The "Official" Denon AVR-4311CI/AVR-A100 thread [NO PRICE TALK] - Page 806 - AVS | Home Theater Discussions And Reviews
post #24151 of 24173 Old 05-25-2015, 02:34 PM
585-645-1006
jdsmoothie's Avatar
Quoted: 4099 Post(s)
Liked: 2273
You can either connect the video source straight to the TV or connect the video source with a set of component video cables to the AVR and use the Video Select setting to select the audio source.
"JD" – jd@avscience.com ; http://shop.avscience.com/ Call for sales info --> 585-645-1006
Daily - 8am to 8pm EST
AVScience sells Denon, Marantz, Yamaha, Pioneer, Onkyo, Def Tech, Oppo, and more
** Think the AVR is defective?  Reset the microprocessor 5 times.
jdsmoothie is online now
post #24152 of 24173 Old 05-25-2015, 02:44 PM
Choptop32's Avatar
You see, there is the trick... I've got everything routed through my 4311 and dont want to have to pull cables and re-route things when I want to do this.
My Blu-ray player only has one HDMI output, or i would have already just used a 2nd hmdi cable direct to the TV, swithced inputs on the TV and bingo. buuutttt.... only 1 hdmi output.
will have to dig into the "video Select" options and see... but thats a start anyway.
AustinJerry likes this.
Choptop32 is offline
post #24153 of 24173 Old 05-25-2015, 03:06 PM
Choptop32's Avatar
BTW.... where are the "video select" options?
post #24154 of 24173 Old 05-25-2015, 05:48 PM
585-645-1006
jdsmoothie's Avatar
Liked: 2273
Video Select (p. 83 Owner's manual)
MENU - SOURCE SELECT - VIDEO - VIDEO SELECT
post #24155 of 24173 Old 05-27-2015, 01:15 AM
A L Wong's Avatar
Quoted: 16 Post(s)
I am currently running 9.1 with front height speakers.
How do I engage dts Neo:X surround with 5.1 and 7.1 sources?
Similarly for Audyssey DSX Heights.
Currently I am limited to PLIIz as the only option.
A L Wong is offline
post #24156 of 24173 Old 05-27-2015, 02:22 AM
585-645-1006
jdsmoothie's Avatar
Liked: 2273
The 4311CI does not have DTS: Neo:X (rather only DTS Neo:6) as DTS Neo:X was only first introduced in 2012 on the 4520CI.
To activate Audyssey DSX, refer to p. 90 in the Owner's manual:
Press the A-DSX button on the remote or Audyssey-DSX on the front panel until "ON-Height" is displayed. You should then be able to select this mode after pressing the MOVIE button.
post #24157 of 24173 Old 05-27-2015, 03:17 AM
A L Wong's Avatar
Quoted: 16 Post(s)
Thank you JD, sad about the Neo-X but will try the DSX Height tonight.
A L Wong is offline
post #24158 of 24173 Old 05-28-2015, 07:37 AM
Ewingr's Avatar
Quoted: 43 Post(s)
I just ordered one of these, and had expectations that it will work with the Denon Android App. but looking at the app in Play, it says for 2012 units and newer.
So, anyone know if there is an app for Android to operate this unit?
Ewingr is offline
post #24159 of 24173 Old 05-28-2015, 08:09 AM
585-645-1006
jdsmoothie's Avatar
Liked: 2273
AVR-Remote should work.
post #24160 of 24173 Old 05-28-2015, 08:13 AM
Ewingr's Avatar
Quoted: 43 Post(s)
Hmmm...according to Denon support, it does not. As well, the specs in the app say for 2012 and newer.
I did just find an app that claims to support it, My-AV. I have used that on the Onkyo I am discarding, and it seems to be a nice app. Hopefully that one works.
Ewingr is offline
post #24161 of 24173 Old 05-28-2015, 08:17 AM
585-645-1006
jdsmoothie's Avatar
Liked: 2273
Look again.
post #24162 of 24173 Old 05-28-2015, 11:42 AM
Quoted: 325 Post(s)
Liked: 68
I tried the Denon app on a 4311 and it worked, but prefer the other one on Google store, can't recall its name at the moment. Both are very basic.
bmcn is offline
post #24163 of 24173 Old 05-29-2015, 10:56 AM
pjrace1's Avatar
I use the AVR-Remote app on android. Works well for basic functions around the house. Works great for multi zone, inputs, mode and volume.
