The "Official" Denon AVR-4311CI/AVR-A100 thread [NO PRICE TALK] - Page 795 - AVS Forum
post #23821 of 23834 Old 12-22-2014, 01:36 PM
mcd4959's Avatar
Er .. no. If you turn off the main zone, you also disconnect the signal to the pre-outs as well. So you likely want to just lower the main zone volume, but raise the gain on the headphone amp.
D'oh!!! Yeah, duh, should have thought that through more. I blame Monday. Thanks again.
I love this site!
mcd4959 is offline
post #23822 of 23834 Old 12-22-2014, 01:39 PM
585-645-1006
jdsmoothie's Avatar
Quoted: 2272 Post(s)
Liked: 1828
Yup. Been there .. done that.
"JD" – jd@avscience.com ; Direct line 585-645-1006, AVScience - Authorized dealer for AVRs, Speakers, etc.
Daily 8am – 8pm EST
Call for pricing - Denon, Marantz, Yamaha, Pioneer, Onkyo, Def Tech, Atlantic Tech, Oppo
** Think the AVR is defective?  Reset the microprocessor 4-5 times.
jdsmoothie is online now
post #23823 of 23834 Old 12-22-2014, 03:00 PM
blipszyc's Avatar
Quoted: 70 Post(s)
Liked: 38
Is there a way to reset the Audyssey settings without resetting the whole AVR? I've moved to a new house and need to recalibrate the speaker settings, but don't want to lose all my other custom labels, etc.
Visit the Lipszyc Home Theater! 1.0
2.0 done and finally posted! - Theater 2.0
And now...The Queen City Theater (3.0)
blipszyc is offline
post #23824 of 23834 Old 12-22-2014, 03:37 PM
pbarach's Avatar
Quoted: 105 Post(s)
Liked: 113
Yes, it's easy; just run the Audyssey calibration in the new location once you have everything plugged in and the speakers placed and toed in where you want them. Running an Audyssey calibration doesn't change other settings not related to the speakers.
AT&T U-Verse Northeast Ohio
Denon x4000, Samsung LED TV, B&W 704 mains, two M&K subwoofers, Oppo 103, etc.
pbarach is online now
post #23825 of 23834 Old 12-22-2014, 03:38 PM
blipszyc's Avatar
Quoted: 70 Post(s)
Liked: 38
I thought the AVR saved all the individual calibrations and used them to come to the final settings? Sounds like each time we run Audyssey it starts fresh?
blipszyc is offline
post #23826 of 23834 Old 12-22-2014, 03:48 PM
pbarach's Avatar
Quoted: 105 Post(s)
Liked: 113
Yes, Audyssey has to start fresh because it's really a room correction system, not a speaker correction system. If you move your speakers to a new room (or even move them around), the interactions of the speakers with the room and its contents will inevitably change. So you have to rerun Audyssey or else live with a calibration that is irrelevant to your new location. However, your input labels and other settings in your AVR, which have nothing to do with speaker settings, remain unchanged when you run Audyssey.
Rerunning Audyssey is an annoyance, but it really isn't that complicated or time=-consumming, especially if you have a mic boom and adapter to make mic placement easier:
"Official" Audyssey thread (FAQ in post #51779)
post #23827 of 23834 Old 12-22-2014, 04:40 PM
gregavi's Avatar
I disagree. I enjoy running the Audyssey process. I do it every few months whether I need to or not.
I usually need to because I'm constantly moving something or adding something.
It used to be:"Wine, Women and Song"Now it's: "Beer, The Old Lady and TV"My Theater Build http://s1116.photobucket.com/user/Gr...?sort=6&page=1
gregavi is online now
post #23828 of 23834 Old 12-22-2014, 05:23 PM
pbarach's Avatar
Quoted: 105 Post(s)
Liked: 113
Glad it's not an annoyance for you, but the OP was worried abnout deleting all the settings if Audyssey was rerun and didn't want to do through the trouble of recalibration after a change of venue--in that situation, recalibration is a necessity, annoyance or not...
post #23829 of 23834 Old 12-22-2014, 05:51 PM
gregavi's Avatar
I agree with that. My point was, if you have to re-do it, it can be enjoyable.
post #23830 of 23834 Old 12-22-2014, 06:52 PM
pbarach's Avatar
Quoted: 105 Post(s)
Liked: 113
So can getting your teeth cleaned
post #23831 of 23834 Old Today, 07:27 AM
swilson317's Avatar
Simultaneously watching video and listening to audio from different sources
I thought this would be easy, but I am having a hard time accomplishing it. I want to play a BD video, but play audio from the DVR (Pandora) or dock. Can this be done?
Thanks, Steve
swilson317 is offline
post #23832 of 23834 Old Today, 01:15 PM
gregavi's Avatar
Thanks, Steve
Yes, but not if both sources are running through the 4311. You could run the 'HDMI out' from your BD player directly to your TV (or projector) and then use whatever source you want on the 4311. This will work. Even better if your TV has more than 1 HDMI input so you can toggle back and forth from the 4311 input to the TV with the BD input to the TV in order to monitor what the 4311 is doing. There may be other ways of accomplishing this, but I believe this is the easiest way. It cannot be done the way you want though, AFAIK.
post #23833 of 23834 Old Today, 02:30 PM
585-645-1006
jdsmoothie's Avatar
Liked: 1828
Thanks, Steve
Yup. Also connect the DVR with an optical or analog cable using the same source name as the BDP. Then with the BDP source selected change the INPUT MODE to either "Digital" or "Analog" depending on the cable you use. And voila! Video from the BDP and audio from the DVR.
Daily 8am – 8pm EST
post #23834 of 23834 Old Today, 04:18 PM
gregavi's Avatar
Good call JD. I didn't think of that.
So Steve, you've got at least 2 options.
Audyssey , Denon Avr 4311ci 9 2 Channel Network Multi Room Home Theater Receiver With Hdmi 1 4a , Denon Avr A100 100th Anniversary 9 2 140w , Denon
