The Official Marantz SR7005 Receiver Page!! - Page 87 - AVS Forum | Home Theater Discussions And Reviews
post #2581 of 2594 Old 05-23-2015, 12:00 AM
585-645-1006
jdsmoothie's Avatar
Quoted: 4429 Post(s)
Liked: 2380
Originally Posted by Sanjay View Post
Given that I have connected my TV & SR7005 as shown below, why am I not able to get any audio via ARC to the receiver from material streamed on the TV? Is there any particular input that has to be selected on the receiver to get the audio? Any help is appreciated.
Connection between TV & Receiver:
(Marantz SR7005) HDMI Monitor Out 1 (ARC) <--> HDMI 3 (ARC) (Samsung 64F8500 TV)
In addition to connecting the HDMI cable to each of the HDMI ARC jacks on the TV and AVR, there are specific settings on each component that must be set as well.
TV - a. HDMI-CEC (ie. Anynet+ on Samsung TVs) set to ON. b. TV audio set to "external speakers."
AVR - HDMI Control set to ON.
Power off both components. Power on the TV. Power on the AVR. If HDMI(ARC) is working correctly (which isn't always true especially with Samsung TVs), the AVR will automatically switch to the TV audio source. If it doesn't work, the work around is to connect an optical cable from the TV to the OPT1 input on the AVR and manually select the TV source on the remote when you want to listen to the TV's smart app audio.
"JD" – jd@avscience.com ; http://shop.avscience.com/ Call for sales info --> 585-645-1006
Daily - 8am to 8pm EST
AVScience sells Denon, Marantz, Yamaha, Pioneer, Onkyo, Def Tech, Oppo, and more
** Think the AVR is defective?  Reset the microprocessor 5 times.
jdsmoothie is offline
post #2582 of 2594 Old 05-23-2015, 12:35 PM
Scott Oakley's Avatar
Quoted: 18 Post(s)
Liked: 80
Are you getting audio from the TV speakers? If so, there may be a setting in the TV's menu settings to select Home Theater Speakers, or some such nomenclature. I had to do that on my Panasonic TV.
Panasonic 2013 55VT60
Marantz SR-5005 AVR
B&W 805 Speakers
Velodyne 15" Sub
TiVO Roamo OTA
Scott Oakley is offline
post #2583 of 2594 Old 06-04-2015, 10:40 AM
J`eremySt's Avatar
Liked: 0
I have the same issue. I just got a Sony XBR65X850b. No matter what i do, I cannot get the ARC function to work on my SR7005. the Sony sees the SR7005 in the Bravia settings, and the CEC functions seem to work, but i cannot get the audio from netflix to play on the Marantz. IF it was working, what would happen? would the the Marantz front panel say "TV" or something?
J`eremySt is offline
post #2584 of 2594 Old 06-04-2015, 10:41 AM
585-645-1006
jdsmoothie's Avatar
Liked: 2380
If it was working, the AVR would switch to the TV Audio source a few seconds after the AVR is powered on.
post #2585 of 2594 Old 06-04-2015, 11:04 AM
J`eremySt's Avatar
Liked: 0
and what would the front of the Marantz display?
post #2586 of 2594 Old 06-04-2015, 11:48 AM
585-645-1006
jdsmoothie's Avatar
Liked: 2380
The same as if you just manually select "TV" from the remote control.
post #2587 of 2594 Old 06-27-2015, 12:14 PM
Trond-Eirik's Avatar
Hi
I'm having a problem with my receiver (Marantz SR7005) and wonder if anyone has experienced the same.
See the attached picture to see how my setup is.
The problem I'm experience is that the projector suddenly goes black. I'm actually not sure if the sound always goes off or if it's just sometime. I think the sound usually also goes. This can happen after a random time of use. From quite short time to several hours. I think that it most often happens after long time of use. Sometimes (quite often) it does not happen at all.
It is not the projector that is the problem. If I for example opens the projectors menu it shows just fine.
It is not the source that is the problem. It happens for all sources, even for the wii that is connected using component input.
If I turn the receiver off, wait a few seconds and then turn it on again, I will often - but not always, get the picture back.
