The Official Integra DHC-80.2 Pre/Pro Thread - Page 73 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #2161 of 3842 Old 04-11-2011, 04:08 PM
fitzcaraldo215's Avatar
Quoted: 38 Post(s)
Liked: 42
Originally Posted by LarryChanin View Post
To Fitz, Joel, or others running Audyssey Pro on the Integra DHC-80.2,
After your initial Audyssey Pro calibrations have you attempted a new Pro calibration? If so, have you experienced any difficulties?
Larry
I have done several Pro calibrations on my 80.2, and there were no special difficulties that were not caused by my own stupidity. I have never had to do the reset that Kal found necessary, for example.
fitzcaraldo215 is offline
post #2162 of 3842 Old 04-11-2011, 06:00 PM
jmschnur's Avatar
Larry
Yes. I have had problems 2 times when I needed to turn off and on the AVR and then restart multieq but the last several weeks no problems and three calibrations as I integrate my new jl 112 into my system.
The problems may have been caused by my errors or the AVR
Probably we will need a poll to see better what is going on
I have wifi from my netgear 3700 to a buffalo n Ethernet converter
No problems after latest netgear firmware
Here hoping it stays that way.
I would like an easier way to change settings in pro than exists. Now I have to go thru the whole program to load the measurements I want to use.
jmschnur is offline
post #2163 of 3842 Old 04-14-2011, 01:00 PM
ABSiNTH's Avatar
Test.
My Gear...
| Display: Samsung UN85HU8550 (85" 4K) TV w/ SEK-3500U
| Speakers: Revel F208s, C208, and M106s (11x Channels) | Subs: SVS PB-13 Ultra (x4)
| Amps: Parasound Halo A21, A51, and A23 (x2) | Preamp: Marantz AV8801
| Sources: HTPC, Dish Hopper, PS3, PS4, XB1, and Oppo BDP-93
| Power: PS Audio Power Plant Premier (x2)
ABSiNTH is offline
post #2164 of 3842 Old 04-16-2011, 10:42 AM
hawkster27's Avatar
Quoted: 29 Post(s)
Originally Posted by com5984 View Post
How does the apple tv work with the 80.2? I have the 9.8 and it never syncs (hdmi) I have to stand on one foot, poke out my tongue and turn all components on in a specific order
I use Apple TV Gen2 with my 5508. When it works, it works great, but I'd say sync fails one time out of three. I believe this is entirely the fault of the ATV2. There is much weeping and gnashing of teeth over in the Apple.com forums about how unreliable and buggy ATV2 is. I've been trying to stick with it though, because the UI is superior to the one in my Netflix BD player (LG BD390).
hawkster27 is offline
post #2165 of 3842 Old 04-16-2011, 02:45 PM
rushwj's Avatar
Anyone know of a way to get the volume to change more rapidly? It is extremely slow to respond and go up or down in volume compared to other receivers I've had. Any thoughts?
I have the dtr 70.2, but posted this here since it's a more populated thread and they're pretty similar devices with the same manual. Thanks for any help/advice.
rushwj is offline
post #2166 of 3842 Old 04-17-2011, 10:22 AM
calentz's Avatar
Quoted: 57 Post(s)
Liked: 42
Give the knob on the front of your 70.2 a spin.
Carl
--Carl
calentz is offline
post #2167 of 3842 Old 04-17-2011, 07:43 PM
rushwj's Avatar
Carl
Thanks Carl but I wasn't specific enough I guess...I meant with the remote, it changes at a snails pace. Any other ideas or thoughts. Thanks.
rushwj is offline
post #2168 of 3842 Old 04-17-2011, 08:12 PM
calentz's Avatar
Quoted: 57 Post(s)
Liked: 42
Mine is slow also, that is why the reference to the knob.
Carl
--Carl
calentz is offline
post #2169 of 3842 Old 04-17-2011, 08:37 PM
Kal Rubinson's Avatar
Quoted: 673 Post(s)
Liked: 458
Carl
Try this:
Kal Rubinson
"Music in the Round"
Kal Rubinson is offline
post #2170 of 3842 Old 04-17-2011, 08:46 PM
jmschnur's Avatar
Carl
Oremote is a bit faster
jmschnur is offline
post #2171 of 3842 Old 04-19-2011, 08:45 AM
jmschnur's Avatar
I am switching to Fios from Direct TV in two weeks. Are there any 80.2 users with Fios here? Any tips for the 80.2 with Fios?
Joel
jmschnur is offline
post #2172 of 3842 Old 04-19-2011, 09:17 AM
rickardl's Avatar
Quoted: 101 Post(s)
Liked: 90
I guess it increases the volume in 0.5dB steps, right?
