The Official Integra DHC-80.2 Pre/Pro Thread - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
Old 10-10-2010, 07:13 AM
Wireless member
pepar's Avatar
Quoted: 911 Post(s)
Liked: 502
Originally Posted by meller127 View Post
I have hade the 80.2 about 2 weeks now, and it seems like thers a bug with PLIIx. After about 30-60min the relay clicks start going nuts, its clicking so fast that the 80.2 never loose the audio stream. Only way around this i have found is to change to another listning mode and back again. But it repeats after 30-60min again.
This is the first I have heard of it. As the unit gets into more hands, we'll get more data and be able to see if it is a bug or an isolated problem.
Jeff
"The future is already here, it's just not evenly distributed." W. Gibson
"I like the future, I'm in it." F. Theater
pepar is offline
Old 10-10-2010, 10:51 AM
jmschnur's Avatar
do you have this in the other modes-thx, ultra cinema etc?
is the firmware the 9/17 release?
joel
jmschnur is offline
Old 10-10-2010, 10:54 AM
jmschnur's Avatar
Originally Posted by LarryChanin View Post
Hi Joel,
Perhaps I am misinterpreting your use of the word "compares", but Audyssey Pro enabled devices always inherit the resolution of the version of Audyssey on the installer-ready device. This has nothing to do with whether or not MultEQ Pro is used or not.
Therefore you really can't directly compare MultEQ XT32 to MultEQ Pro. MultEQ Pro enhances the capabilities of the version of MultEQ residing on the device, including MultEQ XT32.
MultEQ Pro adds the following capabilities to the version running on the device:
  • a more accurate microphone
  • it permits taking up to 32 measurements
  • it permits editing the target curves
  • it uses a more sophisticated method to recommend crossover settings
  • it provides frequency response graphs
  • it permits saving and reloading measurement files
Larry
Thanks for this -it helps.
So I am still curious how a no pro kit xt 32 (with sub eq) 80.2 compares with a pro kit install from an xt from an earlier version (9.9 9.9, 876 etc)
Joel
jmschnur is offline
Old 10-10-2010, 11:04 AM
meller127's Avatar
joel
Nope only on PIIx, yes i have 9/17 firmware.
meller127 is offline
Old 10-10-2010, 11:50 AM
Wireless member
pepar's Avatar
Quoted: 911 Post(s)
Liked: 502
Joel
I'm not sure that that is knowable.
Jeff
pepar is offline
Old 10-10-2010, 11:56 AM
Kal Rubinson's Avatar
Quoted: 679 Post(s)
Liked: 461
Joel
I do not think there will ever be an answer to this. First, any A/B comparison of correction measurements will be specific to the system context including the particular room acoustics. Second, any A/B comparison of correction audibility will also be confused by the many other differences between the earlier machines and the new ones. Still, it is an interesting question.
Kal Rubinson
"Music in the Round"
Kal Rubinson is online now
Old 10-10-2010, 12:47 PM
Solon-HD Install's Avatar
I'm sorry to hear that there might be a bug with the PLIIx and we thank you for sharing that with us but do you have anything positive to report????
Solon-HD Install is offline
Old 10-10-2010, 05:51 PM
LarryChanin's Avatar
Also will be interested inthe heat from the 80.2. The 885 runs rather warm and I have put fans on top of it since the internal fan does not seem to work properly.
Hi Joel,
Are you sure the 885 even has a fan? I wasn't aware that any of this family of preamplifiers had any internal fans. I thought that they simply relied on internal heat sinks and natural convection with vents under the units pulling in cool outside air, and hot air exhausting via the vents on the top.
Larry
LarryChanin is offline
Old 10-10-2010, 07:32 PM
jmschnur's Avatar
There is a temperature sensor that does not work. There is one in my 805 that does. I assumed the sensors were there to turn on and off a fan. At any rate it gets very warm in back and I placed a small fan over the rear grill which seems to have addressed the problem. Perhaps the senors are there to turn off the set if it gets too hot. At any rate the 885 is working fine and I will put it in another room after I get the 80.2. I put a temperature sensor on the top of both of my 885 and my new 80.2, The 885 came in at 101. The new Integra dhc-802 was 106 with the 1.04 firmware. I am now using an Antec cooler for the Integra which seems to handle the load quite well. It will be key to NEVER put another component on top of the DHC-80.2
Joel
jmschnur is offline
Old 10-11-2010, 07:31 AM
meller127's Avatar
More problems!
Today my front panel is showing weird symbols
Like "All Channel Stereo" is "All Channel $tereo"
after the input like Game, DVD, Sat, its a extra letter "Game G"
Turning volume up down becomes 334,98 or 4489,89 really strange, going to call tomorow for a replacement ASAP!
Will post a picture
Old 10-11-2010, 07:34 AM
Wireless member
pepar's Avatar
Quoted: 911 Post(s)
Liked: 502
More problems!
