What receiver to use for a pre pro to go with emotiva 7 channel amp? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 09-22-2010, 08:42 PM - Thread Starter
Slinger12's Avatar
What receiver will work best as a pre pro to go with emotiva 7 channel amp? I'm looking for the best value receiver out. how much do I need to spend and what would you recommend.
thanks
Slinger12 is offline
post #2 of 5 Old 09-22-2010, 09:03 PM
JeffreyMercado's Avatar
The Denon 4311 allows you to shut off the internal amp, might be a good choice
JeffreyMercado is offline
post #3 of 5 Old 09-22-2010, 09:09 PM
MichaelJHuman's Avatar
Quoted: 266 Post(s)
Liked: 148
Yamaha has some affordable models with pre outs. I think Onkyo does too.
"But this one goes up to 11"
MichaelJHuman is offline
post #4 of 5 Old 09-22-2010, 09:14 PM - Thread Starter
Slinger12's Avatar
if I went with the Denon 4311 I probably wouldn't need a separate amp. I would like to go with the emotiva amp $700 and a receiver for $600 -1000.
post #5 of 5 Old 09-22-2010, 09:18 PM
Bill Mac's Avatar
Quoted: 1269 Post(s)
Liked: 1446
I would look at the entry level AVRs that offer preouts. Then go from there to see which ones from Denon, Marantz, Onkyo, Pioneer and Yamaha that have the features you are looking for. Many good choices in your price range.
Bill
My SACD collection and HRAudio.net Library, getting larger as my wallet gets smaller ;-).
Emotiva XMC-1, Wyred 4 Sound SX-500s, ST-500, ST-250, Oppo BDP-103/105D, Panasonic TC-P60GT50 plasma, Panamax 5100EX, Salk HT2-TLs, Salk 1801b center, Salk 1801TL (surrounds) and two Rythmik F12SEs.
Bill Mac is online now