If you have a Harmony remote, you can send these commands to the
logitech support and ask them to add them to your "database" for your dtr 70.2
and then you can map those to the normal volume up/down buttons on the remote.
Works great!
Volume Level Up 1dB Step
0000 006c 0000 0022 0156 00ac 0015 0016 0015 0041 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0041 0015 0016 0015 0041 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0020 06F0
Volume Level Down 1dB Step
0000 006c 0000 0022 0156 00ac 0015 0016 0015 0041 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0041 0015 0016 0015 0041 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0020 06C5
rickardl is online now
post #2173 of 3842 Old 04-19-2011, 12:31 PM
DonH50's Avatar
Quoted: 1792 Post(s)
Liked: 1325
Just curious, stoopid thought: On a couple of my AVRs, holding down the volume button for a few seconds causing it take bigger/faster steps. Is that not true for the Integra?
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is online now
post #2174 of 3842 Old 04-19-2011, 07:45 PM
Bill-99's Avatar
Quoted: 36 Post(s)
After reading this thread, I decided to take the plunge. I ordered the 80.2 and an Anthem A5 amp from my local audio emporium, the mic stand and adapter from Amazon, and 5 xlr cables from Monoprice. Yikes.
Thanks for taking the time to post and educate us ignorant masses. You folks are a bad influence... in a good way, of course.
And now the wait begins... (Sit on hands, be patient...)
Bill-99 is offline
post #2175 of 3842 Old 04-19-2011, 08:16 PM
g_bartman's Avatar
Quoted: 143 Post(s)
Liked: 122
Joel
I have uverse with an 80.1. It's at&t's version of fios. I just have it connected via hdmi. I do get some clicking between commercials but other than that there are no issues. The pq is very good
g_bartman is offline
post #2176 of 3842 Old 04-19-2011, 08:32 PM
jmschnur's Avatar
I will surely use hdmi for picture and sound if possible. I was hoping clicks will go away. However commercials will not be a big issue
jmschnur is offline
post #2177 of 3842 Old 04-20-2011, 10:12 AM
Traction143's Avatar
I have an Integra 80.2 and recently picked up a Sony 5400es and may not have one of the units configured properly. Kal's most recent Stereophile article uses the Sony as a reference player against the latest Yamaha.
Both players are stated as bitstreaming sacd via dsd at a 176 kHz sampling rate. I have the same sacd as in the article and checked my display and it shows sacd via dsd at 44.1 kHz. What give's? Is the display not accurate or is the Integra not able to process at this sampling rate.
I have the Sony configured for HDMI output, HDMI cabled correctly, etc. As a side note I also have an Oppo 93 and this unit will bitstream dsd at 44.1 kHz or will output PCM at 96.4 kHz as indicated on the display. Any help would be appreciated.
Traction143 is offline
post #2178 of 3842 Old 04-20-2011, 10:29 AM
rushwj's Avatar
yeah, that's what i'm used to also, but it doesn't seem to happen w/ these Integras. i do have a Harmony One remote, but haven't programmed it yet w/ the new receiver (time and i wanted to figure out what buttons i use on it so i can better program it), but i'll try some tricks w/ that too.
rushwj is offline
post #2179 of 3842 Old 04-20-2011, 10:33 AM
rushwj's Avatar
hey all...really enjoying my new receiver, especially with the Audyssey - it's a very enveloping experience and gives a nice "wall of sound" from the fronts consistently.
my question is regarding the video... do most people let the Integra do the video processing or just pass it through? i have TW Cable, use a panasonic BD player (a bit older, but very good functioning) and AppleTV which i watch a fair amount of Netflix from. my TV is a 65" Panasonic VT10. curious on peoples thoughts on this. (i actually have the 70.2, but it's the same video processor as the 80.2, so i'm posting here also for more thoughts/opinions). what are most people doing? thanks.
-bill
rushwj is offline
post #2180 of 3842 Old 04-20-2011, 12:13 PM
Quoted: 673 Post(s)
Liked: 458
It is the display of the Integra when receiving DSD. This has been discussed from the release of the DTC-9.8.
DSD display issue is the same but I doubt you are getting PCM at 9.4. I always get 88.2 from Oppo SACD via PCM.
Kal Rubinson
post #2181 of 3842 Old 04-20-2011, 01:12 PM
Thanks Kal.
On the Integra display panel after pressing the display button on the remote the status of the dsd bitstream and channel configuration is displayed. This is where I am getting the 44.1 sampling rate information on dsd bitstreaming with sacd.
