The "Official" Denon AVR-4311CI/AVR-A100 thread [NO PRICE TALK] - Page 803 - AVS | Home Theater Discussions And Reviews
post #24061 of 24086 Old 04-02-2015, 07:32 PM
secureinoz's Avatar
Liked: 0
Originally Posted by secureinoz View Post
Playing WDTV media Player Music without needing to have TV on
Why does the BD music play without the TV on, but not the WDTV?
Try connecting the WDTV to the other HDMI inputs to see if the same issue presents. If yes, try doing an HDMI HDCP reset as noted below ...
I said that I'd follow up jdsmoothie's suggestions and report back.
From reading about 'HDCP reset' on the link provided by jdsmoothie it seems this is an 'HDMI handshake issue' most likely arising in the WDTV media player.
I tried the HDCP reset power down and power up as suggested on the link without any change.
But I know when I first stup my 4311 and had 'HDMI Control' set to on in 4311 and also similar setting (I think called CEC) on the Panasonic TV, the 2 devices would battle for control with unpredictable results. So, I have them set to off. And I also have had CEC set to off in the WDTV.
But I wondered if I DID allow HDMI to be controlled by ONE of the devices if that would work. So I switched CEC on in WDTV player, rebooted all (in the sequence that results from use of my Logitech universal remote),...same result. So, I switched CEC off again in WDTV, rebooted all ...and the problem was fixed. And, so far, that fix has survived several switch offs and back ons in various orders...but I suspect the fix is fragile.
It seems there has been some sort of HDMI reset forced by switching CEC in the WDTV.
I'll see how long the fix lasts, and if I lose it I think I'll next try switching on 'HDMI Control' in the 4311.
Does anybody know more about managing HDMI handshake issues? Thanks
secureinoz is offline
post #24062 of 24086 Old 04-04-2015, 12:38 AM
Kris404's Avatar
Can anyone advise how to turn Subwoofer on when in Multi-Channel Stereo mode?
The sub turns on in 2Ch Stereo just fine.
Kris404 is offline
post #24063 of 24086 Old 04-04-2015, 03:44 AM
585-645-1006
jdsmoothie's Avatar
Quoted: 3687 Post(s)
Liked: 2172
If you have the FL/FR speakers set to SMALL/80Hz, the sub should always be fed audio < 80Hz with either mode.
"JD" – jd@avscience.com ; http://shop.avscience.com/ Call only for sales info --> 585-645-1006
Daily - 8am to 8pm EST
AVScience sells Denon, Marantz, Yamaha, Pioneer, Onkyo, Def Tech, Oppo, and more
** Think the AVR is defective?  Reset the microprocessor 5 times.
jdsmoothie is online now
post #24064 of 24086 Old 04-04-2015, 10:02 PM
Kris404's Avatar
Thank you, that did the trick.
Should I set Subwoofer to 'LFE' or 'LFE+Main'?
Kris404 is offline
post #24065 of 24086 Old 04-05-2015, 03:43 AM
585-645-1006
jdsmoothie's Avatar
Liked: 2172
Leave it set at the default of LFE.
post #24066 of 24086 Old 04-05-2015, 05:07 AM
pbarach's Avatar
Quoted: 172 Post(s)
Liked: 123
Batpig (http://batpigworld.com/setup.html) says it doesn't matter whether you choose LFE+MAIN or LFE if all of the speakers are set to SMALL:
"The LFE vs. LFE+MAIN setting is only relevant if you have set any speakers to "large". If all of your speakers are set to "small", this setting doesn't do anything. For speakers set to "large", think of this as the "double bass" setting. For more info on the LFE vs LFE+MAIN setting, click here to read a good explanation."
AT&T U-Verse Northeast Ohio
Denon x4000, Carver m1.0t, Samsung LED TV, B&W 704 mains, two M&K subwoofers, Oppo 103, Roku 2, etc.
Headphone system: Sennheiser HD600, AKG K701, Burson HA-160, Marantz CD5004, Denon DVD-3910
pbarach is online now
post #24067 of 24086 Old 04-05-2015, 05:33 AM
585-645-1006
jdsmoothie's Avatar
Liked: 2172
Thanks, but I'm well aware of how the setting works.
post #24068 of 24086 Old 04-05-2015, 06:55 AM
Kris404's Avatar
Thank you jdsmoothie & pbarach.
Kris404 is offline
post #24069 of 24086 Old 04-05-2015, 02:44 PM
pbarach's Avatar
Quoted: 172 Post(s)
Liked: 123
I was certain you were, but then I was puzzled as to why you didn't tell him that the LFE/LFE+MAIN setting is irrelevant when all of the speakers are SMALL...
post #24070 of 24086 Old 04-05-2015, 03:12 PM
585-645-1006
jdsmoothie's Avatar
Liked: 2172
I told him as well as the lurkers reading the post what they needed to hear. There is no reason to change the default setting.
post #24071 of 24086 Old 04-06-2015, 11:29 AM
Knucklehead90's Avatar
Quoted: 141 Post(s)
Liked: 155
Too many posts to find the answer to one question I have with the 4311. I've got my search for a new AVR down to two Denons - the 4311 and the 4520 but I think the 4311 has more of what I'm looking for since it allows you to use different setting inside Audyssey for stereo and multi channel if I'm reading the manual correctly.
