The "Official" Denon AVR-4311CI/AVR-A100 thread [NO PRICE TALK] - Page 103 - AVS Forum | Home Theater Discussions And Reviews
 107Likes
Old 11-09-2010, 02:21 PM
beever's Avatar
just checked, no firmware updates on my 4311
beever is offline
Old 11-09-2010, 02:23 PM
bodosom's Avatar
Quoted: 206 Post(s)
Liked: 68
Originally Posted by Biship View Post
No problems here with video or audio. Sources are HTPC via HDMI and Comcast Cable Box via HDMI; display is an Toshiba Plasma 50"
Parameters (AVR-A100):
- S/N: 0101500057
- Firm. Package Ver: 0003
- Main: 00.62
- Main ROM: 00.62
- Main FBL: 00.05
The 4311 is 09 and the A100 is a 10.
Anyway it looks like the 4311 has the potential for an update.
bodosom is offline
Old 11-09-2010, 02:26 PM
jdsmoothie's Avatar
Quoted: 12232 Post(s)
Liked: 5571
To be expected as it was released later ... so the 4311 (009 = Sep) and the A100 (010 = Oct).
jdsmoothie is offline
Old 11-09-2010, 02:29 PM
cra1g's Avatar
First mention of a firmware update.
For you 4311 owners: No comparable update notice?
I just checked. After connecting to the server, it still says "latest" with nothing in the date.
cra1g is offline
Old 11-09-2010, 02:38 PM
jdsmoothie's Avatar
Liked: 5571
I just checked with DenonJeff ....
The A100 firmware update involves some GUI issue fixes and using Party Mode Plus when networking. The 4311 is apparently not effected.
Old 11-09-2010, 02:39 PM
swedmaveric's Avatar
More importantly:
... his Main Ver # is 58 ... yours is 49
... his Sub Ver # is 28 ... yours is 25
My
Main 62
Sub 28
AVR-A100
swedmaveric is offline
Old 11-09-2010, 02:41 PM
Super Moderator
markrubin's Avatar
Quoted: 1047 Post(s)
Liked: 2300
my A-100 update failed: gave me update failure 83
so now it will stay locked in a retry mode unless I reset it and lose all my settings
this is getting tiring
please take the high road in every post:do not respond to or quote a problematic post: report it
HDMI.org:what a mess
HDCP = Hollywood's Draconian Copy Protection system
markrubin is offline
Old 11-09-2010, 02:43 PM
jdsmoothie's Avatar
Liked: 5571
swedmaverick -
Yes, it's apparent now that the A100 and 4311 will be tracking with separate firmware versions, and quite possibly your EU version might have some differences as well from the USA/CA model.
Old 11-09-2010, 02:45 PM
tallnick's Avatar
Originally Posted by WiWavelength View Post
Of course. Why would you think otherwise?
AJ
I figured as much, but from looking at the manual it looked like the only options were to pre-out the fronts, the heights, or all speakers. just clarifying before I get my 4311 shipped all the way down to nz.
tallnick is offline
Old 11-09-2010, 02:46 PM
noah katz's Avatar
Quoted: 887 Post(s)
Liked: 305
Originally Posted by batpig View Post
has anyone confirmed video degradation (e.g. changed black level) with a TEST PATTERN or some other objective source? It would be very disturbing if the HDMI pass-through is altering the image even when Video Convert is OFF! (and would support the idea that the cause is bad video hardware)
I think I've read about black level offsets w/other receivers (don't remember which).
Not a good thing, but as long as it's constant I don't think it's a big deal; readjusting black level in the display should take care of it.
Noah
noah katz is offline
Old 11-09-2010, 03:00 PM
bakerwi's Avatar
Quoted: 66 Post(s)
Liked: 44
Originally Posted by Kbueno View Post
Anyone having no problems? No blue rain or video issues?
Yes! My only challenge has been the HDMI passthrough. I'm getting sound, but no video and sometimes I'm getting video, but garbled sound. I need to revisit my settings in both the A100 and my Pioneer 151FD. Other than that; no blue rain or audio drop outs.
