Computer Speaker Amp - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 09-05-2010, 08:29 AM - Thread Starter
Oldfart's Avatar
I am about to replace my 20 year old Cambridge Soundworks Original Ensembles (6 ohm impedance speakers) and use them as computer speakers. I believe that to do this I will need a 2 channel power amp and a mini plug to dual RCA cable. The mini plug goes into the computer line out, the RCAs to the amp left and right line ins.
Questions:
1) Do I have this right?
2) Is there a problem with an impedance mismatch?
3) Recommendations for an amp to buy and where to buy it?
Alan
Oldfart is offline
post #2 of 3 Old 09-05-2010, 09:07 AM
Knucklehead90's Avatar
Quoted: 394 Post(s)
Liked: 336
A small (cheap) stereo receiver like an Onkyo TX-8255 (ebay auctions) or similar will give you all the power you need for near field listening and brings you an AM/FM tuner and switching for other sources should you wish to plug one in. Some power amps have a level control (volume gain) but very little else. No remote - no ability to change sources - and often will cost more than the stereo receiver.
Any stereo receiver or amp can drive those speakers just fine.
I own a Harman Kardon 3390 and the above mentioned Onkyo 8255. Both sound great for two channel sound.
Yamaha CX-A5000 - Acurus A100x3 & Outlaw 7075 - Salk Song Towers - Custom Selah Audio Center - Oppo 103 - Marantz TT42
***GO SEAHAWKS ***
Twas a woman who drove me to drink. I never had the decency to write and thank her ~ WC Fields
Knucklehead90 is online now
post #3 of 3 Old 09-05-2010, 12:37 PM
rdclark's Avatar
Quoted: 285 Post(s)
Liked: 553
Questions:
Yes, you have it right. The CSWs can be properly driven by any consumer amp or receiver, with no impedance issues. I would look for something used. Almost any functioning stereo receiver of any vintage will do this job. You can probably find something on ebay or at a local Goodwill or pawn shop for $25-50.
It doesn't matter with LCDs, but keep in mind that the original Ensemble satellites aren't shielded, and should be kept away from anything that doesn't react well to magnetic fields, like CRT displays or floppy disks (sorry, classical reference).
Great speakers, IMO. I still have two pairs in service.
Wide Awake
on the Edge
of the World
rdclark is offline
