The "Official" Denon AVR-4311CI/AVR-A100 thread [NO PRICE TALK] - AVS Forum | Home Theater Discussions And Reviews
 109Likes
post #1 of 24654 Old 09-03-2010, 04:50 AM - Thread Starter
DisTreSs's Avatar
Hard to believe with all the buzz going on that no-one has bothered to open a thread on what looks to be a killer-receiver (to me at least)...
So here goes!
My first question would be the following:
We already know that this receiver will be 11.2 capable with external amplification, but will the internal amps be assignable?
If not, you'll probably be stuck using the internal amps for your 9.2 setup (including your mains) and adding the external amp for a wide/height/SB channel (whatever Denon decides).
If yes, which I much prefer, the 2 added channels of external amplification could be assignable to the front speakers for instance.
This way you could set-up your system with a quality external amp for your mains and keep the internal amps for the remaining speakers...
I admit, I've been out of the game for quite some time (still the owner of an AVR-3801 currently! Hence the interest in the 4311 ) so apologies in advance if I'm missing the obvious here, but at this point it's the only thing unclear to me.
EDIT:
Batpig suggested it would be a good idea to make a FAQ section in the first post of this thread and who am I to refuse.
So here goes, the first little FAQ trivia, courtesy of batpig.
Special thx goes out to jdsmoothie for keeping me informed on the FW updates!!!
FAQ
Where can I find more info on this behemoth?
http://usa.denon.com/ProductDetails/5414.asp
What is the difference between the 4311ci and the A100?
A100 gets the following over 4311:
- Gloss Finish
- 100th Anniversary badge
- 100th anniversary block condensers
- Gold plated terminals
- Premium upgraded speaker binding posts
- Cast iron feet
- 5 year warranty
- Brand history book
- Inspection sheet
- fancy box
In terms of processing / amps / internals they are otherwise identical.
Which possible combinations of internal and external amps are there?
- You can have ANY combination of internal and external amps. You can power 5 speakers with external amps and 4 with internal... you can power 3 with external and 8 with internal.... you can power 2 with external and 9 with internal.... 9 with external and 2 with internal.... IT'S ALL GOOD. The ONLY thing you can't do is power 11 speakers internally...... because there are only 9 amps built in!
- The ONLY exception is that, because the receiver only has 9 amps built in, when you activate 11 channel mode, the receiver forces you to choose whether the FIRST TWO extra channels will be the heights or the front L/R mains.
How do I activate the preouts?
- You do not need to activate anything. When you are in 11ch mode, ALL THE PREOUTS ARE HOT at all times. You don't have to assign anything or set anything beyond the selection for the first two externally amped channels, the preouts are ALL HOT.
Then what is preamp mode for?
- PREAMP MODE however disconnects the signal from ALL the amps, so you should ONLY use this mode if you are using ONLY external amps for all channels. You cannot "shut off" specific amps internally, so if you will be using any of the internal amps for the main zone, you cannot use PREAMP mode.
A100 Firmware Updates
1. GUI issue fixes and using Party Mode Plus when networking
2. Audio drop out issues (12/22/10)
3. "Blue rain" video issue resolved (1/24/2011)
4. See items added below (7/1/11)
- Last.fm for German. (E2 only)
- It fails in the DPMS update of the firmware when the product is connected with "Control4".
- When Page Up/Down is done in the music list of iRadio, the product is frozen.
- When network connection speed is slow, the error occurs in the display of the FL tube.
- There is a case that the backup data of the parameter etc. initializes.
- There is a case where the network doesn't start.
- When the NSE command of AMX is sent, the data of the answer is wrong.
5. See items below (7/30/11)
- Allow connectivity to new Rhapsody servers
- Improve network connectivity
6. Allow connectivity to Pandora servers (12/19/12)
Note: If you have installed the Airplay firmware upgrade, the firmware version number on your unit will be incremented by 0001.
4311CI Firmware Updates
1. Fixes Party Mode feature, Pop Up menu function, USB functionality and also to the IP/232 controllability.
4. See A100 updates (7/1/11)
5. See A100 updates (7/30/11)
6. See A100 update (12/19/12)
photobias likes this.
DisTreSs is offline
post #2 of 24654 Old 09-03-2010, 04:59 AM
buggs1a's Avatar
Quoted: 179 Post(s)
Liked: 24
I'm not sure there needs to be an official thread for this avr right now being it's not even out yet. But it's of course a good idea and I'm glad it's here.
