The "Official" Denon AVR-4311CI/AVR-A100 thread [NO PRICE TALK] - Page 801 - AVS | Home Theater Discussions And Reviews
post #24001 of 24009 Unread 02-27-2015, 04:45 PM
AustinJerry's Avatar
Quoted: 1953 Post(s)
Liked: 1108
Originally Posted by mdrew View Post
I have not performed a firmware update in a couple years. I tried to connect to the server, and after numerous attempts, and getting a "connection failed" message, gave up. The AVR does connect to my home network, as I can play music from the PC in my office, but it will not connect to the internet. Is there any way to download the last firmware update to a usb stick and update that way?
If you can play local content, but can't get to the Internet, something must be wrong with your network configuration. I would check the default gateway and DNS settings. You can get the correct settings from any other device on your network that can successfully connect to the Internet.
I am unaware of any other way to update the firmware.
AustinJerry is online now
post #24002 of 24009 Unread 02-27-2015, 08:23 PM
585-645-1006
jdsmoothie's Avatar
Quoted: 3080 Post(s)
Liked: 2008
Although this is planned at some point in the future, not currently an option on USA models.
"JD" – jd@avscience.com ; http://shop.avscience.com/ Call for sales info --> 585-645-1006
Daily - 8am to 8pm EST
AVS - We sell Denon, Marantz, Yamaha, Pioneer, Onkyo, Def Tech, Oppo
** Think the AVR is defective?  Reset the microprocessor 5 times.
jdsmoothie is offline
post #24003 of 24009 Unread Yesterday, 10:35 AM
mdrew's Avatar
Quoted: 12 Post(s)
Well I wasted a couple hours trying to get this damn thing to talk to the internet. Nothing. I even copied the entire network protocols from my Oppo that's sitting right next to it (and connects flawlessly). My network sees it, and I gave it full permission, even made sure it was not blocked by a firewall or Norton.
I hope so, cause this stupid thing isn't connecting.
mdrew is online now
post #24004 of 24009 Unread Yesterday, 05:45 PM
wilbur_the_goose's Avatar
Quoted: 82 Post(s)
Liked: 38
Did you see if your router is noting the Denon in its IP list?
Try a different cable?
Are you using DHCP or manual?
wilbur_the_goose is offline
post #24005 of 24009 Unread Today, 12:31 PM
AVS Club Gold
rajdawar's Avatar
If you can connect to your local network there is a good chance that you should be able to connect to the Internet too as long as the Default Gateway is specified and correct in the network settings.
Having said that, I've seen issues with connecting to Denon's servers and being able to update the firmware if the receiver is not registered at Denon's website. No harm double checking that.
Raj
rajdawar is offline
post #24006 of 24009 Unread Today, 12:38 PM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 300 Post(s)
Liked: 272
Can you connect to the receiver's web page? Put the IP address of the AVR-4311 into a web browser and you should see a web page where you can access the settings and control the AVR. If you can get this far, you at least know that the AVR-4311 is connected to your home network properly and that the network port on it is working. If you can't get this far, then focus on getting this to work before worrying about accessing things outside your home, such as firmware updates.
wilbur_the_goose likes this.
gsr is online now
post #24007 of 24009 Unread Today, 05:06 PM
585-645-1006
jdsmoothie's Avatar
Liked: 2008
Really? I've never heard that before. I also have never registered any of my Denon AVRs (no point really as the warranty is based on a paid invoice from an Authorized dealer and not whether it's registered or not).
post #24008 of 24009 Unread Today, 05:23 PM
mdrew's Avatar
Quoted: 12 Post(s)
Just tried as you suggest. I can pull up the 4811, make changes, etc... Damn thing still won't connect to the internet. No Pandora, no nothing. I have networks, computers....
mdrew is online now
post #24009 of 24009 Unread Today, 05:30 PM
Liked: 1108
Following the process of elimination, and if you have a long enough piece of Cat5 network cable, I would temporarily connect the AVR directly to the cable modem, bypassing your internal router. There could well be a firewall setting on the router that is blocking the AVR internet access. Just make sure the AV4 is configured for DHCP and Proxy is off.
Audyssey , Denon Avr 4311ci 9 2 Channel Network Multi Room Home Theater Receiver With Hdmi 1 4a , Denon Avr A100 100th Anniversary 9 2 140w , Denon