My question is this: can two subs be set up differently - one for two channel and both for multi channel movies without having to resort to changes made inside the menu? IOW does one button reconfigure the way subs are used? I have two 12" DIY sealed subs that will be daisy chained for music and movies - and an eD A5-350 on the other sub channel for movies only. The A5 isn't capable of playing music like the two 12" sealed subs. Its not even close!
My speakers are Salk Song Towers with the OW2 tweeters and a custom Selah center with the same tweeter and a 4" mid and two 7" woofers for movies only. The ST's are capable of playing to 42hz - I'll play around with crossovers for 2 channel to finesse that setup - for movies the crossover likely will be at the standard 80hz. I'm about 98% music vs movies - music takes a huge priority in this home. I don't know whether I'll keep my Rotel 5 channel amp - depends on how well whichever Denon I get plays two channel.
When all else fails - RTFM!
♫♫♫ Two Channel Rules! ♫♫♫
GO SEAHAWKS!!!
Knucklehead90 is offline
post #24072 of 24086 Old 04-06-2015, 12:26 PM
AustinJerry's Avatar
Quoted: 2407 Post(s)
Liked: 1227
I have owned both the 4520 and the 4311 (the 4311 still resides in my bedroom system, and the 4520 has been replaced by a Marantz 8801).
I find the two to be sonically equivalent. Both have XT32, same number of amps, etc., and I never developed a preference of one over the other.
The feature differences are what is important, IMO. The 4520 has a slightly improved GUI, a network hub, InstaPreview, all of which don't make a huge difference. On the other hand, the ability of setting a different configuration for 2-channel sources, which the 4311 has, but which was dropped on the 4520, is a very useful feature for one who uses the AVR primarily for music. In summary, I would choose the 4311 over the 4520 for a music-only system.
And a final note, I have recently left Audyssey behind in favor of Dirac Live, implemented using the MiniDSP DDRC-88a. If you ever see yourself wanting to move in this direction, you should keep your external power amp, since the 88a would use the Pre-out signals from the 88a, and require external amplification. This is certainly something to consider, since Dirac Live is wonderful for music systems.
Edit: No way to save two different sub configurations on the 4311, though
AustinJerry is online now
post #24073 of 24086 Old 04-06-2015, 01:46 PM
Quoted: 141 Post(s)
Liked: 155
Thanks for the quick reply Jerry. I've looked into the Mini-DSP before - sounds like a great piece of gear. For $1k more I could get the XMC-1 - I'm not really interested in that though. I've sold almost all of my Emo gear - just two pairs of bookshelf speakers and a zone II amp left and I'll probably keep those. They all work pretty good.
Well I've got my finger hovering over the 'add to cart' on the 4311 - right now I'm trying to get in the first game of the MLB - Mariners to be exact. I'll be buying one soon and it looks more and more like the 4311 is the better one for my situation. I'm getting tired of the limitations of my bedroom 2 channel Onkyo 8050. No HDMI but at least it has a DAC. And I have no bedroom sounds currently. Something has to give.
GO SEAHAWKS!!!
post #24074 of 24086 Old 04-06-2015, 01:55 PM
Liked: 1227
You can't go wrong with either of your two choices. Both are great AVR's.
post #24075 of 24086 Old 04-06-2015, 04:17 PM
Quoted: 141 Post(s)
Liked: 155
OK - got one refurbed 4311 on the way along with a 3 year extended warranty from New Leaf. I did some research on them - seems they get things fixed when problems arise - I checked them out on the BBB - they have a B+ overall - better than Square Trader. The warranty was only $49.99 and takes over once the factory 1 year refurb warranty expires.
Thanks for your help Jerry. I appreciate it. The last Denon I owned was a long time ago - an AVR-589 I think it was. I used it in the bedroom - I 'thought' I wanted surround sound in there. Turns out when you have one ear or the other buried in a pillow you can't hear surround sound. Been 2 channel in there ever since. That also cleaned up the wiring mess. The Denon will do the same in my audio rack - gotta love HDMI if only for that feature. I'm still waffling over selling or keeping my Rotel RMB-1085. I love the sound of the B&O IcePower amps. And at 15# its easy to move should I need to do that. I'll have to do some serious listening after the Denon arrives. Probably not much if any difference - we shall see.
GO SEAHAWKS!!!
post #24076 of 24086 Old 04-07-2015, 08:16 AM
Pianist718's Avatar
Quoted: 121 Post(s)
I am not sure why, maybe I am just wasting time, but I got to thinking about 4311 power (140 watts).
