$1200 to spend on processor: Get a real Pre/Pro or Reciever? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 122 Old 08-22-2010, 11:19 AM - Thread Starter
BKSinAZ's Avatar
I currently have have a Rotel RMB-1095 as my power source but would like to upgrade my Yamaha RXV-2095 reciever (over 10 years old) that I am using as a PRE\\PRO.
I only have between $1000 and $1200 to spend, but on what.. another reciever that I will only use for processing or make a jump to a real pre\\pro? What brands and models should I be considering. I can spend a wee bit more if it is an absolute must.
50/50 percent music and blu-ray watcher. 3D is not needed. Would be nice to have Burr-Brown DACs.
Also, is it worth upgrading the Yamaha reciever if my Pioneer BDP-23FD's audio is connected via the component cables (not hdmi for audio)
BKSinAZ is offline
post #2 of 122 Old 08-22-2010, 12:33 PM
stereo55's Avatar
Since you've had a Yamaha for quite awhile , I'll start with that ...
RX-V1900
or
RX-V3900
Yamaha specs/comparison here: http://www.yamaha.com/yec/compare/De..._items=5016804
Both have good reviews and the price at Amazon right now is pretty darn good .
RX-V1900 - $579.99 http://www.amazon.com/Yamaha-RX-V190...2505563&sr=1-1
RX-V3900 - $999.90 http://www.amazon.com/Yamaha-RX-V390.../dp/B001E5CDRS
I miss my old Altec 1590 monoblocks ....
stereo55 is offline
post #3 of 122 Old 08-22-2010, 12:37 PM - Thread Starter
BKSinAZ's Avatar
RX-V1900
or
RX-V3900
Thanks, but I've owned Yamaha stuff since 1985. I think it's time to move on to something new.
BKSinAZ is offline
post #4 of 122 Old 08-22-2010, 01:42 PM
bfm
bfm's Avatar
Originally Posted by BKSinAZ View Post
I currently have have a Rotel RMB-1095 as my power source but would like to upgrade my Yamaha RXV-2095 reciever that I am using as a PRE\\PRO.
If you 'only' have 1200 your choice will likely have to be a receiver. prepros are more $$$. Sad but true. I think Integra has a prepro in that price range?
For 1200 you can get some serious receivers. Electronics these days seem to be a commodity in the midfi world. Would they be better than your existing Yammy? Do you want the new hd formats? hdmi? If you don't, used could be a good option. Parasound C1?
Or stretch your budget http://www.audiogon.com/cgi-bin/cls....2155&demo&3&4&
Choices...
What are your speakers?
bfm is offline
post #5 of 122 Old 08-22-2010, 01:44 PM
MichaelJHuman's Avatar
Quoted: 266 Post(s)
Liked: 151
I think Onkyo and Integra may have processors in your range. Receivers can of course be cheaper processors than dedicated processors.
Receivers may have less output voltage than your typical dedicated processor. That could result in not being able to drive your amp to full power. I think they are often measured around 1 volt RMS.
The Yamaha RX-Z7 measured very well as a preprocessor, and might be had for $1200 on closeout (but for some reason, you are dismissing Yamaha with no good explanation.)
Whether there's an audible difference, I could not say.
"But this one goes up to 11"
MichaelJHuman is offline
post #6 of 122 Old 08-22-2010, 02:18 PM
Bill Mac's Avatar
Quoted: 1588 Post(s)
Liked: 1851
The Integra DHC-40.2 would fit within your budget.
Bill
My SACD collection and HRAudio.net Library, getting larger as my wallet gets smaller ;-).
Emotiva XMC-1, Wyred 4 Sound SX-500s, ST-500, ST-250, Oppo BDP-103/105D, Panasonic TC-P60GT50 plasma, Panamax 5100EX, Salk HT2-TLs, Salk 1801b center, Salk 1801TL (surrounds) and two Rythmik F12SEs.
Bill Mac is offline
post #7 of 122 Old 08-22-2010, 02:45 PM - Thread Starter
BKSinAZ's Avatar
Choices...
B&W 600 series speakers all the way around with a ACI Titan ll sub.
BKSinAZ is offline
post #8 of 122 Old 08-22-2010, 02:53 PM - Thread Starter
BKSinAZ's Avatar
Bill
Does the Integra have Burr-Brown DACs?
