The "Official" Denon AVR-4311CI/AVR-A100 thread [NO PRICE TALK] - Page 376 - AVS Forum
post #11251 of 23296 Old 09-12-2011, 03:10 PM
ccotenj's Avatar
Liked: 89
your upgrade suggestions always have a way of hurting my wallet... my trust of your judgment (well earned trust, i might add) can cause financial pain...
- chris
ccotenj is offline
post #11252 of 23296 Old 09-13-2011, 11:02 AM
mphfrom77's Avatar
Quoted: 35 Post(s)
Liked: 120
So...how do I watch a youtube video on my laptop but listen to it through the 4311ci?
mphfrom77 is offline
post #11253 of 23296 Old 09-13-2011, 11:07 AM
batpig's Avatar
Quoted: 93 Post(s)
Liked: 894
do none of your devices (e.g. Blu-ray player or Apple TV etc.) that are already connected to the receiver support YouTube? That would be by far the easiest way.
barring that, you need some sort of audio connection to the AVR from the laptop. Easiest way is with a basic 3.5mm-to-RCA stereo cable, going from the headphone/speaker output mini-jack on the laptop to the front panel AUX inputs on the receiver.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is online now
post #11254 of 23296 Old 09-13-2011, 11:28 AM
mphfrom77's Avatar
Quoted: 35 Post(s)
Liked: 120
No, I kind of have been wanting a ATV though.
Just asked and apparently youtube videos are going to be coming to xbox with the next update, for what it's worth.
post #11255 of 23296 Old 09-13-2011, 11:31 AM
ccotenj's Avatar
Liked: 89
i use an atv, and i like it a lot... of course, i am an apple nerd...
i'm not much of a youtube user... i use it primarily for netflix and as a music streaming device...
- chris
ccotenj is offline
post #11256 of 23296 Old 09-13-2011, 11:31 AM
batpig's Avatar
Quoted: 93 Post(s)
Liked: 894
do you have a PS3? That does YouTube.
ATV is awesome if you are already in the "apple universe" with music on iTunes etc.
Setup Guide and FAQ
post #11257 of 23296 Old 09-13-2011, 11:44 AM
mphfrom77's Avatar
Quoted: 35 Post(s)
Liked: 120
I've always sortof been forced into the apple world or pwned by apple. Either way a ATV is probably a good fit for me.
post #11258 of 23296 Old 09-13-2011, 12:09 PM
bodosom's Avatar
Not all YouTube content plays on the ATV-2g with stock software. This comes up more often than I would have expected. I use optical to connect my MacBook to my 4311 although the front-panel connectors would be simpler.
bodosom is offline
post #11259 of 23296 Old 09-13-2011, 12:42 PM
mphfrom77's Avatar
Quoted: 35 Post(s)
Liked: 120
What has me interested is mainly the music videos. Duh, I just remember I am playon for life. I joined and then got away from it for a while. That plays through the xbox. But I really do not like the format. I may look into the ATV some more. Kind of a bummer considering the free airplay and all
post #11260 of 23296 Old 09-13-2011, 01:01 PM
broekh's Avatar
A software application called Airfoil will allow you to send the audio output of any other application running on your computer to an Airplay device - see:
http://www.rogueamoeba.com/airfoil/
broekh is offline
post #11261 of 23296 Old 09-13-2011, 02:19 PM
mphfrom77's Avatar
Quoted: 35 Post(s)
Liked: 120
I downloaded a trial of airfoil. I can't figure out what it wants me to do or what things are my options to play sounds through, or how it works.
post #11262 of 23296 Old 09-14-2011, 06:21 AM
ghstudio's Avatar
I just tried airfoil and it works with my 4311. When you open the screen, it should show Denon:[avr-4311CI] as one of the options. If not, you need to get the airplay code on your 4311...and get it hooked to your in home network.
Then click on SOURCES (on the top) and select your source (eg. Windows Media Player). Start WMP and then click on the music symbol aftere the Denon:[AVR...] entry.
Alternatively, RTFM
ghstudio is offline
post #11263 of 23296 Old 09-14-2011, 07:41 AM
bodosom's Avatar
To be clear, AirPlay on the Denon and Airfoil are audio only (plus artwork). If music videos are your goal then those products won't help.
bodosom is offline
post #11264 of 23296 Old 09-14-2011, 11:07 AM
DenPureSound's Avatar
Alternatively, RTFM
Will AIRFOIL serve these file types:
1.) .flac
2.) .mp3 @ 320kbps
3.) .ogg
4.) .wav
5.) .wma
6.) Windows Media Audio Lossless (WMA Lossless)
Does Airfoil support the files that you want to serve by TYPE (i.e.: Serve only .flac files)?
