QSC RMX series fan mod - AVS Forum | Home Theater Discussions And Reviews
Old 09-28-2010, 10:49 AM - Thread Starter
Brad Horstkotte's Avatar
Liked: 68
I've got a QSC RMX850 that I'm going to use to power my subwoofer. The fan is pretty loud - who has done a fan mod on one of the RMX series amps, and what fan did you use? How did it work out for you?
Brad Horstkotte is offline
Old 09-28-2010, 11:24 AM
cmryan821's Avatar
Quoted: 191 Post(s)
Liked: 59
I have not personally done it but this thread may be of some help.
cmryan821 is offline
Old 09-28-2010, 12:14 PM
penngray's Avatar
Liked: 41
I have modded my QSC RMX1850 with these fans.
Digi-Key, part P9739-ND fan 24VDC 1.30W 80mm, $8.25 + shipping.
http://www.digikey.com/
It works great! I have modded 5 pro amps with these fans actually.
penngray is offline
Old 09-28-2010, 10:54 PM - Thread Starter
Liked: 68
Perfect, thanks very much guys, off to order one of those.
p.s. man what a horrible web site
Old 03-06-2012, 07:41 AM
rblnr's Avatar
Quoted: 66 Post(s)
Liked: 38
Realize this is a very dead thread, but does anyone know of an alternate part to the one suggested above. Neither it nor its successor is available at digikey and won't be for a long time. thx
rblnr is offline
Old 10-14-2013, 10:32 AM
timmay77's Avatar
Sorry to bump up an old thread, again, but I have the same question as the above poster.
Would this fan work? It is the "possible substitute" according to digikey.com
Digikey part # P14751-ND
Manufacturer part # 3110SB-05W-B20-E00
http://www.digikey.com/product-detail/en/3110SB-05W-B20-E00/P14751-ND/2615564
timmay77 is offline
Old 11-15-2013, 03:41 AM
timmay77's Avatar
Just to update, if anyone cares, the replacement fan I linked above works perfect. Excellent mod, amp is now silent and works great. The only thing I had to do was drill out the mounting holes a little bit on the fan to fit. No big deal.
timmay77 is offline
Qsc
