The "Official" Denon AVR-4311CI/AVR-A100 thread [NO PRICE TALK] - Page 822 - AVS Forum | Home Theater Discussions And Reviews
 108Likes
Old 01-26-2017, 09:28 PM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 6837 Post(s)
Liked: 3808
Firmware Update
I received a FW update for my 4311 this evening. Anyone know what it contained?
AustinJerry is online now
Old 01-26-2017, 10:37 PM
duc135's Avatar
Quoted: 155 Post(s)
Liked: 225
I haven't performed the update yet, but I'm guessing it's the fix for Pandora.
duc135 is online now
Old 01-26-2017, 11:47 PM
Sdca7718's Avatar
Originally Posted by Longeze View Post
Hi, Could someone tell me the procedure for recovering a deleted source? I had deleted the "Game" input from the GUI and would like to add it back now. When I press that input button on my remote it won't come up in the source list. Thanks in advance for your help!
Go to Menu>manual setup(gear w/wrench)>option(suitcase)>source delete
Sdca7718 is offline
Old 01-27-2017, 12:07 AM
pjrace1's Avatar
Yep, fixes Pandora issue.
Pistol Pete
pjrace1 is offline
Old 01-27-2017, 09:48 AM
Longeze's Avatar
Liked: 0
Thanks very much for taking the time to help me out with that! I think I lost 20 IQ points in the process )
Longeze is offline
Old 01-27-2017, 01:13 PM
wilbur_the_goose's Avatar
Quoted: 291 Post(s)
Liked: 136
Shoot - after the update, I lost all my favorites
wilbur_the_goose is offline
Old 01-27-2017, 04:14 PM
culliganman's Avatar
Quoted: 20 Post(s)
After the update I tried Pandora and it did not work. It tells me not in this country and then tells me my network is not working.
Oh well I don't use Pandora, I use Spotify mostly and I use my tv or laptop to play on the Denon.
culliganman is offline
Old 01-28-2017, 12:46 PM
nugga22's Avatar
I'm having an odd issue with my AVR-A100. I had Control4 installed recently and we couldn't get the receiver to turn on via network control. Additionally, the power button and source select knob don't work. I can still turn the receiver on via IR so it is currently being controlled that way, but I'd like to get network control working. Unfortunately, I can't do any reset because the power button isn't functioning. Any thoughts, settings I'm missing, or other troubleshooting tips?
nugga22 is offline
Old 01-28-2017, 09:50 PM
apw2607's Avatar
Quoted: 204 Post(s)
Liked: 279
Pandora works fine after the update but Rhapsody/napster remains broken.
apw2607 is online now
Old 01-31-2017, 02:02 PM
Quoted: 291 Post(s)
Liked: 136
I just breathed new life into my AVR-4311:
* I use it in my home office - pair of powered studio monitors provide the sound
* I use Roon to play music from my media server. All 33K songs ripped to FLAC (lossless).
* I was using AirPlay to get the music to the AVR-4311, but Roon showed just how just audio goodness was being stripped by Air Play.
* I bought a Raspberry PI with a HiFiBerry Digi+ card (cost < $100). Loaded the Roon Bridge server on the Raspberry PI.
* Now, through Ethernet (works on WiFi too), I get my FLAC in full fidelity! Feeding the audio from the Pi to the Denon with digital coax (the card has Toslink too).
* I switched on the long-forgotten Pure Direct mode. It's even nicer now.
It sounds amazing!
Briant73 and 65Goat like this.
Old 02-02-2017, 05:10 PM
gregavi's Avatar
Quoted: 37 Post(s)
Discrete Codes for the 4311
Hi, I have a question about using my Harmony One remote to change the setting of the HDMI output from Amp to TV using a discrete code. Is that possible with my Harmony and my 4311. It's a pain to have to navigate through the menu of my 4311 in order to make that change, which I do on a regular basis, depending on what type of programming I'm watching.