DenPureSound is offline
post #11265 of 23296 Old 09-14-2011, 12:12 PM
bodosom's Avatar
It doesn't work like that. You should download the relevant bits and try it out. Rogue Amoeba is big on free trials.
bodosom is offline
post #11266 of 23296 Old 09-14-2011, 12:17 PM
broekh's Avatar
1.) .flac
2.) .mp3 @ 320kbps
3.) .ogg
4.) .wav
5.) .wma
Airfoil does not by itself "serve" audio files. My understanding is that Airfoil resamples the audio output of an application that is putting out sound (which can be anything from a media player application to a web browser) and directs it to an Airplay device.
broekh is offline
post #11267 of 23296 Old 09-14-2011, 02:19 PM
DTV DRAGON's Avatar
Hey guys, was listining to some music today and for the heck of it turned audyssey off and was surprised when it sounded more fuller,I actually liked how it sounded allot better, would you suggest re-running audyssey again and maybe trying different mic placement from what I did earlier? what i have for a mic stand is basicaly something i made up to hold my mic. its my daughters music stand with a flat peice of wood ruler sticking out and the mic taped to it, yeah I know I will hear it from you guys on this lol! would you suggest getting a better mic stand?will it be that much better with a proper stand?any other info you might need please just ask.
DTV DRAGON is offline
post #11268 of 23296 Old 09-14-2011, 04:51 PM
pbarach's Avatar
Quoted: 21 Post(s)
Liked: 85
I have had to redo my Audyssey calibration several times, and each time it sounded better with Audyssey turned on than when it was off. If Audyssey is making your music sound less full, it's possible that this is because you are used to bloated midbass and Audyssey has tamed that. On the other hand, if you know what well balanced sound should be like and Audyssey is giving you something worse, then there are probably a bunch of possible reasons why it might sound less "full," including improper mic placement, not enough measuring positions, reflections from stuff in front of your speakers such as coffee tables, and a mic stand that transmits vibrations to the mic.
Most of the music stands I've seen are made of thin metal that resonates, and wooden rulers vibrate plenty--trying holding the end of a ruler flat over your earhole and tapping or scraping near the other end, or put your ear flat on the music stand and tap on various places on the stand.
FWIW, I am using a $30 camera tripod from Walmart with rubber feet that I am placing on the couch where my only listening positions are, and also on the floor in front of the couch (carpeted, wood floor, wooden frame house). Maybe I'd get better results with the mic stand that people talk about, I dunno... But I am VERY happy with the sound post-calibration.
AT&T U-Verse Northeast Ohio
Denon x4000, Samsung LED TV, B&W 704 mains, two M&K subwoofers, Oppo 103, etc.
pbarach is offline
post #11269 of 23296 Old 09-14-2011, 05:01 PM
SoundofMind's Avatar
Liked: 158
...turned audyssey off and was surprised when it sounded more fuller,I actually liked how it sounded allot better...
Is DEQ on with Audyssey and what is the MV? At low volumes, Audyssey's flat bass may sound thin compared to uncorrected room boominess. That being said, a cheap camera tripod is the minimum autosetup tool for any self-respecting forum member.
Yes, I still like playing with Dalis.
SoundofMind is offline
post #11270 of 23296 Old 09-14-2011, 09:05 PM
dasanii19's Avatar
Was curious what after market warranty you guys buy for you denon 4311ci? Id really like to buy a decent one.
MY NAME IS SUE!!! HOW DO YOU DO!!!
"I started out with nothing, and I still have most of it."
dasanii19 is offline
post #11271 of 23296 Old 09-14-2011, 09:15 PM
Hudda's Avatar
I was using a camera tripod (a very good one) until last week when I got the On-Stage boom + adapter. The tripod gave me very inconsistent results each time I ran Audyssey. The new boom stand did a MUCH better job. It's also a lot easier to use.
Chris
Hudda is offline
post #11272 of 23296 Old 09-14-2011, 09:47 PM
petetherock's Avatar
Quoted: 17 Post(s)
Liked: 27
I know price discussions are not permitted openly, but is the amazon price what I should expect?
If not can someone pm me a source?