Often the picture will just be away for a few seconds and the come back on again by itself, but other times it will be away for a long time.
I have no way to reproduce the problem. It seems like it might happen often in periods and then again there may be no problem for a long time. It's very irritating and of course not very impressive to invite friends and family into the "movie theater" and then, in the middle of a great movie, suddenly only have a black screen to show them. Quite embarrassing.
Would love to hear if anyone else is or have experienced something like this, and if they found a solution.
Trond-Eirik is offline
post #2588 of 2594 Old 06-27-2015, 12:45 PM
Quoted: 18 Post(s)
Liked: 80
Hello,
Is this a new problem after a long period of normal operation or something that's happened since day one?
If it were me, I'd do the following, one at a time and check results:
1. I would consider resetting the AVR (see owners manual).
2. If the issue continues, I'd connect the AVR to a TV with a shorter HDMI cable and see if the problem manifests itself.
3. Disconnect one source at a time and see results.
Scott
Marantz SR-5005 AVR
B&W 805 Speakers
Velodyne 15" Sub
TiVO Roamo OTA
post #2589 of 2594 Old 06-27-2015, 02:04 PM
m. zillch's Avatar
Quoted: 534 Post(s)
Liked: 358
Originally Posted by Trond-Eirik View Post
I'm having a problem with my receiver (Marantz SR7005) and wonder if anyone has experienced the same..
I have the preamp version called the AV-7005 and have had two different Panasonic projectors, and although the problem is less frequent on the newer one, an 8000, I still have the same issue. As best as I can tell it is triggered by a scene which has a flash (or a fade to) a very bright all white frame. I discovered this because I had a recording on my DVR and whenever I repeated the exact same video sequence it would trigger the problem over and over again. There is no remedy that I know of, sorry.
Next time it happens, rewind the scene and play it over again to see if replaying the exact same video sequence triggers it in yours too, and then please report back.
In A/V reproduction accuracy, there is no concept of "accounting for taste". We don't "pick" the level of bass, etc., any more than we pick the ending of a play. High fidelity means an unmodified, neutral, exact copy (or "reproduction") of the original artist's tonal balance, timing, dynamics, etc..
m. zillch is offline
post #2590 of 2594 Old 06-27-2015, 02:49 PM
Scott: I'm not sure when it first occurred, it's quite a long time ago. I do believe that the problem has been from quite early on, and that it has survived a couple of firmware updates.
m. zillch: Thanks for your feedback - I'll remember that the next time it happens and report back here.
post #2591 of 2594 Unread Today, 02:06 PM
seanh1978's Avatar
I'm having a problem with my receiver shutting down when using zone 2. I have 2 outdoor speakers which are 2 way speakers going into a monster cable speaker selector which then feeds into zone2. Whenever i turn it up anywhere near loud the whole receiver shuts down, is there a better way of setting this up to avoid this problem ?
seanh1978 is online now
post #2592 of 2594 Unread Today, 02:14 PM
m. zillch's Avatar
Quoted: 534 Post(s)
Liked: 358
^ Are you engaging the speaker selector box's "use when driving two or more pair" protection circuit?
post #2593 of 2594 Unread Today, 07:36 PM
seanh1978's Avatar
Yes I am
post #2594 of 2594 Unread Today, 07:51 PM
m. zillch's Avatar
Quoted: 534 Post(s)
Liked: 358
shut down is usually due to excessive heat build up tripping an internal protection circuit due to too much heat generated from excess current demands. The list of causes is large:
-too many speakers with or without external protection circuits being engaged
-too loud
-to much deep bass [that's one of the reasons adding powered subs helps since it lessens this burden]
- a partial short in the speaker or speaker wire
You might see if driving just the most distant pair all by itself still triggers the shut down or not. That wiring, being the longest, has the greatest likelihood of failure. If it doesn't cause any problems then play all the other speaker pairs individually to see if one particular set is the culprit. If none by them selves poses a problem then it sounds like you are just asking too much of the receiver and need a much stronger one [although that's a very small list] or much better: multiple outboard amps.
Marantz , Marantz Sr7005 Audio Video Receiver Black
