The "Official" Denon AVR-4311CI/AVR-A100 thread [NO PRICE TALK] - Page 818 - AVS Forum | Home Theater Discussions And Reviews
 95Likes
Old 05-30-2016, 12:11 AM
djos's Avatar
Originally Posted by a aa View Post
Got it, thanks djos. Haven't opened that door since I installed the receiver a couple of years ago.
Hehe, I suspected that was the case.
The impossible often has a kind of integrity which the merely improbable lacks.
djos is offline
Old 06-01-2016, 03:49 AM
Liked: 0
Hi Everybody there, Got somme annoying issues with my Denon 4311. Can no more store odyssey settings, in fact the calibration process work with no problem but after next standby audyssey presets disppear !
Another issue is related to the standby red light led that doesn't light anymore when the denon is in standby mode.
Lastly a GUI display problem on the net/usb which displays on front panel but not on TV screen.
Many Thanks in advance for your help and advice.
alamikam is offline
Old 06-14-2016, 04:35 AM
585-645-1006
jdsmoothie's Avatar
Quoted: 9434 Post(s)
Liked: 4364
1. By disappear, do you mean "greyed out" and a message displays that Audyssey must be run? Try doing a "soft reset" by powering off and unplugging the 4311 for 10 minutes. If no joy, then do a microprocessor reset (p. 138 Owner's manual).
2. As noted on p.13 of the Owner's manual, the Standby light only lights when "HDMI Control" or "Network Standby" are ON.
3. This may be resolved by the microprocessor reset, otherwise, if not, repair would be next option.
"JD" - Call 585-645-1006 or email jd@avscience.com for AVR selection and pricing discussion 8am - 8pm EST daily (incl Sat/Sun)
AV Science - Dealer for Denon, Marantz, Yamaha, Onkyo, Def Tech, Atl Tech, SVS, Oppo
Think you have a defective AVR? Owner's manual - Factory reset 4-5 times in a row.
jdsmoothie is offline
Old 06-15-2016, 06:16 AM
Liked: 0
Hi,
The denon works now in very erratic way
It becomes even worst , now i have audio drops and i hear clear "clics" within the amplifier. I will try to check the speaker and cdmi cables and do complete reset.
alamikam is offline
Old 06-17-2016, 09:04 PM
BFI6603's Avatar
Odd behavior by my 4311ci
My receiver is hooked up to the internet and is functioning properly.
However from time to time and sometimes during a movie, it will turn itself on unattended and change its source to USB/NET.
This is especially annoying when watching a movie.
Any suggestions as to what is happening....is my internet connections causing this problem....should I remove internet hookup.
All advice is welcomed
-Pete
BFI6603 is offline
Old 06-17-2016, 09:12 PM
bigdogaxis's Avatar
Quoted: 66 Post(s)
Liked: 59
Yeah I don't know man. Mine started doing similar things before I replaced it.
My equipment: JVC RS-55, SI Performance 120" 1.3 gain, OPPO BDP-105, ANTHEM MRX-1120, Roomie-iPad, QNAP 469L NAS, ROKU 4, ATV, DTV HR34-500, PS3, XBOX 360. ML Source (F), Matinee (C), MotionFX (S), Motion4 (.4), (2) Depth-i subs. M/ASlim5 Rack, CalMAN 5 Enthusiast/C6 meter.
bigdogaxis is offline
Old 06-17-2016, 09:32 PM
BFI6603's Avatar
Thanks for the reply...guess I am not the only one....
Anybody know of a fix....hopefully its only a menu fix.
Thanks-Pete
Forgot to mention my projector in an Infocus IN83, which should have nothing to do with this issue because it is turned off whenever this happens.
BFI6603 is offline
Old 06-17-2016, 11:14 PM
jconjason's Avatar
Quoted: 213 Post(s)
Liked: 146
-Pete
Ever use an external device such a tablet or phone to stream through your Denon that's still on the network?