Pistol Pete
pjrace1 is offline
post #24164 of 24173 Old 05-29-2015, 01:42 PM
scottknight's Avatar
I have been using the Android app called AVR-Remote for Denon/Marantz for as long as I can remember. Works very well from all tablets and phones. I love being able to change the volume from a different room or outside.
scottknight is offline
post #24165 of 24173 Old 05-30-2015, 09:09 AM
ynglwyr's Avatar
My 4311 used to work with AVR-Remote. I switched my router to an Asus AC-87U and now it sees the 4311 but says its off. Can't send any commands or controls. What do I need to to make it work again? Great app for zone 2 and 3 control and basic functions.
ynglwyr is offline
post #24166 of 24173 Old 05-30-2015, 09:34 AM
585-645-1006
jdsmoothie's Avatar
Liked: 2273
Try rebooting the router, otherwise, you could send an email to the app author or change back to the original brand of router you were using.
post #24167 of 24173 Old 05-30-2015, 09:47 AM
duc135's Avatar
Quoted: 101 Post(s)
Liked: 185
If you have the IP address of the AVR saved as a favorite in your browser, make sure the AVR has the same IP address as it did before the router upgrade. If you have a static IP address set on the AVR, make sure the router has that IP reserved and is not part of the DHCP scope. If you have the AVR set to obtain an IP address via DHCP then you will need to map the AVR's MAC address to the same IP address as you had it set to before. Another thing to check is to make sure the ports used by the app are open on the router. Quick check would be to see if you you can ping the AVR from your PC and that you are indeed pinging the AVR and not another device in the network.
duc135 is online now
post #24168 of 24173 Old Yesterday, 08:18 PM
sandtrooper's Avatar
Hello all,
I have a beyond stupid newb question so came here for help.
First time for me setting up a home theater so keep that in mind.
I have an A100 AVR. I'm wanting to use banana plugs on the AVR binding posts. The ones I bought are Sewell Deadbolt locking plugs. They don't seem to fit in the center hole of the binding post and am not willing to force them. What banana plugs would work with the Denon or am I doing something wrong.
THanks.
sandtrooper is online now
post #24169 of 24173 Old Yesterday, 08:27 PM
djos's Avatar
Remove the little black plastic lugs first, then your banana plugs will fit.
My Home Theatre site + Blog
The impossible often has a kind of integrity which the merely improbable lacks.
djos is offline
post #24170 of 24173 Old Yesterday, 08:41 PM
Squirrel!'s Avatar
Quoted: 54 Post(s)
What little black plastic lugs are you referring to?
Main: Mitsubishi 73734 DLP|Amazon Fire TV|Toshiba HD DVD-A35|Panasonic BD65|Denon AVR-4311CI|MartinLogan Preface|Phantom|MartinLogan Encore TF|2 DIY Class 'G' 540w 12" Subs|APC H15|Harmony 720 Remote|Linksys E3000 Dual Band N-Router|Linksys SE2500 Ethernet Switch
MBR: Vizio VF550M|Roku 2XS|Sony BDP-S1100|Denon AVR-X1000|Chane A1rx-c|Phantom|(Temporary)Dayton Audio SAT-BK|MartinLogan Dynamo 300|Belkin PureAV PF30|Harmony 550 Remote
Squirrel! is offline
post #24171 of 24173 Old Yesterday, 08:42 PM
djos's Avatar
The ones that are normally in the middle of the binding posts.
djos is offline
post #24172 of 24173 Old Today, 09:34 AM
It doesn't have the black lugs in the binding posts. They are open but the banana plugs won't fit. (Picture is from the web).
post #24173 of 24173 Unread Today, 11:48 AM
duc135's Avatar
Quoted: 101 Post(s)
Liked: 185
They are a spring loaded, press fit so you'll need a little force to push them in. That resistance is what keeps the plugs from popping back out inadvertently. Also, make sure you're plugging into the speaker posts and not the RCA outputs.
Audyssey , Denon Avr 4311ci 9 2 Channel Network Multi Room Home Theater Receiver With Hdmi 1 4a , Denon Avr A100 100th Anniversary 9 2 140w , Denon