The amps are able to be assigned yes. I think all the new avrs from Denon are able to assign which speakers the amps control. I might be wrong though.
I want vtuner but don't think any denon does that. I also want a really good UI over hdmi and all sources and non buggy UI/update firmware feature. Rhapsody and Napster would be cool to have as well.
I don't even really know anything about the 4311, but for some reason I think I've read its web page or something. Maybe not, lol. I do want to though. Have to go to denon site again.
I'm interested in this avr being I'm looking for a new avr between $1000-$2000. The 3311 doesn't have what I want so hopefully this will, but I doubt it. I'll probably stick with my thinking of getting the Onkyo 1008, but I'd much rather get a Denon.
buggs1a is offline
post #3 of 24654 Old 09-03-2010, 05:44 AM - Thread Starter
DisTreSs's Avatar
Well I did wonder whether I wouldn't be overstepping my bounds by posting it while the product isn't even listed on the denon website, but hey it's here now, might as well use it
You can find a first look here if you're looking for more info:
http://www.audioholics.com/reviews/r...-avr-4311ci-fl
Main selling features would seem to be:
- MultEQ XT32 (provided they don't have the same bug that crept into the NR3008/5008)
- 9.2 with 11.2 expandability
- Pre-amp mode
DisTreSs is offline
post #4 of 24654 Old 09-03-2010, 06:42 AM
Darin's Avatar
I think generally the "official" XXXX threads pop up whenever someone has enough interest and commitment to a particular product to initiate the thread and continually update the first post with the latest information. Thanks for stepping up!
My dual Rythmik Servo sub project (actually quad now, need to update page)
HDM format neutral thanks to the pricing wars of the '07 xmas shopping season :)
Darin is offline
post #5 of 24654 Old 09-03-2010, 07:55 AM
mastermaybe's Avatar
Quoted: 386 Post(s)
Liked: 321
I don't think the earth is going to stop spinning if this is a week or two "premature". If you want, change the title to the "4311 anticipation thread" and then change it to the "official" thread upon its release.
I'm looking for the whole ball of wax ampl-flexibility-wise, as I have external amplification and 3 zones. That said, I just eliminated the Yammy RX A3000 because their amp assign function wasn't versatile enough. I'm expecting Denon's MUCH more flexible "free amp assign" (which isn't in ALL models, but in the upper range) to be in this unit, which pretty much allows you to assign ANY audio channel to ANY amplifier channel output (there is a slight limitation with the rear/back surround/ and zone posts, but that's mostly inconsequential).
I for instance want to externally power the 7 channels of a traditional array and then internally amplify the remaining (4) presence (in the case of Yamaha) or Wides and Heights (in the case of DSX) channels.
Yamaha simply will not let me do this, only allowing the presence channels to be externally powered, but then you MUST power the other 7 internally. And then on top of that, since the rear presence speakers and zone 3 share the same pre-outs, you lose the ability to run a zone 3.
There's a rather comprehensive list of configs (with the Yamaha) that will undoubtedly satisfy most users, but not someone like me, .
I'm sure the Denon will allow me to power BOTH the heights and wides internally and even use 4 of the 5 remaining channels to power zones 2 and 3 if I choose!
FWIW I still believe this will be one of the most capable, feature-packed, hi-performance, value-orinetated AVR's in the history of the industry and I'm dead-serious.
James
My Parlor and Theatre: "Jimbo's Dugout" : http://www.avsforum.com/forum/15-gen...re-parlor.html
Actual phone call (see pic to left):
 Tech (responding to laughter): "I'm sorry sir, did I miss something?"
Me: "Yeah, a case of Diet Mountain Dew walking across my living room."
mastermaybe is offline
post #6 of 24654 Old 09-03-2010, 08:11 AM
WiWavelength's Avatar
Quoted: 29 Post(s)
Liked: 24
If this is going to be the "official" thread, the title & thread should also include the AVR-4311CI's spruced up Denon anniversary sibling, the AVR-A100.
AJ
WiWavelength is offline
post #7 of 24654 Old 09-03-2010, 10:31 AM - Thread Starter
DisTreSs's Avatar
Errrrmm, me no speaky engrish, me no understanding...
James
same here. I will use this in my setup as described, but in the future I would want to use the internal amps to distribute the audio around the house for the most part.
I have yet to find fault with anything I've found on this receiver and it pretty much has anything I could ask for.
The only caveat would be the price as here in the EU it's rather difficult to find the deals the guys in the US seem to find all the time
I hope that the msrp of 1999$ will translate to a lower price...