BKSinAZ is offline
post #9 of 122 Old 08-22-2010, 02:56 PM
Quoted: 266 Post(s)
Liked: 151
They are quite common. I see no reason to assume that devices which don't have them are inferior though.
post #10 of 122 Old 08-22-2010, 03:07 PM
bfm
bfm's Avatar
Nice.
bfm is offline
post #11 of 122 Old 08-22-2010, 03:44 PM
jblaschk's Avatar
For about half your budget you can get a Pioneer VSX-1120 AVR that uses the highly regarded BB PCM1691 DAC for audio and the equally regarded Marvell 88DE2750 Qdeo video processor. The Marvell is the same silicon used in the $2000 Pioneer flagship SC-37 AVR. You could use the other half of your budget to put towards a nice external amp with the VSX-1120 pre-outs.
This new 1120 model from pioneer is IMHO one of the best values in consumer electronics in quite a while. I think newegg even has it on sale right now for 499 or something which if you are ordering from outside CA is absolutely ridiculous bang for the buck in home theater kit.
jblaschk is offline
post #12 of 122 Old 08-22-2010, 04:18 PM
WiWavelength's Avatar
Quoted: 29 Post(s)
Liked: 24
Originally Posted by jblaschk View Post
For about half your budget you can get a Pioneer VSX-1120 AVR that uses the highly regarded BB PCM1691 DAC for audio...
The Burr Brown PCM1691 is "highly regarded"? How so? Not to open the age old debate over the audible differences between modern DACs w/ outstanding specs, but the PCM1691 is a monolithic 8 channel DAC, essentially a base model. One 8 channel PCM1691 costs less than many of the Burr Brown or Wolfson stereo DACs found in higher end AVRs. And those AVRs require at least four of the stereo DACs for 7.1 channel D/A conversion.
AJ
WiWavelength is offline
post #13 of 122 Old 08-22-2010, 04:46 PM
Bill Mac's Avatar
Liked: 1851
Not sure but it would not be my biggest concern.
Bill
Bill Mac is offline
post #14 of 122 Old 08-22-2010, 04:48 PM
mani's Avatar
Quoted: 65 Post(s)
Marantz is coming up with AV7005 pre pro with MSRP of 1499 and receiver with similar features for 1599. AGain these are MSRP's so you may be able to get them close to your budget. They all have HDMI 1.4 inputs. Supposedly available in Oct
mani is offline
post #15 of 122 Old 08-22-2010, 04:50 PM
mani's Avatar
Quoted: 65 Post(s)
http://us.marantz.com/Products/172.asp
Here is link for reciever . If you google AV7005 for pre pro you will get enough hits
mani is offline
post #16 of 122 Old 08-22-2010, 06:03 PM
ccotenj's Avatar
Liked: 101
while the marvell is the same as used in the 37, the sc-09 is the "flagship" pioneer avr...
agreed on the "bargain" that the 1120 appears to be... ton of "goodies" for a REALLY good price...
- chris
ccotenj is offline
post #17 of 122 Old 08-22-2010, 07:20 PM - Thread Starter
BKSinAZ's Avatar
Why do I need to buy another external amp? I already have a rotel rmb-1095
BKSinAZ is offline
post #18 of 122 Old 08-22-2010, 07:52 PM
teekster's Avatar
I have an Integra 40.1 that replaced my Rotel Rsp-1098. I have it paired with an RMB-1095. I have been impressed with the Integra pre-amp vs. the Rotel, especially at this price point. My dealer offered to let me trade it in on the Marantz AV7005 when it comes out, but I think I may stick with the Integra.
Good luck.
teekster is offline
post #19 of 122 Old 08-22-2010, 08:52 PM
Antibayi's Avatar
For that price range, I would choose an Onkyo 3007 to use as a prepro. You can use the internal amps for heights or wides.
Brian
Antibayi is offline
post #20 of 122 Old 08-23-2010, 04:12 AM
dougeee's Avatar
A "real" pre/pro is going to cost a heck of a lot more than $1200 unless you buy used.
dougeee is offline
post #21 of 122 Old 08-23-2010, 05:22 AM
mcsoul's Avatar
Quoted: 16 Post(s)
This is what I was thinking too, or add $300 and go 5007.
mcsoul is offline
post #22 of 122 Old 08-23-2010, 05:24 AM
Bill Mac's Avatar
Liked: 1851
What are the sonic differences between a "real" prepro and using a quality AVR as a prepro? The Integra DHC-40.2 at $1200.00 and the Marantz AV7005 at $1500.00 (will most likely street price for close to $1200.00) are not real prepros? As a matter of fact what is a "real" prepro anyhow?