Thanks in advance.
It used to be:"Wine, Women and Song"Now it's: "Beer, The Old Lady and TV"My Theater Build http://s1116.photobucket.com/user/Gr...?sort=6&page=1
gregavi is offline
Old 02-02-2017, 05:31 PM
batpig's Avatar
Quoted: 3596 Post(s)
Liked: 3439
Thanks in advance.
Yes, discrete Input commands should be pre-loaded on your Harmony remote when you added the device to your profile. Any button that's on the factory remote should be represented in the Harmony setup.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is online now
Old 02-02-2017, 06:53 PM
gregavi's Avatar
Quoted: 37 Post(s)
Thanks batpig.
But there is no dedicated button on the factory remote that toggles that function. My question was, is there a discrete code that would toggle that command without navigating through the menu.
gregavi is offline
Old 02-03-2017, 09:11 AM
gregavi's Avatar
Quoted: 37 Post(s)
I'm making some progress on this as I have found the discrete code list for the 4311 which includes what I am looking for which is:
HDMI Audio Out (Toggle)
HDMI Audio Out TV
HDMI Audio Out Amp
I'm just not sure what to do with the codes though. I'm not sure if I need a Pronto or RC5000 remote in order to input the codes and then learn them to the Harmony. I guess that's a question for a different thread.
gregavi is offline
Old 02-03-2017, 04:07 PM
batpig's Avatar
Liked: 3439
Oops, I thought you were talking about input selection! You might want to read through my blog post here: http://batpigworld.com/wp/?p=117
You can send the raw hex code to Harmony and they will add the discretes.
thepainter likes this.
Setup Guide and FAQ
Old 02-03-2017, 05:57 PM
gregavi's Avatar
Quoted: 37 Post(s)
Now we're getting somewhere.
Thanks batpig!
gregavi is offline
Old 02-03-2017, 09:59 PM
gregavi's Avatar
Quoted: 37 Post(s)
The link https://dl.dropboxusercontent.com/u/7593163/Hex to Harmony Rev2.zip
is a dead end and the Routine System Maintenance doesn't seem to work with the new Harmony software.
gregavi is offline
Old 02-19-2017, 05:11 PM
gregavi's Avatar
Quoted: 37 Post(s)
I was able to get the following discrete commands working with my Harmony One remote.
HDMI Audio Out Amp
HDMI Audio Out TV
HDMI Audio Out Toggle
I did this by sending the HEX codes to Harmony. With the help from William Wong (with an assist to batpig) from Harmony, I now have the ability to change the HDMI Out from TV > Amp and back without navigating through the menus. I big time saver/convenience for me.
batpig likes this.
gregavi is offline
Old Today, 03:06 PM
mayhem666's Avatar
Liked: 5
Originally Posted by joehonest View Post
Quote: Originally Posted by SeattleHTGuy
I am not that talented when using audio equipment testing gear, software, or other fancy methods of measurement. My ears are also just average. (They work but are not golden). However, this 40Hz "bug" issue, I am suspect of. It simply makes no sense that just setting a crossover at 40Hz causes a polarity problem. Also, if I understand the original posters question, the perceived "Polarity" issue is from just listening.
So, correct me if I am wrong in covering this issue but here is my layman's understanding of the issue.
1) this problem occurs when playing LFE + Main and setting the Fronts crossover to 40Hz within the 4311
2) The configuration involves two sub powered towers upfront + 2 Subs for a total of four low Bass drivers.
3) I am assuming the front towers are placed left and right of the viewing area and up against or closer to the front wall.
4). As mentioned, the problem is not really verified by anyone else and in addition most people do not even recommend setting LFE + Main as this really adds too much Bass. Most other posters, including myself do not use LFE + Main.