Willie
Basement: Oppo BDP-105D, Denon DVD-5910CI, Arcam FMJ BDP300
Master Bedroom: Sony BDP-S790
Family Room: Oppo BDP-93, Pioneer BDP-320
Breakfast Area: Pioneer BDP-320
Office: Pioneer BDP-320, Cambridge 640C V2
Revel F208 (pair), C208
bakerwi is offline
Old 11-09-2010, 03:08 PM
SeattleHTGuy's Avatar
Liked: 55
It can be a bit much to get your head around but what the manual is trying to say is, you have to pick the L/R Fronts, or Heights to go out. So, if you tell the 4311 that you are going to use external power for the fronts, you don't get amplification for the front speaker terminals. All Pres are still lit and you can plug in other speakers to your hearts content. but....... The front Pres is all ya got for your fronts no power... Make sense?
SeattleHTGuy is offline
Old 11-09-2010, 03:27 PM
tallnick's Avatar
yes, that makes sense. and thanks for the help. my question was that it didn't specify if you can select CENTER (or something like that) to specify that you are powering your CENTER channel externally (along with the fronts).
tallnick is offline
Old 11-09-2010, 03:34 PM
Vzfiosrocks's Avatar
Originally Posted by JimmyTango View Post
The issues is most likely firmware and will be fixed at a later date.
While you may think replacing it will fix the issue, i highly doubt it. Not only that, but if you think another AVR or proc will fix the issue, HDMI is a serious issue for all companies. Your best bet if you want minimal issues is to find a previous generation AVR or proc as they will have matured enough to have corrected the bugs.
After my post this morning I did replace the 4311. Prior to leaving the shop the AV tech connected the new box to a TV in their demo room, and it worked fine for 10 minutes or so (good store, the best b if you get my drift). As soon as I got home I connected HDMIs and started a burn in, and video has been clean all afternoon. I did notice the blacks on DVD upconvert from 720p to 1080p moved up a few shades towards blue-gray, so disabled convert on that feed (but am using it to upconvert Fios 1080i to 1080p fine). When I get done with work I'll connect all the audio cables as long as it behaves itself, and hopefully have a keeper (still on probation though).
General observation on the 4311 issues listed on this forum is that the folks that post are the (hopefully) small percentage that have encountered issues, so hopefully this will calm fears, but the forum also needs to be heard by Denon and responded to accordingly. The first unit I recieved demonstrated blue rain minutes into it being fired up, I firmly believe a thorough testing at site would have prevented this dead bug from being shipped. I am not too sure it is firmware addressable (think the black levels might be), earlier threads refer to bad chips. Will leave to the engineers and process folks at Denon to address their issues.
Vzfiosrocks is offline
Old 11-09-2010, 03:36 PM
Super Moderator
markrubin's Avatar
Liked: 2300
I learned something thanks to a PM from a member:
it was suggested I disconnect the RS232 control cable from my RTI processor and retry the update
I did that, and the update went through
Old 11-09-2010, 03:38 PM
Kbueno's Avatar
Just received A100 from UPS, will report back on any issues later after set-up.
Kbueno is offline
Old 11-09-2010, 03:44 PM
bodosom's Avatar
Quoted: 206 Post(s)
Liked: 68
And then you saved your config?
bodosom is offline
Old 11-09-2010, 03:55 PM
tallnick's Avatar
what is "free assign" that the 4810 has and the 4311 lacks?
tallnick is offline
Super Moderator
markrubin's Avatar
Liked: 2300
I had not done a save yet: the microprocessor reset wiped my Audyssey settings as well: but I wanted to redo it anyway: now I have to
It will be worth it having figured out the fw update issue: I had similar issues with the AVP-A1: the RS232 connection was always left in place: now I know to disconnect it
Old 11-09-2010, 04:12 PM
jdsmoothie's Avatar
Liked: 5571
When doing updates, apparently Denon AVRs treat the RS-232 jack much like a PC treats a DVD drive prior to booting up.
Old 11-09-2010, 05:12 PM
Liked: 55
Well, that's a weird issue.... No mention of this in the manual anywhere I could see. Strange....Glad you got the answer on this one...