My main concern is to get the highest sampling rate bitstream out of the Sony 5400 for processing and based upon the Integra display I am not. Is this a limitation of the Integra or do I have something configured incorrectly?
Also, I stand corrected with the Oppo-it is in fact a 88.2 pcm sampling rate.
post #2182 of 3842 Old 04-20-2011, 04:16 PM
Quoted: 673 Post(s)
Liked: 458
Thanks Kal.
You are getting the highest bitstream sampling rate and you are configured correctly. It is a quirk of the Onlyo/Integra displays that tell you it is 44.1. From previous posts by others:
"Actually, the receiver is behaving correctly when it displays "44.1 kHz". Here is apparently what happens: the 2822.4 kHz x 1 bit DSD datastream is "partitioned" into a 44.1 kHz x 64 bit datastream when sent over HDMI, or at least "seen" as 44.1 kHz x 64 bit by the receiver. But the receiver display isn't smart enough, or doesn't display enough characters, to report details like bit depth, so the receiver just shows "44.1 kHz"."
"I have set my DV-980H to SACD DSD and my receiver is reporting only 44.1Khz audio. What gives?
This is not an error. According to the HDMI 1.2a specifications, the indicated sample frequency on the receiver will be 44.1kHz. As pulled from the documentation:
"For One Bit Audio streams, the value indicated by the SF bits shall equal the ACR fS value. For Super Audio CD, the SF bits are typically set to 0, 1, 0, to indicate a Sample Frequency of 2.8224MSamples/s (i.e. 64*44.1kHz)."
This is due to 8-channels of audio being available through HDMI at 8 bits per channel at 44.1KHz. The end bandwidth is 2.8224Mbits/second, which equates to 2.8224M 1-bit audio."
Kal Rubinson
post #2183 of 3842 Old 04-20-2011, 07:33 PM
Thanks Kal for the reply. Its good to know that I'm getting the proper sampling bit rate. I really appreciate the all of the technical information and keep up the great work on the multichannel coverage in Stereophile!
post #2184 of 3842 Old 04-21-2011, 08:39 AM
hawkster27's Avatar
Quoted: 29 Post(s)
-bill
One nice thing about the 80.2 and 5508 is you can set whether or not video processing is used on each input. So, I have the Onkyo do processing for every input except blu-ray and DVD, where I let the superior Oppo handle it. I don't know if the 70.2 allows this. The 885 didn't, but I think the 886 did.
post #2185 of 3842 Old 04-21-2011, 10:50 AM
tmaschm's Avatar
Yes the 886 will let you do that if you set it to source.
tmaschm is offline
post #2186 of 3842 Old 04-22-2011, 08:51 AM
Cal68's Avatar
Quoted: 196 Post(s)
Liked: 143
I'm curious to learn what amplifier people are using to drive the Integra DHC 80.2. Are you using the Integra DTA 70.1, or another amp? I've pretty much decided to get the DHC 80.2 as my pre-pro, but I am still undecided on the amp. Personally, I'd like an amp with a little more power than the DTA 70.1 to drive my B&W Nautilus 803 speakers, so I'm looking for suggestions. Thanks.
Cal68
Cal68
Cal68 is online now
post #2187 of 3842 Old 04-22-2011, 08:56 AM
Wireless member
pepar's Avatar
Quoted: 911 Post(s)
Liked: 502
Ati 2007
"The future is already here, it's just not evenly distributed." W. Gibson
"I like the future, I'm in it." F. Theater
pepar is online now
post #2188 of 3842 Old 04-22-2011, 09:25 AM
Cal68's Avatar
Quoted: 196 Post(s)
Liked: 143
Originally Posted by pepar View Post
Ati 2007
Thanks Pepar. Do you like the amp enough to recommend it as an option for consideration?
Cal68
Cal68
Cal68 is online now
post #2189 of 3842 Old 04-22-2011, 09:32 AM
Wireless member
pepar's Avatar
Quoted: 911 Post(s)
Liked: 502
Cal68
Yes, I have had two ATI amps in my home theater, the first of which was a 1505. When I upgraded from 5.1 to 7.1 I bought the 2007 and put the 1505 in the 5.1 system on my main computer.
I also suggest that you look at Outlaw Audio.
Jeff
pepar is online now
post #2190 of 3842 Old 04-22-2011, 09:44 AM
Cal68's Avatar
Quoted: 196 Post(s)
Liked: 143
Jeff
Thanks for the advice about Outlaw Audio, Jeff. I will check it out.
Cal68
Cal68
Cal68 is online now
Integra