Soundofmind just mentioned what has been deeply discussed in this thread and others. I can also verify in my nearly square 16 ft listening room the fact that placing my subs on the front wall, where so many people stick towers is absolutely the worst place to put Bass Drivers in my room. Where I am going with this. I think it should be considered that by placing these big low playing Towers up front and then having the standard subs wherever you have them, that when the 4311 Crossover is set to 40Hz what really is happening is that all 4 drivers are creating a super knarly null field that is being interpreted as some kind of polarity issue at the 4311. Now, I may be wrong but first I'd shut off the whole LFE + Main feature and just try your subs EQ'd and at the 40Hz point. Then try just the towers with no subs at all. Finally, move your towers around some place radically different and re-EQ and try the whole thing again at LFE + Main; of course EQ this as well. Even if the towers are at some strange temporary place, all you are trying to determine is if your bass response is compromised by the location of your towers. Or attempting to verify a weird "bug" in the AVR by ear alone.
I strongly suspect that there is no "polarity" bug but rather a room/speaker problem. You are most likely just making one whopper of a null field with all that redundant Bass coming from 4 drivers really poorly placed.
I tried to respond in plain talk and not go all technical. If you want further information regarding sub crawling and towers in the front; as Soundofmind mentioned, this particular thread is plumb full of these discussions. I too had a problem that could only be solved by really moving my subs all over the place. It took days of trying before I got it right for me. I still want bigger subs but that's for another time.
I'll go over my findings with the 4311. First I use my ears along with a RS sound meter, I did use testing hardware and test tone software to confirm what I was hearing. The problem I found to be was that the mains change phase to the relationship to the subs when switching between large and small speaker settings in the 4311 menu. The spell it out, if the sub is inphase with the small speaker setting it will be out of phase when set to large. If the sub is inphase with the large setting it with be out of phase when switched to small. The LFE + Main has to be on to force the low freqs to both sub and mains when in the large setting.... I used full range (large) and 40,50,60,70,80,90,100,120hz. Inphase reinforces the lowend and out of phase causes a cancellation. Or till either the sub or mains over power the cancellation effect ( one set will need to be at a much higher output level). I believe the phase flip happens by turning the 4311 xover software on or off or the LFE + Main mode. LFE + Main needs to be used so the lowend goes to both subs and mains when set to large. I would only guess to say why so many say don't use LFE + Main it sounds muddy or just not right. Or the low end becomes over blowen, all are affects of what happens when full range main flip phase.
Hi all,
Just wanted to share something with every Denon avr4311 owner. The original complaint from 'joehonest' about the polarity issue when using LFE+main is a true flaw/bug in the Denon itself.
This has been reported by him in this thread like 5 years ago (somewhere around pages 480-490), but I ran into this issue by accident last weekend when I was playing around with the LFE+main setting and measuring the frequency response of my mains together with the subwoofer. I measured with REW and a UMIK-1 mic btw.
So, in short this is the issue:
- The subwoofer output is reversed in polarity the moment you are using a LFE+main setting together with sub(s). This is independent on the 'crossover' setting (40/60/80 hz).
So, I can confirm this bug in the Denon 4311, but there is a nice catch to this:
- It only reproduces when you use analog inputs as input! Whenever you use HDMI as input this bug cannot be reproduced.
Just wanted to share with you this info and catch. Most people use small setting and also HDMI, so there will not be many people having a real problem with this issue.
Denon AVR-4311 | Denon DBT-1713UD | Dune BD Prime 3.0 | Klipsch R-115SW | Klipsch RP-260F | Klipsch RP-450C | Klipsch RP-250F | miniDSP 2x4 | QNAP TS219P (2x1.5 TB) | VdHul - Profigold - VLS | Samsung Full HD 116 cm LED TV | Xbox One | Philips HUE lighting
mayhem666 is online now
Audyssey , Denon Avr 4311ci 9 2 Channel Network Multi Room Home Theater Receiver With Hdmi 1 4a , Denon Avr A100 100th Anniversary 9 2 140w , Denon