Especially since I will probably try to pick one up as soon as it gets here and that pretty much means that you'll always be stuck paying full MSRP.
AJ
Done and done
I have to say I rather like the look of the A100, but no way it's worth the premium price they will be asking for it especially since it offers nothing extra t'echnically compared to the 4311 afaik.
I'm sure there's enough other people out there with money to burn though.
DisTreSs is offline
post #8 of 24654 Old 09-03-2010, 10:44 AM
swspiers's Avatar
Ditto.
I'm in love with Marantz SR7005, and can picture it as the center piece of my system. But then this beast comes along and, well, sometimes you have to go with your head and not your heart.
Decisions, decisions
swspiers is offline
post #9 of 24654 Old 09-03-2010, 10:46 AM
Quoted: 386 Post(s)
Liked: 321
You mean you don't believe iron feet inherently signify a marked increase in sound quality?
James
post #10 of 24654 Old 09-03-2010, 10:51 AM
Darin's Avatar
If nothing else, they should help increase the chances that it will land right side up if it's thrown in the air. Kind of like a cat.
Darin is offline
post #11 of 24654 Old 09-03-2010, 11:51 AM
Quoted: 386 Post(s)
Liked: 321
Ditto.
trust me, I don't think your heart will be disappointed. Why give up what you have to give up with the Marantz? That's the way I looked at it anyway.
James
post #12 of 24654 Old 09-03-2010, 01:03 PM
setanta's Avatar
Not entirely inconsequential. I asked Denon support a couple of weeks ago about bi-amping off zone 2. They informed me the bi-amping only works for fronts.
Why would I want to do this? Well, I only use 5.1 for home theater and and I don't care to rip out or add in new in-walls. I have much nicer in-wall speakers B&W Sig8-NT in my Kitchen/Dining area. These are driven by a carver pro amp today which is very nice (pre-amp is zone2 off an older 4306 which is to be replaced by either the 4311 or A100).
If I were able to assign bi-amping to zone 2 I'd get rid of the power amp and simplify my set up.
So yes while the amp assign looks very good all in all, it's not quite as flexible as I'd like.
setanta is offline
post #13 of 24654 Old 09-03-2010, 01:41 PM
RickAVManiac's Avatar
Quoted: 184 Post(s)
Liked: 166
James
RickAVManiac is offline
post #14 of 24654 Old 09-03-2010, 02:42 PM
batpig's Avatar
Quoted: 3638 Post(s)
Liked: 3486
I think when you are worried about bi-amping Zone 2 you are officially at the outer limits of what consumers could possibly want in terms of amp assign flexibility
I will note that you actually CAN bi-amp the secondary speakers if you are willing to run them as "B" speakers. Obviously you would lose the ability to do true "zone" audio with separate sources in the two rooms, but you can do "Front B Bi-Amp" and set up the nicer B&W in-walls as dedicated 2-ch music speakers with two amps each.
Or, just keep using the Carver amp, which is not only free, but is almost certainly more powerful than even bi-amping from an AVR. A receiver's amp section isn't going to stand up to a Carver pro amp.
Rbjack likes this.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
post #15 of 24654 Old 09-03-2010, 04:32 PM
Brian-HD's Avatar
Quoted: 46 Post(s)
Liked: 42
This will be my next AVR.
Brian-HD is offline
post #16 of 24654 Old 09-03-2010, 06:18 PM
buggs1a's Avatar
Quoted: 179 Post(s)
Liked: 24
I wonder what it means when they say 7500 Internet radio stations. Anyone know?
Anyone know what the GUI will be/look like and if someone could post pictures when possible of the gui?
I hope update firmware will work and give accurate status update progress info.
I wonder when it comes out and when it'll be on Denons site.
I'm going to compare it to the onkyo 1008 and pioneer elite 3 models and the 3 yamaha aventage new ones.
Not sure what else to compare it to.
buggs1a is offline
post #17 of 24654 Old 09-03-2010, 07:02 PM
Quoted: 184 Post(s)
Liked: 166
+1
(If the first reports are positive and no major defect are detected)
post #18 of 24654 Old 09-03-2010, 08:18 PM
ghstudio's Avatar
Quoted: 13 Post(s)
I'll be an early user....if
My key decision factors: Audyssey Multeq xt32, ability to power off amps
I've been living with the Emotiva UMC-1 for months now and I am ready to move to a box that just works when you turn it on. I'm just hoping the 4311 makes the grade...
ghstudio is offline
post #19 of 24654 Old 09-03-2010, 08:36 PM
InterestedUser's Avatar
Does anyone know how Denon's syncs zones 2 and 3 with the main speakers. With my current Onkyo it delays the Zone 2 music so that they are not in sync. I suspect it was Audyssey processing time. I know Yamaha's 3900 had a Party Mode where they were all in sync.