Will post a picture
No pics necessary. Try a cold reboot.
Are you using a surge suppressor?
Jeff
pepar is offline
Old 10-11-2010, 07:36 AM
meller127's Avatar
Jeff
Straight to the wall socket, i will try a cold reboot. Its getting really hot back on the perforated metal.
I dont want to reset, XT32 setup will be gone
Old 10-11-2010, 07:47 AM
bummer...keep us posted and good luck.
Old 10-11-2010, 08:07 AM
meller127's Avatar
Just of the phone with tech service, it could be:
1. A HDMI handshake error- Tested fail
2. Reset - Tested fail
3. Language in firmware stuck on 2 language - Cant confirm
4. Make power less for 1h - In progress
5. Return the unit tomorow to get a new one
Wireless member
pepar's Avatar
Quoted: 911 Post(s)
Liked: 502
Well, my theory is that a surge of some sort scrambled the 0's and 1's. The display corruption might only be one of the issues. If I am right about the surge, your calibration could have been affected as well.
If not a surge, perhaps the heat is the cause. I have heard of that, too.
Jeff
pepar is offline
Old 10-11-2010, 09:01 AM
meller127's Avatar
Have unhooked everything and no power, dident help
Have to return the unit tomorrow, i hope this is a isolated case.
I will report back after i have been to the service place.
Old 10-11-2010, 09:05 AM
jmschnur's Avatar
Could be a heat and or overload issue. try a small silent fan over the perforations in the back and see if that helps.
Joel
jmschnur is offline
Old 10-11-2010, 09:45 AM
Wireless member
pepar's Avatar
Quoted: 911 Post(s)
Liked: 502
Joel
... and a surge suppressor ...
pepar is offline
Old 10-11-2010, 09:58 AM
meller127's Avatar
I will buy a Supra Surge Protection tomorrow also.
Attachment 188124
MD06-EU/SP
6 EU sockets, Schuko.
Input connector: IEC-320
10 Amp Fuse
NIF transient filter
3-way Surge Protection.
Old 10-11-2010, 10:12 AM
mangala8's Avatar
That's too bad. I hope they get you a replacement quickly.
I did have a scrambled display on my 9.9 once, and it was fixed by a reset. But it sounds like you have more problems than that.
mangala8 is offline
Old 10-11-2010, 10:22 AM
Wireless member
pepar's Avatar
Quoted: 911 Post(s)
Liked: 502
I don't think meller127 tried a hard reset. Just removing power for a while and re-powering it up. That's nowhere near the same, but maybe that is all he/she is comfortable with doing?
Jeff
pepar is offline
Old 10-11-2010, 10:29 AM
meller127's Avatar
Jeff
Hard reset?
I have cleared to factory default, and no power for 1h. Is there more ways?
Old 10-11-2010, 10:37 AM
Wireless member
pepar's Avatar
Quoted: 911 Post(s)
Liked: 502
Hard reset?
Yes, I don't know it for your unit - but I'm sure someone else here does - but it usually involves pressing the power button while pressing another button or two. You might need to stand on your head, too.
Jeff
pepar is offline
Old 10-11-2010, 11:03 AM
gurkey's Avatar
Quoted: 122 Post(s)
Liked: 90
For a hard reset you just pull the power cord, wait 10s and reinsert...
gurkey is online now
Old 10-11-2010, 11:06 AM
Wireless member
pepar's Avatar
Quoted: 911 Post(s)
Liked: 502
Are you sure? That seems too simple and very different than previous models.
From a SC885 and DTC-9.8 page (on another forum):
To reset the SSP:
To reset the AV receiver to its factory defaults, turn it on and, while holding down the [VCR/DVR] button, press the [STANDBY/ON] button. "Clear" will appear on the display and the AV receiver will enter Standby mode. Note that resetting the AV receiver will delete your radio presets and custom settings.
Jeff
pepar is offline
Old 10-11-2010, 12:30 PM
jmschnur's Avatar
To reset the SSP:
Jeff
Would this be in the manual? Perhaps someone who has one can confirm.
Joel
jmschnur is offline
Old 10-11-2010, 12:34 PM
nethomas's Avatar
I agree tha the hard reset is more than just unplugging it. It is different on my Denon AVP than just unplugging from the wall.
gthomas
nethomas is offline
Old 10-11-2010, 12:44 PM
Wireless member
pepar's Avatar
Quoted: 911 Post(s)
Liked: 502
Joel
Haven't seen a manual online yet.
pepar is offline
Old 10-11-2010, 12:55 PM
fyzziks's Avatar
So the system resets if you lose power for 10s? That doesn't seem right...
fyzziks is offline
Old 10-11-2010, 01:34 PM
meller127's Avatar
To reset you press and hold VCR/DVD+Standby the unit must be ON not in standby.
Integra
