Subwoofer stopped working (connected to Sony STR-DG800) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 08-22-2010, 08:32 AM - Thread Starter
Try4ce's Avatar
I've had my receiver and speakers for 4 years. It's a Sony STR-DG800, and small JBL satellite speakers with a subwoofer. After I moved some stuff last weekend, the subwoofer is no longer working while connected to the receiver. The subwoofer has a LFE input, which I've always used, and left and right RCA inputs, which I've never used.
I tested the subwoofer inputs by connecting my laptop directly to it, and it definitely woofs. I checked the receiver settings, and the subwoofer was set to "Yes." I even just now defaulted my receiver settings. Still nothing. I don't know whether this "subwoofer cable" I've been using is anything special or just a marketing ploy, but for the sake of testing, I tried connecting a nice RCA cable from the subwoofer output to the LFE input... and that also did nothing, so that suggests to me that my "subwoofer cable" is likely still OK. I guess?
Anyway, I'm at a complete loss here. Audio is not my specialty, and I feel like I've troubleshot the issue as far as I can on my own.
Try4ce is offline
post #2 of 9 Old 08-22-2010, 08:45 AM
jdsmoothie's Avatar
Quoted: 12166 Post(s)
Liked: 5544
Unplug the RCA cable from the receiver and gently rub your finger over the tip to confirm the cable and sub are working properly. If you didn't make any settings changes, rather simply plugged the cables back in, then check to see if there is a microprocessor reset feature on the receiver.
jdsmoothie is online now
post #3 of 9 Old 08-22-2010, 09:19 AM - Thread Starter
Try4ce's Avatar
I just tried touching the other end of the subwoofer cable. I do get a very low hum from the subwoofer when I touch it. But plugged in, I'm still getting nothing.
As for the microprocessor reset, a quick search for "processor" over the manual PDF doesn't seem to show anything like that.
Try4ce is offline
post #4 of 9 Old 08-22-2010, 05:36 PM
samsurd2's Avatar
Since you said in the original post that you reset everything to defaults (I assume you used procedure on pg 33 of the manual), have you now gone back into "7-SYSTEM MENU" (see pg 49) to make sure that SUBWOOFER is indeed set to YES (should be since that's the default)? Also, the default for your FL/C/FR/SL/SR is LARGE so you'd need to redo those as SMALL.
samsurd2 is offline
post #5 of 9 Old 08-25-2010, 10:01 PM - Thread Starter
Try4ce's Avatar
I checked my speakers and set them all to small. Subwoofer still isn't doing its job.
Try4ce is offline
post #6 of 9 Old 08-25-2010, 10:11 PM
JChin's Avatar
Quoted: 349 Post(s)
Liked: 204
What happens when performing a manual test tone to the sub?
JChin is offline
post #7 of 9 Old 08-26-2010, 04:31 PM - Thread Starter
Try4ce's Avatar
Nothing.
Try4ce is offline
post #8 of 9 Old 08-26-2010, 05:30 PM
JChin's Avatar
Quoted: 349 Post(s)
Liked: 204
Originally Posted by Try4ce View Post
Nothing.
Is it connected to Sub Out (next to Sur L & R Pre-Out) and not Multi CH In Sub In (next to Zone 2 L & R Out)?
JChin is offline
post #9 of 9 Old 09-15-2012, 10:23 AM
liteon163's Avatar
I was running into a similar problem. Pushing the AFD button on your remote or on the receiver might help. This is how my STR-DG800 started using my subwoofer for music as well as movies.
liteon163 is offline
