The "Official" Denon AVR-4311CI/AVR-A100 thread [NO PRICE TALK] - Page 536 - AVS Forum | Home Theater Discussions And Reviews
 108Likes
post #16051 of 24648 Old 03-20-2012, 12:28 PM
markabuckley's Avatar
Quoted: 95 Post(s)
Liked: 33
for interest - what do people find their levels to be after cal (speaker levels in manual test tones) ? with my Radioshack SPL they seem rather low - about 69-70dB ?
I only checked as Audyssey set all my speakers to -ve numbers - the centre the lowest at -9dB - the fronts at -5dB etc - all seemed rather low
markabuckley is offline
post #16052 of 24648 Old 03-20-2012, 01:16 PM
digitalart's Avatar
Originally Posted by batpig View Post
yes, 150 is higher than 50
the point of maxing out the crossover (LPF) knob on the sub is to get it out of the way because the receiver is doing all the bass management digitally. You do NOT want to touch that knob after Audyssey for the same reason -- the receiver is doing the bass management.
Originally Posted by badgerpilot View Post
You can adjust the crossover for the individual speakers in the AVR, but don't touch the crossover on the sub. Leave it at 150. Also, on the AVR, you can raise the crossover on the individual speakers, just don't lower it below what Audyssey sets it at.
I didn't know that. I always thought that it only sent out a signal to the sub and I would need to adjust the cut-off frequency on the sub to my preference. So what's the point of having this adjustment on the sub? BTW I have an older Paradigm PDR-10 Powered Subwoofer.
digitalart is offline
post #16053 of 24648 Old 03-20-2012, 01:36 PM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 6779 Post(s)
Liked: 3747
Using REW and an EMM-6 mic, my levels measure approx 74dB. The important thing is that all speakers measure the same level, which tells me Audyssey is doing what it is supposed to do. Since the EMM-6 mic is calibrated using an RS SPL, I'm sure it could be 1-2 dB off.
AustinJerry is offline
post #16054 of 24648 Old 03-20-2012, 01:37 PM
Quoted: 95 Post(s)
Liked: 33
cheers - they all measure the same - just levels seem low - I may increase all the levels 4dB or so though as I've set the max level at -10dB (so kids don't turn up volume too loud) and for some programs its a bit low
post #16055 of 24648 Old 03-20-2012, 01:54 PM
IcetomLT's Avatar
Originally Posted by SoundofMind View Post
AFAIK the DL cable supplied with my DBPA100 is just a Cat5/6 cable, though there's avery special versionfor the dedicated and gullible audiophile, critiqued here.
I recently saw alternatyve products for Denon item:
http://www.audioquest.com/ethernet/cat-7-700-bulk-spool
You can go to forest or add spicies, or drink vodka, or have your presious diamond
IcetomLT is offline
post #16056 of 24648 Old 03-20-2012, 01:54 PM
pbarach's Avatar
Quoted: 331 Post(s)
Liked: 200
The RS meter is best used for checking the RELATIVE values of all your speakers (except the sub)--if all of them show the same number on the test tones (regardless of what the number is), then Audyssey set your speaker levels right. But disregard the RS meter reading for your sub--this meter is not accurate for low bass, and the available correction tables are suspect.
The level of the test tones varies with the setting of the big volume knob on your receiver. The dB reading itself is irrelevant. I usually put the meter on a tripod (accuracy is less if you're holding it) at the main listening position and pointing upward, set the meter to 70, C weighting, and SLOW, then I use the test tones and the receiver main volume control to get the test tones at the center of the meter for the left front speaker (which would be 70 dB). Then I cycle through the test tones to make sure I get the same 70 dB reading for my other non-sub speakers. Post-calibration, my speakers are all quite close to 70 dB (and the Audyssey mic is accurate +/- 2 dB, so that's as good as you can expect).
AT&T U-Verse Northeast Ohio
Denon x4000, Carver m1.0t, Samsung LED TV, B&W 704 mains, two M&K subwoofers, Oppo 103, Roku 2, etc.
Headphone system: Sennheiser HD600, AKG K701, Burson HA-160, Marantz CD5004, Denon DVD-3910
pbarach is offline
post #16057 of 24648 Old 03-20-2012, 02:16 PM
batpig's Avatar
Quoted: 3591 Post(s)
Liked: 3433
I measure about 71-72dB with the RS meter after Audyssey. I would recommend leaving it as is -- as noted above the RS meter should be accurate for *relative* levels but not absolute. In addition, the "boinks" that Audyssey uses are different than the band-limited pink noise of the internal test tones, so that could explain some of the discrepancy as well.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
post #16058 of 24648 Old 03-20-2012, 06:38 PM
russ_777's Avatar
With some of the posts in recent days about the SQ of various interface configurations between the digital source and the 4311, I decided to play with the settings on my disc player, which for the time being is a very "meh" Sony BDP-S570 (it's very good with BluRay).
