The "Official" Denon AVR-4311CI/AVR-A100 thread [NO PRICE TALK] - Page 821 - AVS Forum | Home Theater Discussions And Reviews
 102Likes
post #24601 of 24612 Old 11-29-2016, 03:03 PM
pbarach's Avatar
Quoted: 281 Post(s)
Liked: 175
Originally Posted by batpig View Post
Yes, support for Front Wide has been dropped industry wide with 2016 models (not just Denon/Marantz).
I thought about it, but after seeing a number of posts from people who felt it muddied up the dialogue and sound among the front speakers, I decided against trying it.
AT&T U-Verse Northeast Ohio
Denon x4000, Carver m1.0t, Samsung LED TV, B&W 704 mains, two M&K subwoofers, Oppo 103, Roku 2, etc.
Headphone system: Sennheiser HD600, AKG K701, Burson HA-160, Marantz CD5004, Denon DVD-3910
pbarach is offline
post #24602 of 24612 Old 11-29-2016, 03:42 PM
robc1976's Avatar
Quoted: 80 Post(s)
Liked: 69
Yes, support for Front Wide has been dropped industry wide with 2016 models (not just Denon/Marantz). The industry is basically settling into the 7.1.4 format as the gold standard for immersive audio moving forward.
If you love your wides and want to keep them, then go for a prior year model (X6200W or X7200WA).
I am X7200WA. I REALLY believe most do not set then up correctly. I have experimented over the years and just finally have the perfect. Moving them 5 degrees makes a huge difference. You have to get those wides at 60 degreees and fronts at 30 degreess. I like my heights at 38-40 degrees NOT 45 degrees.
robc1976 is online now
post #24603 of 24612 Old 11-29-2016, 03:44 PM
djos's Avatar
Quoted: 17 Post(s)
Most folks don't have a wide enough room to bother with front wides so it's a bit pointless. I tried them I my previous house and liked them but my current house isn't suitable for then.
The impossible often has a kind of integrity which the merely improbable lacks.
djos is online now
post #24604 of 24612 Old 11-29-2016, 04:37 PM
robc1976's Avatar
Quoted: 80 Post(s)
Liked: 69
Totally true, I built my room for it, my room is 23'W X 37'L and my wides are still on the side walls. I think most set they're wides way to close to fronts because room is not wide enough. My fronts are 6ft from center and wides are 6ft from fronts. Once you separate those wides from fronts it brings it to life. Also your room has to be treated with this many speakers. I have 30 panels in my room and wall to ceiling bass traps ect
post #24605 of 24612 Old Yesterday, 06:41 AM
wilbur_the_goose's Avatar
Quoted: 263 Post(s)
Liked: 117
Width and Height channels have been pretty much rendered obsolete by Atmos. That said, I tried them both and after 2 days, got rid of the extra speakers. To me, it was a gimmick (at best).
wilbur_the_goose is online now
post #24606 of 24612 Old Yesterday, 06:53 AM
robc1976's Avatar
Quoted: 80 Post(s)
Liked: 69
if wides and heights, are set up correctly atmos will have hard time beating them. If set up in incorrectly atmos will kill them. Also with atmos a treated room is not needed as much.
Only way I would do atoms would be with at least 10 speakers on ceiling, my buddy has a 5.1.4 and my 9.2 system kills it. There are so many variables though.
I like the option on the X7200WA receiver that you can add a second set of surrounds for the 2nd row of seating.
I honestly think if I went with another mode it would be something from DTS, maybe NEO X.
I have never been a fan of Dolby, didn't like PL, DD...hate Dolby volume im receivers. Only thing Dolby I will consider is Atmos
post #24607 of 24612 Old Yesterday, 05:51 PM
Quoted: 263 Post(s)
Liked: 117
FWIW, I'm a happy 7.1 guy with my Emotiva XMC-1. My trusty Denon is now running a 2.0 setup.
post #24608 of 24612 Old Today, 10:49 AM
baltar's Avatar
After 6 happy years with my Denon 4311 i have upgrade to a Marantz 7010. I would like to use my 4311 to power the Front and Center channels. Do i connect them to Ext.In and set the 4311 in Pure Direct mode?
Verzonden vanaf mijn iPhone met Tapatalk
baltar is online now
post #24609 of 24612 Old Today, 11:51 AM
jmoline's Avatar
OK, so the LG 65B6P has arrived and replaced my old Panny plasma. Picture is awesome but as I have some ARC questions. THe old Panasonic didn't support ARC but did support HD<I Control. SO when I turned on the TV the 4311 turned on and was tuned to the DVR which was also the standby source. Now the 4311 turns on but tunes back to the TV. I have to tune the 4311 back to the DVR. Just for grins I moved the HDMI cable on the TV to the non ARC port and the 4311 actions were the same except the blue ray player now powers on when the TV does. Is there any combo of settings which will power on the 4311 in sync with the TV and leave the 4311 on it's standby source. Or am I stuck with a power on of the TV and then going to the 4311 remote to select the proper input?
jmoline is offline
post #24610 of 24612 Old Today, 02:35 PM
Quoted: 263 Post(s)
Liked: 117
jmoline - that's what I have to do.
post #24611 of 24612 Old Today, 02:43 PM
batpig's Avatar
Quoted: 3485 Post(s)
Liked: 3320
You actually don't even need to worry about "Pure Direct" mode because the EXT IN mode bypasses ALL digital processing. I would just zero out the speaker volumes/distances on the 4311 and then set it to 0.0dB master volume and then never touch it.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is online now
post #24612 of 24612 Old Today, 03:23 PM
baltar's Avatar
Thanks for your advice Batpig! Really helpful.
Audyssey , Denon Avr 4311ci 9 2 Channel Network Multi Room Home Theater Receiver With Hdmi 1 4a , Denon Avr A100 100th Anniversary 9 2 140w , Denon