My speakers are 87db sensitive and require minimum of 45 watts. I am also noticing that I am turning volume as high as -15 on the dial to listen at not so loud/moderate volume. So ... since I am using only 5.1 channels ... anyway to manually distribute more power to only working channels>?
thanks
Sharp LC-80LE650U 80-inch, Denon AVR 4311ci, Ascend Sierra-1 NrT, Ascend HTM-200 (surrounds), Rythmik F12, WD TV Live Media Player, Samsung BD ES6000, Denon DVD-2910 & Sony BDP-S370 SACD/DVDa, Monster HTS 5100 MKI, Monster Z2 Biwire, Logitech Harmony One, Sennheiser HD600, Schiit Modi/Vali
Pianist718 is offline
post #24077 of 24086 Old 04-07-2015, 08:31 AM
Liked: 1227
thanks
No. -15 is not a very high MV setting, and if that is what you listen at, it doesn't seem that you are lacking for power.
post #24078 of 24086 Old 04-07-2015, 09:01 AM
585-645-1006
jdsmoothie's Avatar
Liked: 2172
thanks
As Jerry notes, -15db is not that high. There is only one power supply so your 5 speakers have access to the full amount available from the AVR.
post #24079 of 24086 Old 04-07-2015, 10:02 AM
Pianist718's Avatar
Quoted: 121 Post(s)
So absolutely no reason to consider external amps ... other than for visual satisfaction :-)
A friend of my is getting yamaha soavo 1 that are 89db and 6 ohms ... swears he needs an amp for those.
post #24080 of 24086 Old 04-09-2015, 11:53 AM
txmxer's Avatar
Quoted: 20 Post(s)
1. Give Denon CSR a call.
2. It's now free.
3. Network Setup - Other - Upgrade Notification - OFF
CS was great. Took them a few days to get it done. They sent an email confirmation that I was registered and called me to let me know.
txmxer is offline
post #24081 of 24086 Old 04-23-2015, 02:43 PM
Brent A's Avatar
Front HDMI connection
So I ordered a UMIK-1 and I am connecting my laptops HDMI output to the HDMI input on the front of the AVR, I have HDMI 7 assigned to V-AUX in the Input Assign menu, but I get nothing on the monitor.
I did verify that the cable was good and the laptop was outputting by running it through an HDMI input I normally use for the PS3 (HDMI 5 - GAME) and it worked fine. Just would rather use the convenience of the front HDMI input, but I can't seem to get it active.
Anyone else run into this or any trouble shooting ideas?
Brent A is offline
post #24082 of 24086 Old 04-23-2015, 04:40 PM
Liked: 1227
It should work. Sometimes I need to power off/on the AVR, the TV, or the laptop to force an HDMI handshake. Also, if you can, use a HDMI port on the back of the AVR to verify that you get the PC desktop appearing on the TV. This would verify or rule out the front panel HDMI port as the root cause.
post #24083 of 24086 Old 04-23-2015, 05:44 PM
Brent A's Avatar
Yeah, I was able to get it to connect using the first random rear port right off the bat, it's just the front port that I don't seem to even get an attempted handshake.
I'll try some different powering up routines of the TV & AVR and see if it will kick start something.
Thanks Jerry
Brent A is offline
post #24084 of 24086 Old Yesterday, 07:01 PM
dclark's Avatar
Quoted: 40 Post(s)
My 4311 can't be fixed!
The hdmi board on my 4311 died, so I sent it in for repair (I think it is 4 years 7 months old).The shop called to say that the part it needs is no longer available and a replacement will be sent to be from Denon.
If you have a unit and the hdmi board goes out, you're screwed. Also, as much as I hope that I get a newer model, I have a feeling they'll send me a refurbed 4311.
dclark is offline
post #24085 of 24086 Unread Today, 03:01 AM
585-645-1006
jdsmoothie's Avatar
Liked: 2172
The 4311CI only has a 3 year warranty. Why is the shop indicating it will be covered under warranty?
post #24086 of 24086 Unread Today, 07:33 AM
Zen Traveler's Avatar
Quoted: 363 Post(s)
Liked: 422
...If you have a unit and the hdmi board goes out, you're screwed. Also, as much as I hope that I get a newer model, I have a feeling they'll send me a refurbed 4311.
I wonder if this is not the bane of modern AVRs...I gather in the old days things weren't so complex and lasted longer whereas nowadays these things are almost 'miracle machines' and these boards are the weak link...
For the record, I had a strange anomaly happen with my AVR-4806 (Intermittent sound disruption) and after numerous resets not fixing the problem only use the amps and have a DVD player hooked up to it (along with projector) to prolong it's useful life.
If they are sending a refurbished AVR-4311ci for any reason I can't see it being a drag especially if you've followed the AVR-4520 thread.
Zen Traveler is online now
Audyssey , Denon Avr 4311ci 9 2 Channel Network Multi Room Home Theater Receiver With Hdmi 1 4a , Denon Avr A100 100th Anniversary 9 2 140w , Denon
