The Official Integra DHC-80.2 Pre/Pro Thread - Page 62 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #1831 of 3842 Old 02-21-2011, 04:40 PM
alanl715's Avatar
Originally Posted by sunsetav View Post
I think its the Integras HDMI Output too .... but i dont think it has to do with "weak" signal since the bosster/repeater (powered by +5vdc) did not help .... and the fact that sometimes i see picture and only when i change channel or source do i lose it.
Makes me believe (with my analog logic) that its a 'handshake' 'sync' issue.
People have suggested an HDMI switcher (defeats the purpose of an AVR) or a Cat5/6 balun sytem, but theres another thread reporting the same problem with a balun system.
Integra keeps insisting on trying a 9-15 foot HDMI cable to see if that solves the problem - and I say: "I dont care if it works with a 9-15' cable ....i need it t work with a 40' cable ...the projector and equipment are in 2 different rooms"
The irony in all this is i actually pushed to get the Integra into this system over a Denon 4311ci.
We had a similar problem trying to push 3d thru on an Integra DTR40.2's from a DTV hd/dvr past 10meters. Once we got down to a 7.5m cable length (yes, we even tried the high speed hdmi's without success), it worked fine.
alanl715 is offline
post #1832 of 3842 Old 02-21-2011, 05:45 PM
sunsetav's Avatar
Originally Posted by Dundas View Post
Have you tried the HDMI forum:
http://www.avsforum.com/avs-vb/forum...ysprune=&f=168
You might be more likely to find a solution there.
Yes - i posted in the Sticky: HDMI Satellite/Cable Issues
sunsetav is offline
post #1833 of 3842 Old 02-21-2011, 05:49 PM
sunsetav's Avatar
The issue im having is with 2D
And lenght seems to be Integra's Tech Support solution -- but i dont have that option -- i need this to work over the measly 40 feet of HDMI
If a replacement DTR-80.2 will not work - i will move down to a Denon AVR-4311ci (anyone know of the same issue with Denons?)
sunsetav is offline
post #1834 of 3842 Old 02-21-2011, 05:51 PM
Wireless member
pepar's Avatar
Quoted: 1043 Post(s)
Liked: 544
You need an "active" HDMI solution.
"The future is already here, it's just not evenly distributed." W. Gibson
"I like the future, I'm in it." F. Theater
pepar is offline
post #1835 of 3842 Old 02-21-2011, 06:03 PM
sunsetav's Avatar
I considered this - but was discouraged after the Gefen Booster/Repeater trial failed.
Although its not saying much = it IS a "Gefen" piece
sunsetav is offline
post #1836 of 3842 Old 02-21-2011, 08:23 PM
Dundas's Avatar
Lumagen?
http://www.lumagen.com/testindex.php...dmiext_details
Contact them and see what they say.
Dundas is online now
post #1837 of 3842 Old 02-21-2011, 08:34 PM
KERMIE's Avatar
My Integra 70.1 runs a 45 foot HDMI (Monoprice) to a Panny 2000 just fine. Through the ceiling in PVC piping. Not sure if that helps or not. Is there anyway of trying a different cable from someone you know? I was having the same problem with a 40 foot HDMI from Atlona and ordered a cheaper one from MP just to try and it has worked for 18 months.
KERMIE is offline
post #1838 of 3842 Old 02-21-2011, 08:58 PM
Johnla's Avatar
Quoted: 39 Post(s)
Liked: 31
In the world of HDMI, 40 feet long is hardly considered measly.....
Johnla is offline
post #1839 of 3842 Old 02-21-2011, 08:59 PM
sunsetav's Avatar
Lumagen?
Thanks - i will
Along with Integra and Integra's West Coast Rep
BTW, JVC has been great through all this - top notch support - real engineers too.
Integra has been lackluster so far = this could be my last Integra (ive been happy with Denon for 10 yrs).
sunsetav is offline
post #1840 of 3842 Old 02-21-2011, 09:02 PM
sunsetav's Avatar
I would try that - but the fact that it works flawless when connected to the DirecTV box makes me believe its not the cable. But i have seen stranger things. So maybe i will try this with a different brand 40' HDMI.
sunsetav is offline
post #1841 of 3842 Old 02-21-2011, 09:06 PM
sunsetav's Avatar
Ive run many 50' and 75' HDMI runs in my day - with no issues.
This is not an acceptable excuse for HDMI, Integra or anyone - we need an av transport cable that works for 15' and for 40'
Demand more - and they will deliver more
Settle for less - and thats what you'll get
sunsetav is offline
post #1842 of 3842 Old 02-21-2011, 09:10 PM
audioguy's Avatar
Quoted: 2381 Post(s)
Liked: 1566
I'm about 35 feet to a JVCRS2 and have had no issues.
Well now that I think about it, I have had an issue on occasion with the background color from my Oppo83 being all green (versus blue) and having to restart the Oppo to fix it. I don't know if it's the 80.2 or the 83. (I came from an Onkyo 885 to the 80.2). Oppo did send me some things to try and we will see if it is the 80.2 or the Oppo !!
Our Theater
Work as though you will live forever; live as though you will die tomorrow.
Proverbs 9:10
audioguy is offline
post #1843 of 3842 Old 02-21-2011, 11:23 PM
tallnick's Avatar
It is an amazing piece of gear, but what it is doing is not bi-amping.
what do you mean?
when I set the dat-70.1 to "bi-amp" mode, set the processor to "bi-amp" mode, plug one set of speaker cables from one amp to the mid-range and tweeter, and a totally separate amp through another set of speaker cables to the woofer I'm NOT bi-amping?