Bill
Bill Mac is offline
post #23 of 122 Old 08-23-2010, 05:26 AM
Bill Mac's Avatar
Liked: 1851
I agree, the 3007 would make an excellent prepro.
Bill
Bill Mac is offline
post #24 of 122 Old 08-23-2010, 06:00 AM
mastermaybe's Avatar
Quoted: 435 Post(s)
Liked: 342
+1 for the 3007.
James
My Parlor and Theatre: "Jimbo's Dugout" : http://www.avsforum.com/forum/15-gen...re-parlor.html
Actual phone call (see pic to left):
 Tech (responding to laughter): "I'm sorry sir, did I miss something?"
Me: "Yeah, a case of Diet Mountain Dew walking across my living room."
mastermaybe is offline
post #25 of 122 Old 08-23-2010, 06:08 AM
mcsoul's Avatar
Quoted: 16 Post(s)
Bill
A real pre/pro is a preamp processor with no built in amplification. In theory, the lack of amplification components in the case makes for less noise and less heat (well the heat part is a fact). The noise thing is more or less up to you to hear, and if the benefit is real, the noise and more can easily be re-introduced unwittingly.
You also should get the benefit of a more powerful amp stage that should be able to reach reference levels and much higher without breaking a sweat.
mcsoul is offline
post #26 of 122 Old 08-23-2010, 06:45 AM
Mr. Brownstone's Avatar
I think he understood that already. You might go back and check the context of his statement -- someone suggested that a "real" pre/pro costs more than a (presumably) "not real" pre/pro.
Anyway, I've owned several stereo preamps and multi-channel preamp/processors, and I've never heard any sonic advantages simply because they're separate. There are some theoretical advantages as you've described (lower noise and heat, as the low-level section is isolated from the high-power section), but I can't honestly say that that manifests itself sonically.
I have a Rotel RSP-1570 these days. I dunno if it's "real" or not.
Mr. Brownstone is offline
post #27 of 122 Old 08-23-2010, 07:04 AM
Quoted: 435 Post(s)
Liked: 342
"There are some theoretical advantages as you've described (lower noise and heat, as the low-level section is isolated from the high-power section), but I can't honestly say that that manifests itself sonically."
always the key of course, and always why no one does (differentiates) in properly conducted ABX listening tests.
James
post #28 of 122 Old 08-23-2010, 07:26 AM
Bill Mac's Avatar
Liked: 1851
[quote=mcsoul;19088062]
Thanks but I'm quite aware what a prepro is. My question was to the member that posted that you need to spend more than $1200.00 to get a "real" prepro. I am wondering why he thinks that.
Both are true to a certain extent. Although I do not think anyone could hear an audible noise difference between a prepro and a quality AVR used as a prepro. As far as heat output my Onkyo 886 puts out some serious heat which is most likely from the video processor. So it is not a guarantee that you will have more heat output from an AVR compared to a prepro.
True but when using an AVR as a prepro you are using an external amp.
Bill
Bill Mac is offline
post #29 of 122 Old 08-23-2010, 07:27 AM
mcsoul's Avatar
Quoted: 16 Post(s)
I agree with both of you and I probably did misunderstand his question. I would go with a high end Onkyo 3007 or 5007 maybe the new Marantz sr7005. Put the money saved on the 7 channel amp into 2 nice subs (DSP-3400's used being on top of my list if I could find them). Unless I had money to burn then the Marantz av8003 or av7005 pre/pros look like fun. Main benefit from pre/pro....the cool gadget factor. I'm sure with the "money to burn" thrown in the mix, there are people who could dream much bigger than me and already consider the av8003 combo some kind of compromise lol.
mcsoul is offline
post #30 of 122 Old 08-23-2010, 07:31 AM
Bill Mac's Avatar
Liked: 1851
That would most definitely be a "real" prepro and a very good one at that.
Bill
Bill Mac is offline
