two new satellites in the back of my room now. I'd like to get the most out of them. Is there an option that allows them to be used with 5.1 material? So that, for example, audio for the Left Surround channel could be heard from the Back Left Surround speaker as well?
I'd also like to sometimes have stereo sound mirrored by the surround speakers, to have music playing throughout different parts of the room - I am assuming there is a "surround stereo" mode that does something like this? I looked through the manual and saw the fader options, but that sounds like it switches the 2.0 material to a different pair of speakers, rather than playing in all speakers simultaneously.
Gsaraco is offline
post #2472 of 2477 Old 10-21-2014, 07:32 AM
585-645-1006
jdsmoothie's Avatar
Liked: 1615
The DD PLIIx surround mode will simulate 7.1 from 2.0, 2.1, and 5.1 audio.
post #2473 of 2477 Old 10-21-2014, 11:09 AM
m. zillch's Avatar
Quoted: 281 Post(s)
Liked: 257
DD PLII will still have a front soundstage though. If the intent is more to have an even distribution of all the music from all speakers, good for people walking about the room during a party facing in random direction, say, MULTI CH STEREO might be a better bet. It even gets center stage information, for instance the lead vocals and movie dialogue (both almost always reserved for the center channel), into all the speakers from a stereo 2ch source.
post #2474 of 2477 Old 10-21-2014, 11:18 AM
585-645-1006
jdsmoothie's Avatar
Liked: 1615
Agreed. I much prefer using Multi CH Stereo.
post #2475 of 2477 Old 10-21-2014, 11:49 AM
Gsaraco's Avatar
Great answers guys, thanks.
Gsaraco is offline
post #2476 of 2477 Old 10-21-2014, 01:06 PM
erhurd's Avatar
Location: San Diego County, southern California, USA, Planet Earth
Quoted: 36 Post(s)
Liked: 40
Neural is yet another option to consider; it is very similar to MULTI CH. All seven channels engaged without any tinny-sounding, echoey effects.
Edwin R. Hurd
AVS Forums Lurker-In-Training!
My Tight-space A/V Setup
erhurd is offline
post #2477 of 2477 Old 10-22-2014, 10:45 PM
redsandvb's Avatar
Anyone know if the SR7005's HDMI ARC input is able to accept Dolby Digital Plus?
Wondering why my TV's Netflix app gets standard DD instead of DD+. I was told it can output DD+...double checking on that, too.
Anyone get DD+ thru HDMI ARC?
I want Ed on DVD/Blu-ray!
redsandvb is offline
Marantz , Marantz Sr7005 Audio Video Receiver Black