InterestedUser is offline
post #20 of 24654 Old 09-04-2010, 03:46 PM
Swancoat's Avatar
Quoted: 51 Post(s)
Originally Posted by RickAVManiac View Post
+1
I'll be glad to report how it goes. I'm ready to go on day 1 of this thing's release.
Swancoat is offline
post #21 of 24654 Old 09-04-2010, 04:33 PM
nydennis's Avatar
I'm pretty well ready to go as well. I have no problems buying day one. According to someone doing pre-ordering on audiogon the shipment date is 9/15 but that is the only place I have seen the release date written so take it for what it is.
My experience with Mackcam Warranties. Projector sent with HDMI issue, returned with Lens damage. Still no ETA. 6 Months waiting to date. Sporadic response from CS. Stated it was sent to Epson, but was sent to another repair shop. Mackcam then bought an Epson projector off Ebay and sent it to me as a replacement.
nydennis is offline
post #22 of 24654 Old 09-04-2010, 05:06 PM
Darin's Avatar
With all of you lining up to buy on day 1, I'm going to wait a few months when the demand (and therefore prices) go down.
Darin is offline
post #23 of 24654 Old 09-04-2010, 06:59 PM
Brian-HD's Avatar
Quoted: 46 Post(s)
Liked: 42
I am sure will be a step up.
Brian-HD is offline
post #24 of 24654 Old 09-04-2010, 08:25 PM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 6994 Post(s)
Liked: 3903
So, does anyone have information about when the 4311 will actually be available for purchase? There is an "Anniversary countdown to October 1" on their website. Does this mean it won't be available until then?
AustinJerry is online now
post #25 of 24654 Old 09-04-2010, 09:11 PM
ronaldjoe's Avatar
I hope Denon would release it earlier before October 1.
I have 'pre-ordered' a unit with local distributor as well. I am in hunger for a new AVR.
Added on:
Interesting specs on Sub EQ HT:
http://www.audyssey.com/aboutus/pres...y-now-on-avrs-
It can integrate 2 subs with Sub EQ. We potentially could save on an extra AS-EQ1.
ONKYO | EAD | SILNOTE | WIREWORLD | KIMBER | TARALABS | RPGC | PARADIGM | PBK Sub Calibration
ronaldjoe is offline
post #26 of 24654 Old 09-05-2010, 02:20 AM - Thread Starter
DisTreSs's Avatar
Added on:
Thx for the link ronaldjoe, I had been wondering about this as well, as it was mentioned in the audioholics preview but I could not find anything on this.
Apparantly this would be included in the MultEQ XT32 so receivers such as the NR-3008/5008 should have this as well.
Damn, and here I was hoping that this would be another reason to get the 4311 over the 3008/5008
Since it's not, I'm even more eager to get to know the price here in the EU as that will become the determining factor for me.
DisTreSs is offline
post #27 of 24654 Old 09-05-2010, 02:27 AM
jwb474's Avatar
Attached below are links to the best front and back shots of the 4311 that I have seen.
If this unit is going to be available as soon as suggested in some of the messages, I am surprised that Denon has not uploaded all of their usual documents.
http://js-kit.com/blob/9Dlp0PE_SGjN377SoAzDeb.jpg
http://js-kit.com/blob/tDrFjX6WhZ9y9CMymD_KOc.jpg
jwb474 is offline
post #28 of 24654 Old 09-05-2010, 04:26 AM
amstaffhd's Avatar
Pity about the "Made in China" - the 4310 was Japan iirc.
amstaffhd is offline
post #29 of 24654 Old 09-05-2010, 05:27 AM
Darin's Avatar
I've been assuming they would release info during Cedia, which starts 9-22.
Darin is offline
post #30 of 24654 Old 09-05-2010, 05:34 AM
jwb474's Avatar
Your are probably right, and as been mentioned before the anniversary editions are Oct 1st per the countdown clock. Once they say go, it only takes seconds to do the upload.
jwb474 is offline
Audyssey , Denon Avr 4311ci 9 2 Channel Network Multi Room Home Theater Receiver With Hdmi 1 4a , Denon Avr A100 100th Anniversary 9 2 140w , Denon