Cheers.
petetherock is online now
post #11273 of 23296 Old 09-14-2011, 10:06 PM
tandy1000rl's Avatar
So how are folks removing the colorful Windows 7 sticker on the front of these receivers without causing faceplate damage or leaving a residue?
Very, very impressed with this receiver and Audyssey XT32. Struggled initially with some harshness in the treble and an overall lean spectrum, thinking i had a bad mic or speaker toe-in problems, until I finally investigated the phase error message I kept skipping during my numerous calibrations (who could possibly reverse such a simple connection? :-).
After checking and correcting the FL wiring, the upper bass filled in nicely and the treble became silky smooth. The dual subs sounded wonderful right out of the gate and even more so after correcting the phase error. Glad I didn't give up on this technology because it's stunning the improvement it has made over my 2003-era receiver which cost 2.5x the Denon.
Substantially improved audio performance (which is obvious, not subtle), hdmi switching, online firmware updates, web setup and control, and a street price well below the "flagship" AVRs. Well done Denon and Audyssey!
tandy1000rl is offline
post #11274 of 23296 Old 09-15-2011, 03:33 AM
Liked: 158
Cheers.
Discussion about reputable, competitively-priced authorized online reseller sources is permitted, and those has been referenced numerous times like here. As yet I seen rare mention of for much more than 20-25% off for NIB. AFAIK there is no clearance in sight, unllike with Onkyo, which has new NeoX-equipped models hitting the stores soon. IMO this baby still leads the pack in value, performance and proven reliability.
post #11275 of 23296 Old 09-15-2011, 03:43 AM
Liked: 158
I can't speak to aftermarket, though jdsmoothis has posted about those on the Denon threads. But if you are shopping for a new 4311, I strongly recommend purchasing from an authorized dealer for the valuable Denon OEM 3 yr warranty, see post above for dealers you should directly contact for pricing. Also, it's not a bad idea to use a credit card which has the "double the OEM warranty" feature on such purchases, which can usually add up to an additional year for free. BTW the A100 has a 5 yr OEM.
post #11276 of 23296 Old 09-15-2011, 03:54 AM
Liked: 158
Originally Posted by tandy1000rl View Post
So how are folks removing the colorful Windows 7 sticker on the front of these receivers without causing faceplate damage or leaving a residue?...
Hi, welcome and congrats. If it won't peel right off cleanly how bout a little alcohol or "goo-gone" on a cotton swab?
post #11277 of 23296 Old 09-15-2011, 04:09 AM
585-645-1006
jdsmoothie's Avatar
Quoted: 275 Post(s)
Liked: 1302
+1
3 years (Denon) + 1 year (credit card) = 4 years : should be more than sufficient
If yet additional peace of mind is desired, a SquareTrade warranty can be purchased from numerous distributors or directly from SquareTrade up to 90 days after purchase of the AVR.
"JD" – jd@avscience.com ; shop.avscience.com ; 585-645-1006, AVScience - AVSForum sponsor for 15 years
Mon - Fri: 8am – 8pm EST (Sat/Sun, leave message)
Call for pricing on Denon, Marantz, Yamaha, Onkyo, Klipsch, Def Tech, Oppo, Parasound
** Think the AVR is defective?  Reset the microprocessor 4-5 times.
jdsmoothie is online now
post #11278 of 23296 Old 09-15-2011, 05:28 AM
Agree but just wanted to confirm with someone who has already tried this that such chemicals will not mar the faceplate. Did you remove yours in such a fashion without incident? I also thought a blowdryer would help loosen the glue but don't want to melt anything either. Thanks!
post #11279 of 23296 Old 09-15-2011, 05:53 AM
Cheers.
PeteTheRock -- I have found to get your best price delivered there on a new 4311, call around to Denon's Authorized Dealers and see what the bottom line is delivered to your door.
Tell the salespersons that you are doing competitive quotes and are buying very soon if their price is right.
You should be down around 20-25% below Amazon's price listed now.
post #11280 of 23296 Old 09-15-2011, 06:29 AM
Drake's Avatar
I had a thought of using the hd radio on the 4211. I need to play music in another room while using the TV/SAT in the main room. Is there a way to set the 4311 up to do that? I suppose I would use zone2 or 3 but I assume that would shut off the TV/SAT. I read about these features in the manual but still not sure if my senario will work. Thanks
Drake is offline
Audyssey , Denon Avr 4311ci 9 2 Channel Network Multi Room Home Theater Receiver With Hdmi 1 4a , Denon Avr A100 100th Anniversary 9 2 140w , Denon