I wanted to see if DSD from the 570 to the 4311 sounded better than PCM on SACDs, as some have claimed.
Unfortunately when I set the 570 to output DSD and slapped in an SACD, what I heard was a faint version of the music masked by what sounded like AM radio atmospheric noise -- i.e., not white or even pink, very unpleasant. I tried several different SACDs with the same result. The 4311 display shows "DSD DIG" when I change the 570 setting. It does fine in that setting when I insert a RBCD as it senses the absence of DSD and reverts to PCM.
Any ideas? I've probably got something set wrong somewhere.
russ_777 is offline
post #16059 of 24648 Old 03-20-2012, 06:46 PM
djos's Avatar
Quoted: 28 Post(s)
Liked: 24
try a Firmware update on your player as my Oppo bitstreams DSD over HDMI to my 4311 perfectly.
The impossible often has a kind of integrity which the merely improbable lacks.
djos is offline
post #16060 of 24648 Old 03-20-2012, 06:55 PM
russ_777's Avatar
I updated it not too long ago. A review I found of the Sony confirmed that DSD worked with whatever AVR or pre-pro they were using. So it's supposed to work. I'll check the BR player forum.
russ_777 is offline
post #16061 of 24648 Old 03-21-2012, 08:34 PM
jchong's Avatar
Quoted: 12 Post(s)
Liked: 32
Does anyone know if the 4311 will play the full Akira 24bit/192kHz soundtrack with Audyssey on?
jchong is offline
post #16062 of 24648 Old 03-21-2012, 09:39 PM
djos's Avatar
Quoted: 28 Post(s)
Liked: 24
It will, it will also allow Audyssey DSX Wides to be on for bitstreamed 5.1DSD.
djos is offline
post #16063 of 24648 Old 03-21-2012, 09:43 PM
jchong's Avatar
Quoted: 12 Post(s)
Liked: 32
Great. Thanks for the reply.
jchong is offline
post #16064 of 24648 Old 03-21-2012, 11:54 PM
netjumper's Avatar
Quoted: 14 Post(s)
I'm having a problem connecting a usb drive to the 4311 front usb port. Tried to different drives. As soon as I connect it. the receiver powers the drive for few secs then turns it off and keeps cycling. Is this not suppose to work with a usb hard drive ? Any suggestions would be great help. thanks
netjumper is offline
post #16065 of 24648 Old 03-22-2012, 03:15 AM
nevea2be's Avatar
I couldn't get mine to work either though I didn't spend a whole lot of time messing with it. I would connect it and it would power/spin up but never read as connected to the receiver. In the GUI I tried going to both the usb/ipod section and one would say no device connected while the other would just bring up my favorites list. Under connections it would just show my normal computer and directv boxes. I tired powering off then back on the receiver and still nothing.
*note* my hard drive has a regular a/c plug for it.
nevea2be is offline
post #16066 of 24648 Old 03-22-2012, 03:31 AM
wilbur_the_goose's Avatar
Quoted: 290 Post(s)
Liked: 136
For what it's worth, AppleTV is, IMHO, the perfect media player paired with the Denon 4311. Next best is Air Play with the iPad/iPod "Remote" app connected to your PC/Mac's iTunes collection.
The $99 for AppleTV is less than a "nice" remote but provides so much more functionality.
And, to me, the SQ is great.
wilbur_the_goose is offline
post #16067 of 24648 Old 03-22-2012, 03:35 AM
Answer Seeking / Sharing
cavchameleon's Avatar
Quoted: 195 Post(s)
Liked: 220
Netjumper and Nevea2be,
As far as I can recall, the USB port on the AVR is only for iPod control and USB Flash drives, not for standard hard drives. Someone correct me if I'm wrong.
Ray
"Listen with an open heart and mind."
cavchameleon is offline
post #16068 of 24648 Old 03-22-2012, 03:37 AM
Quoted: 195 Post(s)
Liked: 220
I agree, and the GUI can't be beat. We also use the ROKU XS to stream other material (Hulu Plus, etc) and the GUI is better on the Roku unit for Pandora then going directly from the AVR (you get full graphic art).
