The "Official" Denon AVR-4311CI/AVR-A100 thread [NO PRICE TALK] - Page 809 - AVS | Home Theater Discussions And Reviews
post #24241 of 24245 Unread Today, 09:12 AM
Squirrel!'s Avatar
Quoted: 127 Post(s)
Liked: 49
Ahhhhh...OK, I understand now. Didn't really pay attention to the app names. AVR Remote does NOT control the X1000, only Denon Remote will control the X1000. And Denon Remote does not control the 4311, only AVR Remote will control the 4311.
Guess I have no choice but to use 2 different apps. Thanks for your time.
Main: Mitsubishi 73734 DLP|Amazon Fire TV|Toshiba HD DVD-A35|Panasonic BD65|Denon AVR-4311CI|MartinLogan Preface|Phantom|MartinLogan Encore TF|2 DIY Class 'G' 540w 12" Subs|APC H15|Harmony 720 Remote|Linksys E3000 Dual Band N-Router|Linksys SE2500 Ethernet Switch
MBR: Vizio VF550M|Roku 2XS|Sony BDP-S1100|Denon AVR-X1000|Chane A1rx-c|Phantom|Dayton Audio SAT-BK|MartinLogan Dynamo 300|Belkin PureAV PF30|Harmony 550 Remote
Squirrel! is offline
post #24242 of 24245 Unread Today, 09:37 AM
585-645-1006
jdsmoothie's Avatar
Quoted: 4387 Post(s)
Liked: 2364
No reason it shouldn't work on the X1000. As listed below in the app's description the 4311CI and X1000 are both supported.
"JD" – jd@avscience.com ; http://shop.avscience.com/ Call for sales info --> 585-645-1006
Daily - 8am to 8pm EST
AVScience sells Denon, Marantz, Yamaha, Pioneer, Onkyo, Def Tech, Oppo, and more
** Think the AVR is defective?  Reset the microprocessor 5 times.
jdsmoothie is online now
post #24243 of 24245 Unread Today, 09:45 AM
Squirrel!'s Avatar
Quoted: 127 Post(s)
Liked: 49
I know. And the Denon Remote app lists the 4311 as being compatible.
post #24244 of 24245 Unread Today, 09:53 AM
585-645-1006
jdsmoothie's Avatar
Liked: 2364
Actually, for the Android app you are using, no it does not as it is listed as only working with 2012 and newer models. I used AVR-Remote on my X4000 so it should work with your X1000 as well.
post #24245 of 24245 Unread Today, 10:28 AM
eyespy39's Avatar
Originally Posted by 4i2fly View Post
I tried pinging but return message is "Host is Down"...port scan also doesn't work but the airplay device definitely sees it and cannot handshake with it!
Even though it might still be a software problem, I cannot think of another useful step that you could perform at home or by yourself, now. Maybe someone else here on the forum can offer another idea, or else: service?
Best luck
…and now to something completely different!
eyespy39 is online now
Audyssey , Denon Avr 4311ci 9 2 Channel Network Multi Room Home Theater Receiver With Hdmi 1 4a , Denon Avr A100 100th Anniversary 9 2 140w , Denon
