The "Official" Denon AVR-4311CI/AVR-A100 thread [NO PRICE TALK] - Page 797 - AVS | Home Theater Discussions And Reviews
post #23881 of 23897 Old 01-16-2015, 09:55 PM
AustinJerry's Avatar
Quoted: 1609 Post(s)
Liked: 1020
Swap the left and right speakers. If the problem moves with the speaker, then the speaker is at fault. If the problem stays with the same channel, then it isn't the speakers.
AustinJerry is offline
post #23882 of 23897 Old 01-17-2015, 12:09 PM
dinomite's Avatar
Originally Posted by duc135 View Post
Swap the connections in the back of the receiver. IOW plug your right speaker to the left speaker output and vice versa with the left speaker. Now run the setup again. Does the setting follow the speaker (left +4 and right -3) or does the setting stay where it was at originally (left -3 and right +4)? If it follows the speaker then there might be an issue with your speaker. If it stays the same then there may be an issue with your right channel amp. Are these new speakers or a new receiver?
Thanks guys I had already tried that. Ended up resetting it, problem solved.
dinomite is offline
post #23883 of 23897 Old 01-18-2015, 02:31 PM
anilpani's Avatar
Losing OSD after Airplay
Hi, I'm experiencing a reproducible issue after using Airplay streaming from my Mac. The connection and playback is fine, however, once stopped I no longer am able to access the on-screen display.
Additionally, when cycling through sources using the source-select button on the remote and source select knob on the receiver I am unable to choose the DVR input. I am able to select the DVR input using the DVR button on the remote.
This problem occurs every time I use Airplay. The only solution I have found is to unplug the receiver for a few minutes. Once plugged back in the OSD returns as does the source select menu.
Is anyone else experiencing this? Any ideas for a lasting solution? I tried resetting the microprocessor in the past, which helped only briefly.
Pani
anilpani is offline
post #23884 of 23897 Old 01-19-2015, 07:23 AM
blipszyc's Avatar
Quoted: 87 Post(s)
Liked: 43
I'm trying to save my configuration through the web interface but my 4311 never goes into the "Saving" mode on the screen. After about 2 minutes I get prompted to save a .dat file, but it appears to be empty. All other web functions seem to work properly. Any ideas?
Visit the Lipszyc Home Theater! 1.0
2.0 done and finally posted! - Theater 2.0
And now...The Queen City Theater (3.0)
blipszyc is offline
post #23885 of 23897 Old 01-19-2015, 08:04 AM
Liked: 1020
In my experience, the success rate of the network save is higher if the network is set to "Off in Standby", rather than "Always On". Is that the setting you are using?
post #23886 of 23897 Old 01-19-2015, 08:44 AM
blipszyc's Avatar
Quoted: 87 Post(s)
Liked: 43
Thank you! I do recall from many years ago that I had to change the Standby setting to OFF to get the save to work. I currently have it set to ON. I'll try it again when I get home tonight!
blipszyc is offline
post #23887 of 23897 Old 01-19-2015, 08:44 PM
UberRob's Avatar
Hi folks -
Question for the wisdom of the crowd, which I hope will be quick:
I am trying (without success) to have analog audio output from the AVR-4311ci always on... Essentially, I am trying to pass whatever audio is being picked up by the receiver to a Sonos system, essentially so I can continue to listen to the audio channel of my video source(s) when I walk around the house.
I had been assuming that I could hijack the DVR L/R output port on the back and pass the audio out that way, but I haven't been able to find a way to pull that off.
Does anyone have any suggestions, or is that just not possible with this receiver?
- R
UberRob is offline
post #23888 of 23897 Old 01-20-2015, 01:22 AM
585-645-1006
jdsmoothie's Avatar
Quoted: 2654 Post(s)
Liked: 1903
Only possible with analog and PCM 2.0 via optical/digital coax (ie. no HDMI) when using the Zone 2 pre-outs or DVR analog out. Otherwise, connect to the FL/FR pre-outs if using STEREO mode.
"JD" – jd@avscience.com ; Call me --> 585-645-1006, AVScience - AVSForum sponsor and dealer for AVRs and Speakers
Daily 8am – 8pm EST
Call for info on Denon, Marantz, Yamaha, Pioneer, Onkyo, Def Tech, Atlantic Tech, Oppo
** Think the AVR is defective?  Reset the microprocessor 4-5 times.
jdsmoothie is online now
post #23889 of 23897 Old 01-20-2015, 05:20 AM
wilbur_the_goose's Avatar
Quoted: 44 Post(s)
I went to a high-end audio store on Saturday and listened to some McIntosh separates. They were demo'ing the Elton John 60 concert blu-ray (which I think has fantastic audio). I was pretty impressed, so I plopped the same blu-ray into my Oppo, turned on my trusty AVR-4311 (assisted by an Emotiva amp and Paradigm speakers). My wife said, "Wow - that sounds a lot better", and I tend to agree with her.
Our little AVR-4311 is still one really sweat machine
wilbur_the_goose is online now
post #23890 of 23897 Old 01-21-2015, 05:37 AM
sobi's Avatar
Wow, you must play it really loud -- my 4311 hardly ever breaks a sweat!
gsr and Johnla like this.
sobi is offline
post #23891 of 23897 Unread 01-23-2015, 04:26 AM
kgveteran's Avatar
Quoted: 77 Post(s)
Liked: 67
I've always used Denon receivers as processors. Which means i use outboard amps. In my apt electrocity is limited so i have to use just the 4311 for the LCR/surrounds. It does sound sweet !
kgveteran is offline
post #23892 of 23897 Unread Yesterday, 11:38 PM
8trackJack's Avatar
Active Bi-Amp 9.2?