Panasonic 60VT60 3DTV
Denon AVR 4311CI
Klipsch F-30 Fronts
Klipsch C-20 Center
Klipsch S-20 Sides
Klipsch B-20 Rears,PA 120 12" Sub,klipsch R-10SW
jconjason is online now
Old 06-17-2016, 11:18 PM
BFI6603's Avatar
Yes i have....(ipad, iphone and laptop). I also have the Denon App.
-Pete
BFI6603 is offline
Old 06-17-2016, 11:22 PM
BFI6603's Avatar
I also stream movies via a ROKU stick and a Panasonic Blu-ray player.
-Pete
BFI6603 is offline
Old 06-17-2016, 11:53 PM
jconjason's Avatar
Quoted: 213 Post(s)
Liked: 146
It's possible one of those devices is switching the Denon. If memory is correct, I believe I've read about that here before.
Denon AVR 4311CI
Klipsch F-30 Fronts
Klipsch C-20 Center
Klipsch S-20 Sides
Old 06-17-2016, 11:58 PM
585-645-1006
jdsmoothie's Avatar
Liked: 4364
-Pete
If not already doing so ... when finished streaming the network source, press the "black box" STOP button on the remote to end the network streaming vs. simply turn the AVR off or changing to another source.
BFI6603 and bigdogaxis like this.
Old 06-18-2016, 12:01 AM
BFI6603's Avatar
Will give that a try.....
-Pete
BFI6603 is offline
Old 06-18-2016, 09:04 AM
blipszyc's Avatar
Quoted: 134 Post(s)
Liked: 72
-Pete
I had a similar problem a while back. Turned out that I had a PC that was sending Wake-on-Lan signals to my whole network. I ended up turning WOL off on the PC and the problem went away.
Visit the Lipszyc Home Theater! 1.0
2.0 done and finally posted! - Theater 2.0
And now...The Queen City Theater (3.0)
blipszyc is offline
Old 06-18-2016, 09:09 AM
BFI6603's Avatar
I realize every operating system is different but where should Ilook for this WOL feature on my PC
Thanks-Pete
BFI6603 is offline
Old 06-18-2016, 01:59 PM
jconjason's Avatar
Quoted: 213 Post(s)
Liked: 146
Thanks-Pete
You'll have to Google it for your specific model. It varies. Some it's in BIOS and some it's done in network settings.
Denon AVR 4311CI
Klipsch F-30 Fronts
Klipsch C-20 Center
Klipsch S-20 Sides
Old 06-19-2016, 06:21 AM
BFI6603's Avatar
Thanks......I,will do that!
-Pete
BFI6603 is offline
Old 06-19-2016, 06:24 AM
BFI6603's Avatar
Smile
Thank you, jdsmoothie....I tried your fix first.....so far so good. It appears to be working now as it should!
-Pete
BFI6603 is offline
Old 06-20-2016, 08:36 AM
Spaceman's Avatar
Quoted: 41 Post(s)
Liked: 135
I think my HDMI board might be gone. Audio and video are dead except for my HD Radio input. If I switch to another input and then go back to HD Radio, that is dead too. I'm now getting a solid red power button after powering down. I see several scenarios in the troubleshooting guide about flashing red power buttons, but nothing for a solid red power button. Am I now the proud owner of a $1200 paper weight?
I have it unplugged for a soft reset and will try a microprocessor reset if that doesn't work. Regarding the processor reset, does it matter if I press and hold the up & down arrows as mentioned in some of these posts vs. the "standard" and "dsp simulation" buttons mentioned in the manual? Same results? Any other ideas?
FWIW, I've never done a firmware upgrade in the 4 years I've owned the unit. From what I can tell from the FW summaries, that won't really help me.
Spaceman is offline
Old 06-20-2016, 09:36 AM
585-645-1006
jdsmoothie's Avatar
Liked: 4364
1. When the unit has powered down, the sollid red light simply means you either have HDMI Control or Network Standby enabled.
