Current iOS App (iPod Touch/iPhone/iPad) controlled receivers? - Page 10 - AVS Forum | Home Theater Discussions And Reviews
post #271 of 295 Old 04-25-2011, 09:20 PM
rworne's Avatar
Liked: 32
I managed to fix an obscure bug in the uPNP stack and the Denon AVR is now detected properly.
My development version that is nearing beta testing now supports 2011 receivers, with a bunch of new things to do, like searching network sources. Also, AirPlay support is going in as long as an AirPlay compatible device is connected to the AVR.
rworne is offline
post #272 of 295 Old 05-09-2011, 12:42 PM
LAR196's Avatar
Hi All,
I've just gotten my new Onkyo TX-NR609 up and running and am now interested in comments wrt app options for it. I would run the apps on an iPad, iTouch, and iPhone4.
I see a lot of talk about oRemote by Robert Worne. Sounds nice but in the app store my AV model is not listed as supported. Is that right?
What other apps should I consider?
Thanks much.
LAR196 is offline
post #273 of 295 Old 05-09-2011, 02:57 PM
rworne's Avatar
Liked: 32
Originally Posted by LAR196 View Post
Hi All,
Thanks much.
The other two apps on the App store should work. I tested Onkyo's free app and it does what it is supposed to.
My update is still pending and 2011 models will be supported soon. It takes some effort to get the new functions shoehorned in without breaking all the legacy stuff.
rworne is offline
post #274 of 295 Old 06-03-2011, 07:23 PM
rworne's Avatar
Liked: 32
The update of oRemote with 2011 Onkyo support (509,609,709,809,1009) and Integra 20.3 and 30.3 support just went up on the AppStore.
rworne is offline
post #275 of 295 Old 06-04-2011, 06:23 AM
Al Sherwood's Avatar
Quoted: 759 Post(s)
Liked: 277
Ahhh now if you only had oRemote for my Android 3.0 tablet...
Al
Al Sherwood is online now
post #276 of 295 Old 06-04-2011, 11:45 PM
rworne's Avatar
Liked: 32
Well, you have Onkytroller...
rworne is offline
post #277 of 295 Old 06-05-2011, 06:43 AM
Quoted: 759 Post(s)
Liked: 277
Thanks for the tip Robert, I will likely try it but your IOS offering is so slick!
I suppose it is a whole other world (droids I mean)?
Al
post #278 of 295 Old 06-05-2011, 08:54 AM
K-Wood's Avatar
Quoted: 16 Post(s)
Nice! Are you still working on a similar application for Denon receivers?
K-Wood is online now
post #279 of 295 Old 06-06-2011, 01:13 AM
rworne's Avatar
Liked: 32
Later this year, possibly this summer.
rworne is offline
post #280 of 295 Old 06-06-2011, 06:55 AM
Quoted: 759 Post(s)
Liked: 277
Although I am really liking my Xoom Android tablet, your 2 receiver apps keep me on the hunt for a deal that will see an iPad in my theater!
Al
post #281 of 295 Old 06-06-2011, 07:39 AM
wfbarn's Avatar
Will you be able to implement voting Thumbs Up or Down when listening to Pandora?
wfbarn is offline
post #282 of 295 Old 06-06-2011, 08:34 AM
tmaschm's Avatar
Never mind just saw the post above
Robert,
Is this app AirPlay/AirTunes compatible?
tmaschm is offline
post #283 of 295 Old 06-06-2011, 04:31 PM
rworne's Avatar
Liked: 32
Robert,
If you have an AirPlay device hooked up. You can access your iTunes library and set up a playlist in the app.
There's no sign of AirPlay on the 2011 models, though the 3009 and up models have some unusual streaming service called "namihei" that really doesn't mean anything in particular. The Onkyo app has AirPlay support in it, so if I had to guess...
rworne is offline
post #284 of 295 Old 06-06-2011, 04:32 PM
rworne's Avatar
Liked: 32
This isn't supported in the protocol, but as a consolation, you can search now. That's really nice.
rworne is offline
post #285 of 295 Old 06-06-2011, 04:38 PM
rworne's Avatar
Liked: 32
Just a heads up for those keeping tabs and have a 2011 model:
I uncovered a serious bug in Onkyo's firmware with the latest oRemote release, making it next to useless for Zone 2-4 network streaming. I have a workaround ready to go and it's going through final checkout now.