Hey there ever-wise-AVS-Community...
At the risk of incurring the wrath of the forum, may I ask a question that I'm sure has been answered in the previous 700 pages of AVR-4311CI posts, namely:
-Can the 4311CI handle, and if so, how do I configure this receiver, to drive the following 9.2 configuration?:
-active bi-amp F/L speakers
-F/L Heights
-Center
-F/L Surround Backs
-F/L Surrounds
-SW 1/2
From what I can tell, when I set the "assign amp" to bi-amp, I'm forced to choose where/how to assign the other amp to *either* "Heights" or "Surround Back".... and as a result, the receiver only plays using "heights" *or* "surround backs" (and never, both).... effectively limiting me to a 7.2 configuration.
AFAIK, I can use the "pre-amp" option to buy an external amplifier hooked in turn to my F/L heights. And so, use this as my way to get the desired active bi-amp'd 9.2 config?
Yes, I am in a sorry state.
Or should I just trade up and buy the new AVR-X7200W???
(Apologies in advance for the muddled, naive, and otherwise ignorant question! Please be kind!)
8trackJack is offline
post #23893 of 23897 Unread Yesterday, 11:55 PM
NorthSky's Avatar
Location: Canada - West Island: Vancouver, South Direction: Go East
Quoted: 2886 Post(s)
Liked: 960
If you are the least interested by the new 3D surround sound formats (Dolby Atmos, DTS:X, Auro-3D), I would wait until March, and slowly prepare my next move; perhaps the 7200.
* Sorry, couldn't answered your other previous questions, only give my thought on that last one.
NorthSky is offline
post #23894 of 23897 Unread Today, 12:10 AM
batpig's Avatar
Quoted: 1327 Post(s)
Liked: 1702
8track - the 7200 wouldn't give you any different options. Like the 4311 it has 9 amps built in so the arithmetic of 11 amplifiers is identical.
Second, just to be clear, splitting a channel to two amps, hooked up to the dual binding posts on the back of a typical speaker, is NOT active bi amping. It's actualy "passive" bi amping (also known as fools bi amping) and doesn't really do anything that just having a single powerful amp wouldn't do. Active bi amping requires an active external crossover splitting the signal before the amp stage and then bypassing any internal crossover in the speaker.
The smart approach if you need more power: get a beefy 2 or 3 ch amp for the front speakers, use the quite capable internal amps in the Denon for the surrounds / heights. Forget bi amping.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
post #23895 of 23897 Unread Today, 12:50 AM
8trackJack's Avatar
Arghh! Thanks batpig!.... and here I thought I *was* doing the true "active" bi-amp (not the fools errand version!)... meaning I thought I was assigning a separate amp (sending a separate and different audio signal) to each of the woofer and tweeter of my R and L Fronts! Now, I am not an audio-engineer, but from a simple reading of the Denon's 4311Ci's user manual, it really sounds like one is able to set up one's system using an "active" (i.e., not passive) set up... (the following, from p28 of my user manual):
"You can use the front speakers via the bi-amp connection.
A bi-amp connection is to connect separate amplifiers to the tweeter terminals and woofer terminals of speakers compatible with the bi-amp function. This prevents the back electromotive force (returned force without output) of the woofer sent to the tweeter, which affects the sound quality of the tweeter, and you can enjoy playback with higher-quality sound.
To use the bi-amp connection for the front speakers, select “Amp Assign” and set “Assign Mode” to “Bi-AMP” using steps 3 and 4 of “Set up “Amp Assign”” (vpage 63)".
That said: if you're right (and from what I've read in the forums here, you usually are!...) I guess I should put-back the short-circuit plates on my F/L NHT 2.5i speakers, and just go with the simple 9.2 set up in Denon's manual?
post #23896 of 23897 Unread Today, 12:54 AM
8trackJack's Avatar
And Batpig... in lieu of doing away with the idea of actively bi-amping the F/L speakers... you're suggestion to "get a beefy 2 or 3 ch amp for the front speakers, use the quite capable internal amps in the Denon for the surrounds / heights"... does have me intrigued...
I take it the 4311CI can handle such a setup?
And if so (to put it simply), can you suggest any decent "2 or 3 channel amps" to purchase?
And then: how do/would you configure the 4311CI for this???
post #23897 of 23897 Unread Today, 03:56 AM
585-645-1006
jdsmoothie's Avatar
Liked: 1903
Either an Emotiva XPA-2 or XPA-3 would be good a choice. Also, you would only use "Pre-amp" mode when using external amps for all speakers. Simply set AMP ASSIGN to "Normal", connect the external amp to the FL/FR pre-outs and run Audyssey again.
Daily 8am – 8pm EST
post #23898 of 23897 Unread Today, 06:06 AM
Quoted: 44 Post(s)
FWIW, I have an Emotiva XPA-5 running F/C/L/SL/SR, and I'm using the Denon to drive the SBL/SBR and Left & Right Heights (which I almost never use).
I love the sound, but you know the "evil" of our hobby - we're always looking to improve the audio quality. I'm intrigued by the Anthem AVRs and the new Emotiva with Dirac room correction. However, I don't have $2K available for it right now (actually, I can think of smarter things to spend it on - things like a new hot water heater )
Of course, you always have the point of diminishing returns to keep in mind. Would a new $2K processor/AVR make $2k worth of difference in the quality of the audio????
Audyssey , Denon Avr 4311ci 9 2 Channel Network Multi Room Home Theater Receiver With Hdmi 1 4a , Denon Avr A100 100th Anniversary 9 2 140w , Denon