Old 11-09-2010, 05:25 PM
noah katz's Avatar
Quoted: 887 Post(s)
Liked: 305
Really? The 4311 will power down amp channels individually?
tallnick, the reason you can't go wrong is that all of the pre-outs are always active and can be fed into external amps/speakers, irrespective of whether the internal amps are active or connected to anything.
Noah
Old 11-09-2010, 05:56 PM
tallnick's Avatar
that's the answer I've been looking for. again, thanks to everyone for clarifying.
tallnick is offline
Liked: 55
No and yes. 9 amps 11 channels. It can only power 9 so you gotta pick which 9. you can have da fronts powered or you can have da Heights. Not both. W
So, really only one amp is truly assignable and switches between heights and fronts. Look to page 94 and 95 of the manual. You can switch this amp but you can't turn it off independently.
Noahs right though, all the pre-outs are good to go.
Old 11-09-2010, 06:23 PM
mjfink's Avatar
Wow; didn't realize this beast had come out, I've been too busy working..
This has a feature that I'm really in "need" of; the ability to balance 2 subs independently. Up until now, I was looking at the SVS SubEQ and a 3311CI; would this receiver provide performance as good as that combo? I currently run 7.2 (rears, not height), and don't really need more power (I'm going to move to external amps for the front 3 speakers). However, I'm always looking more towards "integrated" rather than having more processing devices (I'd rather not have the SubEQ), so this is pretty attractive to me.
So, what do you all think? 3311 + SubEQ? Or 4311?
_____________________________________
My Onkyo 3008 (non-professional) review
http://www.avsforum.com/avs-vb/showt...php?p=19539055
mjfink is offline
Old 11-09-2010, 07:39 PM
Liked: 55
Brief response. Yep it will do 2 subs in style. Yep, it'll negate the need for the SVS SubEQ, yep it sounds great. Caveat... See recent mostly A 100 problems...
Old 11-09-2010, 07:57 PM
Liked: 55
Let's keep it fun. Since we've all determined the remote is one ugly beast and I've actually used it a bit. Anyone brave enough to admit it actually works quite well and is laid out much better than previous models. I think it's not very puuuuurty but do find it does the dirty work well and supports my Harmony 1100 nicely. So..... What do you despise and like about the thing.
Me like.... Dynamic Volume Toggle
Direct source keys, smallish size. Lit middle and upper section.
It works and makes sense.
Me no like.
squishy sort of buttons
Most important EQ and Volume buttons are not lit.
Stupid LCD panel should be a color panel and backlit better.
denon ( as should every AVR manufacturer) should just throw in the towel here and license logitech for a preprogrammed Harmony as an additional $100 option.
Old 11-09-2010, 08:06 PM
jchong's Avatar
Liked: 32
thanks batpig.
so to clarify. I DEFINITELY can power my L-R-C with an xpa-3 and let the 4311 power everything else?
Definitely. That's what I'm doing.
I too have an XPA-3 powering the LCR with the 4311 doing the surrounds.
jchong is offline
Old 11-09-2010, 08:17 PM
jchong's Avatar
Liked: 32
On the video convert setting have we definitively concluded whether to leave it ON or OFF?
I know that with it OFF I don't get the menu and volume overlays.
Also, since I mainly watch blurays which is natively 1080p will the video convert ON still be doing any processing?
jchong is offline
Old 11-09-2010, 08:32 PM
mjfink's Avatar
Do I give up anything going the 4311 route instead of the SVS + 3311? Is the SVS "better" at SubEQ, or is the 4311 using the same software/DSP?
I'm so happy this feature is making its way into receivers; it's so common to have 2 subs in larger (or crazier owners) rooms; it's really great that we can start to EQ them with the integrated units. IMHO, great bass is lacking in so many rooms; the DSP/EQs have done a great job (for a long time) on mid/high EQ, but bass is so much harder; without 2 subs (or even 4) it's very difficult to get anything approaching flat response across a room.
mjfink is offline
Audyssey , Denon Avr 4311ci 9 2 Channel Network Multi Room Home Theater Receiver With Hdmi 1 4a , Denon Avr A100 100th Anniversary 9 2 140w , Denon