2. UP/DOWN arrow procedure is a NETWORK RESET which resets the network card + microprocessor reset while the standard microprocessor reset in the manual simply resets the microprocessor. In this instance, not likely to matter which one you do; however, try doing several in a row before giving up on it.
Old 06-20-2016, 09:49 AM
Spaceman's Avatar
Quoted: 41 Post(s)
Liked: 135
Yeah, the red light is bugging me. I'm 95% sure that the power button simply went dark when I used to power down, but everything I'm reading says it stays red. Is there a setting somewhere where I might have previously had that turned off (set to go dark rather than red)?
Spaceman is offline
Old 06-20-2016, 09:53 AM
585-645-1006
jdsmoothie's Avatar
Liked: 4364
Yup. Please read item 1 in my previous post. You can also refer to p. 13 in your Owner's manual.
Old 06-20-2016, 10:07 AM
Spaceman's Avatar
Quoted: 41 Post(s)
Liked: 135
Thanks, jdsmoothie. Hdmi control got turned on. That solves 1 problem. Troubleshooting hdmi ports now.
Spaceman is offline
Old 06-20-2016, 11:20 AM
swilson317's Avatar
Want to use RC-1148 remote in zone 2/3.
I'm not familiar with IR and the lingo for it. I see that there is a jack in the back of the receiver. I somewhat understand the concept of attached emitters to the face of the devices, etc. I find it comical that the manual for the AVR-4311CI implies that the RC-1148 remote can be magically used in another zone...out of the box.
In my case, I want the simplest setup to allow me to use the remote in zone 2...mostly for volume/mute control. Can I just setup an IR receiver (is that the correct term) in that zone that plugs into the back of the receiver? I don't want to disrupt the IR receiving on the face of the receiver for normal use in the main zone. If I got some sort or RF repeater, can that be plugged into that jack on the back with the companion device in zone 2 (kitchen/great room)?
I have speakers on the back up the house under the eves for zone 3. It would be cool to have something similar to handle that zone as well.
Thanks, Steve
swilson317 is offline
Old 06-20-2016, 12:40 PM
585-645-1006
jdsmoothie's Avatar
Liked: 4364
Thanks, Steve
Another option if you have the 4311CI connected to your home's modem/router is to use one of the Denon smart phone remote apps (AVR-Remote (Android), DeRemote (iOS)) to control Zones 2/3.
Old 06-20-2016, 02:21 PM
swilson317's Avatar
Thanks. I had that thought too. But both Andoid apps that I downloaded and installed (Denon Remote App or Denon 2016 AVR Remote v 1.1.0) stated my device wasn't supported after I typed in the IP address.
Thanks, Steve
Old 06-20-2016, 07:15 PM
585-645-1006
jdsmoothie's Avatar
Liked: 4364
Thanks, Steve
Correct. Your model is too old for those apps; however, the AVR-Remote android app should work just fine.
https://play.google.com/store/apps/d...vrremote&hl=en
Old 07-16-2016, 07:15 PM
CalKoon's Avatar
RC-1145 Remote Volume button is sticking.
Volume button is sticking on remote. Might just need cleaning but I cannot find way to open up remote. Does not appear to have any screws or accessible catch releases.
Unknown if prying along seams is the solution or if that might damage remote.
Is remote permanently factory sealed?
Any suggestions on how to open?
CalKoon is offline
Old Today, 08:08 AM
kgveteran's Avatar
Quoted: 309 Post(s)
Liked: 123
Hello 4311 experts, I plugged my old ipad into the front USB port, switched to USB/NET, and it worked perfect using my ipad as a music server kinda.
After about 30 seconds the screen goes blank, Denon functions bring back my music screen, then 30 seconds later and poof, gone again. I turned off screen saver, didn't work. I don't think its the TV, it has no power function settings....
any other features I don't know of to keep my Denon onscreen on all the time
kgveteran is online now
Audyssey , Denon Avr 4311ci 9 2 Channel Network Multi Room Home Theater Receiver With Hdmi 1 4a , Denon Avr A100 100th Anniversary 9 2 140w , Denon