The bug is if I query the playing song - like from Pandora - for the artist, title, or album, the command is ignored. If I query a certain number of times, the network stack on the AVR crashes and oRemote loses communication until someone pulls the plug on the AVR. The fix is simply not to query, but let the AVR send it out when it wants to. The bad part is the first song's info will not be displayed, but can be refreshed by momentarily pausing and restarting the stream.
Note that pre 2011 models work fine, and only Zones 2-4 are affected on 2011 models.
rworne is offline
post #286 of 295 Old 06-06-2011, 05:28 PM
wfbarn's Avatar
What is searching?
wfbarn is offline
post #287 of 295 Old 06-06-2011, 05:28 PM
wfbarn's Avatar
What is searching?
wfbarn is offline
post #288 of 295 Old 06-06-2011, 08:58 PM
tmaschm's Avatar
Yea I read your post above sorry. I have an airport express and 886 so I think your app is relevant. But after looking at the app market maybe I'll make an app. There weren't very many options.
tmaschm is offline
post #289 of 295 Old 06-06-2011, 11:09 PM
rworne's Avatar
Liked: 32
What is searching?
2011 models:
When in Pandora's "Create a channel" or DLNA "Search" a dialog pops up and you can search for.. well.. whatever. Type in a title or band and you get a list of matching items. It's slick.
Also 2011 models will allow you to type in the username and password when you visit subscription services for the first time.
rworne is offline
post #290 of 295 Old 06-11-2011, 09:42 PM
rworne's Avatar
Liked: 32
1.2.9 was submitted a couple of days ago, with a fix for an Onkyo Zone 2 firmware bug, direct tuning, and improved pickers on the iPad version.
Quite a few tweaks and bugfixes too.
rworne is offline
post #291 of 295 Old 06-15-2011, 08:45 PM
frohlir944's Avatar
how is dremote evolving?
frohlir944 is offline
post #292 of 295 Old 06-16-2011, 02:19 PM
rworne's Avatar
Liked: 32
I have a version that does quite a bit of the major functions. I am having a much more difficult time due to the fact that Denon has a ton of undocumented commands in regards to speaker levels, active speaker selection, and other commands. These are different among different receivers too. If I do not have these functions in the app, then I'm not really differentiating myself from the free OEM version.
I am going to work on it when oRemote settles down - it's nearly there now. I'm still planning on getting a release of dRemote out this summer.
rworne is offline
post #293 of 295 Old 06-17-2011, 09:15 AM
drunkmunk's Avatar
I use this app mainly on my back porch to control tracks and volume while grilling or stoking the fire pit and it works great other than one issue and It is probably a fault of the receivers but I am having a small issue with zone 2 DLNA playback. The problem is that I can't get the random button to work. For example I can select NET and press play and it will start streaming music from my PC (Windows 7 share) but it plays all the tracks in order and I can't get it to shuffle even if it is displaying the shuffle symbol on the oremote. It does work in regular receiver mode though. More than likely it's the onkyo's fault though because I can have both the main and zone 2 playing off of DLNA with shuffle enabled and it works but once I turn off the main zone than zone 2 faults back to playing the tracks in order again.
If there is a separate support forum I can also post over there.
drunkmunk is offline
post #294 of 295 Old 06-17-2011, 10:02 AM
rworne's Avatar
Liked: 32
I handle most complaint/issues through email or through oRemote's Facebook site. From what you describe, it sounds like it could be breakage on my part. I have 1.2.10 ready to submit, I'm just looking to polish a few things over the weekend. So I will look into this too.
Onkyo's Zone 2 support can get a little weird too. I'll get to the bottom of it.
I take that back. I just looked over the protocol sheet, and Onkyo indeed does not support repeat or random on Zone 2. Those functions are reserved for an iPod connected via USB cable.
The shuffle symbol appears because it is enabled, but only will work if an iPod is connected,
rworne is offline
post #295 of 295 Old 06-17-2011, 08:42 PM
drunkmunk's Avatar
Aaargg! Onkyo strikes again! Thanks for the quick response, I kind of figured it was the receiver since it did the same thing whether using oremote or the real deal.
Love the app though!