Ray
post #16069 of 24648 Old 03-22-2012, 04:41 AM
ccotenj's Avatar
Liked: 101
the usb port likely does not provide enough power to run the drive... as another poster noted, you'll likely be more successful with a powered drive... if you are already using a powered drive, then post back and we can troubleshoot...
agreed... other than sacd/dvd-a, i almost never spin the actual disk anymore... rip 'em to itunes on the mac mini, stream from there to the atv, control it all with the remote app... and away we go...
- chris
ccotenj is offline
post #16070 of 24648 Old 03-22-2012, 08:28 AM
nevea2be's Avatar
I would most likely go with the Apple TV box bot it doesn't do Amazon videos and I wouldn't mind having that on something other then my TV set so I could listen to movies in 5.1 sound.
Looked at the Roku XS and there are a lot of bad reviews out there on it. How fast is the GUI? Do you get the full 196kbs from Pandora or is it still capped at 128kbs? I found that the 128kbs version on my Denon 4311CI sounds so much better then the app on my Directv box.
I'm using a self powered LaCie Minimus 2tb with 3.0 usb drive reformatted and it doesn't show up on my receiver whether it's plugged into my computer or to the usb port in the front.
nevea2be is offline
post #16071 of 24648 Old 03-22-2012, 08:39 AM
ccotenj's Avatar
Liked: 101
how do you have it formatted? keep in mind that it will not recognize a ntfs formatted drive... only fat16/32...
- chris
ccotenj is offline
post #16072 of 24648 Old 03-22-2012, 08:59 AM
nevea2be's Avatar
I'm not sure is there a way to check? I just remember something about drives being under and over 2tb and how windows wouldn't recognize a hard drive that is over 2tb if formatted in the old standard way to do it.
nevea2be is offline
post #16073 of 24648 Old 03-22-2012, 09:01 AM
ccotenj's Avatar
Liked: 101
connect it to a pc and check the drive properties...
- chris
ccotenj is offline
post #16074 of 24648 Old 03-22-2012, 09:11 AM
nevea2be's Avatar
You couldn't find a simpler way?
It's NTFS. Is that not the standard now for larger hard drives? What are the 2-3-4tb hard drives in computer's, cable boxes formatted as?
nevea2be is offline
post #16075 of 24648 Old 03-22-2012, 09:16 AM
ccotenj's Avatar
Liked: 101
lol... sorry, i don't have my "karnac the magnificent" hat today...
well, from a windows perspective it is... but almost all cem equipment will only read fat formatted drives... my guess is that they don't want to pay for ntfs licensing...
reformat it as fat32 with multiple partitions... that oughta work...
- chris
ccotenj is offline
post #16076 of 24648 Old 03-22-2012, 09:20 AM
nevea2be's Avatar
Well considering I have over a 100MB of music on there the reformatting project will have to wait till another day.
Thanks for the help/information.
nevea2be is offline
post #16077 of 24648 Old 03-22-2012, 09:21 AM
ccotenj's Avatar
Liked: 101
on that, i do not blame you...
you are welcome... glad i could help...
- chris
ccotenj is offline
post #16078 of 24648 Old 03-22-2012, 11:27 AM
DonH50's Avatar
Quoted: 1874 Post(s)
Liked: 1403
Re. drive formatting: There used to be third-party tools that would allow you to switch NTFS to FATxx and back. I think Windows OS only allows you to go from FAT to NTFS, not back. Another suggestion is to pick up a new drive, format FAT32, and copy the music over. Then you can reformat the original and use it as backup drive.
Newest drives are going to a new sector size just to make life more interesting...
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is online now
post #16079 of 24648 Old 03-22-2012, 01:50 PM
schm66's Avatar
Quoted: 13 Post(s)
Airplay quit working for me. I installed it when it was free and tried it out but it been months since I tried. Now I do not get the airplay icon on my iphone, ipad or mac anymore. Checked the 4311 and it shows it is installed but does not function. I can connect to the 4311 with ip and that all works but airplay does not anymore. Any ideas??
schm66 is offline
post #16080 of 24648 Old 03-22-2012, 01:51 PM
60SXRD's Avatar
I think "CompuApps SwissKnife" can go both ways.
Cheers,
Jeff
LG 65UHD/Denon/OppO/HTPC/PS4/NHT/HSU/7.1
PSN: Krondorian
XBL: Midkemian
Twitter: @Krondo_jd
60SXRD is offline
Audyssey , Denon Avr 4311ci 9 2 Channel Network Multi Room Home Theater Receiver With Hdmi 1 4a , Denon Avr A100 100th Anniversary 9 2 140w , Denon