I'm confused.
tallnick is offline
post #1844 of 3842 Old 02-22-2011, 01:54 AM
Wireless member
pepar's Avatar
Liked: 544
Originally Posted by tallnick View Post
what do you mean?
I'm confused.
Biamping involves replacing the speaker's internal passive crossover with an external active one. There is no external crossover, i.e. the 80.2 doesn't have that function, for the mids/highs in this situation, so there is no biamping happening. Google it.
pepar is offline
post #1845 of 3842 Old 02-22-2011, 07:22 AM
Dave Vaughn's Avatar
Quoted: 1040 Post(s)
Liked: 1511
Try turning off the video processing completely in the Integra (VCR/DVR button and display button at same time--I think that's the sequence.). I bet you this fixes the problem.
I was having similar issues between the 80.2 and JVC RS40. Strangely, no issues with a 40.2 though. Turning off the video processing allowed the pre/pro and projector to sync. Every source I had worked fine connected directly to the source, but if they ran through the pre/pro, it wouldn't lock on the signal (although the PS3 worked OK through the pre/pro to the JVC...very strange on that one).
David Vaughn Blu-ray Reviewer / Technical Writer Sound & Vision Magazine (Print & Online)
My Atmos Renovation Part 1 http://www.soundandvision.com/conten...odyssey-part-1
My Atmos Renovation Part 2 http://www.soundandvision.com/conten...odyssey-part-2
Dave Vaughn is offline
post #1846 of 3842 Old 02-22-2011, 07:46 AM
sunsetav's Avatar
That sounds exactly like my problem....
I thought setting each input on the AVR to "through" was turning the video processing off?
I will try your video processing off sequence -- can ayone confirm the sequence? Is it in the manual?
sunsetav is offline
post #1847 of 3842 Old 02-22-2011, 08:33 AM
tallnick's Avatar
ok, I'm "passively" bi-amping.
tallnick is offline
post #1848 of 3842 Old 02-22-2011, 11:28 AM
SPLawren's Avatar
Interesting. How is this "video processing shutoff" key sequence (VCR/DVR + display) different from the menu "through" setting?
Is the result of this keyed shutoff noted somewhere in the 80.2 menus so that you'd know if the processing was on or off?
I wonder if it would help more in syncing audio and video or make it worse, since the 80.2 was no longer doing anything to the video signal.
SPLawren is offline
post #1849 of 3842 Old 02-22-2011, 11:55 AM
Wireless member
pepar's Avatar
Liked: 544
I think you are "buy-wiring" but have at it.
pepar is offline
post #1850 of 3842 Old 02-22-2011, 12:47 PM
Guinness77's Avatar
I had the exact same thing happen to me, but only worse. The entire unit wouldn't respond to any commands. It fixed itself when I unplugged it for a few hours.
Dave,
I left mine unplugged, went out for the night and the next day it was working perfectly. Thanks!
Guinness77 is offline
post #1851 of 3842 Old 02-22-2011, 02:28 PM
Liked: 1511
Through is not a true "Through" signal, or so I found out. When I disabled the video processing via the method mentioned above, everything now works perfectly. Personally, I don't really care about the video processing because the JVC is very good in that regard and I've bought a Lumagen scaler in order to have CMS on my RS40.
post #1852 of 3842 Old 02-22-2011, 02:28 PM
Liked: 1511
Originally Posted by Guinness77 View Post
Dave,
Glad to hear!
post #1853 of 3842 Old 02-22-2011, 03:51 PM
sunsetav's Avatar
Is this in the manual?
What is the exact procedure? Just turn the unit on and hold the 2 buttons down....or push the 2 buttons simultaneously ...or??
How do i confirm that the Vid processing is disabled? Are there any indicators in the OSD ...or front panel?
Thanks ahead - this sounds like its gonna solve my issue - am going to be onsite tomorrow.
sunsetav is offline
post #1854 of 3842 Old 02-22-2011, 04:47 PM
Dundas's Avatar
Here:
http://www.avsforum.com/avs-vb/showt...267456&page=13
Post 387
post #1855 of 3842 Old 02-22-2011, 06:53 PM
sunsetav's Avatar
Here:
Post 387
Cool - found it - Thanks
http://www.avsforum.com/avs-vb/showp...&postcount=387
sunsetav is offline
post #1856 of 3842 Old 02-22-2011, 07:31 PM
Liked: 1511
Let me know if that fixed it for you. I've been working with Onkyo/Integra on this issue and the more examples I can give them, the better.
post #1857 of 3842 Old 02-23-2011, 02:02 PM
KB1
KB1's Avatar
Just curious, does the 80.2 On Screen Display still work when you disable the video processor? In other words, can you still hit Setup or Home and see the options displayed on your TV or projector or are the options only shown on the 80.2 itself once VCR+Return is toggled to Skip ? Thx.
KB1 is offline
post #1858 of 3842 Old 02-23-2011, 03:25 PM
Liked: 1511
The setup menu will come up on the screen, but the OSD is disabled so you need to see the front of the unit to see the info. My old 885 didn't have an OSD, so I'm not really missing it, but it doesn't make me happy that Onkyo/Integra still hasn't fixed this issue with JVC.
post #1859 of 3842 Old 02-23-2011, 03:51 PM
Wireless member
pepar's Avatar
Liked: 544
My 885 *will* display volume and channel trim settings if the source is not 24p. I have never used the button press procedure being discussed ... does that mean my 885 is interfering with the video?
pepar is offline
post #1860 of 3842 Old 02-23-2011, 06:09 PM
Liked: 1511
Let me restate...I never turned the OSD "on."
Integra
